schnapper79 Posted September 29, 2015 Posted September 29, 2015 got this message during build (during installation of additional packages: bridge-utils): [ error ] Installation failed initctl: Unable to connect to Upstart: Failed to connect to socket /com/ubuntu/upstart: Connection refused invoke-rc.d: unknown initscript, /etc/init.d/systemd-logind not found. dpkg: error processing package libpam-systemd:armhf (--configure): subprocess installed post-installation script returned error exit status 100 Processing triggers for libc-bin (2.19-0ubuntu6) ... Processing triggers for sgml-base (1.26+nmu4ubuntu1) ... Processing triggers for ureadahead (0.100.0-16) ... Errors were encountered while processing: libpam-systemd:armhf E: Sub-process /usr/bin/dpkg returned an error code (1) root@d9c64ede3eb0:/armbian# any idea?
Igor Posted September 30, 2015 Posted September 30, 2015 Do reboot and try again. Sometimes the deboostrap process hangs. Ubuntu is even more prone to this. I just rebuild all images two days ago from scratch. No problems at least with building. Currently testing and fixing.
schnapper79 Posted September 30, 2015 Author Posted September 30, 2015 Thanks... I managed to build armbian "4.4" from your git sources. I did build the Ubuntu trusty with Kernel 4.2.1 (next) and desktop. Now when starting the X (startx) I get a segmentation fault: root@udoo:~# cat /var/log/Xorg.0.log [ 378.989] X.Org X Server 1.15.1 Release Date: 2014-04-13 [ 378.990] X Protocol Version 11, Revision 0 [ 378.990] Build Operating System: Linux 3.2.0-67-highbank armv7l Ubuntu [ 378.991] Current Operating System: Linux udoo 4.2.1-udoo #1 SMP Tue Sep 29 23:33:34 CEST 2015 armv7l [ 378.991] Kernel command line: root=/dev/mmcblk0p1 rootfstype=ext4 rootwait console=tty1 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 rd.dm=0 rd.luks=0 rd.lvm=0 raid=noautodetect pci=nomsi ahci_imx.hotplug=1 quiet [ 378.993] Build Date: 12 February 2015 02:55:07PM [ 378.993] xorg-server 2:1.15.1-0ubuntu2.7 (For technical support please see http://www.ubuntu.com/support) [ 378.993] Current version of pixman: 0.30.2 [ 378.994] Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. [ 378.995] Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. [ 378.997] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Sep 30 09:18:42 2015 [ 378.998] (==) Using system config directory "/usr/share/X11/xorg.conf.d" [ 378.999] (==) No Layout section. Using the first Screen section. [ 378.999] (==) No screen section available. Using defaults. [ 378.999] (**) |-->Screen "Default Screen Section" (0) [ 378.999] (**) | |-->Monitor "<default monitor>" [ 379.000] (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration. [ 379.000] (==) Automatically adding devices [ 379.000] (==) Automatically enabling devices [ 379.000] (==) Automatically adding GPU devices [ 379.000] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. [ 379.000] Entry deleted from font path. [ 379.000] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist. [ 379.000] Entry deleted from font path. [ 379.000] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist. [ 379.000] Entry deleted from font path. [ 379.000] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist. [ 379.001] Entry deleted from font path. [ 379.001] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist. [ 379.001] Entry deleted from font path. [ 379.001] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist. [ 379.001] Entry deleted from font path. [ 379.001] (==) FontPath set to: /usr/share/fonts/X11/misc, built-ins [ 379.001] (==) ModulePath set to "/usr/lib/arm-linux-gnueabihf/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules" [ 379.001] (II) The server relies on udev to provide the list of input devices. If no devices become available, reconfigure udev or disable AutoAddDevices. [ 379.001] (II) Loader magic: 0x54c06f10 [ 379.001] (II) Module ABI versions: [ 379.001] X.Org ANSI C Emulation: 0.4 [ 379.001] X.Org Video Driver: 15.0 [ 379.001] X.Org XInput driver : 20.0 [ 379.001] X.Org Server Extension : 8.0 [ 379.002] (II) xfree86: Adding drm device (/dev/dri/card0) [ 379.002] (EE) [ 379.002] (EE) Backtrace: [ 379.003] (EE) [ 379.003] (EE) Segmentation fault at address 0x0 [ 379.004] (EE) Fatal server error: [ 379.004] (EE) Caught signal 11 (Segmentation fault). Server aborting[ 379.005] (EE) [ 379.006] (EE) Please consult the The X.Org Foundation support at http://wiki.x.org for help. [ 379.008] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information. [ 379.008] (EE) root@udoo:~# Any idea ?
Igor Posted September 30, 2015 Posted September 30, 2015 Known issue on many imx boards. I couldn't find a cause for this. I guess the troubles are within Ubuntu since Debian works. ... but it used to work in the past.
schnapper79 Posted September 30, 2015 Author Posted September 30, 2015 thanks.. i'll try using your trusty desktop image with the legacy kernel which seemed to work and gonna compile a new kernel. (I need the SocketCan modules compiled, which actually worked fine with 4.2.1)
