  • 0
udoo: problems with build
schnapper79
Question
got this message during build (during installation of additional packages: bridge-utils):
[ error ] Installation failed
initctl: Unable to connect to Upstart: Failed to connect to socket /com/ubuntu/upstart: Connection refused
invoke-rc.d: unknown initscript, /etc/init.d/systemd-logind not found.
dpkg: error processing package libpam-systemd:armhf (--configure):
 subprocess installed post-installation script returned error exit status 100
Processing triggers for libc-bin (2.19-0ubuntu6) ...
Processing triggers for sgml-base (1.26+nmu4ubuntu1) ...
Processing triggers for ureadahead (0.100.0-16) ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@d9c64ede3eb0:/armbian#
any idea?
4 answers to this question
  • 0
Do reboot and try again. Sometimes the deboostrap process hangs. Ubuntu is even more prone to this.
I just rebuild all images two days ago from scratch. No problems at least with building. Currently testing and fixing.
  • 0
Thanks... I managed to build armbian "4.4" from your git sources. I did build the Ubuntu trusty with Kernel 4.2.1 (next) and desktop.
Now when starting the X (startx) I get a segmentation fault:
root@udoo:~# cat /var/log/Xorg.0.log
[   378.989]
X.Org X Server 1.15.1
Release Date: 2014-04-13
[   378.990] X Protocol Version 11, Revision 0
[   378.990] Build Operating System: Linux 3.2.0-67-highbank armv7l Ubuntu
[   378.991] Current Operating System: Linux udoo 4.2.1-udoo #1 SMP Tue Sep 29 23:33:34 CEST 2015 armv7l
[   378.991] Kernel command line: root=/dev/mmcblk0p1 rootfstype=ext4 rootwait console=tty1 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24,bpp=32 rd.dm=0 rd.luks=0 rd.lvm=0 raid=noautodetect pci=nomsi ahci_imx.hotplug=1 quiet
[   378.993] Build Date: 12 February 2015  02:55:07PM
[   378.993] xorg-server 2:1.15.1-0ubuntu2.7 (For technical support please see http://www.ubuntu.com/support)
[   378.993] Current version of pixman: 0.30.2
[   378.994]    Before reporting problems, check http://wiki.x.org
        to make sure that you have the latest version.
[   378.995] Markers: (--) probed, (**) from config file, (==) default setting,
        (++) from command line, (!!) notice, (II) informational,
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[   378.997] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Sep 30 09:18:42 2015
[   378.998] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   378.999] (==) No Layout section.  Using the first Screen section.
[   378.999] (==) No screen section available. Using defaults.
[   378.999] (**) |-->Screen "Default Screen Section" (0)
[   378.999] (**) |   |-->Monitor "<default monitor>"
[   379.000] (==) No monitor specified for screen "Default Screen Section".
        Using a default monitor configuration.
[   379.000] (==) Automatically adding devices
[   379.000] (==) Automatically enabling devices
[   379.000] (==) Automatically adding GPU devices
[   379.000] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[   379.000]    Entry deleted from font path.
[   379.000] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[   379.000] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[   379.000] (WW) The directory "/usr/share/fonts/X11/Type1" does not exist.
[   379.001]    Entry deleted from font path.
[   379.001] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[   379.001] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[   379.001] (==) FontPath set to:
        /usr/share/fonts/X11/misc,
        built-ins
[   379.001] (==) ModulePath set to "/usr/lib/arm-linux-gnueabihf/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[   379.001] (II) The server relies on udev to provide the list of input devices.
        If no devices become available, reconfigure udev or disable AutoAddDevices.
[   379.001] (II) Loader magic: 0x54c06f10
[   379.001] (II) Module ABI versions:
[   379.001]    X.Org ANSI C Emulation: 0.4
[   379.001]    X.Org Video Driver: 15.0
[   379.001]    X.Org XInput driver : 20.0
[   379.001]    X.Org Server Extension : 8.0
[   379.002] (II) xfree86: Adding drm device (/dev/dri/card0)
[   379.002] (EE)
[   379.002] (EE) Backtrace:
[   379.003] (EE)
[   379.003] (EE) Segmentation fault at address 0x0
[   379.004] (EE)
Fatal server error:
[   379.004] (EE) Caught signal 11 (Segmentation fault). Server aborting[   379.005] (EE)
[   379.006] (EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
[   379.008] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[   379.008] (EE)
root@udoo:~#
Any idea ?
