Hi guys ! So far I tested building bullseye without luck and the bookworm release img
Building bullseye and burn it to an sd card system will not boot even after pressing the RCY button.   I've build today a new img and it boots bullseye but it freezes loading first boot
With bookworm it does boot pressing the RCY button but the Boot from MTD flash and system to nvme seems broken
if power off the board remove the sd card the system won't boot with or without sd card
(If I boot it again using the RCY with the installer already configured on the sd card and use the command df the nvme disk is not present but it appears in the installation)  (Pic 4)
Also on bookworm booting from sd card and installing system to nvme works without issues
The nvme it's a 2TB 970 evo plus which according to hardkernel is compatible and it is since the boot from sd is working without issues
I've notice a blazing fast line while using the MTD
Thanks !
Edited by j0ta
Petitboot is gone
board can load from usb installer
but fails to boot from nvme after using MTD Flash Boot
Just tested Jammi same behavior with MTD Flash Boot has in bookworm
Installing boot to sd and system to nvme works has bookworm
probably related
I'm burning the desktop img for gparted,
I'll give an update if it booted correctly after apply this workaround
No luck booting it without the sd card
building bullseye today some items loading were marked with an yellow fault
the freeze occurs now before the installer input of the root password
Probably some repos are still being work out
Using @rpardini repo I was able to build 23.08 truck and apt upgraded successfully to Armbian 23.8.1 Bullseye didn't test if it boots from MTD
Edited by j0ta
Using the archived bullseye img instead of building one was able to boot and update to 23.8.1
if I try MTD Flash and system to nvme
Shutdown
my board only light ethernet port lights and keeps looping all other leds remain off when I boot it without the sd card
Ok @rpardini I've received my usb to uart
It's the first time doing such
How do I get the SPI logs after running the mtd flash spi and system nvme and poweroff ?
Following these to connect the board to the usb uart on Putty
- Install drivers
- Connection Type
Select the radio box, Serial of Connection type.
- Serial Line
Input the Serial line to COM Port number. You can get the COM port number from Device Manager menu.
- Speed (Baudrate)
Change the Serial speed to 115200 baudrate.
Every setting is now complete to run putty.
Open your serial port!
Thanks !
Sorry what are you talking about? Which board? Why you mention me here? 😉
