j0ta Posted September 1, 2023 Posted September 1, 2023 (edited) Hi guys ! So far I tested building bullseye without luck and the bookworm release img Building bullseye and burn it to an sd card system will not boot even after pressing the RCY button. I've build today a new img and it boots bullseye but it freezes loading first boot With bookworm it does boot pressing the RCY button but the Boot from MTD flash and system to nvme seems broken if power off the board remove the sd card the system won't boot with or without sd card (If I boot it again using the RCY with the installer already configured on the sd card and use the command df the nvme disk is not present but it appears in the installation) (Pic 4) Also on bookworm booting from sd card and installing system to nvme works without issues The nvme it's a 2TB 970 evo plus which according to hardkernel is compatible and it is since the boot from sd is working without issues I've notice a blazing fast line while using the MTD Thanks ! Edited September 3, 2023 by j0ta 0 Quote
j0ta Posted September 2, 2023 Author Posted September 2, 2023 Petitboot is gone board can load from usb installer but fails to boot from nvme after using MTD Flash Boot Just tested Jammi same behavior with MTD Flash Boot has in bookworm Installing boot to sd and system to nvme works has bookworm 0 Quote
j0ta Posted September 3, 2023 Author Posted September 3, 2023 (edited) probably related I'm burning the desktop img for gparted, I'll give an update if it booted correctly after apply this workaround No luck booting it without the sd card building bullseye today some items loading were marked with an yellow fault the freeze occurs now before the installer input of the root password Probably some repos are still being work out Using @rpardini repo I was able to build 23.08 truck and apt upgraded successfully to Armbian 23.8.1 Bullseye didn't test if it boots from MTD Edited September 4, 2023 by j0ta 0 Quote
Timo12357 Posted September 7, 2023 Posted September 7, 2023 Orangepi 3 LTS lost wifi after upgrade to this release. 0 Quote
j0ta Posted September 27, 2023 Author Posted September 27, 2023 Using the archived bullseye img instead of building one was able to boot and update to 23.8.1 if I try MTD Flash and system to nvme Shutdown my board only light ethernet port lights and keeps looping all other leds remain off when I boot it without the sd card 0 Quote
j0ta Posted October 4, 2023 Author Posted October 4, 2023 Ok @rpardini I've received my usb to uart It's the first time doing such How do I get the SPI logs after running the mtd flash spi and system nvme and poweroff ? Following these to connect the board to the usb uart on Putty Quote - Install drivers - Connection Type Select the radio box, Serial of Connection type. - Serial Line Input the Serial line to COM Port number. You can get the COM port number from Device Manager menu. - Speed (Baudrate) Change the Serial speed to 115200 baudrate. Every setting is now complete to run putty. Open your serial port! Thanks ! 0 Quote
rpardini Posted October 5, 2023 Posted October 5, 2023 10 hours ago, j0ta said: Ok @rpardini I've received my usb to uart It's the first time doing such How do I get the SPI logs after running the mtd flash spi and system nvme and poweroff ? Sorry what are you talking about? Which board? Why you mention me here? 😉 0 Quote
j0ta Posted October 5, 2023 Author Posted October 5, 2023 The board is the Odroid-M1, sorry I thought you were familiar with the issue The following videos demonstrate the board being able to boot from sd but not booting from mtd flash sd-boot.mp4 mtd-flash-nvme.mp4 after-mtd-flash-no-boot.mp4 boots-again-if-put-sd.mp4 0 Quote
j0ta Posted October 29, 2023 Author Posted October 29, 2023 The bullseye build created with the framework now boots correctly, but still no luck booting from the nvme without the sd 0 Quote
