How to make the whole "media support" branch a module
Go to solution Solved by Tony3,
I am trying to compile a new kernel in order to support some satellite receiver tuner (from TBS).
I did that successfully (In February 2023) on Orange Pi 5 with Linux kernel 5.10.110, but I am struggling doing it with Orange PI 5 Plus with Linux 5.10.160 (jammy).
Basically I would like to turn as Modules lots of CONFIG_VIDEOBUF2_*, in order to replace the modules with the ones compiled separately (that I know are working fine with my TBS USD card).
These are my issues:
     - I do not manage to set separately those CONFIG_VIDEOBUF2_* through the menu config.
     - Thus I tried to set the whole "multimedia support" as a module and got the error:
[🔨]   /usr/bin/aarch64-linux-gnu-ld: drivers/phy/rockchip/phy-rockchip-samsung-dcphy.o: in function `samsung_mipi_dcphy_power_on':
[🔨]   phy-rockchip-samsung-dcphy.c:(.text+0xe1c): undefined reference to `v4l2_subdev_call_wrappers'
[🔨]   /usr/bin/aarch64-linux-gnu-ld: drivers/phy/rockchip/phy-rockchip-samsung-dcphy.o: relocation R_AARCH64_ADR_PREL_PG_HI21 against symbol `v4l2_subdev_call_wrappers' which may bind externally can not be used when making a shared object; recompile with -fPIC
[🔨]   phy-rockchip-samsung-dcphy.c:(.text+0xe1c): dangerous relocation: unsupported relocation
[🔨]   /usr/bin/aarch64-linux-gnu-ld: phy-rockchip-samsung-dcphy.c:(.text+0xe2c): undefined reference to `v4l2_subdev_call_wrappers'
[🔨]   /usr/bin/aarch64-linux-gnu-ld: phy-rockchip-samsung-dcphy.c:(.text+0xe74): undefined reference to `v4l2_subdev_call_wrappers'
[🔨]   phy-rockchip-samsung-dcphy.c:(.text+0xe74): dangerous relocation: unsupported relocation
[🔨]   /usr/bin/aarch64-linux-gnu-ld: phy-rockchip-samsung-dcphy.c:(.text+0xe84): undefined reference to `v4l2_subdev_call_wrappers'
Any idea on how to unblock that?
I am compiling on native on the PI 5 Plus.
Thanks.
Looks like you need to set a few drivers at least to y instead of module. Something about linking static library against dynamic library.
I've made this script as executable in /usr/local/bin/findtext
#!/bin/bash
location="$1"
text="$2"
grep -rnw $location -e $text
Then you could search with findtext /location/of/kernel/drivers/media v4l2_subdev_call_wrappers
Perhaps you could find the options in the kernel config after enabling/saving?
cat saved-kernel-config | grep CONFIG_VIDEOBUF2_
Or with findtext without the "w"
Edited by royk
  • Solution
The solution consisted to set the parameter CONFIG_PHY_ROCKCHIP_SAMSUNG_DCPHY=m.
This eliminates the compilation error, as it makes that code a Module.
Edited by Tony3
typo
