£22.99 used GeoBook 1E - Intel Celeron N3450 - 4GB RAM - 64GB SSD on Ebay
Hi, I just got 2 of these. Everything is fine but you need to order power adapter 12V 2A with 3.5mm x 1.35mm connector.
Unfortunately due to earlier version of BIOS compare to same looking GeoBook 1E but with dualcore Celeron N4020 it cannot boot from microSD card.
Speakers are rubbish but it could be good for some low powered machine projects.
And one advice. Do not change "Quick boot" option in BIOS setting or it will not boot and you will need to unplug battery to reset BIOS.
It work with both Windows 11 or Linux with no  extra drivers mods needed. 5Ghz wifi and bluetooth also included.
https://www.ebay.co.uk/itm/166222480445
One more it consume about 0.8A during load so in theory it could work with different power adapter like 1A. And it is able to handle USB spindle hard drives or USB-C NVME SSD compare to some similar laptops but powered over 5V adapters with obviously have to fail due to high amps demand and long power cable resistance.
