Grzegorz Smaga Posted December 4, 2016 Posted December 4, 2016 Hello. I want to autostart Jivelite. I can do this with /root/jivelite/bin/jivelite But I want this start on power on. How to do this?
slinde Posted December 4, 2016 Posted December 4, 2016 Put your command in the file /etc/rc.local. Put it on a new line just above the "exit 0" line.
Grzegorz Smaga Posted December 4, 2016 Author Posted December 4, 2016 I did but it does not work. That file is: #!/bin/sh -e # # rc.local # # This script is executed at the end of each multiuser runlevel. # Make sure that the script will "exit 0" on success or any other # value on error. # # In order to enable or disable this script just change the execution # bits. # # By default this script does nothing. /root/jivelite/bin/jivelite exit 0
mariuszb Posted December 4, 2016 Posted December 4, 2016 try as root: sudo /root/jivelite/bin/jivelite
slinde Posted December 4, 2016 Posted December 4, 2016 I did but it does not work. That file is: #!/bin/sh -e # # rc.local # # This script is executed at the end of each multiuser runlevel. # Make sure that the script will "exit 0" on success or any other # value on error. # # In order to enable or disable this script just change the execution # bits. # # By default this script does nothing. /root/jivelite/bin/jivelite exit 0 Maybe the PATH in environment is not sufficient at system start. When you are logged in as root check your environment wit the command: env Find the line that starts with "PATH=" Copy that line and paste it into the file /etc/rc.local above your "/root/jivelite/bin/jivelite" line. Then add a line: export PATH between the "PATH=" line and the "/root/jivelite/bin/jivelite" line. So the end of your rc.local should look similar to: # By default this script does nothing. PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin export PATH /root/jivelite/bin/jivelite exit 0 But it is important that you replace the PATH example above with your real PATH from your system.
tkaiser Posted December 4, 2016 Posted December 4, 2016 Maybe doing a web search for 'jivelite systemd service' is the better idea?
