Armbian now supports MangoPI M28K (BOARD=mangopi-m28k BRANCH=vendor), which uses kernel 6.1. HDMI-audio works with dtb from MangoPI. But now Ethernet port doesn't work, neither with this dtb, nor with what I did for the old kernel.
Posted (edited)
I recently got two rk3528 tvbox.
Lemfo T1 2G/16G only.
transpeed mx10 (Mx box S)
They work with hinlink ht2 image, hdmi always out. ( LAN should be changed , gmac1 - > gmac0  )
DQ08 has missed something on hdmi or rk3528 becomes a revision up ??
Edited by blust0ne
Is it like this in the dts file or did you do it another way?
-        ethernet0 = &gmac1;
+        ethernet0 = &gmac0;
 &gmac0 {
-	status = "disabled";
+  	status = "okay";
I tried this in rk3528-mangopi-m28k.dts but no luck.
 &gmac0 {
+  	status = "okay";
It's been a while so I don't remember exactly, but I think I made this change.
Posted (edited)
Please give at least compiled dtb's for your TV-boxes.
I tried to rebuild the image for legacy kernel with the latest Armbian-build, and now HDMI doesn't work at all.
Update: The problem seems to be that the TV boxes use gmac0, the driver of which is RK630_PHY, and this driver is not enabled in linux-rk35xx-vendor.config.
compatible = "ethernet-phy-id0044.1400", "ethernet-phy-ieee802.3-c22";
#define RK630_PHY_ID                0x00441400
Update2: Still doesn't work, even with this driver (preinstalled Android uses this driver).
Edited by jpegqs
update
Posted (edited)
# TV Box X88PRO13
My TV box is the X88PRO13. It  is equipped with the RK3528 chip.
I successfully  running Armbian on the box.
Find How To build and create Image for this BOX  on http://github.com/joilg/x88pro
A ready to go iso image is on  https://github.com/joilg/x88pro/releases/tag/0.3
## For those who have a different TV Box with RK3528 CPU, try the following procedure:
The USB 2.0 and HDMI interfaces are the same for most boxes, so the console output should also be posible over HDMI here.
1. Flash MMC with the x88pro image and insert it into the box's MMC slot.
2. Connect a monitor via the HDMI interface.
3. Connect a USB keyboard to a USB port.
4. Power on the box.
5. In most cases, boot messages appear on the monitor, ending in a login prompt.
6. Follow the instructions on the monitor.
## 7. Extracting the correct DTB file
binwalk /dev/mmcblk1 | grep -i "Flattened device tree"
This should give output something like this:
67451654      0x4053B06       Flattened device tree, size: 99077 bytes, version: 17
67550731      0x406BE0B       Flattened device tree, size: 99112 bytes, version: 17
138280448     0x83DFE00       Flattened device tree, size: 99112 bytes, version: 17
143958080     0x894A040       Flattened device tree, size: 379 bytes, version: 17
143960064     0x894A800       Flattened device tree, size: 99078 bytes, version: 17
Select the row with the largest size value.
Replace the placeholders in the following commands:
- `<TV_BOX_NAME>` with your box's name
- `<START_ADDR>` with the first number from the selected row
- `<SIZE>` with the size value from the selected row
Extract the DTB file with:
dd if=/dev/mmcblk1p2 of=rk3528-<TV_BOX_NAME>.dtb skip=<START_ADDR> count=<SIZE> bs=1
Copy it to boot directory:
```bash
cp rk3528-<TV_BOX_NAME>.dtb /boot/dtb-6.1.115-vendor-rk35xx/rockchip/
# or
cp rk3528-<TV_BOX_NAME>-android.dtb /boot/dtb-$(uname -r)/rockchip/
Edit the `armbianEnv.txt` file:
sed -i '/fdtfile=/c\fdtfile=rockchip/rk3528-<TV_BOX_NAME>.dtb' /boot/armbianEnv.txt
sync and reboot your box.
Now test if LAN, Audio, IR Remote Control,  RTC ... is OK.
Wifi is only implemented for the AIC8800 Chip.
### optional
convert dtb file to readable DTS source file::
dtc -@ -I dtb -O dts -o rk3528-<TV_BOX_NAME>-android.dts rk3528-<TV_BOX_NAME>-android.dtb
## Additional notes
I only have a  X88PRO13 box, so I 'm not be able to test whether this works for your device. But it might be worth a try.
### all in one Script
#! /bin/sh
## Note:** Replace all placeholders (`<TV_BOX_NAME>`, `<START_ADDR>`, `<SIZE>`) with your actual values.
dd if=/dev/mmcblk1 of=rk3528-<TV_BOX_NAME>-android.dtb skip=<START_ADDR> count=<SIZE> bs=1
sed -i '/fdtfile=/c\fdtfile=rockchip/rk3528-<TV_BOX_NAME>-android.dtb' /boot/armbianEnv.txt
## contribute
please report if you have success or anny problens.
please contribute also Info to your box, embedded chips (wifi,RTC)  and publish your DTB or DTS file.
Edited by johlnx
I made a typing error:
Please use the the correct emmc block instead the parition:
dd if=/dev/mmcblk1 of=rk3528-<TV_BOX_NAME>.dtb skip=<START_ADDR> count=<SIZE> bs=1
Posted (edited)
On 11/12/2025 at 12:14 PM, johlnx said:
## contribute
Really thank you for this!!!
Just tested it today, using the provided "ready to go" ISO image.
At first, system boots up Ok, and it automatically detects LAN Network , as I have an auto assigned IP shown in screen 😁
So this is (for me) a step up with the device (I have this one) as in my previous attemps with Armbian I couldn't manage to connect any network.
Using armbian-config, I understand that WiFi also works... but... I couldn't connect. I can "see" all available Networks, and when I choose mine and enter password, the query (armbian-config) shows an error about the yaml file (I understand this is the configuration file). I did a quick test, and as I had wired netwrok I moved on. A little note: check the pictures in my device and WiFi Chip is LGX8800D, for sure somthing from the AIC8800 family you mentioned...
I could also manage to extract .DTB, but when I edited armbianEnv.txt and pointed to it, after rebooting I had black screen... the device showed nothing on screen , like completly dead.
I noticed that when using the binwalk command I had many partition with the same (and biggest) size, so I used the first one. (image attached).
I attach also DTB and DTS files; but probabbly I did sth wrong. Any tips are welcome :D
I wanted to try sound through HDMI as it wasn't working in previous version, but struggled a little to install xfce4 and then run out of space in my 4gb sd card so I had no time to do so.
Will try to do it soon, when I have the time.
Edit: couldn't test the remaingng hardware (IR, LCD display, RTC?, also I would like to test HDMI-CEC). I think that would take much more time as I dont know how to make it work.
rk3528-CHAD_TV.dtb rk3528-CHAD_TV.dts
Edited by fedes_gl
Hello fedes_gl, thx for testing.
Regarding wifi I got the same error with connectet LAN  cable  because the default Gateway is pointed to LAN address.  Remove the LAN cable and you should be able to connect over wifi.
x88pro:~:# routel
Dst             Gateway         Prefsrc         Protocol Scope   Dev              Table
default         192.168.178.1   192.168.178.71  dhcp             wlan0
192.168.178.0/24                 192.168.178.71  kernel   link    wlan0
127.0.0.0/8                     127.0.0.1       kernel   host    lo               local
127.0.0.1                       127.0.0.1       kernel   host    lo               local
127.255.255.255                 127.0.0.1       kernel   link    lo               local
192.168.178.71                  192.168.178.71  kernel   host    wlan0            local
192.168.178.255                 192.168.178.71  kernel   link    wlan0            local
Did someone test the build on TV98 Rockchip RK3528 4GB RAM + 64GB Storage TV box? If yes, is it possible to install from SD Card?
@Fit Girl The image available here works from emmc. I could not test this with SD card. Please be informed that there is no HDMI display post boot. You have to find out the IP address from your DHCP Server/Router once the box got booted. Post boot you are working on a blind box with command lines. It is working for me though without much issues so far.
Posted (edited)
@sr4armbian Thanks for your response. I found a way to build the vendor release for my box with kernel 6.xxx. SD card and USB 2.0 flash drive are tested, and HDMI audio, HDMI video, Ethernet, and the front LED display are working so far. I am running it on my eMMC, but the built-in Wi-Fi and Bluetooth modules are not working. I have modified a bit of scripts to remove the HAOS part and create a firmware image that can be flashed directly via the factory flash tool using using usb cable in maskrom mode.
Edited by Fit Girl
Glad that you got it fixed and figured out a way to set this up. 🙌. I went with similar method, used USB Male to Male cable, Factory Flash Tool and maskrom pins to load the image that I have mentioned in above post, However I am still stuck with no HDMI and LED Display is not showing the clock, but a script which shows the IP address. This was part of the image created by the one who complied it.  If you could share steps to get the one that is working (HDMI, Clock, Etc.,) for you would be helpful.
It's working on the x88pro13 here. However, is there a way to install it to the internal memory? I tried, and it wouldn't turn on anymore; I restored it, and now it only boots from the SD card.
@ulumid
Ram Initialstation ist done by U-Boot with a suitibal rkbin binary located in the first sectors of mmc. This ist spezific for your Board. connect PC to  serial debug console and Test If Android Boot Starts and switchover to mmc if it is pluged.
