RK3399 DWC3 USB3.0 driver failed after recent kernel update
After recent kernel update, USB3.0 ports no longer work, There is an error printed in kernel log.
[    2.826383] phy phy-ff800000.phy.6: phy poweron failed --> -110
[    2.827119] dwc3 fe900000.usb: error -ETIMEDOUT: failed to initialize core
[    2.827881] dwc3: probe of fe900000.usb failed with error -110
I found this issue in NanoPC T4, but it might also appear in other RK3399 boards.
lsusb didn't show any USB3.0 controller.
Confirmed this isn't my hardware's problem, another board have this issue too.
dwc3.txt
FWIW, I've been running 6.3.0-0.rc1 for 154 days, just rebooted to switch to 6.5.0-0.rc2.
USB will continue to work as before:
/:  Bus 08.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
    |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
    |__ Port 1: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
/:  Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
/:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
        |__ Port 4: Dev 3, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
        |__ Port 1: Dev 4, If 0, Class=Vendor Specific Class, Driver=ftdi_sio, 12M
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
        |__ Port 1: Dev 3, If 0, Class=Mass Storage, Driver=uas, 5000M
        |__ Port 4: Dev 4, If 0, Class=Vendor Specific Class, Driver=ax88179_178a, 5000M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
        |__ Port 2: Dev 3, If 0, Class=Vendor Specific Class, Driver=ftdi_sio, 12M
Issue must be blamed on the build configuration, the kernel source code does not seem to introduce regression.
1 hour ago, winnt5 said:
Do you test it on NanoPC T4?
Not only with the NanoPC T4, I'm running the same generic kernel build on all devices with aarch64 architecture. The only thing that is device-specific is the DTB, which informs the kernel about device-specific components.
There is no Armbian build system involved for me, hence my claim about the build configuration.
After searching, I know kernel 6.5 rc2 is released before this bug appears. According to my tests, probably these two commits caused the problem.
usb: dwc3: don't reset device side if dwc3 was configured as host-only
Revert "usb: dwc3: core: Enable AutoRetry feature in the controller"
Moved on to 6.6.0.rc2 and can now confirm the mainline regression.
USB 3.0 keeps working on my M1, but haven't checked if the rk3568 uses the same USB IP.
FWIW, with my NanopiM4 RK3399 on 6.1.50-current-rockchip6, I have usb drives disconnected when doing file transfer between them. Revert back to 5.15.93-rockchip64, it works fine.
> [ +39.294664] xhci-hcd xhci-hcd.3.auto: xHCI host not responding to stop endpoint command
> [  +0.013618] xhci-hcd xhci-hcd.3.auto: xHCI host controller not responding, assume dead
> [  +0.000049] xhci-hcd xhci-hcd.3.auto: HC died; cleaning up
> [  +0.000233] sd 0:0:0:0: [sda] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x03 driverbyte=DRIVER_OK cmd_age=35s
> [  +0.000011] usb 3-1: USB disconnect, device number 2
> [  +0.000013] sd 0:0:0:0: [sda] tag#0 CDB: opcode=0x88 88 00 00 00 00 05 2d 19 ca e0 00 00 01 00 00 00
> [  +0.000011] I/O error, dev sda, sector 22231501536 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 2
> [  +0.000188] usb 4-1: USB disconnect, device number 2
> [  +0.000014] usb 4-1.1: USB disconnect, device number 3
FWIW, I've moved to 6.7.0.rc2 and the mainline USB regression can no longer be observed:
/:  Bus 08.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
/:  Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
        |__ Port 1: Dev 5, If 0, Class=Vendor Specific Class, Driver=ftdi_sio, 12M
        |__ Port 2: Dev 6, If 0, Class=Vendor Specific Class, Driver=ftdi_sio, 12M
    |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=uas, 5000M
But new toys in town to play with:
fluster-run
FriendlyElec NanoPC-T4
CPU 0-3: schedutil 408 MHz - 1416 MHz
CPU 4-5: schedutil 408 MHz - 1800 MHz
6.7.0-0.rc2.22.fc37.aarch64+ #1 SMP PREEMPT_DYNAMIC Sat Nov 25 19:54:14 CET 2023
GStreamer-H.264-V4L2SL-Gst1.0
GStreamer-H.265-V4L2SL-Gst1.0
GStreamer-VP8-V4L2SL-Gst1.0
GStreamer-VP9-V4L2SL-Gst1.0
Running test suite JCT-VC-HEVC_V1 with decoder GStreamer-H.265-V4L2SL-Gst1.0
[TEST SUITE    ] (DECODER                      ) TEST VECTOR                     ... RESULT
[JCT-VC-HEVC_V1] (GStreamer-H.265-V4L2SL-Gst1.0) AMP_A_Samsung_7                 ... Success
[JCT-VC-HEVC_V1] (GStreamer-H.265-V4L2SL-Gst1.0) WPP_F_ericsson_MAIN_2           ... Success
Ran 116/147 tests successfully               in 278.760 secs
Running test suite JVT-FR-EXT with decoder GStreamer-H.264-V4L2SL-Gst1.0
[TEST SUITE] (DECODER                      ) TEST VECTOR                         ... RESULT
[JVT-FR-EXT] (GStreamer-H.264-V4L2SL-Gst1.0) alphaconformanceG                   ... Success
[JVT-FR-EXT] (GStreamer-H.264-V4L2SL-Gst1.0) HVLCPFF0_Sony_B                     ... Success
Ran 44/69 tests successfully               in 52.795 secs
Running test suite JVT-AVC_V1 with decoder GStreamer-H.264-V4L2SL-Gst1.0
[JVT-AVC_V1] (GStreamer-H.264-V4L2SL-Gst1.0) AUD_MW_E                            ... Success
[JVT-AVC_V1] (GStreamer-H.264-V4L2SL-Gst1.0) SVA_NL2_E                           ... Success
Ran 129/135 tests successfully               in 110.934 secs
Running test suite VP9-TEST-VECTORS with decoder GStreamer-VP9-V4L2SL-Gst1.0
[VP9-TEST-VECTORS] (GStreamer-VP9-V4L2SL-Gst1.0) vp90-2-00-quantizer-00.webm     ... Success
[VP9-TEST-VECTORS] (GStreamer-VP9-V4L2SL-Gst1.0) vp91-2-04-yuv444.webm           ... Error
Ran 228/305 tests successfully               in 329.996 secs
Running test suite VP8-TEST-VECTORS with decoder GStreamer-VP8-V4L2SL-Gst1.0
[VP8-TEST-VECTORS] (GStreamer-VP8-V4L2SL-Gst1.0) vp80-00-comprehensive-001       ... Success
[VP8-TEST-VECTORS] (GStreamer-VP8-V4L2SL-Gst1.0) vp80-05-sharpness-1443          ... Success
Ran 59/61 tests successfully               in 14.547 secs
