Hi, please help me install Armbian.
Hardware:
I have an X96 TV box with 2GB of memory and 16GB of storage.
Software:
I'm trying to install Armbian_23.08.0_amlogic_s905x-t95_lunar_5.15.132_server_2023.09.21.
I downloaded the image, wrote it to the SD card and successfully booted using the toothpick method.
Booting from the SD card is successful, everything works fine. When I try to install Armbian on emmc the installation just stops. If you cancel the installation (ctrl + c), the system continues to work normally.
I also tried using the image Armbian_23.08.0_amlogic_s905x-t95_lunar_6.1.52_server_2023.09.12.
To install, I used the commands armbian-install and armbian-install -m yes -a no.
I chose all possible DTB options for the s905x.
It's always the same. The installation just stops (in the picture).
Android boots successfully without an SD card.
Thank you in advance!
Expand
This is not the file name for an genuine Armbian image.  You will need to look for support from where ever you downloaded this non-armbian image.
