Hello
I tried to shrink my sdcard (64gb, 17gb in use) and copy it to a 32gb card.
I found a tutorial, but it don't work
I fownloaded gparted and create a bootable device.
The instruction
1.resize2fs /dev/sda1 [new size of the partition]
in my case the original card is sdc1
2. Copy the shrinked device to the new device
dd if=/dev/sda of=/dev/sdb
In my case dd if=/dev/sdc of=/dev/mmcblk0
Is it really correct to use it without the "1" ? Sda, not sda1?
However It didn't work....
Gparted gui shows me, that the original sd card has the original size 58.24gb. But I shrinked it to 27gb..... with resize2fs /dev/sdc1 27000M
So I use gpated gui, by right click on device and select change volumesize.
This worked, now I shrink the partition to 17gb.
So looks good. After this , i tried
dd if=/dev/sdc1 of=/dev/mmcblk0 to copy the partition.
The odroid not boot, when I insert the card.
Thd card hasn't a partition table, maybe this is the fail.
So I do it again, but create a partition on the new sdcard, before i copy the old files on it. When I copy the files with dd, i will lose the partitions table.
What is the fail
Should i try to copy the full card to the new card
Remember: on the new card is one shrinked partition with my armbian (17gb) and the rest of the card isn't as a partition.
Thank you
Edited by jumbo125
  • jumbo125 changed the title to shrinkt sdcard and copy to other one
