Fresh install no X server, no GUI.
Unfortunately the cursor is not shown in the terminal.
You can type and delete text, but the character under the cursor position is not at all highlighted.
I can make it shown with adding something like  "echo -e '\e[?16;0;200c' " (colors it orange) to my bash prompt, but in then I start vim and the cursor is still hidden!
I can set colorcolumn and colorrow to work around this in vim, but it seems that the problem lies deeper.
So I looked around and found the setterm command. It works for setting my background and foreground colors, however when I do
"setterm --cursor on" or "setterm --blink on" nothing happens, cursor is still not shown.
So I looked around even more! And found that the virtual console can be configured in kernel boot options. The options are documented here: https://www.kernel.org/doc/Documentation/kernel-parameters.txt
And there is the option "vt.global_cursor_default= " which looks promising.
BUT! It looks like Armbian does not use grub. (no /etc/default/grub folder)
So the question is:
1) Is there any way to set kernel boot parameters?
OR
2) Is there any other way to solve this?
