cippo Posted December 12, 2016 Posted December 12, 2016 Hello, I try to use the Armbian build framework to generate a debian package with modified kernel, generated packages.deb works fine, but the compiled kernel is everytime the default and not mine. I use: ./compile.sh KERNEL_CONFIGURE=yes KERNEL_KEEP_CONFIG=no and then load my kernel_config but the result is everytime the default kernel, the .config become change then my .config I also try to bypass the problem by adding immutable attribute to my personalized .config (chattr +i ./.config) but the script crash: │ /home/maxi/sources/linux-sun8i/sun8i/scripts/kconfig/Makefile:33: recipe for target 'silentoldconfig' failed │ │ make[2]: *** [silentoldconfig] Error 1 │ │ /home/maxi/sources/linux-sun8i/sun8i/Makefile:493: recipe for target 'silentoldconfig' failed │ │ make[1]: *** [silentoldconfig] Error 2 │ │ make: *** No rule to make target 'include/config/auto.conf', needed by 'include/config/kernel.release'. Stop. Thankyou for your support (and sorry for my bad english)
zador.blood.stained Posted December 12, 2016 Posted December 12, 2016 If you place your changed config in userpatches/linux-$LINUXFAMILY-$BRANCH.config (i.e. linux-sun8i-default.config) it should be loaded instead of default one from lib/config/kernel/ 1
