Armbian image have a different gcc version that the one used for kernel compilation
Guys, I installed "Armbian_23.08.0_amlogic_s905x2_lunar_5.15.133_server_2023.10.02.img.gz" on SD card and entered into TESLA MediaTech X700 with soc s905x2 in it.
It boots flawlessly, I have created user name etc ...
I am trying to install xone driver. https://github.com/medusalix/xone
When I hit the "sudo ./install.sh --release" command, I got warning that my gcc is different the one that was used for kernel compilation. I belive that is the issue of not compiling the code.
Why is it different ? What can I do in order to match it ?
Here are details of the commnad:
Installing xone v0.3-2-gbbf0dcc...
Sign command: /lib/modules/5.15.133-ophub/build/scripts/sign-file
Binary /lib/modules/5.15.133-ophub/build/scripts/sign-file not found, modules won't be signed
Creating symlink /var/lib/dkms/xone/v0.3-2-gbbf0dcc/source -> /usr/src/xone-v0.3-2-gbbf0dcc
Building module:
Cleaning build area...
make -j4 KERNELRELEASE=5.15.133-ophub -C /lib/modules/5.15.133-ophub/build M=/var/lib/dkms/xone/v0.3-2-gbbf0dcc/build.....(bad exit status: 2)
Error! Bad return status for module build on kernel: 5.15.133-ophub (aarch64)
Consult /var/lib/dkms/xone/v0.3-2-gbbf0dcc/build/make.log for more information.
DKMS make.log for xone-v0.3-2-gbbf0dcc for kernel 5.15.133-ophub (aarch64)
St 11. října 2023, 21:39:39 CEST
make: Entering directory '/usr/src/linux-headers-5.15.133-ophub'
warning: the compiler differs from the one used to build the kernel
  The kernel was built by: aarch64-none-linux-gnu-gcc (Arm GNU Toolchain 12.3.Rel1 (Build arm-12.35)) 12.3.1 20230626
  You are using:           gcc (Ubuntu 12.3.0-1ubuntu1~23.04) 12.3.0
  CC [M]  /var/lib/dkms/xone/v0.3-2-gbbf0dcc/build/transport/wired.o
  CC [M]  /var/lib/dkms/xone/v0.3-2-gbbf0dcc/build/transport/dongle.o
  CC [M]  /var/lib/dkms/xone/v0.3-2-gbbf0dcc/build/transport/mt76.o
  CC [M]  /var/lib/dkms/xone/v0.3-2-gbbf0dcc/build/bus/bus.o
/bin/sh: 1: scripts/basic/fixdep: Exec format error
make[1]: *** [scripts/Makefile.build:289: /var/lib/dkms/xone/v0.3-2-gbbf0dcc/build/bus/bus.o] Error 126
make[1]: *** Deleting file '/var/lib/dkms/xone/v0.3-2-gbbf0dcc/build/bus/bus.o'
make[1]: *** Waiting for unfinished jobs....
make[1]: *** [scripts/Makefile.build:289: /var/lib/dkms/xone/v0.3-2-gbbf0dcc/build/transport/wired.o] Error 126
make[1]: *** Deleting file '/var/lib/dkms/xone/v0.3-2-gbbf0dcc/build/transport/wired.o'
make[1]: *** [scripts/Makefile.build:289: /var/lib/dkms/xone/v0.3-2-gbbf0dcc/build/transport/dongle.o] Error 126
make[1]: *** Deleting file '/var/lib/dkms/xone/v0.3-2-gbbf0dcc/build/transport/dongle.o'
make[1]: *** [scripts/Makefile.build:289: /var/lib/dkms/xone/v0.3-2-gbbf0dcc/build/transport/mt76.o] Error 126
make[1]: *** Deleting file '/var/lib/dkms/xone/v0.3-2-gbbf0dcc/build/transport/mt76.o'
make: *** [Makefile:1909: /var/lib/dkms/xone/v0.3-2-gbbf0dcc/build] Error 2
make: Leaving directory '/usr/src/linux-headers-5.15.133-ophub'
You are not using original Armbian build. This way you can check if its original build:
https://docs.armbian.com/User-Guide_Getting-Started/#how-to-check-download-authenticity
And here you can show minimal respect to open source software you are using (even you use some random armbian fork). It will help authors paying utility bills when spending time answering your questions and you to get attention in first place.
Bugs are collected this way: https://www.armbian.com/bugs If its a build framework issue, open a ticket here
  • Igor locked this topic
