Slow speed during access to HDDs in external enclousure with Helios64
Dear to all, I have a Helios64 unit with 2 hdd (both WD60EFRX). I have bought also an external enclousure UGREEN 5 Bay Hard Drive Enclosure ( https://eu.ugreen.com/collections/hard-drive-enclosures/products/ugreen-5-bay-hard-drive-enclosure-5-x-18tb-raid-array-hard-disk-docking-station ) and 2 WD140EDGZ and these 2 hdd are mounted inside UGREEN enclousure because I want format and test it (when all will work fine I'll exchange a WD60EFRX with a WD140EDGZ  so the drives inside the enclousure will have a backup scope). The enclousure is powered by external adapter, the system image installed is the Armbian 22.02.1 with Linux kernel 5.15.93-rockchip 64 and openmediavault 6.6.0-2 (Shaitan).
If I have the enclousure turned off and from open media vault access to smart drive section (storage -> S.M.A.R.T. -> device section), the smart information (related to the 2 WD60EFRX) are showed in about 4-5 seconds but if I turn on the enclousure with the 2 device WD140EDGZ , the smart drive section is showed after 4 minutes. Sometimes the section isn't showed but it's showed an error message "Http failure response for http://192.168.1.44/rpc.php: 504 Gateway Time-out". I'm sure that this problem occur also with the transfer of files (hoping that doesn't occur wrong data information transfer with damaged files also) and I have already googled for this issue on the web but I haven't found nothing that help me to solve the issue. I attach here the 2 dmesg output that I have take from 2 distinct session with putty
dmesg of first session
helios64:~:# dmesg
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.15.93-rockchip64 (root@cf2b4ed83279) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #23.02.2 SMP PREEMPT Fri Feb 17 23:48:36 UTC 2023
[    0.000000] Machine model: Helios64
[    0.000000] efi: UEFI not found.
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] NUMA: NODE_DATA [mem 0xf77cc100-0xf77cdfff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
[    0.000000] On node 0, zone DMA: 512 pages in unavailable ranges
[    0.000000] cma: Reserved 128 MiB at 0x00000000e8c00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.0
[    0.000000] percpu: Embedded 29 pages/cpu s80984 r8192 d29608 u118784
[    0.000000] pcpu-alloc: s80984 r8192 d29608 u118784 alloc=29*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 999432
[    0.000000] Policy zone: DMA
[    0.000000] Kernel command line: root=UUID=08a42967-5c72-4a18-b476-9a8e0ccc5d14 rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=1 ubootpart=ccc514b5-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] Unknown kernel command line parameters "ubootpart=ccc514b5-01 cgroup_enable=memory cgroup_memory=1", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.000000] Memory: 3802752K/4061184K available (16000K kernel code, 2692K rwdata, 6712K rodata, 4352K init, 593K bss, 127360K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
[    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @500000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000000004d0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000004e0000
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.002162] Console: colour dummy device 80x25
[    0.002230] printk: console [tty1] enabled
[    0.002346] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002368] pid_max: default: 32768 minimum: 301
[    0.002501] LSM: Security Framework initializing
[    0.002543] Yama: becoming mindful.
[    0.002683] AppArmor: AppArmor initialized
[    0.002829] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.002867] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.006962] rcu: Hierarchical SRCU implementation.
[    0.008544] Platform MSI: interrupt-controller@fee20000 domain created
[    0.009099] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.011407] EFI services will not be available.
[    0.012310] smp: Bringing up secondary CPUs ...
[    0.013448] Detected VIPT I-cache on CPU1
[    0.013517] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.013541] GICv3: CPU1: using allocated LPI pending table @0x00000000004f0000
[    0.013615] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.015103] Detected VIPT I-cache on CPU2
[    0.015170] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.015194] GICv3: CPU2: using allocated LPI pending table @0x0000000000580000
[    0.015266] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.016820] Detected VIPT I-cache on CPU3
[    0.016886] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.016909] GICv3: CPU3: using allocated LPI pending table @0x0000000000590000
[    0.016979] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.018471] CPU features: detected: Spectre-v2
[    0.018485] CPU features: detected: Spectre-v3a
[    0.018491] CPU features: detected: Spectre-v4
[    0.018496] CPU features: detected: Spectre-BHB
[    0.018505] CPU features: detected: ARM erratum 1742098
[    0.018511] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.018517] Detected PIPT I-cache on CPU4
[    0.018554] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.018572] GICv3: CPU4: using allocated LPI pending table @0x00000000005a0000
[    0.018619] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.019987] Detected PIPT I-cache on CPU5
[    0.020032] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.020052] GICv3: CPU5: using allocated LPI pending table @0x00000000005b0000
[    0.020098] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.020283] smp: Brought up 1 node, 6 CPUs
[    0.020321] SMP: Total of 6 processors activated.
[    0.020331] CPU features: detected: 32-bit EL0 Support
[    0.020338] CPU features: detected: 32-bit EL1 Support
[    0.020347] CPU features: detected: CRC32 instructions
[    0.047112] CPU: All CPU(s) started at EL2
[    0.047211] alternatives: patching kernel code
[    0.050362] devtmpfs: initialized
[    0.065956] Registered cp15_barrier emulation handler
[    0.065982] Registered setend emulation handler
[    0.065995] KASLR disabled due to lack of seed
[    0.066206] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.066283] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.069305] pinctrl core: initialized pinctrl subsystem
[    0.069966] DMI not present or invalid.
[    0.070836] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.075455] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.077142] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.079941] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.080038] audit: initializing netlink subsys (disabled)
[    0.080314] audit: type=2000 audit(0.080:1): state=initialized audit_enabled=0 res=1
[    0.081705] thermal_sys: Registered thermal governor 'fair_share'
[    0.081715] thermal_sys: Registered thermal governor 'bang_bang'
[    0.081722] thermal_sys: Registered thermal governor 'step_wise'
[    0.081728] thermal_sys: Registered thermal governor 'user_space'
[    0.082220] cpuidle: using governor menu
[    0.082497] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.082728] ASID allocator initialised with 65536 entries
[    0.084060] Serial: AMBA PL011 UART driver
[    0.114087] platform ff770000.syscon:phy@f780: Fixing up cyclic dependency with fe330000.mmc
[    0.117353] platform ff8f0000.vop: Fixing up cyclic dependency with fec00000.dp
[    0.118674] platform ff900000.vop: Fixing up cyclic dependency with fec00000.dp
[    0.131549] rockchip-gpio ff720000.gpio0: probed /pinctrl/gpio0@ff720000
[    0.132342] rockchip-gpio ff730000.gpio1: probed /pinctrl/gpio1@ff730000
[    0.133046] rockchip-gpio ff780000.gpio2: probed /pinctrl/gpio2@ff780000
[    0.133826] rockchip-gpio ff788000.gpio3: probed /pinctrl/gpio3@ff788000
[    0.134541] rockchip-gpio ff790000.gpio4: probed /pinctrl/gpio4@ff790000
[    0.159746] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.159762] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.159771] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.159780] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.164973] cryptd: max_cpu_qlen set to 1000
[    0.244401] raid6: neonx8   gen()  1666 MB/s
[    0.312565] raid6: neonx8   xor()  1222 MB/s
[    0.380735] raid6: neonx4   gen()  1727 MB/s
[    0.448896] raid6: neonx4   xor()  1268 MB/s
[    0.517073] raid6: neonx2   gen()  1541 MB/s
[    0.585230] raid6: neonx2   xor()  1177 MB/s
[    0.653406] raid6: neonx1   gen()  1203 MB/s
[    0.721565] raid6: neonx1   xor()   932 MB/s
[    0.789725] raid6: int64x8  gen()  1001 MB/s
[    0.857922] raid6: int64x8  xor()   577 MB/s
[    0.926065] raid6: int64x4  gen()  1002 MB/s
[    0.994235] raid6: int64x4  xor()   591 MB/s
[    1.062381] raid6: int64x2  gen()   944 MB/s
[    1.130546] raid6: int64x2  xor()   524 MB/s
[    1.198721] raid6: int64x1  gen()   724 MB/s
[    1.266870] raid6: int64x1  xor()   391 MB/s
[    1.266877] raid6: using algorithm neonx4 gen() 1727 MB/s
[    1.266884] raid6: .... xor() 1268 MB/s, rmw enabled
[    1.266891] raid6: using neon recovery algorithm
[    1.268527] vcc12v_dcin_bkup: supplied by vcc12v_dcin
[    1.268909] vcc12v_hdd: supplied by vcc12v_dcin_bkup
[    1.269405] vcc5v0_perdev: supplied by vcc12v_dcin_bkup
[    1.269765] vcc5v0_hdd: supplied by vcc12v_dcin_bkup
[    1.270106] vcc5v0_sys: supplied by vcc12v_dcin_bkup
[    1.271515] iommu: Default domain type: Translated
[    1.271525] iommu: DMA domain TLB invalidation policy: strict mode
[    1.274688] vgaarb: loaded
[    1.275155] SCSI subsystem initialized
[    1.275673] libata version 3.00 loaded.
[    1.275932] usbcore: registered new interface driver usbfs
[    1.275978] usbcore: registered new interface driver hub
[    1.276022] usbcore: registered new device driver usb
[    1.276823] pps_core: LinuxPPS API ver. 1 registered
[    1.276831] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.276858] PTP clock support registered
[    1.277180] EDAC MC: Ver: 3.0.0
[    1.278496] NetLabel: Initializing
[    1.278504] NetLabel:  domain hash size = 128
[    1.278511] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.278584] NetLabel:  unlabeled traffic allowed by default
[    1.279101] clocksource: Switched to clocksource arch_sys_counter
[    1.329993] VFS: Disk quotas dquot_6.6.0
[    1.330080] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.330912] AppArmor: AppArmor Filesystem Enabled
[    1.341556] NET: Registered PF_INET protocol family
[    1.341898] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    1.345019] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    1.345270] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    1.345391] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    1.345924] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    1.346592] TCP: Hash tables configured (established 32768 bind 32768)
[    1.346789] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.346958] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.347344] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    1.347380] NET: Registered PF_XDP protocol family
[    1.347394] PCI: CLS 0 bytes, default 64
[    1.348139] Trying to unpack rootfs image as initramfs...
[    1.348749] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    1.349258] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    1.350045] kvm [1]: IPA Size Limit: 40 bits
[    1.351391] kvm [1]: vgic-v2@fff20000
[    1.351427] kvm [1]: GIC system register CPU interface enabled
[    1.351725] kvm [1]: vgic interrupt IRQ18
[    1.352049] kvm [1]: Hyp mode initialized successfully
[    1.364419] Initialise system trusted keyrings
[    1.364482] Key type blacklist registered
[    1.364774] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    1.371501] zbud: loaded
[    1.373290] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.374201] fuse: init (API version 7.34)
[    1.377013] integrity: Platform Keyring initialized
[    1.441702] xor: measuring software checksum speed
[    1.449829]    8regs           :  1220 MB/sec
[    1.456941]    32regs          :  1402 MB/sec
[    1.461164]    arm64_neon      :  2352 MB/sec
[    1.461174] xor: using function: arm64_neon (2352 MB/sec)
[    1.461188] Key type asymmetric registered
[    1.461195] Asymmetric key parser 'x509' registered
[    1.461326] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.461561] io scheduler mq-deadline registered
[    1.461571] io scheduler kyber registered
[    1.461787] io scheduler bfq registered
[    1.488445] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.488462] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    1.489902] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.489915] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.495307] vdd_log: supplied by regulator-dummy
[    1.496957] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    1.500394] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 40, base_baud = 1500000) is a 16550A
[    1.501459] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 41, base_baud = 1500000) is a 16550A
[    1.501732] printk: console [ttyS2] enabled
[    1.503211] Serial: AMBA driver
[    1.505364] rockchip-vop ff8f0000.vop: Adding to iommu group 2
[    1.506403] rockchip-vop ff900000.vop: Adding to iommu group 3
[    1.513199] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.523213] loop: module loaded
[    1.532595] tun: Universal TUN/TAP device driver, 1.6
[    1.533827] thunder_xcv, ver 1.0
[    1.533871] thunder_bgx, ver 1.0
[    1.533914] nicpf, ver 1.0
[    1.535173] e1000e: Intel(R) PRO/1000 Network Driver
[    1.535181] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.535236] igb: Intel(R) Gigabit Ethernet Network Driver
[    1.535243] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.535285] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    1.535292] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.535611] sky2: driver version 1.30
[    1.536392] VFIO - User Level meta-driver version: 0.3
[    1.547814] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.547845] ehci-pci: EHCI PCI platform driver
[    1.547892] ehci-platform: EHCI generic platform driver
[    1.548266] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.548284] ohci-pci: OHCI PCI platform driver
[    1.548325] ohci-platform: OHCI generic platform driver
[    1.549548] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.549576] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    1.549779] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010
[    1.549856] xhci-hcd xhci-hcd.0.auto: irq 75, io mem 0xfe900000
[    1.550077] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.550094] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    1.550110] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    1.550331] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    1.550347] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.550358] usb usb1: Product: xHCI Host Controller
[    1.550367] usb usb1: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd
[    1.550376] usb usb1: SerialNumber: xhci-hcd.0.auto
[    1.550954] hub 1-0:1.0: USB hub found
[    1.551006] hub 1-0:1.0: 1 port detected
[    1.551476] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.551638] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    1.551653] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.551664] usb usb2: Product: xHCI Host Controller
[    1.551673] usb usb2: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd
[    1.551682] usb usb2: SerialNumber: xhci-hcd.0.auto
[    1.552205] hub 2-0:1.0: USB hub found
[    1.552246] hub 2-0:1.0: 1 port detected
[    1.552741] usbcore: registered new interface driver usb-storage
[    1.555691] mousedev: PS/2 mouse device common for all mice
[    1.557230] i2c_dev: i2c /dev entries driver
[    1.563613] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    1.564242] vdd_cpu_b: supplied by vcc5v0_sys
[    1.566962] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    1.567696] vdd_gpu: supplied by vcc5v0_sys
[    1.576851] dw_wdt ff848000.watchdog: No valid TOPs array specified
[    1.578986] sdhci: Secure Digital Host Controller Interface driver
[    1.578996] sdhci: Copyright(c) Pierre Ossman
[    1.579023] Synopsys Designware Multimedia Card Interface Driver
[    1.580432] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.584987] ledtrig-cpu: registered to indicate activity on CPUs
[    1.586539] hid: raw HID events driver (C) Jiri Kosina
[    1.586670] usbcore: registered new interface driver usbhid
[    1.586678] usbhid: USB HID core driver
[    1.591839] drop_monitor: Initializing network drop monitor service
[    1.592623] NET: Registered PF_INET6 protocol family
[    1.807133] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    1.957318] usb 1-1: New USB device found, idVendor=2109, idProduct=2815, bcdDevice= 7.04
[    1.957342] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.957353] usb 1-1: Product: USB2.0 Hub
[    1.957363] usb 1-1: Manufacturer: VIA Labs, Inc.
[    1.998579] hub 1-1:1.0: USB hub found
[    1.998820] hub 1-1:1.0: 4 ports detected
[    2.093336] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[    2.211688] usb 2-1: New USB device found, idVendor=2109, idProduct=0815, bcdDevice= 7.04
[    2.211710] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.211721] usb 2-1: Product: USB3.0 Hub
[    2.211730] usb 2-1: Manufacturer: VIA Labs, Inc.
[    2.236620] Freeing initrd memory: 18012K
[    2.238615] hub 2-1:1.0: USB hub found
[    2.238752] hub 2-1:1.0: 4 ports detected
[    2.292997] Segment Routing with IPv6
[    2.293084] In-situ OAM (IOAM) with IPv6
[    2.293188] NET: Registered PF_PACKET protocol family
[    2.293398] 8021q: 802.1Q VLAN Support v1.8
[    2.293464] Key type dns_resolver registered
[    2.295152] registered taskstats version 1
[    2.295170] Loading compiled-in X.509 certificates
[    2.298737] Loaded X.509 cert 'Build time autogenerated kernel key: 1fb701576c47097ebe5805564f004ecdeffa983a'
[    2.305330] zswap: loaded using pool zstd/z3fold
[    2.306519] Key type .fscrypt registered
[    2.306529] Key type fscrypt-provisioning registered
[    2.309620] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
[    2.336603] Key type encrypted registered
[    2.336623] AppArmor: AppArmor sha1 policy hashing enabled
[    2.385455] pcie_power: supplied by vcc5v0_perdev
[    2.396399] vcc3v3_sys_s3: supplied by vcc5v0_sys
[    2.397067] vcc3v0_sd: supplied by vcc3v3_sys_s3
[    2.398001] vcc5v0_usb: supplied by vcc5v0_perdev
[    2.398945] vcc5v0_typec: supplied by vcc5v0_usb
[    2.399527] usblan_power: supplied by vcc5v0_usb
[    2.403622] pca953x 2-0020: using no AI
[    2.406503] rk808 0-001b: chip id: 0x0
[    2.412592] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    2.412649] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    2.412665] rk808-regulator rk808-regulator: max buck steps per change: 4
[    2.413426] vdd_center: supplied by vcc5v0_sys
[    2.414421] vdd_cpu_l: supplied by vcc5v0_sys
[    2.414872] vcc_ddr_s3: supplied by vcc5v0_sys
[    2.415655] vcc1v8_sys_s3: supplied by vcc5v0_sys
[    2.416685] vcc1v8_dvp: supplied by vcc5v0_sys
[    2.417272] vcc3v0_touch: supplied by vcc5v0_sys
[    2.417967] vcc1v8_s3: supplied by vcc5v0_sys
[    2.419151] vcc_sdio_s0: Bringing 3300000uV into 3000000-3000000uV
[    2.419594] vcc_sdio_s0: supplied by vcc5v0_sys
[    2.420974] vcca3v0_codec: supplied by vcc5v0_sys
[    2.421516] vcc1v5_s3: supplied by vcc5v0_sys
[    2.422973] vcca1v8_codec: supplied by vcc5v0_sys
[    2.423556] vcc3v0_s3: supplied by vcc5v0_sys
[    2.424587] vcc3v3_sys_s0: failed to get the current voltage: -EPROBE_DEFER
[    2.424625] vcc3v3_sys_s0: supplied by vcc3v3_sys_s3
[    2.425302] vcc3v3_s0: supplied by vcc3v3_sys_s3
[    2.429592] rk808-rtc rk808-rtc: registered as rtc0
[    2.430190] rk808-rtc rk808-rtc: setting system clock to 2023-09-30T16:15:39 UTC (1696090539)
[    2.433746] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[    2.433787] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
[    2.433803] dwmmc_rockchip fe320000.mmc: Version ID is 270a
[    2.433869] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 32,32 bit host data width,256 deep fifo
[    2.434598] dwmmc_rockchip fe320000.mmc: Got CD GPIO
[    2.435724] vcc1v8_sys_s0: supplied by vcc1v8_sys_s3
[    2.436431] vcc0v9_s3: supplied by vcc3v3_sys_s3
[    2.437060] avdd_0v9_s0: supplied by vcc1v8_sys_s3
[    2.437707] avdd_1v8_s0: supplied by vcc3v3_sys_s3
[    2.438849] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[    2.438919] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
[    2.438953] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
[    2.439902] rockchip-pcie f8000000.pcie: no bus scan delay, default to 0 ms
[    2.447506] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.468276] rockchip-pcie f8000000.pcie: wait 0 ms (from device tree) before bus scan
[    2.468800] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[    2.468820] pci_bus 0000:00: root bus resource [bus 00-1f]
[    2.468836] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
[    2.468854] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
[    2.468925] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
[    2.469112] pci 0000:00:00.0: supports D1
[    2.469125] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    2.477103] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.477449] pci 0000:01:00.0: [197b:0585] type 00 class 0x010601
[    2.477533] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[    2.477547] pci 0000:01:00.0: reg 0x10: [io  size 0x0080]
[    2.477591] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
[    2.477604] pci 0000:01:00.0: reg 0x14: [io  size 0x0080]
[    2.477645] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
[    2.477658] pci 0000:01:00.0: reg 0x18: [io  size 0x0080]
[    2.477700] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
[    2.477713] pci 0000:01:00.0: reg 0x1c: [io  size 0x0080]
[    2.477755] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
[    2.477767] pci 0000:01:00.0: reg 0x20: [io  size 0x0080]
[    2.477809] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff]
[    2.477851] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[    2.477899] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512)
[    2.478270] pci 0000:01:00.0: PME# supported from D3hot
[    2.478531] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[    2.485916] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01
[    2.485971] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff]
[    2.486010] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref]
[    2.486031] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff]
[    2.486059] pci 0000:01:00.0: BAR 0: no space for [io  size 0x0080]
[    2.486073] pci 0000:01:00.0: BAR 0: failed to assign [io  size 0x0080]
[    2.486087] pci 0000:01:00.0: BAR 1: no space for [io  size 0x0080]
[    2.486101] pci 0000:01:00.0: BAR 1: failed to assign [io  size 0x0080]
[    2.486115] pci 0000:01:00.0: BAR 2: no space for [io  size 0x0080]
[    2.486129] pci 0000:01:00.0: BAR 2: failed to assign [io  size 0x0080]
[    2.486143] pci 0000:01:00.0: BAR 3: no space for [io  size 0x0080]
[    2.486157] pci 0000:01:00.0: BAR 3: failed to assign [io  size 0x0080]
[    2.486171] pci 0000:01:00.0: BAR 4: no space for [io  size 0x0080]
[    2.486184] pci 0000:01:00.0: BAR 4: failed to assign [io  size 0x0080]
[    2.486204] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.486223] pci 0000:00:00.0:   bridge window [mem 0xfa000000-0xfa0fffff]
[    2.486552] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    2.487017] pcieport 0000:00:00.0: PME: Signaling with IRQ 89
[    2.487658] pcieport 0000:00:00.0: AER: enabled with IRQ 89
[    2.488117] ahci 0000:01:00.0: version 3.0
[    2.488158] ahci 0000:01:00.0: enabling device (0000 -> 0002)
[    2.488981] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled
[    2.489098] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode
[    2.489121] ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh
[    2.497254] scsi host0: ahci
[    2.498211] scsi host1: ahci
[    2.499019] scsi host2: ahci
[    2.499855] scsi host3: ahci
[    2.500728] scsi host4: ahci
[    2.501060] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 90
[    2.501079] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 91
[    2.501092] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 92
[    2.501106] ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 93
[    2.501118] ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 94
[    2.510180] mmc1: CQHCI version 5.10
[    2.510601] WCN: marlin_init entry!
[    2.512176] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    2.512804] of_cfs_init
[    2.512844] of_cfs_init: OK
[    2.514064] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    2.536480] mmc1: SDHCI controller on fe330000.mmc [fe330000.mmc] using ADMA
[    2.606939] mmc1: Command Queue Engine enabled
[    2.606971] mmc1: new HS200 MMC card at address 0001
[    2.608075] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[    2.611576] mmcblk1boot0: mmc1:0001 AJTD4R 4.00 MiB
[    2.614090] mmcblk1boot1: mmc1:0001 AJTD4R 4.00 MiB
[    2.616446] mmcblk1rpmb: mmc1:0001 AJTD4R 4.00 MiB, chardev (241:0)
[    2.823142] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd
[    2.976671] usb 1-1.1: New USB device found, idVendor=04b4, idProduct=5500, bcdDevice= 0.01
[    2.976689] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.976700] usb 1-1.1: Product: USB to Serial
[    2.976710] usb 1-1.1: Manufacturer: Cypress Semiconductor
[    3.039167] dwmmc_rockchip fe320000.mmc: Successfully tuned phase to 187
[    3.039195] mmc0: new ultra high speed SDR104 SDHC card at address 59b4
[    3.040385] mmcblk0: mmc0:59b4 SN32G 29.7 GiB
[    3.043717]  mmcblk0: p1
[    3.054199] usb 2-1.4: new SuperSpeed USB device number 3 using xhci-hcd
[    3.072242] usb 2-1.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=30.00
[    3.072260] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    3.072271] usb 2-1.4: Product: USB 10/100/1G/2.5G LAN
[    3.072281] usb 2-1.4: Manufacturer: Realtek
[    3.072290] usb 2-1.4: SerialNumber: 000000001
[    5.731153] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    5.731801] ata1.00: ATA-9: WDC WD60EFRX-68L0BN1, 82.00A82, max UDMA/133
[    5.732339] ata1.00: 11721045168 sectors, multi 0: LBA48 NCQ (depth 32), AA
[    5.733585] ata1.00: configured for UDMA/133
[    5.733959] scsi 0:0:0:0: Direct-Access     ATA      WDC WD60EFRX-68L 0A82 PQ: 0 ANSI: 5
[    5.735393] sd 0:0:0:0: [sda] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB)
[    5.735416] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    5.735490] sd 0:0:0:0: [sda] Write Protect is off
[    5.735508] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    5.735630] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    5.808694]  sda: sda1
[    5.823468] sd 0:0:0:0: [sda] Attached SCSI disk
[    6.049589] ata2: SATA link down (SStatus 0 SControl 300)
[    6.523146] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    6.523802] ata3.00: ATA-9: WDC WD60EFRX-68L0BN1, 82.00A82, max UDMA/133
[    6.524373] ata3.00: 11721045168 sectors, multi 0: LBA48 NCQ (depth 32), AA
[    6.525673] ata3.00: configured for UDMA/133
[    6.526216] scsi 2:0:0:0: Direct-Access     ATA      WDC WD60EFRX-68L 0A82 PQ: 0 ANSI: 5
[    6.527963] sd 2:0:0:0: [sdb] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB)
[    6.527986] sd 2:0:0:0: [sdb] 4096-byte physical blocks
[    6.528076] sd 2:0:0:0: [sdb] Write Protect is off
[    6.528096] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    6.528256] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    6.585835]  sdb: sdb1
[    6.599468] sd 2:0:0:0: [sdb] Attached SCSI disk
[    6.841774] ata4: SATA link down (SStatus 0 SControl 300)
[    7.153760] ata5: SATA link down (SStatus 0 SControl 300)
[    7.156109] Freeing unused kernel memory: 4352K
[    7.156239] Run /init as init process
[    7.156249]   with arguments:
[    7.156258]     /init
[    7.156267]   with environment:
[    7.156274]     HOME=/
[    7.156283]     TERM=linux
[    7.156291]     ubootpart=ccc514b5-01
[    7.156300]     cgroup_enable=memory
[    7.156308]     cgroup_memory=1
[    8.407667] input: adc-keys as /devices/platform/adc-keys/input/input1
[    8.567950] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
[    8.567983] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
[    8.568199] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[    8.570585] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    8.570621] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    8.570638] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20).
[    8.570666] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    8.570792] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[    8.570806] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    8.577908] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    8.578395] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[    8.578429] rk_gmac-dwmac fe300000.ethernet:         DWMAC1000
[    8.578443] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
[    8.578456] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
[    8.578467] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[    8.578478] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
[    8.578489] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[    8.598092] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[    8.598112] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[    8.598122] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    8.860989] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[    8.861024] RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[    9.062964] async_tx: api initialized (async)
[    9.585763] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null). Quota mode: none.
[   10.314197] systemd[1]: Inserted module 'autofs4'
[   10.373772] systemd[1]: systemd 247.3-7+deb11u4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[   10.374796] systemd[1]: Detected architecture arm64.
[   10.383015] systemd[1]: Set hostname to <helios64>.
[   10.543651] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
[   10.843816] random: lvmconfig: uninitialized urandom read (4 bytes read)
[   11.585315] systemd[1]: Queued start job for default target Graphical Interface.
[   11.586846] random: systemd: uninitialized urandom read (16 bytes read)
[   11.590723] systemd[1]: Created slice system-getty.slice.
[   11.591409] random: systemd: uninitialized urandom read (16 bytes read)
[   11.593003] systemd[1]: Created slice system-modprobe.slice.
[   11.595337] systemd[1]: Created slice system-postfix.slice.
[   11.597218] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   11.599047] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[   11.600653] systemd[1]: Created slice User and Session Slice.
[   11.600992] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   11.601460] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   11.602749] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   11.603318] systemd[1]: Reached target Local Encrypted Volumes.
[   11.603951] systemd[1]: Reached target Slices.
[   11.604289] systemd[1]: Reached target Swap.
[   11.604589] systemd[1]: Reached target System Time Set.
[   11.605356] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[   11.610450] systemd[1]: Listening on LVM2 poll daemon socket.
[   11.636267] systemd[1]: Listening on RPCbind Server Activation Socket.
[   11.637461] systemd[1]: Listening on Syslog Socket.
[   11.638419] systemd[1]: Listening on fsck to fsckd communication Socket.
[   11.639014] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   11.640232] systemd[1]: Listening on Journal Audit Socket.
[   11.641136] systemd[1]: Listening on Journal Socket (/dev/log).
[   11.642199] systemd[1]: Listening on Journal Socket.
[   11.644946] systemd[1]: Listening on Network Service Netlink Socket.
[   11.646250] systemd[1]: Listening on udev Control Socket.
[   11.647178] systemd[1]: Listening on udev Kernel Socket.
[   11.652113] systemd[1]: Mounting Huge Pages File System...
[   11.657909] systemd[1]: Mounting POSIX Message Queue File System...
[   11.663295] systemd[1]: Mounting RPC Pipe File System...
[   11.669153] systemd[1]: Mounting Kernel Debug File System...
[   11.674858] systemd[1]: Mounting Kernel Trace File System...
[   11.676130] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[   11.676932] systemd[1]: Finished Availability of block devices.
[   11.683981] systemd[1]: Starting Set the console keyboard layout...
[   11.689631] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   11.695491] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   11.701445] systemd[1]: Starting Load Kernel Module configfs...
[   11.707706] systemd[1]: Starting Load Kernel Module drm...
[   11.713611] systemd[1]: Starting Load Kernel Module fuse...
[   11.714347] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[   11.720538] systemd[1]: Started Nameserver information manager.
[   11.721511] systemd[1]: Reached target Network (Pre).
[   11.724436] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   11.724731] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   11.733326] systemd[1]: Starting Journal Service...
[   11.745963] systemd[1]: Starting Load Kernel Modules...
[   11.754794] systemd[1]: Starting Remount Root and Kernel File Systems...
[   11.764436] systemd[1]: Starting Coldplug All udev Devices...
[   11.785409] systemd[1]: Mounted Huge Pages File System.
[   11.787023] systemd[1]: Mounted POSIX Message Queue File System.
[   11.788925] systemd[1]: Mounted Kernel Debug File System.
[   11.790639] systemd[1]: Mounted Kernel Trace File System.
[   11.794420] systemd[1]: Finished Set the console keyboard layout.
[   11.799057] systemd[1]: Finished Create list of static device nodes for the current kernel.
[   11.802499] systemd[1]: modprobe@configfs.service: Succeeded.
[   11.805042] systemd[1]: Finished Load Kernel Module configfs.
[   11.808529] systemd[1]: modprobe@drm.service: Succeeded.
[   11.810968] systemd[1]: Finished Load Kernel Module drm.
[   11.814648] systemd[1]: modprobe@fuse.service: Succeeded.
[   11.817182] systemd[1]: Finished Load Kernel Module fuse.
[   11.829264] systemd[1]: Mounting FUSE Control File System...
[   11.836840] lm75 2-004c: supply vs not found, using dummy regulator
[   11.837314] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
[   11.839690] hwmon hwmon2: temp1_input not attached to any thermal zone
[   11.839728] lm75 2-004c: hwmon2: sensor 'lm75'
[   11.846411] systemd[1]: Mounting Kernel Configuration File System...
[   11.848425] RPC: Registered named UNIX socket transport module.
[   11.848442] RPC: Registered udp transport module.
[   11.848449] RPC: Registered tcp transport module.
[   11.848455] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   11.862409] systemd[1]: Mounted RPC Pipe File System.
[   11.864821] systemd[1]: Finished Remount Root and Kernel File Systems.
[   11.866033] systemd[1]: Mounted FUSE Control File System.
[   11.866936] systemd[1]: Mounted Kernel Configuration File System.
[   11.867751] random: systemd: uninitialized urandom read (16 bytes read)
[   11.872117] systemd[1]: Starting pNFS block layout mapping daemon...
[   11.874877] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   11.875340] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   11.875567] random: systemd: uninitialized urandom read (16 bytes read)
[   11.881353] systemd[1]: Starting Load/Save Random Seed...
[   11.882304] random: systemd: uninitialized urandom read (16 bytes read)
[   11.890556] systemd[1]: Starting Create System Users...
[   11.894580] systemd[1]: Started pNFS block layout mapping daemon.
[   11.900215] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[   11.921775] NILFS version 2 loaded
[   11.964338] spl: loading out-of-tree module taints kernel.
[   11.965936] spl: module verification failed: signature and/or required key missing - tainting kernel
[   11.984529] systemd[1]: Finished Create System Users.
[   11.992605] systemd[1]: Starting Create Static Device Nodes in /dev...
[   12.009988] icp: module license 'CDDL' taints kernel.
[   12.010008] Disabling lock debugging due to kernel taint
[   12.084617] systemd[1]: Finished Create Static Device Nodes in /dev.
[   12.085963] systemd[1]: Reached target Local File Systems (Pre).
[   12.094073] systemd[1]: Mounting Mount /tmp as tmpfs to reduce write access to the root device...
[   12.107832] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[   12.117262] systemd[1]: Mounted Mount /tmp as tmpfs to reduce write access to the root device.
[   12.156341] systemd[1]: Started Journal Service.
[   12.210862] systemd-journald[456]: Received client request to flush runtime journal.
[   12.230079] systemd-journald[456]: File /var/log/journal/1f99336995dc4c3bbc239523003d1d8d/system.journal corrupted or uncleanly shut down, renaming and replacing.
[   12.902101] random: systemd: uninitialized urandom read (16 bytes read)
[   12.918171] random: systemd: uninitialized urandom read (16 bytes read)
[   13.137577] input: beeper as /devices/platform/beeper/input/input2
[   13.178291] random: systemd: uninitialized urandom read (16 bytes read)
[   13.313389] mc: Linux media interface: v0.10
[   13.340713] videodev: Linux video capture interface: v2.00
[   13.450536] rockchip-rga ff680000.rga: HW Version: 0x03.02
[   13.453903] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22
[   13.457828] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[   13.464628] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[   13.469808] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
[   13.475715] rockchip-iep ff670000.iep: Device rockchip-iep registered as /dev/video1
[   13.484163] rkvdec ff660000.video-codec: Adding to iommu group 1
[   13.512507] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[   13.543462] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video3
[   13.566496] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   13.568551] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video4
[   13.569351] sd 2:0:0:0: Attached scsi generic sg1 type 0
[   13.706912] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[   13.707082] [drm] unsupported AFBC format[3231564e]
[   13.708858] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[   13.709466] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[   13.713935] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[   13.718191] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[   13.726959] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
[   13.755885] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   13.755910] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3
[   13.756032] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010
[   13.756050] xhci-hcd xhci-hcd.3.auto: irq 74, io mem 0xfe800000
[   13.756153] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   13.756160] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4
[   13.756166] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[   13.756282] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[   13.756288] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.756293] usb usb3: Product: xHCI Host Controller
[   13.756296] usb usb3: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd
[   13.756299] usb usb3: SerialNumber: xhci-hcd.3.auto
[   13.756748] hub 3-0:1.0: USB hub found
[   13.756768] hub 3-0:1.0: 1 port detected
[   13.756873] ehci-platform fe380000.usb: EHCI Host Controller
[   13.757072] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[   13.757137] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[   13.757143] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.757146] usb usb4: Product: xHCI Host Controller
[   13.757150] usb usb4: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd
[   13.757153] usb usb4: SerialNumber: xhci-hcd.3.auto
[   13.757531] hub 4-0:1.0: USB hub found
[   13.757548] hub 4-0:1.0: 1 port detected
[   13.757796] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 5
[   13.758515] ehci-platform fe380000.usb: irq 34, io mem 0xfe380000
[   13.771163] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[   13.772317] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[   13.772338] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.772345] usb usb5: Product: EHCI Host Controller
[   13.772350] usb usb5: Manufacturer: Linux 5.15.93-rockchip64 ehci_hcd
[   13.772356] usb usb5: SerialNumber: fe380000.usb
[   13.786845] ZFS: Loaded module v2.1.11-1~bpo11+1, ZFS pool version 5000, ZFS filesystem version 5
[   13.810361] hub 5-0:1.0: USB hub found
[   13.810410] hub 5-0:1.0: 1 port detected
[   13.835545] panfrost ff9a0000.gpu: clock rate = 500000000
[   13.890867] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[   13.890909] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 6
[   13.891066] ohci-platform fe3a0000.usb: irq 35, io mem 0xfe3a0000
[   13.892260] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[   13.892272] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
[   13.892277] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[   13.892284] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
[   13.912560] [drm] Initialized panfrost 1.2.0 20180908 for ff9a0000.gpu on minor 1
[   13.923214] random: crng init done
[   13.923222] random: 99 urandom warning(s) missed due to ratelimiting
[   13.951542] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[   13.951568] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.951576] usb usb6: Product: Generic Platform OHCI controller
[   13.951583] usb usb6: Manufacturer: Linux 5.15.93-rockchip64 ohci_hcd
[   13.951589] usb usb6: SerialNumber: fe3a0000.usb
[   13.964364] hub 6-0:1.0: USB hub found
[   13.964429] hub 6-0:1.0: 1 port detected
[   14.181551] usbcore: registered new interface driver usbserial_generic
[   14.181638] usbserial: USB Serial support registered for generic
[   14.196685] usbcore: registered new interface driver cypress_m8
[   14.196761] usbserial: USB Serial support registered for DeLorme Earthmate USB
[   14.196801] usbserial: USB Serial support registered for HID->COM RS232 Adapter
[   14.196839] usbserial: USB Serial support registered for Nokia CA-42 V2 Adapter
[   14.196910] cypress_m8 1-1.1:1.0: HID->COM RS232 Adapter converter detected
[   14.363400] usb 1-1.1: HID->COM RS232 Adapter converter now attached to ttyUSB0
[   14.491283] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   14.492332] rk_gmac-dwmac fe300000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   14.503137] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found
[   14.503165] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW
[   14.503818] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode
[   14.542819] usb 2-1.4: reset SuperSpeed USB device number 3 using xhci-hcd
[   14.641526] r8152 2-1.4:1.0: load rtl8156a-2 v1 04/15/21 successfully
[   14.679473] r8152 2-1.4:1.0 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 256
[   14.695355] r8152 2-1.4:1.0 eth1: v1.12.13
[   14.695574] usbcore: registered new interface driver r8152
[   14.723281] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[   14.858846] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl. Quota mode: journalled.
[   14.977195] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl. Quota mode: journalled.
[   17.754398] cyphidcom ttyUSB0: HID->COM RS232 Adapter converter now disconnected from ttyUSB0
[   17.754503] cypress_m8 1-1.1:1.0: device disconnected
[   18.626966] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   18.627006] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   23.256549] systemd-journald[456]: Failed to read journal file /var/log/journal/1f99336995dc4c3bbc239523003d1d8d/user-1000.journal for rotation, trying to move it out of the way: Device or resource busy
[  116.076595] usb 2-1.2: new SuperSpeed USB device number 4 using xhci-hcd
[  116.097920] usb 2-1.2: New USB device found, idVendor=152d, idProduct=0576, bcdDevice=42.01
[  116.097949] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  116.097968] usb 2-1.2: Product: Ugreen Storage Device
[  116.097982] usb 2-1.2: Manufacturer: Ugreen
[  116.097996] usb 2-1.2: SerialNumber: 740200010001
[  116.099472] usb-storage 2-1.2:1.0: USB Mass Storage device detected
[  116.100573] scsi host5: usb-storage 2-1.2:1.0
[  116.140102] usbcore: registered new interface driver uas
[  117.116856] scsi 5:0:0:0: Direct-Access     WDC      WD140EDGZ-11B1PA 4201 PQ: 0 ANSI: 6
[  117.117106] sd 5:0:0:0: Attached scsi generic sg2 type 0
[  117.117464] scsi 5:0:0:1: Direct-Access     WDC      WD140EDGZ-11B1PA 4201 PQ: 0 ANSI: 6
[  117.117675] sd 5:0:0:1: Attached scsi generic sg3 type 0
[  117.117801] sd 5:0:0:0: [sdc] Very big device. Trying to use READ CAPACITY(16).
[  117.118125] sd 5:0:0:1: [sdd] Very big device. Trying to use READ CAPACITY(16).
[  117.118299] sd 5:0:0:0: [sdc] 27344764928 512-byte logical blocks: (14.0 TB/12.7 TiB)
[  117.118307] sd 5:0:0:0: [sdc] 4096-byte physical blocks
[  117.118736] sd 5:0:0:0: [sdc] Write Protect is off
[  117.118746] sd 5:0:0:0: [sdc] Mode Sense: 47 00 00 08
[  117.118919] sd 5:0:0:1: [sdd] 27344764928 512-byte logical blocks: (14.0 TB/12.7 TiB)
[  117.118927] sd 5:0:0:1: [sdd] 4096-byte physical blocks
[  117.119293] sd 5:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  117.119771] sd 5:0:0:1: [sdd] Write Protect is off
[  117.119788] sd 5:0:0:1: [sdd] Mode Sense: 47 00 00 08
[  117.120242] sd 5:0:0:1: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  117.252293] GPT:Primary header thinks Alt. header is not at the end of the disk.
[  117.252310] GPT:27344699391 != 27344764927
[  117.252318] GPT:Alternate GPT header not at the end of the disk.
[  117.252321] GPT:27344699391 != 27344764927
[  117.252325] GPT: Use GNU Parted to correct GPT errors.
[  117.252344]  sdc: sdc1
[  117.252420] GPT:Primary header thinks Alt. header is not at the end of the disk.
[  117.252440] GPT:27344699391 != 27344764927
[  117.252446] GPT:Alternate GPT header not at the end of the disk.
[  117.252449] GPT:27344699391 != 27344764927
[  117.252454] GPT: Use GNU Parted to correct GPT errors.
[  117.252471]  sdd: sdd1
[  117.254663] sd 5:0:0:1: [sdd] Attached SCSI disk
[  117.255013] sd 5:0:0:0: [sdc] Attached SCSI disk
[  242.742731] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[  308.276721] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[  373.814806] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[  439.344776] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[  504.878943] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[  570.413292] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[  635.947458] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[  701.481524] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[  857.125026] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[  922.659182] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 1078.303074] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 1143.837057] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 1209.375168] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 1274.905286] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 1340.439426] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 1405.977583] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 1590.288648] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 1655.822779] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 1721.356925] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 1786.891100] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 1852.425160] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 1917.959329] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 1983.493538] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 2049.027714] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 2216.959060] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 2282.493300] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 2376.698667] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 2442.232839] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 2507.767019] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 2573.305168] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 2870.252782] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 2935.787058] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 3001.321267] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
[ 3066.855416] usb 2-1.2: reset SuperSpeed USB device number 4 using xhci-hcd
helios64:~:#
dmesg of second session
helios64:~:# dmesg
[    0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.002159] Console: colour dummy device 80x25
[    0.002226] printk: console [tty1] enabled
[    0.002342] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002365] pid_max: default: 32768 minimum: 301
[    0.002500] LSM: Security Framework initializing
[    0.002541] Yama: becoming mindful.
[    0.002681] AppArmor: AppArmor initialized
[    0.006970] rcu: Hierarchical SRCU implementation.
[    0.008554] Platform MSI: interrupt-controller@fee20000 domain created
[    0.009136] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.011445] EFI services will not be available.
[    0.012347] smp: Bringing up secondary CPUs ...
[    0.013485] Detected VIPT I-cache on CPU1
[    0.013553] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.013577] GICv3: CPU1: using allocated LPI pending table @0x00000000004f0000
[    0.013651] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.015138] Detected VIPT I-cache on CPU2
[    0.015204] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.015228] GICv3: CPU2: using allocated LPI pending table @0x0000000000580000
[    0.015300] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.016855] Detected VIPT I-cache on CPU3
[    0.016921] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.016944] GICv3: CPU3: using allocated LPI pending table @0x0000000000590000
[    0.017013] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.018505] CPU features: detected: Spectre-v2
[    0.018518] CPU features: detected: Spectre-v3a
[    0.018524] CPU features: detected: Spectre-v4
[    0.018530] CPU features: detected: Spectre-BHB
[    0.018538] CPU features: detected: ARM erratum 1742098
[    0.018545] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.018551] Detected PIPT I-cache on CPU4
[    0.018587] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.018605] GICv3: CPU4: using allocated LPI pending table @0x00000000005a0000
[    0.018652] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
[    0.020015] Detected PIPT I-cache on CPU5
[    0.020061] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.020080] GICv3: CPU5: using allocated LPI pending table @0x00000000005b0000
[    0.020127] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
[    0.020313] smp: Brought up 1 node, 6 CPUs
[    0.020351] SMP: Total of 6 processors activated.
[    0.020361] CPU features: detected: 32-bit EL0 Support
[    0.020367] CPU features: detected: 32-bit EL1 Support
[    0.020377] CPU features: detected: CRC32 instructions
[    0.047210] CPU: All CPU(s) started at EL2
[    0.047309] alternatives: patching kernel code
[    0.050454] devtmpfs: initialized
[    0.066253] Registered cp15_barrier emulation handler
[    0.066279] Registered setend emulation handler
[    0.066292] KASLR disabled due to lack of seed
[    0.066502] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.066580] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.069597] pinctrl core: initialized pinctrl subsystem
[    0.070258] DMI not present or invalid.
[    0.071127] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.075716] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.077405] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.080216] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.080310] audit: initializing netlink subsys (disabled)
[    0.080577] audit: type=2000 audit(0.080:1): state=initialized audit_enabled=0 res=1
[    0.081833] thermal_sys: Registered thermal governor 'fair_share'
[    0.081843] thermal_sys: Registered thermal governor 'bang_bang'
[    0.081850] thermal_sys: Registered thermal governor 'step_wise'
[    0.081856] thermal_sys: Registered thermal governor 'user_space'
[    0.082338] cpuidle: using governor menu
[    0.082613] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.082865] ASID allocator initialised with 65536 entries
[    0.084165] Serial: AMBA PL011 UART driver
[    0.114257] platform ff770000.syscon:phy@f780: Fixing up cyclic dependency with fe330000.mmc
[    0.117516] platform ff8f0000.vop: Fixing up cyclic dependency with fec00000.dp
[    0.118840] platform ff900000.vop: Fixing up cyclic dependency with fec00000.dp
[    0.131714] rockchip-gpio ff720000.gpio0: probed /pinctrl/gpio0@ff720000
[    0.132511] rockchip-gpio ff730000.gpio1: probed /pinctrl/gpio1@ff730000
[    0.133213] rockchip-gpio ff780000.gpio2: probed /pinctrl/gpio2@ff780000
[    0.133988] rockchip-gpio ff788000.gpio3: probed /pinctrl/gpio3@ff788000
[    0.134706] rockchip-gpio ff790000.gpio4: probed /pinctrl/gpio4@ff790000
[    0.159846] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.159862] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.159871] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.159880] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.165325] cryptd: max_cpu_qlen set to 1000
[    0.244491] raid6: neonx8   gen()  1666 MB/s
[    0.312650] raid6: neonx8   xor()  1222 MB/s
[    0.380815] raid6: neonx4   gen()  1727 MB/s
[    0.448977] raid6: neonx4   xor()  1268 MB/s
[    0.517149] raid6: neonx2   gen()  1539 MB/s
[    0.585311] raid6: neonx2   xor()  1177 MB/s
[    0.653471] raid6: neonx1   gen()  1201 MB/s
[    0.721631] raid6: neonx1   xor()   932 MB/s
[    0.789816] raid6: int64x8  gen()  1002 MB/s
[    0.858000] raid6: int64x8  xor()   577 MB/s
[    0.926140] raid6: int64x4  gen()  1001 MB/s
[    0.994289] raid6: int64x4  xor()   591 MB/s
[    1.062454] raid6: int64x2  gen()   943 MB/s
[    1.130608] raid6: int64x2  xor()   524 MB/s
[    1.198800] raid6: int64x1  gen()   724 MB/s
[    1.266941] raid6: int64x1  xor()   391 MB/s
[    1.266949] raid6: using algorithm neonx4 gen() 1727 MB/s
[    1.266956] raid6: .... xor() 1268 MB/s, rmw enabled
[    1.266963] raid6: using neon recovery algorithm
[    1.268732] vcc12v_dcin_bkup: supplied by vcc12v_dcin
[    1.269087] vcc12v_hdd: supplied by vcc12v_dcin_bkup
[    1.269551] vcc5v0_perdev: supplied by vcc12v_dcin_bkup
[    1.269953] vcc5v0_hdd: supplied by vcc12v_dcin_bkup
[    1.270310] vcc5v0_sys: supplied by vcc12v_dcin_bkup
[    1.271707] iommu: Default domain type: Translated
[    1.271717] iommu: DMA domain TLB invalidation policy: strict mode
[    1.274866] vgaarb: loaded
[    1.275364] SCSI subsystem initialized
[    1.275888] libata version 3.00 loaded.
[    1.276161] usbcore: registered new interface driver usbfs
[    1.276207] usbcore: registered new interface driver hub
[    1.276251] usbcore: registered new device driver usb
[    1.277032] pps_core: LinuxPPS API ver. 1 registered
[    1.277040] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.277057] PTP clock support registered
[    1.277378] EDAC MC: Ver: 3.0.0
[    1.278683] NetLabel: Initializing
[    1.278693] NetLabel:  domain hash size = 128
[    1.278699] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    1.278791] NetLabel:  unlabeled traffic allowed by default
[    1.279310] clocksource: Switched to clocksource arch_sys_counter
[    1.330530] VFS: Disk quotas dquot_6.6.0
[    1.330611] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.331466] AppArmor: AppArmor Filesystem Enabled
[    1.342131] NET: Registered PF_INET protocol family
[    1.342475] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    1.345571] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    1.345827] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    1.345949] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    1.346486] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[    1.347155] TCP: Hash tables configured (established 32768 bind 32768)
[    1.347389] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.347562] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    1.347913] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    1.347949] NET: Registered PF_XDP protocol family
[    1.347963] PCI: CLS 0 bytes, default 64
[    1.348644] Trying to unpack rootfs image as initramfs...
[    1.349247] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    1.349777] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    1.350569] kvm [1]: IPA Size Limit: 40 bits
[    1.351910] kvm [1]: vgic-v2@fff20000
[    1.351946] kvm [1]: GIC system register CPU interface enabled
[    1.352241] kvm [1]: vgic interrupt IRQ18
[    1.352571] kvm [1]: Hyp mode initialized successfully
[    1.364849] Initialise system trusted keyrings
[    1.364964] Key type blacklist registered
[    1.365223] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    1.372013] zbud: loaded
[    1.373746] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.374676] fuse: init (API version 7.34)
[    1.377453] integrity: Platform Keyring initialized
[    1.443494] xor: measuring software checksum speed
[    1.451618]    8regs           :  1218 MB/sec
[    1.458711]    32regs          :  1402 MB/sec
[    1.462934]    arm64_neon      :  2353 MB/sec
[    1.462944] xor: using function: arm64_neon (2353 MB/sec)
[    1.462959] Key type asymmetric registered
[    1.462966] Asymmetric key parser 'x509' registered
[    1.463092] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.463352] io scheduler mq-deadline registered
[    1.463363] io scheduler kyber registered
[    1.463583] io scheduler bfq registered
[    1.490168] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.490185] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    1.491694] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.491709] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.497039] vdd_log: supplied by regulator-dummy
[    1.498733] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    1.502218] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 40, base_baud = 1500000) is a 16550A
[    1.503322] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 41, base_baud = 1500000) is a 16550A
[    1.503602] printk: console [ttyS2] enabled
[    1.505083] Serial: AMBA driver
[    1.507236] rockchip-vop ff8f0000.vop: Adding to iommu group 2
[    1.508295] rockchip-vop ff900000.vop: Adding to iommu group 3
[    1.515068] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.525128] loop: module loaded
[    1.534529] tun: Universal TUN/TAP device driver, 1.6
[    1.535819] thunder_xcv, ver 1.0
[    1.535873] thunder_bgx, ver 1.0
[    1.535917] nicpf, ver 1.0
[    1.537150] e1000e: Intel(R) PRO/1000 Network Driver
[    1.537157] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    1.537204] igb: Intel(R) Gigabit Ethernet Network Driver
[    1.537210] igb: Copyright (c) 2007-2014 Intel Corporation.
[    1.537253] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    1.537259] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    1.537573] sky2: driver version 1.30
[    1.538367] VFIO - User Level meta-driver version: 0.3
[    1.550011] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.550049] ehci-pci: EHCI PCI platform driver
[    1.550093] ehci-platform: EHCI generic platform driver
[    1.550466] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.550483] ohci-pci: OHCI PCI platform driver
[    1.550534] ohci-platform: OHCI generic platform driver
[    1.551787] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.551816] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    1.552014] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010
[    1.552090] xhci-hcd xhci-hcd.0.auto: irq 75, io mem 0xfe900000
[    1.552328] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.552344] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    1.552361] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    1.552571] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    1.552587] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.552599] usb usb1: Product: xHCI Host Controller
[    1.552608] usb usb1: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd
[    1.552617] usb usb1: SerialNumber: xhci-hcd.0.auto
[    1.553208] hub 1-0:1.0: USB hub found
[    1.553250] hub 1-0:1.0: 1 port detected
[    1.553693] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.553844] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    1.553858] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.553869] usb usb2: Product: xHCI Host Controller
[    1.553878] usb usb2: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd
[    1.553887] usb usb2: SerialNumber: xhci-hcd.0.auto
[    1.554419] hub 2-0:1.0: USB hub found
[    1.554462] hub 2-0:1.0: 1 port detected
[    1.554959] usbcore: registered new interface driver usb-storage
[    1.557906] mousedev: PS/2 mouse device common for all mice
[    1.559470] i2c_dev: i2c /dev entries driver
[    1.565817] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    1.566446] vdd_cpu_b: supplied by vcc5v0_sys
[    1.569231] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    1.569970] vdd_gpu: supplied by vcc5v0_sys
[    1.579259] dw_wdt ff848000.watchdog: No valid TOPs array specified
[    1.581487] sdhci: Secure Digital Host Controller Interface driver
[    1.581497] sdhci: Copyright(c) Pierre Ossman
[    1.581525] Synopsys Designware Multimedia Card Interface Driver
[    1.582887] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.587415] ledtrig-cpu: registered to indicate activity on CPUs
[    1.588974] hid: raw HID events driver (C) Jiri Kosina
[    1.589147] usbcore: registered new interface driver usbhid
[    1.589155] usbhid: USB HID core driver
[    1.594282] drop_monitor: Initializing network drop monitor service
[    1.595084] NET: Registered PF_INET6 protocol family
[    1.807343] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    1.957399] usb 1-1: New USB device found, idVendor=2109, idProduct=2815, bcdDevice= 7.04
[    1.957424] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.957435] usb 1-1: Product: USB2.0 Hub
[    1.957445] usb 1-1: Manufacturer: VIA Labs, Inc.
[    2.000814] hub 1-1:1.0: USB hub found
[    2.001053] hub 1-1:1.0: 4 ports detected
[    2.095467] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[    2.213808] usb 2-1: New USB device found, idVendor=2109, idProduct=0815, bcdDevice= 7.04
[    2.213830] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.213842] usb 2-1: Product: USB3.0 Hub
[    2.213851] usb 2-1: Manufacturer: VIA Labs, Inc.
[    2.237086] Freeing initrd memory: 18012K
[    2.240871] hub 2-1:1.0: USB hub found
[    2.241143] hub 2-1:1.0: 4 ports detected
[    2.293509] Segment Routing with IPv6
[    2.293605] In-situ OAM (IOAM) with IPv6
[    2.293717] NET: Registered PF_PACKET protocol family
[    2.293920] 8021q: 802.1Q VLAN Support v1.8
[    2.294035] Key type dns_resolver registered
[    2.295730] registered taskstats version 1
[    2.295749] Loading compiled-in X.509 certificates
[    2.299381] Loaded X.509 cert 'Build time autogenerated kernel key: 1fb701576c47097ebe5805564f004ecdeffa983a'
[    2.305912] zswap: loaded using pool zstd/z3fold
[    2.307114] Key type .fscrypt registered
[    2.307124] Key type fscrypt-provisioning registered
[    2.310212] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=yes
[    2.337216] Key type encrypted registered
[    2.337237] AppArmor: AppArmor sha1 policy hashing enabled
[    2.386042] pcie_power: supplied by vcc5v0_perdev
[    2.396996] vcc3v3_sys_s3: supplied by vcc5v0_sys
[    2.397679] vcc3v0_sd: supplied by vcc3v3_sys_s3
[    2.398578] vcc5v0_usb: supplied by vcc5v0_perdev
[    2.399604] vcc5v0_typec: supplied by vcc5v0_usb
[    2.400115] usblan_power: supplied by vcc5v0_usb
[    2.404173] pca953x 2-0020: using no AI
[    2.407085] rk808 0-001b: chip id: 0x0
[    2.413269] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    2.413327] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    2.413343] rk808-regulator rk808-regulator: max buck steps per change: 4
[    2.414108] vdd_center: supplied by vcc5v0_sys
[    2.415097] vdd_cpu_l: supplied by vcc5v0_sys
[    2.415620] vcc_ddr_s3: supplied by vcc5v0_sys
[    2.416373] vcc1v8_sys_s3: supplied by vcc5v0_sys
[    2.417357] vcc1v8_dvp: supplied by vcc5v0_sys
[    2.417992] vcc3v0_touch: supplied by vcc5v0_sys
[    2.418683] vcc1v8_s3: supplied by vcc5v0_sys
[    2.419835] vcc_sdio_s0: Bringing 3300000uV into 3000000-3000000uV
[    2.420277] vcc_sdio_s0: supplied by vcc5v0_sys
[    2.421680] vcca3v0_codec: supplied by vcc5v0_sys
[    2.422222] vcc1v5_s3: supplied by vcc5v0_sys
[    2.423670] vcca1v8_codec: supplied by vcc5v0_sys
[    2.424226] vcc3v0_s3: supplied by vcc5v0_sys
[    2.425225] vcc3v3_sys_s0: failed to get the current voltage: -EPROBE_DEFER
[    2.425263] vcc3v3_sys_s0: supplied by vcc3v3_sys_s3
[    2.425969] vcc3v3_s0: supplied by vcc3v3_sys_s3
[    2.430266] rk808-rtc rk808-rtc: registered as rtc0
[    2.430864] rk808-rtc rk808-rtc: setting system clock to 2023-09-30T17:41:11 UTC (1696095671)
[    2.434463] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
[    2.434502] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
[    2.434518] dwmmc_rockchip fe320000.mmc: Version ID is 270a
[    2.434584] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 32,32 bit host data width,256 deep fifo
[    2.435268] dwmmc_rockchip fe320000.mmc: Got CD GPIO
[    2.436409] vcc1v8_sys_s0: supplied by vcc1v8_sys_s3
[    2.437069] vcc0v9_s3: supplied by vcc3v3_sys_s3
[    2.437721] avdd_0v9_s0: supplied by vcc1v8_sys_s3
[    2.438352] avdd_1v8_s0: supplied by vcc3v3_sys_s3
[    2.439538] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
[    2.439607] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
[    2.439641] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
[    2.440539] rockchip-pcie f8000000.pcie: no bus scan delay, default to 0 ms
[    2.448218] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    2.468520] rockchip-pcie f8000000.pcie: wait 0 ms (from device tree) before bus scan
[    2.469015] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[    2.469035] pci_bus 0000:00: root bus resource [bus 00-1f]
[    2.469051] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff]
[    2.469070] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff])
[    2.469141] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400
[    2.469357] pci 0000:00:00.0: supports D1
[    2.469371] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    2.477284] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    2.477649] pci 0000:01:00.0: [197b:0585] type 00 class 0x010601
[    2.477734] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[    2.477748] pci 0000:01:00.0: reg 0x10: [io  size 0x0080]
[    2.477792] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid
[    2.477806] pci 0000:01:00.0: reg 0x14: [io  size 0x0080]
[    2.477847] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid
[    2.477860] pci 0000:01:00.0: reg 0x18: [io  size 0x0080]
[    2.477901] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid
[    2.477914] pci 0000:01:00.0: reg 0x1c: [io  size 0x0080]
[    2.477955] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid
[    2.477968] pci 0000:01:00.0: reg 0x20: [io  size 0x0080]
[    2.478010] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff]
[    2.478052] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[    2.478100] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512)
[    2.478470] pci 0000:01:00.0: PME# supported from D3hot
[    2.478731] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link)
[    2.486122] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01
[    2.486177] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff]
[    2.486206] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref]
[    2.486225] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff]
[    2.486253] pci 0000:01:00.0: BAR 0: no space for [io  size 0x0080]
[    2.486268] pci 0000:01:00.0: BAR 0: failed to assign [io  size 0x0080]
[    2.486282] pci 0000:01:00.0: BAR 1: no space for [io  size 0x0080]
[    2.486295] pci 0000:01:00.0: BAR 1: failed to assign [io  size 0x0080]
[    2.486310] pci 0000:01:00.0: BAR 2: no space for [io  size 0x0080]
[    2.486323] pci 0000:01:00.0: BAR 2: failed to assign [io  size 0x0080]
[    2.486337] pci 0000:01:00.0: BAR 3: no space for [io  size 0x0080]
[    2.486350] pci 0000:01:00.0: BAR 3: failed to assign [io  size 0x0080]
[    2.486364] pci 0000:01:00.0: BAR 4: no space for [io  size 0x0080]
[    2.486378] pci 0000:01:00.0: BAR 4: failed to assign [io  size 0x0080]
[    2.486395] pci 0000:00:00.0: PCI bridge to [bus 01]
[    2.486415] pci 0000:00:00.0:   bridge window [mem 0xfa000000-0xfa0fffff]
[    2.486747] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[    2.487224] pcieport 0000:00:00.0: PME: Signaling with IRQ 89
[    2.487904] pcieport 0000:00:00.0: AER: enabled with IRQ 89
[    2.488353] ahci 0000:01:00.0: version 3.0
[    2.488395] ahci 0000:01:00.0: enabling device (0000 -> 0002)
[    2.489210] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled
[    2.489327] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode
[    2.489350] ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh
[    2.497516] scsi host0: ahci
[    2.498485] scsi host1: ahci
[    2.499364] scsi host2: ahci
[    2.500172] scsi host3: ahci
[    2.500943] scsi host4: ahci
[    2.501267] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 90
[    2.501286] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 91
[    2.501299] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 92
[    2.501312] ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 93
[    2.501324] ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 94
[    2.510393] mmc1: CQHCI version 5.10
[    2.510828] WCN: marlin_init entry!
[    2.512435] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    2.513066] of_cfs_init
[    2.513106] of_cfs_init: OK
[    2.514309] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
[    2.536739] mmc1: SDHCI controller on fe330000.mmc [fe330000.mmc] using ADMA
[    2.607799] mmc1: Command Queue Engine enabled
[    2.607832] mmc1: new HS200 MMC card at address 0001
[    2.608940] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB
[    2.612408] mmcblk1boot0: mmc1:0001 AJTD4R 4.00 MiB
[    2.614920] mmcblk1boot1: mmc1:0001 AJTD4R 4.00 MiB
[    2.617280] mmcblk1rpmb: mmc1:0001 AJTD4R 4.00 MiB, chardev (241:0)
[    2.823355] usb 1-1.1: new low-speed USB device number 3 using xhci-hcd
[    2.977005] usb 1-1.1: New USB device found, idVendor=04b4, idProduct=5500, bcdDevice= 0.01
[    2.977022] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.977034] usb 1-1.1: Product: USB to Serial
[    2.977043] usb 1-1.1: Manufacturer: Cypress Semiconductor
[    3.035377] dwmmc_rockchip fe320000.mmc: Successfully tuned phase to 188
[    3.035404] mmc0: new ultra high speed SDR104 SDHC card at address 59b4
[    3.036599] mmcblk0: mmc0:59b4 SN32G 29.7 GiB
[    3.040407]  mmcblk0: p1
[    3.056457] usb 2-1.2: new SuperSpeed USB device number 3 using xhci-hcd
[    3.076591] usb 2-1.2: New USB device found, idVendor=152d, idProduct=0576, bcdDevice=42.01
[    3.076608] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.076619] usb 2-1.2: Product: Ugreen Storage Device
[    3.076628] usb 2-1.2: Manufacturer: Ugreen
[    3.076637] usb 2-1.2: SerialNumber: 740200010001
[    3.077603] usb-storage 2-1.2:1.0: USB Mass Storage device detected
[    3.078319] scsi host5: usb-storage 2-1.2:1.0
[    3.159415] usb 2-1.4: new SuperSpeed USB device number 4 using xhci-hcd
[    3.180438] usb 2-1.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=30.00
[    3.180454] usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6
[    3.180465] usb 2-1.4: Product: USB 10/100/1G/2.5G LAN
[    3.180474] usb 2-1.4: Manufacturer: Realtek
[    3.180482] usb 2-1.4: SerialNumber: 000000001
[    4.095911] scsi 5:0:0:0: Direct-Access     WDC      WD140EDGZ-11B1PA 4201 PQ: 0 ANSI: 6
[    4.097120] sd 5:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
[    4.097391] scsi 5:0:0:1: Direct-Access     WDC      WD140EDGZ-11B1PA 4201 PQ: 0 ANSI: 6
[    4.097643] sd 5:0:0:0: [sda] 27344764928 512-byte logical blocks: (14.0 TB/12.7 TiB)
[    4.097664] sd 5:0:0:0: [sda] 4096-byte physical blocks
[    4.098165] sd 5:0:0:0: [sda] Write Protect is off
[    4.098183] sd 5:0:0:0: [sda] Mode Sense: 47 00 00 08
[    4.098565] sd 5:0:0:1: [sdb] Very big device. Trying to use READ CAPACITY(16).
[    4.099091] sd 5:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.099341] sd 5:0:0:1: [sdb] 27344764928 512-byte logical blocks: (14.0 TB/12.7 TiB)
[    4.099359] sd 5:0:0:1: [sdb] 4096-byte physical blocks
[    4.099795] sd 5:0:0:1: [sdb] Write Protect is off
[    4.099814] sd 5:0:0:1: [sdb] Mode Sense: 47 00 00 08
[    4.100251] sd 5:0:0:1: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.186887] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    4.186906] GPT:27344699391 != 27344764927
[    4.186919] GPT:Alternate GPT header not at the end of the disk.
[    4.186925] GPT:27344699391 != 27344764927
[    4.186934] GPT: Use GNU Parted to correct GPT errors.
[    4.186967]  sda: sda1
[    4.196203] sd 5:0:0:0: [sda] Attached SCSI disk
[    4.199715] GPT:Primary header thinks Alt. header is not at the end of the disk.
[    4.199731] GPT:27344699391 != 27344764927
[    4.199743] GPT:Alternate GPT header not at the end of the disk.
[    4.199750] GPT:27344699391 != 27344764927
[    4.199757] GPT: Use GNU Parted to correct GPT errors.
[    4.199794]  sdb: sdb1
[    4.201557] sd 5:0:0:1: [sdb] Attached SCSI disk
[    5.731375] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    5.732027] ata1.00: ATA-9: WDC WD60EFRX-68L0BN1, 82.00A82, max UDMA/133
[    5.732598] ata1.00: 11721045168 sectors, multi 0: LBA48 NCQ (depth 32), AA
[    5.733864] ata1.00: configured for UDMA/133
[    5.734204] scsi 0:0:0:0: Direct-Access     ATA      WDC WD60EFRX-68L 0A82 PQ: 0 ANSI: 5
[    5.735503] sd 0:0:0:0: [sdc] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB)
[    5.735524] sd 0:0:0:0: [sdc] 4096-byte physical blocks
[    5.735599] sd 0:0:0:0: [sdc] Write Protect is off
[    5.735617] sd 0:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[    5.735738] sd 0:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    5.798705]  sdc: sdc1
[    5.819664] sd 0:0:0:0: [sdc] Attached SCSI disk
[    6.049814] ata2: SATA link down (SStatus 0 SControl 300)
[    6.523355] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    6.524013] ata3.00: ATA-9: WDC WD60EFRX-68L0BN1, 82.00A82, max UDMA/133
[    6.524586] ata3.00: 11721045168 sectors, multi 0: LBA48 NCQ (depth 32), AA
[    6.525881] ata3.00: configured for UDMA/133
[    6.526497] scsi 2:0:0:0: Direct-Access     ATA      WDC WD60EFRX-68L 0A82 PQ: 0 ANSI: 5
[    6.528089] sd 2:0:0:0: [sdd] 11721045168 512-byte logical blocks: (6.00 TB/5.46 TiB)
[    6.528105] sd 2:0:0:0: [sdd] 4096-byte physical blocks
[    6.528178] sd 2:0:0:0: [sdd] Write Protect is off
[    6.528192] sd 2:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[    6.528320] sd 2:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    6.587636]  sdd: sdd1
[    6.603551] sd 2:0:0:0: [sdd] Attached SCSI disk
[    6.841994] ata4: SATA link down (SStatus 0 SControl 300)
[    7.153966] ata5: SATA link down (SStatus 0 SControl 300)
[    7.156313] Freeing unused kernel memory: 4352K
[    7.156439] Run /init as init process
[    7.156449]   with arguments:
[    7.156459]     /init
[    7.156468]   with environment:
[    7.156475]     HOME=/
[    7.156483]     TERM=linux
[    7.156491]     ubootpart=ccc514b5-01
[    7.156499]     cgroup_enable=memory
[    7.156508]     cgroup_memory=1
[    8.510031] input: adc-keys as /devices/platform/adc-keys/input/input1
[    8.668207] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found
[    8.668238] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found
[    8.668466] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock
[    8.676401] usbcore: registered new interface driver uas
[    8.679846] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    8.684321] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    8.684348] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20).
[    8.684379] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    8.684514] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[    8.684528] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    8.689569] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    8.697659] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[    8.697704] rk_gmac-dwmac fe300000.ethernet:         DWMAC1000
[    8.697718] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported
[    8.697730] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported
[    8.697741] rk_gmac-dwmac fe300000.ethernet: COE Type 2
[    8.697753] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported
[    8.697764] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported
[    8.730550] rk_gmac-dwmac fe300000.ethernet: Normal descriptors
[    8.730581] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled
[    8.730594] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    8.900713] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[    8.900736] RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[    9.390574] async_tx: api initialized (async)
[    9.957463] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null). Quota mode: none.
[   10.411353] random: crng init done
[   10.644831] systemd[1]: Inserted module 'autofs4'
[   10.705217] systemd[1]: systemd 247.3-7+deb11u4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[   10.706255] systemd[1]: Detected architecture arm64.
[   10.714389] systemd[1]: Set hostname to <helios64>.
[   10.880072] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
[   11.903679] systemd[1]: Queued start job for default target Graphical Interface.
[   11.909040] systemd[1]: Created slice system-getty.slice.
[   11.911260] systemd[1]: Created slice system-modprobe.slice.
[   11.913486] systemd[1]: Created slice system-postfix.slice.
[   11.915283] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   11.917130] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[   11.918726] systemd[1]: Created slice User and Session Slice.
[   11.919074] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   11.919569] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   11.920853] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   11.921365] systemd[1]: Reached target Local Encrypted Volumes.
[   11.921954] systemd[1]: Reached target Slices.
[   11.922260] systemd[1]: Reached target Swap.
[   11.922544] systemd[1]: Reached target System Time Set.
[   11.923282] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[   11.928008] systemd[1]: Listening on LVM2 poll daemon socket.
[   11.953261] systemd[1]: Listening on RPCbind Server Activation Socket.
[   11.954416] systemd[1]: Listening on Syslog Socket.
[   11.955403] systemd[1]: Listening on fsck to fsckd communication Socket.
[   11.955992] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   11.957166] systemd[1]: Listening on Journal Audit Socket.
[   11.958061] systemd[1]: Listening on Journal Socket (/dev/log).
[   11.959096] systemd[1]: Listening on Journal Socket.
[   11.962024] systemd[1]: Listening on Network Service Netlink Socket.
[   11.963281] systemd[1]: Listening on udev Control Socket.
[   11.964228] systemd[1]: Listening on udev Kernel Socket.
[   11.969188] systemd[1]: Mounting Huge Pages File System...
[   11.975006] systemd[1]: Mounting POSIX Message Queue File System...
[   11.980501] systemd[1]: Mounting RPC Pipe File System...
[   11.986066] systemd[1]: Mounting Kernel Debug File System...
[   11.992009] systemd[1]: Mounting Kernel Trace File System...
[   11.993198] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[   11.993915] systemd[1]: Finished Availability of block devices.
[   12.000719] systemd[1]: Starting Set the console keyboard layout...
[   12.006373] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   12.012228] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   12.017980] systemd[1]: Starting Load Kernel Module configfs...
[   12.023933] systemd[1]: Starting Load Kernel Module drm...
[   12.030748] systemd[1]: Starting Load Kernel Module fuse...
[   12.031615] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[   12.037671] systemd[1]: Started Nameserver information manager.
[   12.038596] systemd[1]: Reached target Network (Pre).
[   12.041662] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   12.042035] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   12.052790] systemd[1]: Starting Journal Service...
[   12.062705] systemd[1]: Starting Load Kernel Modules...
[   12.068562] systemd[1]: Starting Remount Root and Kernel File Systems...
[   12.074382] systemd[1]: Starting Coldplug All udev Devices...
[   12.088083] systemd[1]: Mounted Huge Pages File System.
[   12.089078] systemd[1]: Mounted POSIX Message Queue File System.
[   12.090005] systemd[1]: Mounted Kernel Debug File System.
[   12.090948] systemd[1]: Mounted Kernel Trace File System.
[   12.093327] systemd[1]: Finished Set the console keyboard layout.
[   12.096022] systemd[1]: Finished Create list of static device nodes for the current kernel.
[   12.098078] systemd[1]: modprobe@configfs.service: Succeeded.
[   12.099730] systemd[1]: Finished Load Kernel Module configfs.
[   12.101945] systemd[1]: modprobe@drm.service: Succeeded.
[   12.103567] systemd[1]: Finished Load Kernel Module drm.
[   12.105773] systemd[1]: modprobe@fuse.service: Succeeded.
[   12.107352] systemd[1]: Finished Load Kernel Module fuse.
[   12.115544] systemd[1]: Mounting FUSE Control File System...
[   12.122542] systemd[1]: Mounting Kernel Configuration File System...
[   12.142579] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
[   12.161690] lm75 2-004c: supply vs not found, using dummy regulator
[   12.162950] hwmon hwmon2: temp1_input not attached to any thermal zone
[   12.162985] lm75 2-004c: hwmon2: sensor 'lm75'
[   12.176385] systemd[1]: Finished Remount Root and Kernel File Systems.
[   12.178191] systemd[1]: Mounted FUSE Control File System.
[   12.183708] systemd[1]: Mounted Kernel Configuration File System.
[   12.186285] RPC: Registered named UNIX socket transport module.
[   12.186303] RPC: Registered udp transport module.
[   12.186310] RPC: Registered tcp transport module.
[   12.186317] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   12.188419] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   12.188731] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   12.193849] systemd[1]: Starting Load/Save Random Seed...
[   12.199865] systemd[1]: Starting Create System Users...
[   12.206759] systemd[1]: Mounted RPC Pipe File System.
[   12.214295] systemd[1]: Starting pNFS block layout mapping daemon...
[   12.229034] systemd[1]: Started pNFS block layout mapping daemon.
[   12.257784] NILFS version 2 loaded
[   12.291436] systemd[1]: Finished Load/Save Random Seed.
[   12.292534] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[   12.304613] systemd[1]: Finished Create System Users.
[   12.308580] spl: loading out-of-tree module taints kernel.
[   12.309966] spl: module verification failed: signature and/or required key missing - tainting kernel
[   12.312993] systemd[1]: Starting Create Static Device Nodes in /dev...
[   12.335848] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[   12.360588] icp: module license 'CDDL' taints kernel.
[   12.360609] Disabling lock debugging due to kernel taint
[   12.401644] systemd[1]: Finished Create Static Device Nodes in /dev.
[   12.402980] systemd[1]: Reached target Local File Systems (Pre).
[   12.411109] systemd[1]: Mounting Mount /tmp as tmpfs to reduce write access to the root device...
[   12.424463] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[   12.434160] systemd[1]: Mounted Mount /tmp as tmpfs to reduce write access to the root device.
[   12.538035] systemd[1]: Started Journal Service.
[   12.594612] systemd-journald[464]: Received client request to flush runtime journal.
[   13.298720] input: beeper as /devices/platform/beeper/input/input2
[   13.555168] sd 5:0:0:0: Attached scsi generic sg0 type 0
[   13.555687] sd 5:0:0:1: Attached scsi generic sg1 type 0
[   13.555869] sd 0:0:0:0: Attached scsi generic sg2 type 0
[   13.577585] sd 2:0:0:0: Attached scsi generic sg3 type 0
[   13.669894] mc: Linux media interface: v0.10
[   13.698243] videodev: Linux video capture interface: v2.00
[   13.724950] ZFS: Loaded module v2.1.11-1~bpo11+1, ZFS pool version 5000, ZFS filesystem version 5
[   13.797006] rockchip-rga ff680000.rga: HW Version: 0x03.02
[   13.806089] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
[   13.808006] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
[   13.808272] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
[   13.809808] rkvdec ff660000.video-codec: Adding to iommu group 1
[   13.809910] hantro-vpu ff650000.video-codec: Adding to iommu group 0
[   13.810553] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1
[   13.813399] rockchip-iep ff670000.iep: Device rockchip-iep registered as /dev/video4
[   13.813446] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video2
[   13.816302] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22
[   13.841159] ehci-platform fe380000.usb: EHCI Host Controller
[   13.843951] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 3
[   13.844744] ehci-platform fe380000.usb: irq 34, io mem 0xfe380000
[   13.859378] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[   13.867794] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[   13.867822] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   13.867830] usb usb3: Product: EHCI Host Controller
[   13.867835] usb usb3: Manufacturer: Linux 5.15.93-rockchip64 ehci_hcd
[   13.867841] usb usb3: SerialNumber: fe380000.usb
[   13.999737] hub 3-0:1.0: USB hub found
[   13.999782] hub 3-0:1.0: 1 port detected
[   14.044259] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[   14.044945] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 4
[   14.045062] ohci-platform fe3a0000.usb: irq 35, io mem 0xfe3a0000
[   14.081681] panfrost ff9a0000.gpu: clock rate = 500000000
[   14.083999] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
[   14.084013] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
[   14.084018] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
[   14.084024] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
[   14.085040] [drm] Initialized panfrost 1.2.0 20180908 for ff9a0000.gpu on minor 0
[   14.107589] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
[   14.107619] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.107629] usb usb4: Product: Generic Platform OHCI controller
[   14.107635] usb usb4: Manufacturer: Linux 5.15.93-rockchip64 ohci_hcd
[   14.107641] usb usb4: SerialNumber: fe3a0000.usb
[   14.269846] hub 4-0:1.0: USB hub found
[   14.270130] hub 4-0:1.0: 1 port detected
[   14.451392] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[   14.452857] rk_gmac-dwmac fe300000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
[   14.464335] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops)
[   14.464441] [drm] unsupported AFBC format[3231564e]
[   14.465938] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found
[   14.465967] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW
[   14.466032] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops)
[   14.466486] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops)
[   14.467839] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[   14.474981] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn
[   14.524373] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1
[   14.617720] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode
[   14.693690] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   14.695457] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 5
[   14.695651] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x8000000002010010
[   14.695685] xhci-hcd xhci-hcd.3.auto: irq 74, io mem 0xfe800000
[   14.695908] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   14.695925] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 6
[   14.695939] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[   14.696153] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[   14.696162] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.696169] usb usb5: Product: xHCI Host Controller
[   14.696174] usb usb5: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd
[   14.696180] usb usb5: SerialNumber: xhci-hcd.3.auto
[   14.809430] hub 5-0:1.0: USB hub found
[   14.809534] hub 5-0:1.0: 1 port detected
[   14.867638] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[   14.867833] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[   14.867845] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   14.867854] usb usb6: Product: xHCI Host Controller
[   14.867861] usb usb6: Manufacturer: Linux 5.15.93-rockchip64 xhci-hcd
[   14.867867] usb usb6: SerialNumber: xhci-hcd.3.auto
[   14.868924] hub 6-0:1.0: USB hub found
[   14.868986] hub 6-0:1.0: 1 port detected
[   14.877182] usbcore: registered new interface driver usbserial_generic
[   14.877246] usbserial: USB Serial support registered for generic
[   14.889008] usbcore: registered new interface driver cypress_m8
[   14.889091] usbserial: USB Serial support registered for DeLorme Earthmate USB
[   14.889146] usbserial: USB Serial support registered for HID->COM RS232 Adapter
[   14.889198] usbserial: USB Serial support registered for Nokia CA-42 V2 Adapter
[   14.890055] cypress_m8 1-1.1:1.0: HID->COM RS232 Adapter converter detected
[   15.024885] usb 1-1.1: HID->COM RS232 Adapter converter now attached to ttyUSB0
[   15.056658] usb 2-1.4: reset SuperSpeed USB device number 4 using xhci-hcd
[   15.151812] r8152 2-1.4:1.0: load rtl8156a-2 v1 04/15/21 successfully
[   15.195881] r8152 2-1.4:1.0 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 256
[   15.211508] r8152 2-1.4:1.0 eth1: v1.12.13
[   15.211688] usbcore: registered new interface driver r8152
[   15.330403] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl. Quota mode: journalled.
[   15.368047] EXT4-fs (sdd1): mounted filesystem with ordered data mode. Opts: user_xattr,usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,acl. Quota mode: journalled.
[   15.487548] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[   18.356785] cyphidcom ttyUSB0: HID->COM RS232 Adapter converter now disconnected from ttyUSB0
[   18.356890] cypress_m8 1-1.1:1.0: device disconnected
[   18.720554] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[   18.720593] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  124.606186] usb 2-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  190.140309] usb 2-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  265.914602] usb 2-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  331.447056] usb 2-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  513.718837] usb 2-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  579.249305] usb 2-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  640.687776] usb 2-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
[  706.222197] usb 2-1.2: reset SuperSpeed USB device number 3 using xhci-hcd
helios64:~:#
my question is: the problem it's related from standard drivers inside the image, from the kernel or it's necessary take manufacturer driver source and compile it? How can I solve this issue?
Hope that somebody help me
Best regards
I believe your issue is that with the USB-C UGREEN 5 bay enclosure SMART data display in OMV times out after 4 minutes (and that you are afraid there could be corrupt files during transfer to the enclosure related to this issue).
I don't know about such an issue (USB to SATA adapter be it RAID or not) taking more than 4 minutes to reply to a SMART data request.
So I suggest you to login to the Helios64 (ssh) if you know how to do this and run smartctl on the UGREEN device
smartctl -i </dev/...>
where the device is /dev/sdc and /dev/sdd in the logs you posted (you could also use the more easily identifiable /dev/disk/by-id/<...device>.
I see two unexpected things in the logs:
the issue seems to be related to smartmontools https://forum.odroid.com/viewtopic.php?t=37153 "reset SuperSpeed USB device number 3 using xhci-hcd" - only if smartmontools are installed .
(note he at first misspelled smartmontools as sysmontools it seems).
Note he tells his UGREEN USB3-SATA adapter works but it could be your enclosure as a different controller than yours.
Was your usb-c cable to the enclosure provided with the enclosure?
A power issue with a weak cable could also cause such a reset (though your external power adapter to the enclose likely removes the power issue so it leaves the cable) ?
Likely an issue with your enclosure and smartmontools. Might be that there is a workaround in smartmontools that could be automatically set up by OpenMediaVault. Or also could be that smartmontools could implement a workaround for your enclosure.
The kernel can implement workarounds for nonstandard controllers, which might help avoid smartmontools confusing the enclosure controller (ie disable UAS).
You might as well contact UGREEN and/or the smartmontools mailing list.
The bridge chip for the USB SATA bridge seems to be JMicron "Gen1 SATA 6Gb/s Bridge" (USB idVendor=152d, idProduct=0576). Which seems supported for a long time https://linux-hardware.org/index.php?id=usb:152d-0576 (also in BSD https://bsd-hardware.info/?id=usb:152d-0576)
The chip is told to be JMS576 https://www.smartmontools.org/ticket/1428
This chip had a fix post smartmontools 7.2 https://www.smartmontools.org/ticket/1428 (probably 7.3) .
You can try if the workaround works by calling the device with:
smartctl -d sat -i /dev/sdc
Note the "-d sat".
About kernel workaround, you might want to try to force usb-storage driver instead of UAS driver in /boot/armbianEnv.txt
usbstoragequirks=152d:0576:u
from https://forums.raspberrypi.com/viewtopic.php?t=338883#p2029597
With this tweak in the kernel logs, you should now have "UAS is blacklisted for this device, using usb-storage instead"
About the GPT header error, I do not expect these to explain a slowdown during SMART retrieval (as this is not related to the partitions).
EDIT: your Armbian 22.02.1 is bullseye which has smartmontools 7.2. Once you have checked that the issue is no more with "smartctl -d sata -i <device>" you will know the culprit.
You can either rebuild the smartmontools package with the patch above for JMS576 or plan an upgrade to bookworm (smartmontools 7.3 has the fix per https://www.smartmontools.org/browser/tags/RELEASE_7_3/smartmontools/drivedb.h#L5936 ) . You cannot directly install the bookworm package on bullseye because it depends on bookworm libc6. But you may be able to rebuild the bookworm source package on bullseye (did not check from https://sources.debian.org/src/smartmontools/7.3-1/debian/control/  if any of the build dependencies are only available on bookworm though).
Edited by prahal
@n3o have you sorted out if the smartctl issue was due to the missing "-d sat" option?
Do you have an ssh session to your helios64?
As I told you could rebuild the bookworm smartmontools package for Bullseye if need be. It is a little bit involved though.
Edited by prahal
@prahal I have tried from ssh "smartctl -d sat -i /dev/sdc" and "smartctl -d sat -i /dev/sdd", the first has take 50 seconds, the second has take 1 minute. However with -d sat option it's more faster than the week ago but run "smartctl -d sat -i /dev/sda" it's take just 1 seconds. It's normal that time or not?
sorry for the lag.
I do not understand. You do not test the same device each time ? 50 seconds or one minute seems a lot, the last test with 1 second is fine.
You should have had the same time for each test on the same enclosure and drive with "-d sat". Otherwise, something changed that is out of smartmontools scope.
And I do not know what could affect "smartctl -i" time out of the "-d sat" (though there likely are other variables that could matter, but I don't know them).
Did you mean by "more faster than the week ago" that nowadays it is always fast (ie 1 second)?
@n3o do you have UAS is blacklisted for this device, using usb-storage instead in the dmesg logs for your usb device?
else check usbstoragequircks as I told you in previous comments (/boot/armbianEnv.txt)
Edited by prahal
