October 15, 20233 yr Hi! I've just downloaded the Armbian_23.8.3_Orangepi3-lts_bookworm_current_6.1.53_cinnamon_desktop.img onto a 16GB SD card, plugged it to the Opi and started it up. Then I connected to it using SSH, and it works just fine. But when I tried VNCViewer (actually, MobaXTerm on Windows), nothing is displayed but a message saying that Cinnamon crashed and "you are currently running in fallback mode". I've tried to install another window manager, like lightdm with xface4 with no success. I also tried to remove cinnamon and reinstall it, again to no avail. I did the same to x11 and again couldn't have any desktop manager running. Then I burned the original img file again and proceeded an update/upgrade on the OS, but nothing happened. I also spent the whole day on google and reading docs and only got more frustrated. Any ideas?
October 15, 20233 yr Author After dealing with this for about 18 hours, I decided to go for another image. I downloaded and burned Armbian_23.8.3_Orangepi3-lts_bookworm_current_6.1.53_xfce_desktop.img image to my SSD and went on following the instructions from NicoD from here: Now everything is running smoothly and I'm able to interact with the desktop from my Windows PC using MobaXterm. Thank you all!
