hi,
i'm running Armbian with kernel 3.14.73 from @balbes150 image for s905
i was trying to upgrade an usb hard drive and started transferring about 400GB of data from the old usb hdd (ext4)  to the new one (brtfs) when this happened :
i've added the initial btrfs disk mount.
[   95.972270] scsi 1:0:0:0: Direct-Access     ATA      Hitachi HUA72302 A840 PQ: 0 ANSI: 6
[   95.990817] sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[   96.007364] sd 1:0:0:0: [sdb] Write Protect is off
[   96.020930] sd 1:0:0:0: [sdb] Mode Sense: 43 00 00 00
[   96.021451] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[   96.081024]  sdb: sdb1 sdb2
[   96.087622] sd 1:0:0:0: [sdb] Attached SCSI disk
[   96.467915] BTRFS: device label USBBackup devid 1 transid 10 /dev/sdb2
[   96.509151] BTRFS: device label USBLinux devid 1 transid 44 /dev/sdb1
[   96.526054] BTRFS: device label USBBackup devid 1 transid 10 /dev/sdb2
[   96.541960] BTRFS: device label USBLinux devid 1 transid 44 /dev/sdb1
[  277.575889] BTRFS: device label USBLinux devid 1 transid 44 /dev/sdb1
[  277.593542] BTRFS info (device sdb1): btrfs: use no compression
[  277.623166] BTRFS info (device sdb1): disk space caching is enabled
[  280.020449] EXT4-fs (sda2): mounted filesystem with writeback data mode. Opts: data=writeback
[17089.147117] BTRFS: sdb1 checksum verify failed on 577847296 wanted 3949F1FD found 26D7F292 level 0
[17089.172645] BTRFS: sdb1 checksum verify failed on 577847296 wanted 3949F1FD found 26D7F292 level 0
[17089.189544] BTRFS: sdb1 checksum verify failed on 577847296 wanted 3949F1FD found 26D7F292 level 0
[17089.199629] BTRFS: sdb1 checksum verify failed on 577847296 wanted 3949F1FD found 26D7F292 level 0
[17089.208591] ------------[ cut here ]------------
[17089.214854] WARNING: CPU: 0 PID: 2160 at fs/btrfs/inode.c:878 $x+0x368/0x420 [btrfs]()
[17089.223015] Modules linked in: tun meson_ir nfsd auth_rpcgss oid_registry nfs_acl nfs lockd sunrpc i2c_gpio i2c_algo_bit bonding fuse autofs4 btrfs xor raid6_pq
[17089.243100] CPU: 0 PID: 2160 Comm: btrfs-transacti Not tainted 3.14.73-vegas95 #1
[17089.250014] Call trace:
[17089.255068] [<ffffffc001089040>] dump_backtrace+0x0/0x140
[17089.260153] [<ffffffc0010891a4>] show_stack+0x24/0x2c
[17089.265214] [<ffffffc00183fa48>] dump_stack+0x80/0xa4
[17089.270261] [<ffffffc0010ad7fc>] warn_slowpath_common+0x94/0xb8
[17089.275740] [<ffffffc0010ad968>] warn_slowpath_null+0x38/0x44
[17089.281604] [<ffffffbffc059fb0>] $x+0x368/0x420 [btrfs]
[17089.286744] [<ffffffbffc05a404>] $x+0x39c/0x968 [btrfs]
[17089.291911] [<ffffffbffc05ac68>] $x+0x298/0x370 [btrfs]
[17089.297089] [<ffffffbffc071eb4>] __extent_writepage+0x660/0x7c4 [btrfs]
[17089.303643] [<ffffffbffc0721c4>] $x+0x1ac/0x2d4 [btrfs]
[17089.308819] [<ffffffbffc07333c>] extent_writepages+0x68/0x88 [btrfs]
[17089.315112] [<ffffffbffc055d54>] $x+0x34/0x48 [btrfs]
[17089.319987] [<ffffffc001182f08>] do_writepages+0x40/0x6c
[17089.325247] [<ffffffc001177678>] __filemap_fdatawrite_range+0x6c/0x78
[17089.331628] [<ffffffc0011777a4>] filemap_fdatawrite_range+0x34/0x40
[17089.337970] [<ffffffbffc06c6f4>] btrfs_wait_ordered_range+0x80/0x16c [btrfs]
[17089.344958] [<ffffffbffc092800>] __btrfs_write_out_cache+0x52c/0x6f8 [btrfs]
[17089.351945] [<ffffffbffc093d48>] $x+0x98/0xfc [btrfs]
[17089.356941] [<ffffffbffc0434d8>] btrfs_write_dirty_block_groups+0x4e8/0x628 [btrfs]
[17089.364540] [<ffffffbffc0c5404>] commit_cowonly_roots+0x13c/0x204 [btrfs]
[17089.371261] [<ffffffbffc0530b4>] btrfs_commit_transaction+0x454/0x888 [btrfs]
[17089.378333] [<ffffffbffc04f5c0>] $x+0x150/0x1d0 [btrfs]
[17089.383380] [<ffffffc0010d1fe0>] kthread+0xdc/0xf0
[17089.388956] ---[ end trace 6da0e760a6c1ab74 ]---
my cp command got stuck and kswapd0 started to go haywire showing 1.5GB/s of I/O
i'm only guessing that a btrfs process crashed, i don't know much about btrfs so i have not configured anything special besides adding the compress=no to my fstab.
The first 200GB copy completed properly.
I did notice that the I/O rate was not completely stable, going around 35MB/s read and write from the two disks, but every 10-15 sec stopping and a btrfs commit process started doing some io for a couple of seconds then the devices read write would come back.
Reading about those "checksum verify" messages, i see quite a lot of mentions of btrfs kernel bugs, so i'm wondering about my choice of btrfs on the current vanilla kernel.
Although it is not the latest one i don't expect it has moved far beyond my version with an up to date kernel..
Edited by zador.blood.stained
Changed topic tithe to not confuse people, 4.14.x != vanilla
This kernel version is too old to consider reliable for btrfs, you can't call 3.14.x a "vanilla" kernel. It was discussed several times on this forum - 4.4.x LTS is the minimum kernel version to use for btrfs and don't worry about stability, though using the latest mainline is still recommended if possible.
yeah sorry i meant legacy not vanilla.
okay so i'll forget about btrfs, not a problem i can format that partition to ext4 and copy everything again.
