George Zhavoronkov Posted October 21, 2023 Share Posted October 21, 2023 I tried to write different images from the h6 family, for example: Arabian_23.11.0_allwinner_tanix-tx6_bullseye_5.136_server_2023.10.20.img to my SD and USB drive, however, this does not work. If you install the SD card and turn it on, then the red LED lights up on the device and that's it. The device simply ignores the USB flash drive and loads android. What could be the problem? 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted October 22, 2023 Share Posted October 22, 2023 sun50iw9 is H616 sun50iw6 is H6 Try images made for H616 rather than H6 since they are incompatible. 0 Quote Link to comment Share on other sites More sharing options...
George Zhavoronkov Posted October 22, 2023 Author Share Posted October 22, 2023 (edited) Ty. I tried again to start from all drives, but this time Armbian_23.11.0-trunk.238_Orangepizero2_lunar_current_6.1.57. The result is the same. SD card - red LED and no SSH/video. USB ignores and loads android. -- But no. There are differences. Now there is output on UART: U-Boot SPL 2023.10-armbian (Oct 14 2023 - 01:14:07 +0000) DRAM:This DRAM setup is currently not supported. resetting ... --- Any ideas how to fix it? Edited October 23, 2023 by George Zhavoronkov append 0 Quote Link to comment Share on other sites More sharing options...
