I need to reset password but can't get to grub in armbian
edit: Found the solution
Got this tv box "x88pro 10" repurposed to run armbian by someone and it demands login/password. The default one(root 1234) doesn't work. Also I can't seem to stop the loading process and get to grub to try and delete passwords manually from there(tried pressing random keys during boot, tried holding shift). Please help :) And also point me to an armbian image I could use in case I fail to reset the password
Armbian version it runs atm is 22.05.0-trunk Bullseye
tech specs are: RK3318 Quad-Core 64bit Cortex-A53, Penta-Core Mali-450 up to 750Mhz, 2 or 4Gb ram
Edited by Alex989
Found the solution
