October 27, 20233 yr Hi, i booted for the sd card, with armbian, and then i went do terminal and armbian-install, it went well, i formated the eMMC, and then after all i shoutdown, now i can't get it to turn back on, i don't have the remote, is there any pins to sort or any possibility to solder a power button ? tnks.
October 28, 20233 yr how exactly did you format the emmc? (what commands?) did you follow the install guide, and use `install-aml.sh` (which preserves the boot block on emmc, keeping the old uboot to chainload into new uboot with) ?
October 29, 20233 yr Author I booted with the externa HD with armbian, and the after booting went to terminal, a armbian-install, the first thing it asks is format the eMMC, and witch format i believe ext4, and formated and install all with out any error, after that, it ask to shutdown or reboot, i selected shutdown and can't turn back on since, no even in recovery mode to flash the original firmware again (holding the reset button and connect to usb to computer). the light on otical turns on, but that's it.
October 30, 20233 yr armbian-install does not work for amlogic tv boxes. Per the instructions in the TV box faq you need to run the install-aml.sh script. You are going to need to reinstall Android firmware for your box to recover it
