armv8 boards comparison and benchmarks
Hello all,
iv'e made some sysbench tests on Pine64, Orange Pi PC2 and Raspberry Pi 3.
all three boards are running on aarch64 based OS, for the Pine64 I used Armbian Ubuntu Xenial Server, for the Orange Pi PC2 I used the latest ubuntu image provided by Xunlong and for the Raspberry Pi 3 I used fedora 24 image provided by kraxel
the boards:
http://s.pictub.club/2016/12/23/sDJQCq.jpg
Raspberry Pi 3:
[eli@fedora-rpi2 ~]$ uname -a
Linux fedora-rpi2 4.9.0-1-main #1 SMP PREEMPT Mon Dec 12 09:14:22 UTC 2016 aarch64 aarch64 aarch64 GNU/Linux
[eli@fedora-rpi2 ~]$ for each in 1 2 4; do sysbench --test=cpu --cpu-max-prime=20000 --num-threads=$each run; done
sysbench 0.4.12:  multi-threaded system evaluation benchmark
Running the test with following options:
Number of threads: 1
Doing CPU performance benchmark
Threads started!
WARNING: Operation time (18446744073215141888.000000) is greater than maximal counted value, counting as 10000000000000.000000
WARNING: Percentile statistics will be inaccurate
Done.
Maximum prime number checked in CPU test: 20000
Test execution summary:
    total time:                          60.6489s
    total number of events:              10000
    total time taken by event execution: 60.6428
    per-request statistics:
         min:                                  6.03ms
         avg:                                  6.06ms
         max:                            18446744073215.31ms
         approx.  95 percentile:               6.05ms
Threads fairness:
    events (avg/stddev):           10000.0000/0.00
    execution time (avg/stddev):   60.6428/0.00
Number of threads: 2
Threads started!
Done.
    total time:                          29.9795s
    total time taken by event execution: 59.9449
         min:                                  5.84ms
         avg:                                  5.99ms
         max:                                  6.21ms
         approx.  95 percentile:               6.04ms
Threads fairness:
    events (avg/stddev):           5000.0000/0.00
    execution time (avg/stddev):   29.9724/0.00
Number of threads: 4
Threads started!
WARNING: Operation time (18446744073214261248.000000) is greater than maximal counted value, counting as 10000000000000.000000
Done.
    total time:                          16.1915s
    total time taken by event execution: 64.7387
         min:                                  6.02ms
         avg:                                  6.47ms
         max:                            18446744073219.71ms
         approx.  95 percentile:               6.83ms
Threads fairness:
    events (avg/stddev):           2500.0000/105.87
    execution time (avg/stddev):   16.1847/0.00
[eli@fedora-rpi2 ~]$ sysbench --test=memory --memory-block-size=1K --memory-scope=global --memory-total-size=10G --memory-oper=read run
Doing memory operations speed test
Memory block size: 1K
Memory transfer size: 10240M
Memory operations type: read
Memory scope type: global
Threads started!
Done.
Operations performed: 10485760 (531318.94 ops/sec)
10240.00 MB transferred (518.87 MB/sec)
    total time:                          19.7353s
    total number of events:              10485760
    total time taken by event execution: 13.8417
         min:                                  0.00ms
         avg:                                  0.00ms
         max:                                  0.07ms
         approx.  95 percentile:               0.00ms
Threads fairness:
    events (avg/stddev):           10485760.0000/0.00
    execution time (avg/stddev):   13.8417/0.00
[eli@fedora-rpi2 ~]$ sysbench --test=memory --memory-block-size=1K --memory-scope=global --memory-total-size=10G --memory-oper=write run
Memory operations type: write
Threads started!
Done.
Operations performed: 10485760 (364193.47 ops/sec)
10240.00 MB transferred (355.66 MB/sec)
    total time:                          28.7917s
    total time taken by event execution: 22.9432
         min:                                  0.00ms
         avg:                                  0.00ms
         max:                                  0.18ms
Threads fairness:
    execution time (avg/stddev):   22.9432/0.00
Orange Pi PC2:
eli@Orangepi:~$ uname -a
Linux Orangepi 3.10.65 #55 SMP PREEMPT Fri Nov 18 16:17:28 CST 2016 aarch64 aarch64 aarch64 GNU/Linux
eli@Orangepi:~$ for each in 1 2 4; do sysbench --test=cpu --cpu-max-prime=20000 --num-threads=$each run; done
Threads started!
Done.
    total time:                          36.7932s
    total time taken by event execution: 36.7893
         min:                                  3.62ms
         avg:                                  3.68ms
         max:                                505.97ms
         approx.  95 percentile:               3.64ms
Threads fairness:
    execution time (avg/stddev):   36.7893/0.00
Threads started!
Done.
    total time:                          17.9530s
    total time taken by event execution: 35.8999
         min:                                  3.51ms
         avg:                                  3.59ms
         max:                                  4.20ms
Threads fairness:
    execution time (avg/stddev):   17.9500/0.00
Threads started!
Done.
    total time:                          9.0700s
    total time taken by event execution: 36.2609
         min:                                  3.60ms
         avg:                                  3.63ms
         max:                                 13.77ms
Threads fairness:
    events (avg/stddev):           2500.0000/3.54
    execution time (avg/stddev):   9.0652/0.00
eli@Orangepi:~$ sysbench --test=memory --memory-block-size=1K --memory-scope=global --memory-total-size=10G --memory-oper=read run
Threads started!
Done.
Operations performed: 10485760 (922210.22 ops/sec)
10240.00 MB transferred (900.60 MB/sec)
    total time:                          11.3702s
    total time taken by event execution: 8.0777
         min:                                  0.00ms
         avg:                                  0.00ms
         max:                                  0.39ms
Threads fairness:
    execution time (avg/stddev):   8.0777/0.00
eli@Orangepi:~$ sysbench --test=memory --memory-block-size=1K --memory-scope=global --memory-total-size=10G --memory-oper=write run
Threads started!
Done.
Operations performed: 10485760 (617633.57 ops/sec)
10240.00 MB transferred (603.16 MB/sec)
    total time:                          16.9773s
    total time taken by event execution: 13.6888
         min:                                  0.00ms
         avg:                                  0.00ms
         max:                                  0.32ms
Threads fairness:
    execution time (avg/stddev):   13.6888/0.00
Pine64:
eli@pine64:~$ uname -a
Linux pine64 3.10.102-pine64 #6 SMP PREEMPT Thu Sep 15 09:11:23 CEST 2016 aarch64 aarch64 aarch64 GNU/Linux
eli@pine64:~$ for each in 1 2 4; do sysbench --test=cpu --cpu-max-prime=20000 --num-threads=$each run; done
Threads started!
Done.
    total time:                          31.7566s
    total time taken by event execution: 31.7533
         min:                                  3.17ms
         avg:                                  3.18ms
         max:                                  3.54ms
         approx.  95 percentile:               3.18ms
Threads fairness:
    execution time (avg/stddev):   31.7533/0.00
Threads started!
Done.
    total time:                          15.8911s
    total time taken by event execution: 31.7757
         min:                                  3.17ms
         avg:                                  3.18ms
         max:                                  3.74ms
         approx.  95 percentile:               3.19ms
Threads fairness:
    events (avg/stddev):           5000.0000/4.00
    execution time (avg/stddev):   15.8878/0.00
Threads started!
Done.
    total time:                          7.9636s
    total time taken by event execution: 31.8266
         min:                                  3.17ms
         avg:                                  3.18ms
         max:                                 13.22ms
Threads fairness:
    events (avg/stddev):           2500.0000/4.95
    execution time (avg/stddev):   7.9567/0.00
eli@pine64:~$ sysbench --test=memory --memory-block-size=1K --memory-scope=global --memory-total-size=10G --memory-oper=read run
Threads started!
Done.
Operations performed: 10485760 (1052151.29 ops/sec)
10240.00 MB transferred (1027.49 MB/sec)
    total time:                          9.9660s
    total time taken by event execution: 7.0809
         min:                                  0.00ms
         avg:                                  0.00ms
         max:                                  0.37ms
Threads fairness:
    execution time (avg/stddev):   7.0809/0.00
eli@pine64:~$ sysbench --test=memory --memory-block-size=1K --memory-scope=global --memory-total-size=10G --memory-oper=write run
Threads started!
Done.
Operations performed: 10485760 (704345.05 ops/sec)
10240.00 MB transferred (687.84 MB/sec)
    total time:                          14.8872s
    total time taken by event execution: 12.0413
         min:                                  0.00ms
         avg:                                  0.00ms
         max:                                  0.15ms
Threads fairness:
    execution time (avg/stddev):   12.0413/0.00
Unfortunately these are numbers without meaning. Sysbench can be used to heat chips but not to measure performance of different hardware, especially not in your mode. Details: https://forum.armbian.com/index.php/topic/1748-sbc-consumptionperformance-comparisons/
It should also be noted that potential throttling has to be monitored, that OPi PC 2 with the crappy BSP based OS image you used is limited to 1008 MHz and that RPi is cheating on you since cpufreq sysfs nodes lie (they report 1200 MHz even when the CPU cores run only with 800 MHz)
CPU wise A64 and H5 should perform identical and RPi when using ARMv8 code should be slightly faster. Apart from that it's all about settings and use cases so these passive benchmarking approaches producing some numbers are always useless anyway :)
