Recently I've installed armbian on my 905 TV box using this article as a guide: https://i12bretro.github.io/tutorials/0269.html
After some experiments with dtb files and tuning everything seems to work fine except of one thing: the box can't be turned off, it boots immediately  after shutting  down.
I've found a similar problem described in several articles, for example: https://gist.github.com/george-hawkins/a897a6fe116093a4c1f29ad19df088de
It is suggested to enable XHCI HCD quirks in grub. But there is not such file in the system I've installed, the closest thing I found was config-5.9.0-arm-64 file. What is the right way to modify it to add XHCI HCD quirks? Or maybe the suggested method doesn't  suite for my system?
Sorry if my question is dumb, I'm a total noob with Linux.
Edited by tolik4
Instead of using random old builds and directions you have found, please try with::
https://forum.armbian.com/topic/16976-status-of-armbian-on-tv-boxes-please-read-first
https://forum.armbian.com/topic/17106-installation-instructions-for-tv-boxes-with-amlogic-cpus
Per the above information, don't expect most things to work.  Also grub is a boot system primarily used on x86 boxes.  Arm based boxes use uboot.
