hryst Posted January 2, 2017 Posted January 2, 2017 Hello!please let me know how to run properly bme280 i2c sensor I installhttps://github.com/adafruit/Adafruit_Python_BME280but orange pi pi + and banana pi displays bugs: python bme280.py Traceback (most recent call last): File "bme280.py", line 5, in <module> sensor = BME280(mode=BME280_OSAMPLE_8) File "/var/www/nettemp/modules/sensors/i2c/BME280/Adafruit_BME280.py", line 90, in __init__ self._load_calibration() File "/var/www/nettemp/modules/sensors/i2c/BME280/Adafruit_BME280.py", line 96, in _load_calibration self.dig_T1 = self._device.readU16LE(BME280_REGISTER_DIG_T1) File "build/bdist.linux-armv7l/egg/Adafruit_GPIO/I2C.py", line 185, in readU16LE File "build/bdist.linux-armv7l/egg/Adafruit_GPIO/I2C.py", line 164, in readU16 File "build/bdist.linux-armv7l/egg/Adafruit_PureIO/smbus.py", line 173, in read_word_data IOError: [Errno 70] Communication error on send Regards
Cedricici Posted December 19, 2017 Posted December 19, 2017 almost one year later, part of answer for those who find the topic. On the orange pi zero, I have to put the CSB pin to Vdd (3.3v) to get the sensors works, but it's not enough for me because the values are not corrects.
Larry Bank Posted December 20, 2017 Posted December 20, 2017 My bme280 is on a little breakout board (see lower right corner of photo). The fusable links are pre-set and I only connect the 4 wires (GND, VCC, SCL, SDA). Show us what you're using.
vlad59 Posted December 20, 2017 Posted December 20, 2017 there are many breadboard compatible boards made with BME280 : Most of mine are more complex than yours : https://fr.aliexpress.com/item/GY-BME280-BME280-I2C-SPI-Num-rique-Capteur-Module-Breakout-Temp-rature-Humidit-Pression-Barom-trique/32840435761.html?spm=a2g0w.search0104.3.112.5bANYG&ws_ab_test=searchweb0_0%2Csearchweb201602_5_10152_10065_10151_10344_10068_10345_10342_10343_51102_10340_10341_10609_10541_5130013_5000013_10084_10083_10305_10304_10307_10306_5080013_10302_10610_5870020_10312_10059_10313_10314_10184_10534_100031_10604_10603_10103_10605_5060013_10594_10142_10107%2Csearchweb201603_25%2CppcSwitch_2&algo_expid=4383f9c8-b5ae-48a5-8fd1-e32deb3d9fb9-16&algo_pvid=4383f9c8-b5ae-48a5-8fd1-e32deb3d9fb9&rmStoreLevelAB=5 either way, the first after connecting is checking if the BME280 is detected on the bus : root@minus:~# i2cdetect -y 1 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- 23 -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- 76 -- See the 76 here, that means BME280 is detected. Here I checked i2c-1 (you may have to change that depending of how many i2c bus your board have. I don't like most Adafruit libraries (find them hard to read), for BME280 I use this library : https://bitbucket.org/MattHawkinsUK/rpispy-misc/raw/master/python/bme280.py
Cedricici Posted December 20, 2017 Posted December 20, 2017 Thanks. I usualy wired my bme280 like you (vdd/GND/SDA/SCK) my version is the same as vlad59 with SPI, so SDO is to put to to GND or Vdd to choose the @, and I read in the datasheet p31 : Quote CSB must be connected to V DDIO to select I2C interface. Expand I do this and after that i can detect the device on the bus, not before.
