@Ya_super_grafiti dts/dtb files are specific to the linux kernel.  Armbian focuses on mainline linux kernels and others out there use vendor kernels (which usually are a ported android based kernels from ancient sources).  The differences between vendor kernels and mainline linux are usually significant preventing direct reuse of a dts/dtb from one to the other.  If you know how dtb's work and have the hardware specs, you could port the dts into mainline, but that is expert level work.
