Timo12357 Posted December 6, 2023 Share Posted December 6, 2023 Bookworm 6.1 kernel Cinnamon terminal is unusable. The terminal screen flickers and the written text blinks with the cursor blink. Occasionally the terminal goes black. I am using an ancient 1024x768 screen. Is this the root cause, or is the terminal broken in Cinnamon? 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted December 6, 2023 Share Posted December 6, 2023 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote Link to comment Share on other sites More sharing options...
Gunjan Gupta Posted December 6, 2023 Share Posted December 6, 2023 @Timo12357Thanks for reporting the issue. I was able to reproduce it. I have been handling maintenance of Orange Pi 3 LTS for past couple of months and was mostly using xfce. Hence I was not aware of this issue. I will try to solve it, but that would take some time. Meanwhile, I suggest you to give xfce image a try the login screen on xfce is similarly broken because of an upstream bug in lightdm, but you can install sddm on xfce image instead and that should get you better user experience. 0 Quote Link to comment Share on other sites More sharing options...
