Hello everyone, after a lot of fruitless research, I am turning to you for a helping hand.
I have a T95 4Gb/32Gb box, on the motherboard it says H616-T95MAX-V4.0-20191217.
And the CPU model is sun50iw9.
Is it possible to remove ANDROID and install ARMBIAN?
Thank you in advance for your answers
@Silv3r_18 Welcome.  Anything is possible, but it won't be easy.  Search for other threads in the forum about TV Boxes and H616 support.  Also read this FAQ item to understand that allwinner on TV Boxes is the least supported as there is no one that is actively focused on that cpu family on TV Boxes.
Here is the resulting log:
U-Boot SPL 2025.01-armbian-2025.01-S6d41-P7f87-H8869-V2e4e-Bb703-R448a-dirty (Ma        r 07 2025 - 05:18:17 +0000)
DRAM:testing 32-bit width, rank = 2
read calibration failed!
testing 32-bit width, rank = 1
DRAM:Store cfg
DRAM:1st writing pattern
DRAM:detecting column address bits
detected 11 columns
DRAM:restore cfg
DRAM:reconfigure for all active rows
DRAM:store cfg
DRAM:2nd writing pattern
DRAM:detecting row address bits
detected 16 rows
DRAM:restoring cfg
DRAM:end of auto detect dram size
MBUS port 0 cfg0 0100000d cfg1 00640080
MBUS port 1 cfg0 06000009 cfg1 01000578
MBUS port 2 cfg0 0200000d cfg1 00600100
MBUS port 3 cfg0 01000009 cfg1 00500064
MBUS port 4 cfg0 20000209 cfg1 1388157c
MBUS port 5 cfg0 00640209 cfg1 00200040
MBUS port 6 cfg0 00640209 cfg1 00200040
MBUS port 8 cfg0 01000009 cfg1 00400080
MBUS port 11 cfg0 01000009 cfg1 00640080
MBUS port 14 cfg0 04000009 cfg1 00400100
MBUS port 16 cfg0 2000060d cfg1 09600af0
MBUS port 21 cfg0 0800060d cfg1 02000300
MBUS port 22 cfg0 01000009 cfg1 00640080
MBUS port 25 cfg0 0064000f cfg1 00200040
MBUS port 26 cfg0 20000209 cfg1 1388157c
MBUS port 37 cfg0 01000009 cfg1 00400080
MBUS port 38 cfg0 00640209 cfg1 00200040
MBUS port 39 cfg0 20000209 cfg1 1388157c
MBUS port 40 cfg0 00640209 cfg1 00200040
 4096 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.10.14(debug):armbian
NOTICE:  BL31: Built : 05:17:11, Mar  7 2025
NOTICE:  BL31: Detected Allwinner H616 SoC (1823)
NOTICE:  BL31: Found U-Boot DTB at 0x4a0b1888, model: Shenzhen Amediatech Techno        logy Co., Ltd X96Q TV Box
INFO:    ARM GICv2 driver initialized
INFO:    Configuring SPC Controller
INFO:    PMIC: Probing AXP305 on RSB
WARNING: PMIC: No regulators DT node, skipping setup
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for erratum 855873 was applied
INFO:    BL31: cortex_a53: CPU workaround for erratum 1530924 was applied
INFO:    PSCI: Suspend is unavailable
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
INFO:    Changed devicetree.
ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_p        handle_id: err=-19
U-Boot 2025.01-armbian-2025.01-S6d41-P7f87-H8869-V2e4e-Bb703-R448a-dirty (Mar 07        2025 - 05:18:17 +0000) Allwinner Technology
CPU:   Allwinner H616 (SUN50I)
Model: Shenzhen Amediatech Technology Co., Ltd X96Q TV Box
DRAM:  4 GiB
Core:  56 devices, 18 uclasses, devicetree: separate
WDT:   Not starting watchdog@30090a0
MMC:   mmc@4020000: 0, mmc@4021000: 3, mmc@4022000: 1
Loading Environment from FAT... Unable to use mmc 0:1...
In:    serial@5000000
Out:   serial@5000000
Err:   serial@5000000
No USB device found
Net:   Could not get PHY for ethernet@5030000: addr 16
No ethernet found.
starting USB...
No USB controllers found
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
4641 bytes read in 8 ms (566.4 KiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
196 bytes read in 7 ms (27.3 KiB/s)
Load fdt: /boot/dtb/allwinner/sun50i-h313-x96-q.dtb
29607 bytes read in 16 ms (1.8 MiB/s)
Working FDT set to 4fa00000
Failed to load '/boot/dtb/allwinner/overlay/sun50i-h616-fixup.scr'
15459855 bytes read in 652 ms (22.6 MiB/s)
42621440 bytes read in 1784 ms (22.8 MiB/s)
Moving Image from 0x40080000 to 0x40200000, end=0x42b50000
## Loading init Ramdisk from Legacy Image at 4ff00000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    15459791 Bytes = 14.7 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Ramdisk to 49141000, end 49fff5cf ... OK
   Loading Device Tree to 00000000490d1000, end 0000000049140fff ... OK
Working FDT set to 490d1000
Starting kernel ...
