knish Posted November 26, 2023 Posted November 26, 2023 Hello, i'm trying to burn with balena etcher but my sd card is unreadable with my macbook at the end of burn. I tested all versions from /armbian/dl/aml-s9xx-box/archive. Is there any instructions to burn? thanks 0 Quote
adrian0541 Posted November 26, 2023 Posted November 26, 2023 (edited) @knish Is it possible that the SD card is only unreadable to the Mac system? On the other hand, I've had problems using the last version of the system (23.8.1), but could make an older version like the 23.02.2 to work. Maybe you could try that. Link Edited November 26, 2023 by adrian0541 1 Quote
knish Posted November 27, 2023 Author Posted November 27, 2023 On 11/26/2023 at 6:35 PM, adrian0541 said: On the other hand, I've had problems using the last version of the system (23.8.1), but could make an older version like the 23.02.2 to work. Maybe you could try that. it worked, thank you very much 0 Quote
