Matheus Gomes Posted December 12, 2023 Posted December 12, 2023 (edited) I have an IK316-EMCP_v4.1 board, and I need to install Armbian on it. But there is no information on the internet about this card. If you have any information on how I can install Armbian, or any other Linux distro on this board, please let me know. Edited December 12, 2023 by Matheus Gomes 1 Quote
Werner Posted December 12, 2023 Posted December 12, 2023 Looks like picked from a random tvbox. Moved. 0 Quote
Faheem Posted March 14, 2025 Posted March 14, 2025 still nobody find the solution of this board jumper pins its too much challenge for all engineers 0 Quote
Nick A Posted March 15, 2025 Posted March 15, 2025 (edited) @Faheem try these images. I can’t see the AXP chip so I can’t tell you which one to try first. https://github.com/NickAlilovic/build/releases/tag/20250306 Edited March 15, 2025 by Nick A 0 Quote
Benedito Portela Posted June 7, 2025 Posted June 7, 2025 Hi @Faheem, are you do it armbian install and working in this board? I use rk3228 boxes and want know more about this H313 boards, i see a mx10 with this chip in aliexpress, but before to buy, i should want sure it working linux! The H313, is it too problematic so or not? Thanks! 0 Quote
marcosdsdba Posted Friday at 10:43 PM Posted Friday at 10:43 PM @Nick A Hi Nick, how are you? I have a motherboard identical to the one in the photo you posted, with an AXP313A. I tried the image you recommended, but the Wi-Fi didn't work. Could you give me any advice? 0 Quote
sicxnull Posted Saturday at 04:02 PM Posted Saturday at 04:02 PM If you can pull the factory DTB from that board that would be great. I need it to get Wifi working 0 Quote
Nick A Posted Saturday at 04:24 PM Posted Saturday at 04:24 PM @marcosdsdba Can you take a picture or just tell us the Wi-Fi chip you have on your board? 0 Quote
marcosdsdba Posted 4 hours ago Posted 4 hours ago (edited) @Nick A Wi-fi chip is SV6256P Edited 4 hours ago by marcosdsdba 0 Quote
Nick A Posted 1 hour ago Posted 1 hour ago @marcosdsdba the only driver that works is from kernel 4.4. Unless someone figures out a way to port this to a modern kernel, your only option is to use a usb wifi adapter. 0 Quote
