Matheus Gomes Posted December 12, 2023 Posted December 12, 2023 (edited) I have an IK316-EMCP_v4.1 board, and I need to install Armbian on it. But there is no information on the internet about this card. If you have any information on how I can install Armbian, or any other Linux distro on this board, please let me know. Edited December 12, 2023 by Matheus Gomes 1 Quote
Werner Posted December 12, 2023 Posted December 12, 2023 Looks like picked from a random tvbox. Moved. 0 Quote
Faheem Posted March 14, 2025 Posted March 14, 2025 still nobody find the solution of this board jumper pins its too much challenge for all engineers 0 Quote
Nick A Posted March 15, 2025 Posted March 15, 2025 (edited) @Faheem try these images. I can’t see the AXP chip so I can’t tell you which one to try first. https://github.com/NickAlilovic/build/releases/tag/20250306 Edited March 15, 2025 by Nick A 0 Quote
Benedito Portela Posted June 7, 2025 Posted June 7, 2025 Hi @Faheem, are you do it armbian install and working in this board? I use rk3228 boxes and want know more about this H313 boards, i see a mx10 with this chip in aliexpress, but before to buy, i should want sure it working linux! The H313, is it too problematic so or not? Thanks! 0 Quote
marcosdsdba Posted February 6 Posted February 6 @Nick A Hi Nick, how are you? I have a motherboard identical to the one in the photo you posted, with an AXP313A. I tried the image you recommended, but the Wi-Fi didn't work. Could you give me any advice? 0 Quote
sicxnull Posted Saturday at 04:02 PM Posted Saturday at 04:02 PM If you can pull the factory DTB from that board that would be great. I need it to get Wifi working 1 Quote
Nick A Posted Saturday at 04:24 PM Posted Saturday at 04:24 PM @marcosdsdba Can you take a picture or just tell us the Wi-Fi chip you have on your board? 0 Quote
marcosdsdba Posted Monday at 12:00 PM Posted Monday at 12:00 PM (edited) @Nick A Wi-fi chip is SV6256P Edited Monday at 12:00 PM by marcosdsdba 0 Quote
Nick A Posted Monday at 02:21 PM Posted Monday at 02:21 PM @marcosdsdba the only driver that works is from kernel 4.4. Unless someone figures out a way to port this to a modern kernel, your only option is to use a usb wifi adapter. 1 Quote
marcosdsdba Posted 12 hours ago Posted 12 hours ago @Nick A Thank you very much, I'll try using it and get back to you if everything is okay. 0 Quote
marcosdsdba Posted 11 hours ago Posted 11 hours ago @sicxnull Yes, I can try to extract the DBT. How can I do that? 0 Quote
sicxnull Posted 2 hours ago Posted 2 hours ago 9 hours ago, marcosdsdba said: @sicxnull Yes, I can try to extract the DBT. How can I do that? boot up armbian. check the /dev partition You will see mmcblk0 mmcblk2,etc The android image likely has many partitions. so you will see mmcblk2-9 etc, thats what we want Go ahead and dump the first 250mb (probably more than needed but just in case) into an image file and upload it, i can extract the dtb from that assuming mmcblk2 is what we want, you would run sudo dd if=/dev/mmcblk2 of=mmcblk2-first250mb.img bs=1M count=250 status=progress then upload that. 1 Quote
marcosdsdba Posted 1 hour ago Posted 1 hour ago @sicxnull I'm uploading it now and it will soon be available on my Google Drive at this link: https://drive.google.com/drive/folders/14Imqiz3u0qjLbLyDGkB0ratNn7k7-p6Z?usp=sharing 0 Quote
sicxnull Posted 1 hour ago Posted 1 hour ago 7 minutes ago, marcosdsdba said: @sicxnull I'm uploading it now and it will soon be available on my Google Drive at this link: https://drive.google.com/drive/folders/14Imqiz3u0qjLbLyDGkB0ratNn7k7-p6Z?usp=sharing DTB extracted. Thanks! I should have some time this weekend to dig into getting wifi to work. @Nick A mentioned it might only work on kernel 4 so im unsure now but will see what i can do 1 Quote
marcosdsdba Posted 1 hour ago Posted 1 hour ago @Nick A Is it possible to create an image using the driver that Kevin posted? Because I tried to compile it and couldn't, several errors with .h file paths and C language function errors. Even importing the include linux/timer.h, etc., several errors occurred and I couldn't compile it on the SD card running Armbian. I don't know if I did something wrong or if I need to do it differently. 0 Quote
Nick A Posted 53 minutes ago Posted 53 minutes ago (edited) @marcosdsdba I would compile this on the box. Install kernel headers. Post the errors you are getting. https://github.com/NickAlilovic/build/releases/download/20250306/linux-headers-edge-sunxi64_25.05.0-trunk_arm64__6.12.11-S62b2-Da873-P8a5c-C1abcH02eb-HK01ba-Vc222-B9bbb-R448a.deb Edited 50 minutes ago by Nick A 1 Quote
