moonlightzzz Posted December 13, 2023 Posted December 13, 2023 Since some upgrades ago, the wlan0 stopped showing. Maybe it got jealous of the usb wifi dongle. They used to play along as wlan0 and wlan1 but that is no more. https://paste.armbian.com/zokubeduxe 0 Quote
SteeMan Posted December 13, 2023 Posted December 13, 2023 4 minutes ago, moonlightzzz said: Since some upgrades ago Can you be more specific? Having the system information for the working system would be necessary to understand your situation and the differences between working and not working. 0 Quote
Gunjan Gupta Posted December 13, 2023 Posted December 13, 2023 You are on 23.8.1 with kernel 6.1.59. Thats pretty old. Why not try updating to latest packages. Might fix your issue 0 Quote
moonlightzzz Posted December 13, 2023 Author Posted December 13, 2023 └─$ uname -a Linux GT1-Ultimate 6.1.63-current-meson64 #1 SMP PREEMPT Mon Nov 20 10:52:19 UTC 2023 aarch64 GNU/Linux GT1 Ultimate S912 Amlogic 3GB of RAM System booting from the microSD card instead of eMMC. 0 Quote
moonlightzzz Posted December 13, 2023 Author Posted December 13, 2023 ┌──(beelink㉿GT1-Ultimate)-[~] └─$ sudo iwconfig lo no wireless extensions. eth0 no wireless extensions. ┌──(beelink㉿GT1-Ultimate)-[~] └─$ sudo ifconfig wlan0 wlan0: error fetching interface information: Device not found I ran sudo apt-get update and sudo apt-get full-upgrade just before creating this topic. 0 Quote
SteeMan Posted December 13, 2023 Posted December 13, 2023 Just now, moonlightzzz said: I ran sudo apt-get update and sudo apt-get full-upgrade just before creating this topic. But we need to know what you upgraded from. 0 Quote
moonlightzzz Posted December 13, 2023 Author Posted December 13, 2023 (edited) I upgraded from the image of August or July this year. Since then, I kept running apt-get update/full-upgrade/dist-upgrade once in a while. Edited December 13, 2023 by moonlightzzz 0 Quote
moonlightzzz Posted December 13, 2023 Author Posted December 13, 2023 (edited) Welcome to Armbian 23.11.1 Bookworm with Linux 6.1.63-current-meson64 Pretty new to me. Unless the armbian-config/diagnostics is getting an old log. Just generated it now: https://paste.armbian.com/ogicejapaw Edited December 13, 2023 by moonlightzzz add link 0 Quote
SteeMan Posted December 14, 2023 Posted December 14, 2023 Did you do anything special for your original install? What dtb file did you use? I would suggest rolling back to an older Linux kernel to see if the issue is there (use armbian-config) 0 Quote
moonlightzzz Posted June 26 Author Posted June 26 No, I didn't change a thing. Things just break after upgrading. Today I did sudo apt-get update and apt-get full-upgrade after many months of not using the box, and broke agian. The kernel is now 6.12.32 and I can see that /boot/dtb/amlogic got updated to a June 4 date. sudo rfkill list shows nothing. 0 Quote
SteeMan Posted June 26 Posted June 26 On 12/13/2023 at 7:44 PM, SteeMan said: What dtb file did you use? Since this issue is well over a year old, I'm not sure where you stand with this. Are you still looking to get a fix? If so, answering all of the questions asked would be helpful. When you say "broke again" what do you mean by broke? Apparently the box is running and you can update it as you continue to update it per the message above saying you have upgraded to 6.12.32. Have you tried a fresh image installed on a new SD card to see if that works (vs. your upgraded system)? 0 Quote
