You need to create ctl.!default block in asoundrc too, since the log tells that it fails to open the mixer controls.
Also I may be wrong about referencing the card in forked-daapd, you should check its manuals too.
I read below link under software mixing
https://www.alsa-project.org/main/index.php/Asoundrc#dmix
I follow .asoundrc overthere and aplay running with default device
unfortunately forked-daapd has very limited reference for the card
Please try
card = "default"
in forked-daapd
/var/log/forked-daapd.log
[2017-01-16 12:28:51] [  LOG]   laudio: Failed to open configured mixer element 'I2s Or Pcm Audio Mode Select format'
[2017-01-16 12:28:51] [  LOG]   laudio: Could not open mixer
[2017-01-16 12:28:51] [  LOG]   player: Could not start ALSA device 'BPi-M2P'
[2017-01-16 12:28:51] [  LOG]   player: Could not activate ALSA device 'BPi-M2P'
FYI, sound output is OK by testing "aplay -f cd -D default test.wav"
I have no idea too. Please try to experiment, maybe comment out this line, use something like "default" or "dmix".
try mixer = "dmix" or mixer = "default", not working
forked-daapd has very poor documentation regarding sound output setting
now to find correct setting, it's like trying to find needle in the desert :(
I think the developer (E.Jurgensen) might be willing to help. So I would suggest to ask him directly in this thread:
https://www.raspberrypi.org/forums/viewtopic.php?t=49928
I know this is a Raspberry-Pi Forum, but regarding sound-card configuration there should be no difference. Maybe he has an idea, or another user has a similar setup to yours. If you can solve your problem it would be nice to post the solution here as well.
Best wishes, Bernie_O
Thanks
Will post the solution here
  • Igor unpinned this topic
Hey dony71, did you get this working?
Because forked-daapd was blocking the audio-device I also had to configure alsa with dmix. Here is a nice tutorial:
That works quite well for me.
