Robson Felix Posted October 11, 2015 Posted October 11, 2015 Hi, Igor, it is a wonderful thing you got going on here I would to add applications to the image by either installing them as anyone would (apt-get install ...) or by compiling source code for the desired applications. What would be the approach to do so? I tried reading the messages on the forum and the documentation but could not find a way to do so. Example: Mono (can either be added with apt-get or compiled. Cheers, Robson
Igor Posted October 12, 2015 Posted October 12, 2015 Thanks! This variable should do the work: AFTERINSTALL is a variable with command executed in a process of building just before closing image to insert some of your custom applications or fixes.
