Posted (edited)
I had a working setup with a small driver issue so I flashed coreelc on an sd card and after booting into it once, I can't seem to be able to boot into armbian anymore.
booting into coreelec still works but the armbian sd stopped working.
I tried editing the extlinux and evreything
I soldered serial pins to see what's going on
bl31 reboot reason: 0xd
bl31 reboot reason: 0x3
system cmd  1.
SM1:BL:511f6b:81ca2f;FEAT:A0F83180:20282000;POC:F;RCY:0;EMMC:0;READ:0;0.0;CHK:0;
bl2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0001 - pwm id 0x00
bl2_stage_init 0xc0
bl2_stage_init 0x02
L0:00000000
L1:00000703
L2:00008067
L3:15000020
S1:00000000
B2:20282000
B1:a0f83180
TE: 97016
BL2 Built : 14:02:05, Nov 23 2020. g12a g966c864 - gongwei.chen@droid11-sz
Board ID = 1
Set cpu clk to 24M
Set clk81 to 24M
Use GP1_pll as DSU clk.
DSU clk: 1200 Mhz
CPU clk: 1200 MHz
Set clk81 to 166.6M
eMMC boot @ 0
sw8 s
board id: 1
Load FIP HDR DDR from eMMC, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0
fw parse done
PIEI prepare done
00000000
emmc switch 1 ok
ddr saved addr:00016000
Load ddr parameter from eMMC, src: 0x02c00000, des: 0xfffd0000, size: 0x00001000, part: 0
00000000
emmc switch 0 ok
fastboot data verify
result: 255
Cfg max: 12, cur: 1. Board id: 255. Force loop cfg
DDR3 probe
LPDDR4_PHY_V_0_1_22-Built : 14:02:12, Nov 23 2020. g12a g966c864 - gongwei.chen@droid11-sz
ddr clk to 672MHz
dmc_version 0001
Check phy result
INFO : End of initialization
INFO : End of read enable training
INFO : End of fine write leveling
INFO : End of read dq deskew training
INFO : End of MPR read delay center optimization
INFO : End of Write leveling coarse delay
INFO : End of write delay center optimization
INFO : End of read delay center optimization
INFO : End of max read latency training
INFO : Training has run successfully!
 dwc_ddrphy_apb_wr((0<<20)|(2<<16)|(0<<12)|(0xb0):00e4
1D training succeed
auto size-- 65535DDR cs0 size: 4096MB
DDR cs1 size: 0MB
DMC_DDR_CTRL: 0000002dDDR size: 3928MB
cs0 DataBus test pass
cs0 AddrBus test pass
non-sec scramble use zero key
ddr scramble enabled
100bdlr_step_size ps== 450
result report
boot times 1Enable ddr reg access
00000000
emmc switch 3 ok
BL2: rpmb counter: 0x000002f9
00000000
emmc switch 0 ok
Load FIP HDR from eMMC, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0
Load BL3X from eMMC, src: 0x00078200, des: 0x01768000, size: 0x000ee000, part: 0
0.0;M3 CHK:0;cm4_sp_mode 0
[Image: g12a_v1.1.3396-c893a7153 2020-11-11 13:54:29 gongwei.chen@droid11-sz]
OPS=0x01
ring efuse init
2b 0b 01 00 01 2d 20 00 00 0b 33 38 50 42 30 50
[0.596487 Inits done]
secure task start!
high task start!
low task start!
boot bl31
NOTICE:  BL31: v1.3(release):ec7984eef
NOTICE:  BL31: Built : 15:24:59, Nov 30 2020
NOTICE:  BL31: G12A normal boot!
NOTICE:  BL31: BL33 decompress pass
ERROR:   Error initializing runtime service opteed_fast
U-Boot 2015.01 (Jun 27 2023 - 15:25:32)
DRAM:  3.8 GiB
Relocation Offset is: d6d85000
mmu cfg end: 0xe0000000
spi_post_bind(spifc): req_seq = 0
register usb cfg[0][1] = 00000000d7e99628
NAND:  get_sys_clk_rate_mtd() 292, clock setting 200!
bus cycle0: 6,timing: 7
NAND device id: 0 ff ff ff ff ff
No NAND device found!!!
nand init failed: -6
MMC:   aml_priv->desc_buf = 0x00000000d3d75a70
aml_priv->desc_buf = 0x00000000d3d77db0
SDIO Port B: 0, SDIO Port C: 1
co-phase 0x3, tx-dly 0, clock 400000
emmc/sd response timeout, cmd8, cmd->cmdarg=0x1aa, status=0x1ff2800
emmc/sd response timeout, cmd55, cmd->cmdarg=0x0, status=0x1ff2800
co-phase 0x3, tx-dly 0, clock 40000000
[set_emmc_calc_fixed_adj][875]find fixed adj_delay=20
init_part() 297: PART_TYPE_AML
[mmc_init] mmc init success
      Amlogic multi-dtb tool
      Single dtb detected
start dts,buffer=00000000d3d7a620,dt_addr=00000000d3d7a620
get_partition_from_dts() 92: ret 0
      Single dtb detected
parts: 17
00:      logo    0000000000800000 1
01:  recovery    0000000001800000 1
02:      misc    0000000000800000 1
03:      dtbo    0000000000800000 1
04:  cri_data    0000000000800000 2
05:     param    0000000001000000 2
06:      boot    0000000001000000 1
set has_boot_slot = 0
07:       rsv    0000000001000000 1
08:  metadata    0000000001000000 1
09:    vbmeta    0000000000200000 1
10:       tee    0000000002000000 1
11:    vendor    000000001c000000 1
12:       odm    0000000008000000 1
13:    system    0000000074000000 1
14:   product    0000000008000000 1
15:     cache    0000000046000000 2
16:      data    ffffffffffffffff 4
eMMC/TSD partition table have been checked OK!
crc32_s:0x1577dad == storage crc_pattern:0x1577dad!!!
crc32_s:0xee152b83 == storage crc_pattern:0xee152b83!!!
crc32_s:0x79f50f07 == storage crc_pattern:0x79f50f07!!!
mmc env offset: 0x4d400000
In:    serial
Out:   serial
Err:   serial
reboot_mode=update
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
_verify_dtb_checksum()-3476: calc 6bfb8fc3, store 6bfb8fc3
dtb_read()-3691: total valid 2
update_old_dtb()-3672: do nothing
      Single dtb detected
amlkey_init() enter!
[EFUSE_MSG]keynum is 4
vpu: driver version: v20190313
vpu: detect chip type: 11
vpu: clk_level default: 7(666667000Hz), max: 7(666667000Hz)
vpu: clk_level in dts: 7
vpu: vpu_power_on
vpu: set_vpu_clk
vpu: set clk: 666667000Hz, readback: 666666667Hz(0x100)
vpu: set_vpu_clk finish
vpu: vpu_module_init_config
vpp: vpp_init
vpp: vpp osd2 matrix rgb2yuv..............
hdr_func 4, hdr_process_select 0x1
cvbs: cpuid:0x2b
cvbs: find clk_path: 0x0
cvbs: find performance_pal config
Net:   dwmac.ff3f0000amlkey_init() enter!
amlkey_init() 71: already init!
CONFIG_AVB2: null
Start read misc partition datas!
info->magic =
info->version_major = 1
info->version_minor = 0
info->slots[0].priority = 15
info->slots[0].tries_remaining = 7
info->slots[0].successful_boot = 0
info->slots[1].priority = 14
info->slots[1].tries_remaining = 7
info->slots[1].successful_boot = 0
info->crc32 = -1075449479
active slot = 0
wipe_data=successful
wipe_cache=successful
upgrade_step=2
reboot_mode:::: update
s_version: U-Boot 2015.01
[KM]Error:f[key_manage_query_size]L515:key[usid] not programed yet
[KM]Error:f[key_manage_query_size]L515:key[deviceid] not programed yet
[KM]Error:f[keymanage_dts_get_key_device]L105:oemkey key name is not exist
[KM]Error:f[_get_km_ops_by_name]L240:key oemkey not know device 4
[KM]Error:f[key_manage_query_exist]L554:There isn't dts cfg for key[oemkey]
[KM]Error:f[key_manage_query_size]L511:Fail in query key exist
hpd_state=0
do_hpd_detect: hdmimode=1080p60hz
do_hpd_detect: colorattribute=rgb,8bit
Saving Environment to aml-storage...
Writing to MMC(1)... done
no sink, fallback to 720p60hz[4]
hdr mode is 0
dv  mode is ver:0  len: 0
hdr10+ mode is 0
read hdmichecksum 0x00000000, colorattribute rgb,8bit
read hdmimode 1080p60hz, colorspace <NULL>, colordepth <NULL>
do_get_parse_edid: autoMode = false, manualMode=16
isYuv4kSink: false, maxTMDSRate=150
do_get_parse_edid: non-yuv4k sink: inColorSpace: HDMI_COLOR_FORMAT_RGB
do_get_parse_edid: default inColorDepth: HDMI_COLOR_DEPTH_24B
TV is same, initial mode is: 576cvbs attr: rgb,8bit
dolby_status 0
dolby_status 0
dolby_vision_process: no tv and dv disabled
[OSD]load fb addr from dts:/meson-fb
[OSD]load fb addr from dts:/fb
[OSD]set initrd_high: 0x7f800000
[OSD]fb_addr for logo: 0x7f800000
[OSD]VPP_OFIFO_SIZE:0xfff01fff
[CANVAS]canvas init
[CANVAS]addr=0x7f800000 width=3840, height=2160
[OSD]osd_hw.free_dst_data: 0,719,0,575
[OSD]osd1_update_disp_freescale_enable
vpp: vpp_matrix_update: 2
cvbs_performance_enhancement
cvbs_config_hdmipll_g12a
cvbs_set_vid2_clk
vdac_enable: 1, module_sel:0x8
dolby_status 0
dolby_status 0
hdr_packet
vpp: hdr_policy = 1
vpp: Rx hdr_info.hdr_sup_eotf_smpte_st_2084 = 0
gpio: pin GPIOAO_3 (gpio 3) value is 1
Command: bcb uboot-command
get bootloader message from misc partition:
[commannd:bootonce-bootloader]
[status:]
[recovery:]
command mark(uboot-command) not match bootonce-bootloader,don't execute.
InUsbBurn
wait for phy ready count is 0
noSof
sof timeout, reset usb phy tuning
card in
co-phase 0x2, tx-dly 0, clock 400000
co-phase 0x2, tx-dly 0, clock 40000000
init_part() 282: PART_TYPE_DOS
Device: SDIO Port B
Manufacturer ID: 0
OEM: 3432
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: (0x1dc200000 Bytes) 7.4 GiB
mmc clock: 40000000
Bus Width: 4-bit
Device: SDIO Port B
Manufacturer ID: 0
OEM: 3432
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
mmc clock: 40000000
Bus Width: 4-bit
reading aml_autoscript
709 bytes read in 4 ms (172.9 KiB/s)
## Executing script at 03080000
bootfromsd=if mmcinfo; then run cfgloadsd; if fatload mmc 0 ${loadaddr} kernel.img; then run sddtb; setenv bootargs ${bootargs} bootfromsd; bootm; fi; fi
reading recovery.img
** Unable to read file recovery.img **
(Re)start USB...
USB0:   USB3.0 XHCI init start
Register 3000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
scanning bus 0 for devices... 1 USB Device(s) found
** Bad device usb 0 **
info->magic =
active slot = 0
active_slot: normal
Unknown command 'wipeisb' - try 'help'
avb2: 0
ee_gate_off ...
avb2: 0
## Booting Android Image at 0x03080000 ...
Kernel command line: androidboot.dtbo_idx=0 --cmdline root=/dev/mmcblk0p18 buildvariant=user
[store]Is good fdt check header, no need decrypt!
active_slot is normal
load dtb from 0x1000000 ......
      Single dtb detected
find 1 dtbos
dtbos to be applied: 0
Apply dtbo 0
   Loading Kernel Image(COMP_NONE) ... OK
   kernel loaded at 0x01080000, end = 0x019e7928
   Loading Ramdisk to 0997f000, end 09fff6f2 ... OK
   Loading Device Tree to 0000000009968000, end 000000000997edbf ... OK
fdt_fixup_memory_banks, reg:0000000000000000
Starting kernel ...
uboot time: 4905713 us
[    0.000000@0] Linux version 4.9.113 (user@xeon) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02) ) #1 SMP PREEMPT Tue Jun 27 15:39:42 CST 2023
I would love any advice
Edited by ajuyg
The first full paragraph in the instructions says:
Note: If you have previously run other distributions on the box such as coreelec the below installation will not work.  You will need to restore the original android firmware before attempting the install.  coreelec changes the boot environment in ways that are incompatible with these Armbian builds.
wow I feel like an idiot :)
I did already try to "restore to factory settings" from the recovery menu but that didn't help. isn't that enough?
does it matter which androind I flash? can I flash it without the usb burning tool?
You need to find the correct Android firmware for your device and reinstall it according to the instructions for that firmware (usually USB burning tool)
