sgjava Posted January 1, 2024 Posted January 1, 2024 Tried installing Armbian_23.11.1_Nanopineoplus2_jammy_current_6.1.63.img and it is super slow during first boot process regardless of SD type. Localization craps out with "Failed to set time zone: Transport endpoint is not connected". I boot with wired Ethernet and when I get to a prompt I can ping outside locations. apt update produces "Hash Sum mismatch" Anyways, doing my part testing legacy boards, hahahaha 0 Quote
Gunjan Gupta Posted January 1, 2024 Posted January 1, 2024 I remember a discussion where Cornelius reported similar issue with some H5 board. He said that problem was being caused by sun8i-a33-mbus module. Does blacklisting the same makes things better? 0 Quote
sgjava Posted January 2, 2024 Author Posted January 2, 2024 I'll try that first, then I'll try building it myself. Thank you. 0 Quote
Solution sgjava Posted Monday at 09:16 PM Author Solution Posted Monday at 09:16 PM I'm back at it, but this time I can boot by setting netplan wifi up. On reboot wifi never comes up. Do the following: Since end0 is reporting as "busy," let's see if forcing it back to eth0 helps udev clear the conflict. Edit /boot/armbianEnv.txt. Add or modify the extraargs line to include: extraargs=net.ifnames=0 biosdevname=0 Fix hash errors: # Remove the cached package lists that are causing the mismatch sudo rm -rf /var/lib/apt/lists/* # Create the partial directory again just in case sudo mkdir -p /var/lib/apt/lists/partial # Clean out the local repository of retrieved package files sudo apt clean # Update the package index again sudo apt update This is latest build. 0 Quote
