Victorhtf Posted January 8, 2024 Posted January 8, 2024 (edited) Did anyone know how can I see if my TX3 has NAND or EMMC? I not sure if this is right but I'm facing some issues when trying to install armbian in my TX3, I burned and image with balenaEtcher in my sdcard but always says kernel panic or mainline 'bootfromsd is not defined' when booting armbian. It could be because of mem type? Edited January 8, 2024 by Victorhtf 0 Quote
SteeMan Posted January 8, 2024 Posted January 8, 2024 The TX3 comes in a lot of different versions. What cpu does yours have? List the steps you have taken to try your install? (u-boot.ext version, dtb). If you are testing with an SD card, what storage you have internally is irrelevant. 0 Quote
Victorhtf Posted January 9, 2024 Author Posted January 9, 2024 Alright, well. My TX3 comes with S905w, I have been testing this following thread. So basically, I have downloaded Armbian_23.11.1_Aml-s9xx-box_bookworm_current_6.1.63_xfce_desktop.img.xz. Flashed into a sdcard with balenaEtcher, then I changed extlinux.conf to match with TX3, uncommenting FDT /dtb/amlogic/meson-gxl-s905w-tx3-mini.dtb. Which is also in DTB folder. Then I renamed 'u-boot-s905x2-s912' file to u-boot.ext. Unmounted from my device and connect the sdcard, applied power while holding reset button pro 10 seconds. Then appears these messages while booting: Error inserting "stdin" variable in TX3-Mini, after this the system made an attempt to boot kernel (I think), after this I got another error message: Kernel Panic - not syncing: Asynchronous SError Interrupt. Following by a message that says CPU: (u-dev-worker) Not tainted 6.1.63-current-meson64. 0 Quote
SteeMan Posted January 9, 2024 Posted January 9, 2024 48 minutes ago, Victorhtf said: 'u-boot-s905x2-s912 I'm assuming this is as typo, since that file doesn't exist. 0 Quote
Victorhtf Posted January 9, 2024 Author Posted January 9, 2024 When I flashed the image in my SD it had some files for u-boot, so I have renamed one of these to u-boot.ext. In my case I renamed this one that I mentioned. I dont know if this is right, but I remember to read this in the february tutorial. 0 Quote
SteeMan Posted January 9, 2024 Posted January 9, 2024 Yes, u-boot-s905x-s912 is correct for an s905w based board. Your original post said u-boot-s905x2-s912 which doesn't exist 0 Quote
Victorhtf Posted January 9, 2024 Author Posted January 9, 2024 (edited) Alright, sorry, I didnt notice the 2 after X. By the way, I dont know why i cant be able to boot normally. I'm always getting this error, and dont know if i'm doing something wrong. Edited January 9, 2024 by Victorhtf 0 Quote
