Baptiste Posted January 23, 2024 Posted January 23, 2024 (edited) Hi, I tried to connect an external USB 3.2 gen 2x2 4TB SSD drive to the only USB-C port available on the Rockpro64, but it's not recognized. I don't know if I need to install some packages for it to work? Any help would be very appreciated! I am on Ubuntu Jammy based Armbian: 6.1.63-current-rockchip64 #1 SMP PREEMPT Mon Nov 20 10:52:19 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux It works well with the same cable on a Macbook Pro. Kind regards, Baptiste dmesg [ 4.879030] usb usb1-port1: Cannot enable. Maybe the USB cable is bad? [ 4.880111] [drm] Initialized panfrost 1.2.0 20180908 for ff9a0000.gpu on minor 1 [ 5.779194] usb usb1-port1: Cannot enable. Maybe the USB cable is bad? [ 5.779596] usb usb1-port1: attempt power cycle [ 6.755189] usb usb1-port1: Cannot enable. Maybe the USB cable is bad? [ 7.655190] usb usb1-port1: Cannot enable. Maybe the USB cable is bad? [ 7.655590] usb usb1-port1: unable to enumerate USB device sudo lsusb -t /: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M Edited January 23, 2024 by Baptiste 0 Quote
