pinebookpro-owner Posted January 29, 2024 Posted January 29, 2024 Hello, unfortunatelly I post again, because of the latest problem with broken install of initramfs .... The system is unable to write it to uboot and gives the error about unsupported architecure. Every standard commands are probed, without result. it comes always the same error. Quote update-initramfs: Generating /boot/initrd.img-6.6.2-edge-rockchip64 update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.6.2-edge -rockchip64 Invalid architecture, supported are: alpha Alpha arc ARC arm ARM arm64 AArch64 avr32 AVR32 blackfin Blackfin ia64 IA64 invalid Invalid ARCH m68k M68K microblaze MicroBlaze mips MIPS mips64 MIPS 64 Bit nds32 NDS32 nios2 NIOS II or1k OpenRISC 1000 powerpc PowerPC riscv RISC-V s390 IBM S390 sandbox Sandbox sh SuperH sparc SPARC sparc64 SPARC 64 Bit x86 Intel x86 x86_64 AMD x86_64 xtensa Xtensa Error: Invalid architecture Usage: mkimage -l image -l ==> list image header information mkimage [-x] -A arch -O os -T type -C comp -a addr -e ep -n name -d data_ file[:data_file...] image -A ==> set architecture to 'arch' -O ==> set operating system to 'os' -T ==> set image type to 'type' -C ==> set compression type 'comp' -a ==> set load address to 'addr' (hex) -e ==> set entry point to 'ep' (hex) -n ==> set image name to 'name' -d ==> use image data from 'datafile' -x ==> set XIP (execute in place) mkimage [-D dtc_options] [-f fit-image.its|-f auto|-F] [-b <dtb> [-b <dtb >]] [-E] [-B size] [-i <ramdisk.cpio.gz>] fit-image <dtb> file is used with -f auto, it may occur multiple times. -D => set all options for device tree compiler -f => input filename for FIT source -i => input filename for ramdisk file -E => place data outside of the FIT structure -B => align size in hex for FIT structure and header Signing / verified boot options: [-k keydir] [-K dtb] [ -c <comment>] [-p addr] [-r] [-N engine] -k => set directory containing private keys -K => write public keys to this .dtb file -G => use this signing key (in lieu of -k) -c => add comment in signature node -F => re-sign existing FIT image -p => place external data at a static position -r => mark keys used as 'required' in dtb -N => openssl engine to use for signing mkimage -V ==> print version information and exit Use '-T list' to see a list of available image types run-parts: /etc/initramfs/post-update.d//99-uboot exited with return code 1 dpkg: error processing package initramfs-tools (--configure): installed initramfs-tools package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: initramfs-tools E: Sub-process /usr/bin/dpkg returned an error code (1) 0 Quote
Solution pinebookpro-owner Posted March 4, 2024 Author Solution Posted March 4, 2024 With the latest update everything works again. 0 Quote
technik007_cz Posted September 10, 2024 Posted September 10, 2024 I am experiencing same problem but on pine64. update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.7.12-edge-sunxi64 Invalid architecture, supported are: alpha Alpha arc ARC arm ARM arm64 AArch64 avr32 AVR32 blackfin Blackfin ia64 IA64 invalid Invalid ARCH m68k M68K microblaze MicroBlaze mips MIPS mips64 MIPS 64 Bit nds32 NDS32 nios2 NIOS II or1k OpenRISC 1000 powerpc PowerPC riscv RISC-V s390 IBM S390 sandbox Sandbox sh SuperH sparc SPARC sparc64 SPARC 64 Bit x86 Intel x86 x86_64 AMD x86_64 xtensa Xtensa Error: Invalid architecture Usage: mkimage [-T type] -l image -l ==> list image header information -T ==> parse image file as 'type' -q ==> quiet mkimage [-x] -A arch -O os -T type -C comp -a addr -e ep -n name -d data_file[:data_file...] image -A ==> set architecture to 'arch' -O ==> set operating system to 'os' -T ==> set image type to 'type' -C ==> set compression type 'comp' -a ==> set load address to 'addr' (hex) -e ==> set entry point to 'ep' (hex) -n ==> set image name to 'name' -R ==> set second image name to 'name' -d ==> use image data from 'datafile' -x ==> set XIP (execute in place) -s ==> create an image with no data -v ==> verbose mkimage [-D dtc_options] [-f fit-image.its|-f auto|-f auto-conf|-F] [-b <dtb> [-b <dtb>]] [-E] [-B size] [-i <ramdisk.cpio.gz >] fit-image <dtb> file is used with -f auto, it may occur multiple times. -D => set all options for device tree compiler -f => input filename for FIT source -i => input filename for ramdisk file -E => place data outside of the FIT structure -B => align size in hex for FIT structure and header -b => append the device tree binary to the FIT -t => update the timestamp in the FIT Signing / verified boot options: [-k keydir] [-K dtb] [ -c <comment>] [-p addr] [-r] [-N engine] -k => set directory containing private keys -K => write public keys to this .dtb file -g => set key name hint -G => use this signing key (in lieu of -k) -c => add comment in signature node -F => re-sign existing FIT image -p => place external data at a static position -r => mark keys used as 'required' in dtb -N => openssl engine to use for signing -o => algorithm to use for signing mkimage -V ==> print version information and exit Use '-T list' to see a list of available image types Long options are available; read the man page for details run-parts: /etc/initramfs/post-update.d//99-uboot exited with return code 1 dpkg: error processing package initramfs-tools (--configure): installed initramfs-tools package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: linux-image-current-sunxi64 initramfs-tools E: Sub-process /usr/bin/dpkg returned an error code (1 0 Quote
technik007_cz Posted September 10, 2024 Posted September 10, 2024 I got it working again. Installed "current" kernel but the same issue was showing during an attempt to update initramfs. So I uninstalled initramfs-tools and did apt autoremove to remove package leftovers. Then I installed armbian-bsp-cli-pine64-current and I got strange response 'version <none>' but then everything started working included broken initramfs update. aptitude install armbian-bsp-cli-pine64-current W: Package initramfs-tools had been marked to reinstall, but the file for the current installed version <none> is not available The following NEW packages will be installed: armbian-bsp-cli-pine64-current busybox-initramfs{a} dracut-install{a} fping{a} initramfs-tools{a} initramfs-tools-bin{a} initramfs-tools-core{a} klibc-utils{a} libklibc{a} 0 Quote
technik007_cz Posted February 1, 2025 Posted February 1, 2025 (edited) I just run into this problem again but on different SBC. With new apt apgrade a new version of kernel came, initramfs complainend about "Invalid architecture" and failed to finish. I tried to fix it differently and it also worked. Removed armbian-bsp-cli-rock-4se-current, with this new attempt to do initramfs started and was completed without error. Then I installed armbian-bsp-cli-rock-4se-current again. Just bear in mind you need to know which armbian-bsp-cli you had previously installed because it could be also -edge , -vendor , etc. Edited February 1, 2025 by technik007_cz 0 Quote
