Hi @John Taylor, @SteeMan,
unfortunatly it takes me time because I was not at home. I found that I can use the minimal or server version and only using Rufus. If I use Balena Etcher it doesn't create the fat32 partition named Boot. now I'm struggling because I would like to use the system on SD card but after that I do any changing for example IP from dynamic to static using armbian-config a lot of messages comes saying that EXT4FS is in read-only mode and I can use the system but not to install programs. I'm a little afraid to install on eemc because I have no android image. It is an old MXQ pro mini from leelbox.
Posted (edited)
@Maurizio Finesso@John Taylor@SteeMan
I've had success using USB stick instead of SD Card (see my post on 1st page), however now the BOOT Fat32 partition was hidden for some reason, I used DiskGenius to unhide it.
I didn't test this on the tv box yet.
This also goes against what is being said in this thread (that there are no more Fat32 paritions visible in Windows) from this thread:
EDIT2: USB stick works, however I'm having trouble with "USB device not recognized" on Windows, and I can' seem to be able to fix it with gparted for example, as it keeps disconnecting, so YMMW.
Edited by 2mg
Disk genius in my case reveals there is NO FAT32 boot partition, hidden or otherwise, only a root partition.
Posted (edited)
Furthermore, today I built an Ubuntu desktop PC, and flashed a build onto an SD Card. The resultant installation has only ONE partition. No Windows involvement whatsoever :( Same with a USB flash drive (to eliminate the SD card adapter).
So where do we go from here?
Edited by John Taylor
Thanks to Nick Alilovic for the solution to this issue. You need to add "BOOTFS_TYPE=fat to the board config. If you are on Windows and using an image created by someone else, it's possible you may need to install a utility to show .ext partitions. The you can edit /boot/armbianEnv.txt or extlinux to config to point to a different dtb etc.
BOOTFS_TYPE=fat is part of the aml-s9xx-box.tvb config file and has always been.  So I'm not sure what your comment is referring to, but it seems to be off topic for this thread which is about instructions for using the aml-s9xx-box Armbian builds.
Posted (edited)
Hello everybody,
My Box is a oxtagon shaped  t95z plus 2 mb 16 mb
I try to install armbian_community_26_2 _0-trunk.100 aml-s9xx-box_noble_current_6.12.63_cinnamon_dektop.img.xz
I use meson-gxm-vega-s96.dtb
And u-boot-s905x-s912.dtb copy and rename as u-boot.ext
It boots to ash then it stops
No asking for password and user
I have no clue what to do next
I have entered armbian-confug but this returns a error
Any tips?
Edited by Herman Hoekstra
More info
