Crossplatform Vlad Posted February 7, 2024 Posted February 7, 2024 My setup is SD boot and rootfs on ssd on USB 2.0 smartctl on laptop reports TIRM is enabled, but it is missing on orange pi PC. using the same SSD in the same USB box. Do I need another ssd, USB box, or armbian upgrade for TRIM support? root@focal-armv7l ~ $ fstrim -v / fstrim: /: the discard operation is not supported root@focal-armv7l ~ $ mount | grep " / " /dev/sda1 on / type ext4 (rw,noatime,nodiratime,discard,errors=remount-ro,commit=600) root@focal-armv7l ~ $ smartctl -i -d sat /dev/sda smartctl 7.1 2019-12-30 r5022 [armv7l-linux-5.9.14-sunxi] (local build) Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: SSD 128GB Serial Number: GS20231128661058 LU WWN Device Id: 0 000000 000000000 Firmware Version: HT3618C8 User Capacity: 128,035,676,160 bytes [128 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-4 T13/BSR INCITS 529 revision 5 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 1.5 Gb/s) Local Time is: Wed Feb 7 06:02:15 2024 EET SMART support is: Available - device has SMART capability. SMART support is: Enabled # Missing TRIM support lsblk -D also reports zeros for discard root@focal-armv7l ~ $ lsblk -D NAME DISC-ALN DISC-GRAN DISC-MAX DISC-ZERO sda 0 0B 0B 0 ├─sda1 0 0B 0B 0 └─sda2 0 0B 0B 0 mmcblk0 0 4M 3.5G 0 ├─mmcblk0p1 0 4M 3.5G 0 └─mmcblk0p2 0 4M 3.5G 0 zram0 0 4K 2T 0 zram1 0 4K 2T 0 I'm using previous armbian ver. Can an upgrade help to solve the missing trim issue? root@focal-armv7l ~ $ cat /etc/*release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepipc BOARD_NAME="Orange Pi PC" BOARDFAMILY=sun8i BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=b9814056 DISTRIBUTION_CODENAME=focal DISTRIBUTION_STATUS=supported VERSION=20.11.3 LINUXFAMILY=sunxi BRANCH=current ARCH=arm IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=Image IMAGE_UUID=3d974917-e04a-4ec3-bc8a-cc3d2427eb76 # PLEASE DO NOT EDIT THIS FILE BOARD=orangepipc BOARD_NAME="Orange Pi PC" BOARDFAMILY=sun8i BUILD_REPOSITORY_URL=git@github.com:armbian/build.git BUILD_REPOSITORY_COMMIT=e846ef656-dirty DISTRIBUTION_CODENAME=focal DISTRIBUTION_STATUS=supported VERSION=21.02.3 LINUXFAMILY=sunxi BRANCH=current ARCH=arm IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=Image DISTRIB_ID=Ubuntu DISTRIB_RELEASE=20.04 DISTRIB_CODENAME=focal DISTRIB_DESCRIPTION="Ubuntu 20.04.6 LTS" NAME="Ubuntu" VERSION="20.04.6 LTS (Focal Fossa)" ID=ubuntu ID_LIKE=debian PRETTY_NAME="Ubuntu 20.04.6 LTS" VERSION_ID="20.04" HOME_URL="https://www.ubuntu.com/" SUPPORT_URL="https://help.ubuntu.com/" BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/" PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy" VERSION_CODENAME=focal UBUNTU_CODENAME=focal P.S. ix.io is taking a break 0 Quote
Crossplatform Vlad Posted February 8, 2024 Author Posted February 8, 2024 Quote Yep, for instance I have a 2TB hard drive in mine that costs like 70ish bucks, a 2TB ssd depending on brand is at least 300 bucks. If you have the money sure go for an SSD it's going to be better and faster I have 500GB ssds in my laptop and desktop and they are so good I'll never use a hard drive in my PCs for the boot drive again, but to get a nice sized SSD that will fit most of my games they're too much money yet. Expand Nice. What about missing trim on SSD over USB 2.0? 0 Quote
Gunjan Gupta Posted February 8, 2024 Posted February 8, 2024 I believe yours is more of a generic Linux related question than something that is specific to Armbian. Have you gone through Arch Linux's Solid State Drive page - https://wiki.archlinux.org/title/Solid_state_drive 0 Quote
Crossplatform Vlad Posted February 13, 2024 Author Posted February 13, 2024 On 2/8/2024 at 9:35 PM, Gunjan Gupta said: I believe yours is more of a generic Linux related question than something that is specific to Armbian Expand It is hardware and its support by armbian question. On the latest armbian smartctl reports Trim is supported, but fstrim still not work (the discard operation is not supported) On 2/8/2024 at 9:35 PM, Gunjan Gupta said: ave you gone through Arch Linux's Solid State Drive page Expand Sure. can't you see Trim is enabled by smartctl and discard mount option is on? 0 Quote
going Posted February 13, 2024 Posted February 13, 2024 On 2/8/2024 at 5:19 AM, Crossplatform Vlad said: What about missing trim on SSD over USB 2.0? Expand This is a common Linux issue and we usually do not provide assistance. But you have interested me in this fact. If I understood correctly, then the same SSD drive connected via the SATA connector - trim mode is possible, and connected via a USB-SATA adapter - trim mode is impossible? Publish the DMESG output of the line where the USB-SATA adapter is defined. I have a lot of these things. I'll check it out. 0 Quote
going Posted February 14, 2024 Posted February 14, 2024 On 2/7/2024 at 4:21 AM, Crossplatform Vlad said: smartctl on laptop reports TIRM is enabled, but it is missing on orange pi PC. using the same SSD in the same USB box. Expand On 2/7/2024 at 4:21 AM, Crossplatform Vlad said: DISTRIBUTION_CODENAME=focal Expand On 2/7/2024 at 4:21 AM, Crossplatform Vlad said: root@focal-armv7l ~ $ smartctl -i -d sat /dev/sda smartctl 7.1 2019-12-30 r5022 [armv7l-linux-5.9.14-sunxi] (local build) Expand uname -r ? Have you updated the kernel on this distribution? @Crossplatform Vlad My recommendations: Make a new installation of the distribution based on ubuntu 22.04. The build system works on this version. Why is that? Do you need further explanations? 0 Quote
Crossplatform Vlad Posted February 14, 2024 Author Posted February 14, 2024 On 2/13/2024 at 7:31 PM, going said: If I understood correctly, then the same SSD drive connected via the SATA connector - trim mode is possible, and connected via a USB-SATA adapter - trim mode is impossible? Expand Not exactly. trim and fstrim works well on the same SSD connected to USB 3.* on laptop using the same USB-SATA adapter. I didn't connect SSD to a sata connecor directly. But trim is missing on USB 2.0 only orange pi pc. On 2/13/2024 at 7:31 PM, going said: Publish the DMESG output of the line where the USB-SATA adapter is defined. Expand here it is (Realtek RTL9201). sda1 is root fs as btrfs, sda2 is swap. Previously I created SSD root fs as ext4 and the result was the same (discard is not supported) The full dmesg is also attached. [ 2.645774] usb 4-1: new high-speed USB device number 2 using ehci-platform [ 2.812076] usb 4-1: New USB device found, idVendor=0bda, idProduct=9201, bcdDevice=f2.00 [ 2.812110] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 2.812123] usb 4-1: Product: RTL9201 [ 2.812133] usb 4-1: Manufacturer: Realtek [ 2.812144] usb 4-1: SerialNumber: 012345678999 [ 2.836676] usb-storage 4-1:1.0: USB Mass Storage device detected [ 2.838158] scsi host0: usb-storage 4-1:1.0 [ 2.845086] usbcore: registered new interface driver uas [ 4.309250] scsi 0:0:0:0: Direct-Access SSD 128G B 1.02 PQ: 0 ANSI: 6 [ 4.310067] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 4.313065] sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB) [ 4.314870] sd 0:0:0:0: [sda] Write Protect is off [ 4.314891] sd 0:0:0:0: [sda] Mode Sense: 37 00 00 08 [ 4.316343] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA [ 4.331219] sda: sda1 sda2 [ 4.331965] sd 0:0:0:0: [sda] Attached SCSI disk [ 4.527111] BTRFS: device fsid df0ead50-f772-46c2-9e27-c76368fe0a04 devid 1 transid 502 /dev/sda1 scanned by systemd-udevd (189) [ 4.755889] BTRFS info (device sda1): using crc32c (crc32c-generic) checksum algorithm [ 4.755972] BTRFS info (device sda1): using free space tree [ 4.791422] BTRFS info (device sda1): start tree-log replay On 2/13/2024 at 7:31 PM, going said: I have a lot of these things. I'll check it out. Expand do you have a many years old orange pi pc? or USB 2.0 only board? dmesg on orange pi pc with usb-sata SSD.txtFetching info... 0 Quote
Crossplatform Vlad Posted February 14, 2024 Author Posted February 14, 2024 (edited) On 2/14/2024 at 8:44 AM, going said: Have you updated the kernel on this distribution? @Crossplatform Vlad My recommendations: Make a new installation of the distribution based on ubuntu 22.04. The build system works on this version. Why is that? Do you need further explanations? Expand Yes. on the latest armbian with ubuntu 22.04 the result is the same. dmesg logs above are grabbed on the latest armbian with ubuntu 22.04 the fresh armbian installation: root@jammy-armv7l ~ $ uname -r 6.1.63-current-sunxi root@jammy-armv7l ~ $ uname -a Linux jammy-armv7l 6.1.63-current-sunxi #1 SMP Mon Nov 20 10:52:19 UTC 2023 armv7l armv7l armv7l GNU/Linux root@jammy-armv7l ~ $ cat /etc/*release # PLEASE DO NOT EDIT THIS FILE BOARD=orangepipc BOARD_NAME="Orange Pi PC" BOARDFAMILY=sun8i BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=b600ead20 LINUXFAMILY=sunxi ARCH=arm IMAGE_TYPE=nightly BOARD_TYPE=csc INITRD_ARCH=arm KERNEL_IMAGE_TYPE=zImage FORCE_BOOTSCRIPT_UPDATE= FORCE_UBOOT_UPDATE= VENDOR="Armbian_community" VENDORDOCS="https://docs.armbian.com" VENDORURL="https://github.com/armbian/build" VENDORSUPPORT="https://community.armbian.com/" VENDORBUGS="https://github.com/armbian/community/issues" BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" VERSION=24.2.0-trunk.540 REVISION=24.2.0-trunk.540 IMAGE_UUID=5774cefd-8728-4d69-8504-636e97a35e54 # PLEASE DO NOT EDIT THIS FILE BOARD=orangepipc BOARD_NAME="Orange Pi PC" BOARDFAMILY=sun8i BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=a7aafb8de LINUXFAMILY=sunxi ARCH=arm IMAGE_TYPE=nightly BOARD_TYPE=csc INITRD_ARCH=arm KERNEL_IMAGE_TYPE=zImage FORCE_BOOTSCRIPT_UPDATE= FORCE_UBOOT_UPDATE= VENDOR="Armbian" VENDORDOCS="https://docs.armbian.com" VENDORURL="https://www.armbian.com/" VENDORSUPPORT="https://forum.armbian.com" VENDORBUGS="https://www.armbian.com/bugs" BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.cmd" VERSION=24.2.0-trunk.551 REVISION=24.2.0-trunk.551 BRANCH=current DISTRIB_ID=Ubuntu DISTRIB_RELEASE=22.04 DISTRIB_CODENAME=jammy DISTRIB_DESCRIPTION="Ubuntu 22.04.3 LTS" PRETTY_NAME="Armbian 24.2.0-trunk.551 jammy" NAME="Ubuntu" VERSION_ID="22.04" VERSION="22.04.3 LTS (Jammy Jellyfish)" VERSION_CODENAME=jammy ID=ubuntu ID_LIKE=debian HOME_URL="https://www.armbian.com" SUPPORT_URL="https://forum.armbian.com" BUG_REPORT_URL="https://www.armbian.com/bugs" PRIVACY_POLICY_URL="https://www.armbian.com" UBUNTU_CODENAME=jammy ARMBIAN_PRETTY_NAME="Armbian 24.2.0-trunk.551 jammy" Edited February 14, 2024 by Crossplatform Vlad 0 Quote
going Posted February 14, 2024 Posted February 14, 2024 (edited) On 2/14/2024 at 8:49 AM, Crossplatform Vlad said: Not exactly. trim and fstrim works well on the same SSD connected to USB 3.* on laptop using the same USB-SATA adapter. I didn't connect SSD to a sata connecor directly. But trim is missing on USB 2.0 only orange pi pc. Expand I need time to think. P.S. Test: OS openSUSE 15.4, desktop computer SATA3 <-> SSD_SATA3 sudo fstrim -v / good work USB2.0 <-> USB2-SATA_adaptor <->SSD_SATA3 fstrim: /mnt: the discard operation is not supported USB2.0 <-> USB3-SATA_adaptor <->SSD_SATA3 fstrim: /mnt: the discard operation is not supported USB3.0 <-> USB3-SATA_adaptor <->SSD_SATA3 fstrim: /mnt: the discard operation is not supported > sudo mount -v -o rw,noatime,nodiratime,discard,errors=remount-ro,commit=600 /dev/sdf1 /mnt > sudo mount | grep /mnt /dev/sdf1 on /mnt type ext4 (rw,noatime,nodiratime,discard,errors=remount-ro,commit=600) > sudo fstrim -v /mnt fstrim: /mnt: the discard operation is not supported I think it's some kind of hardware limitation. You have a newer generation USB3-SATA3 adapter and it supports the function when connected to a USB3 port. Mine is not. Armbian has nothing to do with this. @Crossplatform Vlad I intentionally ran the test on my work computer, not on a banana. Edited February 14, 2024 by going Add P.S. 0 Quote
Crossplatform Vlad Posted February 15, 2024 Author Posted February 15, 2024 (edited) On 2/14/2024 at 8:56 AM, going said: You have a newer generation USB3-SATA3 adapter and it supports the function when connected to a USB3 port. Mine is not. Expand Yeah. RTL9201 is a pretty new controller. Ubuntu 22.04 was released early. I'm waiting for Ubuntu 24.04 based armbian. On 2/14/2024 at 8:56 AM, going said: I think it's some kind of hardware limitation. Expand But USB 2.0 sata controllers support TRIM without queueing according to Google. Probably fstrim unconditionally needs queueing and fails. How to check that continuing trimming works despite fstrim doesn't? Edited February 15, 2024 by Crossplatform Vlad 0 Quote
going Posted February 15, 2024 Posted February 15, 2024 On 2/15/2024 at 7:34 AM, Crossplatform Vlad said: But USB 2.0 sata controllers support TRIM without queueing according to Google. Expand Okay, let's move on. When I mount an ext4 FS, sudo mount -v -o rw,noatime,nodiratime,discard,errors=remount-ro,commit=600 /dev/sdf1 /mnt dmesg reports: [28422.686388] EXT4-fs (sdf1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. [28422.717550] EXT4-fs (sdf1): mounted filesystem with ordered data mode. Opts: errors=remount-ro. Quota mode: none. [28612.985794] EXT4-fs (sdf1): mounting with "discard" option, but the device does not support discard [28612.985800] EXT4-fs (sdf1): mounted filesystem with ordered data mode. Opts: discard,errors=remount-ro,commit=600. Quota mode: none. When I mount an btrfs FS, sudo mount -o rw,relatime,ssd,space_cache,subvolid=5,subvol=/ /dev/sdf /mnt dmesg reports: [35708.200591] BTRFS: device label test-btrfs devid 1 transid 5 /dev/sdf scanned by mkfs.btrfs (24307) [35708.283831] BTRFS info (device sdf): disk space caching is enabled [35708.283837] BTRFS info (device sdf): has skinny extents [35708.283839] BTRFS info (device sdf): flagging fs with big metadata feature [35708.286642] BTRFS info (device sdf): checking UUID tree [36135.461701] BTRFS info (device sdf): disk space caching is enabled [36135.461706] BTRFS info (device sdf): has skinny extents [36268.307315] BTRFS info (device sdf): enabling ssd optimizations [36268.307322] BTRFS info (device sdf): disk space caching is enabled [36268.307324] BTRFS info (device sdf): has skinny extents EXT4 reports that there is no trim support. BTRFS informs you that everything is included. Perhaps I am mistaken and this is the presence/absence of support in the kernel drivers. I have two more devices, adapters for SATA. One is directly soldered to the BPI-M3. The other is an external PCIe-SATA. I'll check them later. 0 Quote
going Posted February 15, 2024 Posted February 15, 2024 On 2/15/2024 at 7:34 AM, Crossplatform Vlad said: How to check that continuing trimming works despite fstrim doesn't? Expand Maybe we should first discuss what is driving your desire in this direction? What is the ultimate goal? 0 Quote
Crossplatform Vlad Posted February 15, 2024 Author Posted February 15, 2024 (edited) On 2/15/2024 at 9:01 AM, going said: Maybe we should first discuss what is driving your desire in this direction? What is the ultimate goal? Expand 1. performance 2. smooth responsiveness. For USB 2.0 SSD reading is 2x (2944 vs 1500) faster than microsd, and writing is 8x faster (3942 vs 500) than microsd. The benchmark above is made on orange pi pc. 3. missing performance degradation on SSD over time if trim is working Edited February 15, 2024 by Crossplatform Vlad 0 Quote
going Posted February 15, 2024 Posted February 15, 2024 On 2/15/2024 at 9:55 AM, Crossplatform Vlad said: 3. missing performance degradation over time if trim is working. Expand This is a key importance for me and for you. Perhaps some hints exist in man fstrim On my SSD, which is 50% full, the slowdown is observed after about 2 months. I just run the command in this case and wait (do nothing). This repeats itself when I start to observe a slowdown. To be honest, I do not know of any other tool for this functionality than dmesg messages when mounting a file system. 0 Quote
Crossplatform Vlad Posted February 16, 2024 Author Posted February 16, 2024 On 2/15/2024 at 10:40 AM, going said: To be honest, I do not know of any other tool for this functionality than dmesg messages when mounting a file system. Expand On my orange pi pc there are no any errors on missing discard support. it says turning on sync discard 🥳 [ 7.831505] BTRFS info (device sda1: state M): turning on sync discard [ 7.831553] BTRFS warning (device sda1: state M): excessive commit interval 600 [ 7.831581] BTRFS info (device sda1: state M): use lzo compression, level 0 Does it mean continuing trimming works despite fstrim doesn't? 0 Quote
Solution going Posted February 16, 2024 Solution Posted February 16, 2024 On 2/16/2024 at 3:43 AM, Crossplatform Vlad said: On my orange pi pc there are no any errors on missing discard support. it says turning on sync discard 🥳 [ 7.831505] BTRFS info (device sda1: state M): turning on sync discard [ 7.831553] BTRFS warning (device sda1: state M): excessive commit interval 600 [ 7.831581] BTRFS info (device sda1: state M): use lzo compression, level 0 Does it mean continuing trimming works despite fstrim doesn't? Expand In this case, the TRIM will be continuous and implemented directly by the kernel. P.S. More info: Solid_state_drive I don't have anything to add to this article. 0 Quote
ngrigoriev Posted December 13, 2024 Posted December 13, 2024 Same problem here, with another board (PINE H64). TRIM is not working and no, it is not magically implemented by the kernel. ``` === START OF INFORMATION SECTION === Device Model: Timetec 30TT253X2-256G Serial Number: PL220901YSA256G1159 Firmware Version: V0718B0 User Capacity: 256,060,514,304 bytes [256 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Form Factor: 2.5 inches TRIM Command: Available Device is: Not in smartctl database 7.3/5319 ATA Version is: ACS-2 T13/2015-D revision 3 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Fri Dec 13 02:05:22 2024 UTC SMART support is: Available - device has SMART capability. SMART support is: Enabled ``` This is the USB-to-SATA adapter: ``` Bus 002 Device 002: ID aabb:1122 Initio 3639S Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 3.20 bDeviceClass 0 bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 9 idVendor 0xaabb idProduct 0x1122 bcdDevice 0.60 iManufacturer 1 Initio iProduct 2 3639S iSerial 3 19053B2F12345 ``` One of my drives started to fail with timeouts. My first thought was that it is time. I took it out, connected to my laptop. Tried to write a couple of gigs on it and observed the same timeouts and, finally, the drive became non-responsive. Powered it off/on, executed fstrim on it. Then successfully wrote several dozens of gigs on it without any issues. Clearly doing TRIM resolved the problem. Now the dilemma, what to do with other identical boards and drives. 0 Quote
eselarm Posted December 13, 2024 Posted December 13, 2024 @ngrigoriev You need UAS transfermode enabled and also then in addition make sure trim is enabled. Many USB-to-SATA chips/adapters can't reliably do UAS, so you never get trim to work. AFAIK no USB2 only adaptor can do UAS (I have never seen it), USB3.0 is buggy, so are several SBCs with USB3.0. RaspberryPi4 is notorious, roughly half of the USB3-to-SATA won't work like a normal direct SATA connection. I had to buy a new/extra adaptor for my Pi4, (use only ASMedia based is the advice) and still needed a udev rule to enable trim. Only then it was acceptable, good server like performance for LVM thin volumes and Btrfs etc. Adaptors based on JMicron chips usually give trouble, this generally know by people who use them, sell them, etc. If I look at: idVendor 0xaabb idProduct 0x1122 my immediate thought is this is just some clone or even counterfeit. I haven't checked, I won't waste time on it anymore. The Pi4 troubles did cost me about 35 Euro in total extra for new USB stuff (and lots of time). There are various no-brand or whatever random brand new name adapters with JMicron chip inside that work good enough for old spinning magnetic HDD, but can turn into trouble or disaster for modern SSD that needs trim. I have 1 that only did UAS after firmware update, in an Intel PC, but still not working correctly with Pi4 USB3 port. 0 Quote
