Jack07 Posted February 9, 2024 Posted February 9, 2024 (edited) Hello, I have Orange Pi One Plus with the kernel 5.15.80 of Armbian 22.11.1 and work well. , but after upgrading to 23.8.1 kernel 6.1.47 the network interfaces stop working at all. Even I try the 23.05.1, 23.05.6 all have same error which because the kernel is 6.1.x. Currenly I limited the internet access without the the network. May I know how to fix it in the console or someone can help to generate the 23.11.1 image for fixed this error. Thanks The error message like as below in the console terminal. [ 9.899195] dwmac-sun8i 5020000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) The spec of the system: dmesg | grep eth0 [ 36.352751] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 36.353587] dwmac-sun8i 5020000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) uname -a Linux orangepioneplus 6.1.47-current-sunxi64 #3 SMP Wed Aug 23 15:52:42 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux ip address 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether 02:01:e7:xx:xx:xx brd ff:ff:ff:ff:ff:ff Edited February 9, 2024 by Jack07 0 Quote
Jack07 Posted February 11, 2024 Author Posted February 11, 2024 (edited) 2024/02/11 update the status. I use addition USB3 ethernet device to work with the network and run apt upgrade to the kernel 6.1.63. But still has a error with inside network device eth0. The below is spec: image file: Armbian_23.8.1_Orangepioneplus_jammy_current_6.1.47.img.xz uname -a Linux orangepioneplus 6.1.63-current-sunxi64 #1 SMP Mon Nov 20 10:52:19 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux ip address 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000 link/ether 02:01:e7:xx:xx:xx brd ff:ff:ff:ff:ff:ff 4: enx000ec6b1d59e: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000 link/ether 00:0e:c6:xx:xx:xx brd ff:ff:ff:ff:ff:ff inet 192.168.xx.xx/24 brd 192.168.xx.xx scope global dynamic noprefixroute enx000ec6b1d59e valid_lft 85927sec preferred_lft 85927sec inet6 fe80::xxxx:xxxx:xxxx:xxxx/64 scope link noprefixroute valid_lft forever preferred_lft forever dmesg | grep eth0 [ 20.495445] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 20.496087] dwmac-sun8i 5020000.ethernet eth0: __stmmac_open: Cannot attach to PHY (error: -19) Edited February 11, 2024 by Jack07 0 Quote
JohnnyLaw Posted February 12, 2024 Posted February 12, 2024 I have the same problem on OrangePi 3 uname -a Linux orangepi3 6.1.63-current-sunxi64 #1 SMP Mon Nov 20 10:52:19 UTC 2023 aarch64 GNU/Linux image file Armbian_23.11.1_Orangepi3_bookworm_current_6.1.63.img.xz ifup end0 ifup: failed to bring up end0 dmesg | grep -i end [ 5.133926] dwmac-sun8i 5020000.ethernet end0: renamed from eth0 [ 11.205978] dwmac-sun8i 5020000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 11.214610] dwmac-sun8i 5020000.ethernet end0: __stmmac_open: Cannot attach to PHY (error: -19) [ 88.248982] ---[ end trace 0000000000000000 ]--- 0 Quote
Char11e Posted January 28 Posted January 28 This is a problem of interaction between the phy driver and MAC in the Linux kernel. ./stmicro/stmmac/stmmac_main.c:928: pr_err("%s: Cannot attach to PHY (error: %d)\n", __func__, ret); ./stmicro/stmmac/stmmac_main.c-894-static int stmmac_open(struct net_device *dev) ./stmicro/stmmac/stmmac_main.c:299:static int stmmac_init_phy(struct net_device *dev) ../phy/phy_device.c:371:struct phy_device * phy_connect(struct net_device *dev, const char *bus_id, ./phy_device.c:336:int phy_connect_direct(struct net_device *dev, struct phy_device *phydev, ./phy_device.c:441:static int phy_attach_direct(struct net_device *dev, struct phy_device *phydev, ./phy_device.c:413:int phy_init_hw(struct phy_device *phydev) It is known that an error will be reported during phy initialization, but I am still looking for the kernel source code for Sunxi Linux 6.1.xx and 5.15.xx. Error code flow: stmmac_open > stmmac_init_phy > phy_connect > phy_connect_direct > phy_attach_direct > phy_init_hw 0 Quote
Char11e Posted 18 hours ago Posted 18 hours ago My log : https://paste.armbian.com/idomububex I find the phy issue stiil happened in OranpePi3 when using Kernel 6.1.47-current-sunxi64 and 6.12.20-current-sunxi64. @Jack07 @JohnnyLaw Do you still have same issue when using 6.X.X verion kernel? 0 Quote
Char11e Posted 17 hours ago Posted 17 hours ago I am trying to downgrade to kernel 5.15.93-sunxi64 and found the eth0 is worked. pi@orangepi3:~$ dmesg | grep eth0 [ 18.467932] dwmac-sun8i 5020000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211E Gigabit Ethernet] (irq=POLL) [ 18.468969] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 18.469701] dwmac-sun8i 5020000.ethernet eth0: No Safety Features support found [ 18.469727] dwmac-sun8i 5020000.ethernet eth0: No MAC Management Counters available [ 18.469734] dwmac-sun8i 5020000.ethernet eth0: PTP not supported by HW [ 18.475463] dwmac-sun8i 5020000.ethernet eth0: configuring for phy/rgmii-id link mode [ 20.510690] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 20.510735] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready 0 Quote
Char11e Posted 14 hours ago Posted 14 hours ago I found the dts setting about "ethernet@5020000" was different between kernel 5.15.93 and kernel 6.1.47. We need to make sure the following things are correct: 1. Ethernet driver uses the correct clock/reset 2. GPIO reset can be pulled up 3. MDIO can correctly go to PHY 4. Pinmux correctly sets Ethernet pins #Kernnel 5.15.93-sunxi64 ethernet@5020000 { compatible = "allwinner,sun50i-h6-emac\0allwinner,sun50i-a64-emac"; syscon = <0x31>; reg = <0x5020000 0x10000>; interrupts = <0x00 0x0c 0x04>; interrupt-names = "macirq"; resets = <0x04 0x21>; reset-names = "stmmaceth"; clocks = <0x04 0x54>; clock-names = "stmmaceth"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <0x32>; phy-mode = "rgmii-id"; phy-handle = <0x33>; phy-supply = <0x34>; phy-io-supply = <0x35>; allwinner,rx-delay-ps = <0xc8>; allwinner,tx-delay-ps = <0xc8>; phandle = <0x78>; mdio { compatible = "snps,dwmac-mdio"; #address-cells = <0x01>; #size-cells = <0x00>; phandle = <0x79>; ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0x01>; reset-gpios = <0x1f 0x03 0x0e 0x01>; reset-assert-us = <0x3a98>; reset-deassert-us = <0x9c40>; phandle = <0x33>; }; }; }; #Kernel 6.1.47-current-sunxi64 ethernet@5020000 { compatible = "allwinner,sun50i-h6-emac\0allwinner,sun50i-a64-emac"; syscon = <0x32>; reg = <0x5020000 0x10000>; interrupts = <0x00 0x0c 0x04>; interrupt-names = "macirq"; resets = <0x06 0x21>; reset-names = "stmmaceth"; clocks = <0x06 0x54>; clock-names = "stmmaceth"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <0x33>; phy-mode = "rgmii-id"; phy-handle = <0x34>; phy-supply = <0x2e>; phy-io-supply = <0x35>; allwinner,rx-delay-ps = <0xc8>; allwinner,tx-delay-ps = <0xc8>; phandle = <0x79>; mdio { compatible = "snps,dwmac-mdio"; #address-cells = <0x01>; #size-cells = <0x00>; phandle = <0x7a>; ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0x01>; reset-gpios = <0x1e 0x03 0x0e 0x01>; reset-assert-us = <0x3a98>; reset-deassert-us = <0x9c40>; phandle = <0x34>; }; }; }; 0 Quote
