OrangePi Zero 2 wont resize after reboot
I've been looking for ways to fix this all afternoon but I'm giving up.
I flash the latest version of the image with BalenaEtcher, it takes about 10 min approximately to boot. I log in I do the setup, and the partition / is only 2GB, I reboot the red light stops flashing and the board stays with a steady green light does not respond to ping. I pull the cable and start in armbian the partition is still the same at 2GB, I check the resize2fs service and it does not start.
I don't know what I'm doing wrong, the PSU is working properly, I did a health test to the SD is also OK.
I don't know what else to check.
Edited by Reproach4475
