carlos nascimento Posted February 11 Share Posted February 11 I can't activate the orange pi 3b uarts Armbian Community_24.2.0-trunk.540_Orangepi3b_jammy_legacy_5.10.160_gnome_desktop, I did it this way armbianEnv.txt overlays=uart3-m0 uart7-m2 uart9-m2 overlays=uart3 uart7 uart9 0 Quote Link to comment Share on other sites More sharing options...
heyrict Posted March 3 Share Posted March 3 Uart port works fine in the latest image `Armbian_community_24.5.0-trunk.93_Orangepi3b_jammy_legacy_5.10.160_gnome_desktop.img.xz` 0 Quote Link to comment Share on other sites More sharing options...
vbk Posted March 22 Share Posted March 22 Hello forum, Hardware options are not working, this submenu is coming null for Orange Pi 3b. I tried the below images for Debian with 3 different fresh(Zero) SD Cards (Sandisk Ultra C10 HC I @16 and 32GB). I do not want to work with Ubuntu base. https://www.armbian.com/orangepi3b/ Armbian_community_24.5.0-trunk.250_Orangepi3b_bookworm_edge_6.7.10_minimal.img.xz Mar 21, 2024 Armbian_community_24.5.0-trunk.250_Orangepi3b_bookworm_vendor_6.1.43_minimal.img.xz Mar 21, 2024 is there anyone who has the solution or advice? Thank you. 0 Quote Link to comment Share on other sites More sharing options...
Protx Posted March 23 Share Posted March 23 @vbk My English is not the best. It seems like you can boot Armbian_community_24.5.0-trunk.250_Orangepi3b_bookworm_vendor_6.1.43_minimal.img.xz ? I made a post that I can't boot my homebuilt bookworm minimal with the vendor kernel. I was curious it my home built image was bad. So I downloaded the above mentioned image and burned it to a sd card, and I got exactly the same kernel panic!. (Kernel panic - not syncing: panic_on_set_idle set). Then I thought that it maybe was an issue with the u-boot I have flashed to spi. (I got another image on emmc) So I erased the spi, and booted from sd card again, it booted further, but got another kernel panic: sysfs: cannot create duplicate filename '/devices/virtual/tty/ttyBT0' and kobject_add_internal failed for ttyBT0 with -EEXIST, don't try to register things with the same name in the same directory. I have no idea what it is, but seems like Bluetooth is registering twice. If you can boot the vendor kernel image that my Orangepi3b board has some issues Or my powersupply(s). But the edge kernel images boots fine. Regards the hardware options/overlays, I do not think is built any overlays with the image and/or the overlay name is wrong. Check the overlay_prefix= in /boot/armbianEnv.txt. The overlay prefix name must match with the first name (before the -)of your overlays in: /boot/dtb/rockchip/overlay/ If your overlays has name like this: rk356x-i2c2-m1.dtbo. Then your overlay_prefix should be: overlay_prefix=rk356x But maybe it is none for the orangepi3b. What I did was downloading a xunlong orangepi3b image to an sd card, or you can loop mount it. Then copy out the overlays, use filezilla and sftp it over to your orangepi3b, place them in your overlay folder and edit armbianEnv.txt to the right overlay name. I have red that it should not work if it was not compiled with the kernel, but I use one overlay and it works. My overlays 1 Quote Link to comment Share on other sites More sharing options...
vbk Posted March 23 Share Posted March 23 @Protx, First of all, thank you for your time. I will try your offered way and inform you. 0 Quote Link to comment Share on other sites More sharing options...
Protx Posted March 23 Share Posted March 23 @vbk Can you verify that this image works on your orangepi3b? On 3/22/2024 at 5:36 AM, vbk said: Armbian_community_24.5.0-trunk.250_Orangepi3b_bookworm_vendor_6.1.43_minimal.img.xz Mar 21, 2024 0 Quote Link to comment Share on other sites More sharing options...
vbk Posted March 23 Share Posted March 23 sure, i will test it and revert you this night 0 Quote Link to comment Share on other sites More sharing options...
vbk Posted March 26 Share Posted March 26 Hi Protx, i tried this image with 3 different SDCard and nothing. It did not work, again. I am not sure how worked the first time. I ordered another OPI3B one, I think, it may be relevant to HW. I will inform you when I get the new board and test it 0 Quote Link to comment Share on other sites More sharing options...
Ruslan Ilin Posted March 29 Share Posted March 29 Hi, did you manage to enable UARTs on orange 3B? I tried to use .dtb and .dtbo from the official orange debian, but it's different kernel version and didn't succeed. 0 Quote Link to comment Share on other sites More sharing options...
Protx Posted March 30 Share Posted March 30 @vbk Ok. I have been testing several different images. I got some progress, I now got the bookworm-minimal-vendor-kernel to boot. Link to my post @Ruslan Ilin Compiled with xunlong orangepis 6.6 kernel dts sources. I dont know if it works. 2 orangepi3b images 1 Quote Link to comment Share on other sites More sharing options...
Ruslan Ilin Posted March 31 Share Posted March 31 (edited) @Protx oh it's cool that you managed to build it, I spend the last nights fighting with kernel panic😃 tnx! uart3 and uart9 work just perfect! Now I need to detach uart2 from debug console and enjoy 3 uarts )) Edited March 31 by Ruslan Ilin 0 Quote Link to comment Share on other sites More sharing options...
vbk Posted April 1 Share Posted April 1 (edited) Quote Ok. I have been testing several different images. I got some progress, I now got the bookworm-minimal-vendor-kernel to boot. Link to my post @Protx Nice Job, I will test these in detail and get back to you. Edited April 1 by vbk 0 Quote Link to comment Share on other sites More sharing options...
