Should uefi-x86 / uefi-arm64 family set UEFI_GRUB_TERMINAL to "gfxterm vga_text console serial" rather than "gfxterm" by default ?
Hi community,
Context
I build my own custom Arabian image on arm 32bit (prod), and experimenting running the following armbian image configuration on Qemu with console/serial only support for  uefi-x86 and uefi-arm64 boards to speed up development/test.
BOARD="refi-x86"
BUILD_DESKTOP="no"
BUILD_MINIMAL="yes"
CONSOLE_AUTOLOGIN="no"
REVISION="23.11.2"
Problem
I stumble upon something odd: both "uefi-*" boards are configured to only run GRUB in gfxterm mode ONLY.
BOARD: uefi-86        -> BOARDFAMILY="uefi-x86".        -> UEFI_GRUB_TERMINAL="gfxterm" [0]
BOARD: uefi-arm64 -> BOARDFAMILY="uefi-arm64".  -> UEFI_GRUB_TERMINAL="gfxterm" [1]
[0] https://github.com/armbian/build/blob/2afd8fe9bb8aca33a2a3913e931fc43c43c8e309/config/sources/families/uefi-x86.conf#L11
[1] https://github.com/armbian/build/blob/2afd8fe9bb8aca33a2a3913e931fc43c43c8e309/config/sources/families/uefi-arm64.conf#L10
Image built from these boards should be runnable as CLI image (no gui) or Desktop image (gui).
However, when running with
qemu -nographic ...
 these image can't boot up to a working shell and produce an error: "GRUB: gfxterm is not supported"
Proposed change
I would like to submit a patch to change UEFI_GRUB_TERMINAL to "gfxterm vga_text console serial" to cover a large set of virtualised hardware configurations.
1. Is this something you guys are interested in ?
2. Does this fix need more than the proposed change to achieve the desired objective ?
Thanks
Edited by David A
  • David A changed the title to Should uefi-x86 / uefi-arm64 family set UEFI_GRUB_TERMINAL to "gfxterm vga_text console serial" rather than "gfxterm" by default ?
