CSC Armbian for RK322x TV box boards
jock
3 hours ago, Seth said:
@jock
been playing with the tylex boxes last night and forgot to unplug it. woke up with 2 dead boxes probably power surge from thunderstorm killed it last night. might try to fix it when i find the time or i might transplant ram and emmc to the scishion box. i gotta unpack my hot air station from storage and go yolo this weekend. the scishion box has a lot of potential though just need to upgrade nand to emmc and add more ram. your rk3318/3328 project is starting to appeal to me too. lots of things to try out. :D
Ah that's a shame!
Well some testing on the real hardware of the device tree overlay could be useful to support extra devices, since your TX3PRO board has some differences from the baseline that prevent some hardware to work properly... Well let me know if you recover the tylex boards!
Link to comment
Share on other sites
6 hours ago, Jonas Fabricio Kozamekinas said:
Hi there, i have a board with R29-MXQ-LP3 20210717 and after make sdcard with Multiools the board dont boot up only give a red light.
Any help to noob?
Well it's a way too short description of the problem to give any useful hint.
Try another sdcard and use a proper tool to write to sdcard (like Balena Etcher) 🤷‍♂️
Link to comment
Hello folks!
I might need your help here...
I have a board with a RK3228A chip. I followed the instructions but could never boot from the SD card directly.
I then flashed multitools on the card and it did boot. I created a backup, saved it, and then flashed the indicated ROM (on the original topic).
Now, it doesn't boot anymore, even with an SD card with multitools in it.
I tried the toothpick method, and it didn't work.
I then managed to get it into Mask ROM mode:
$ lsusb
Bus 003 Device 103: ID 2207:320b Fuzhou Rockchip Electronics Company RK3228/RK3229 in Mask ROM mode
I downloaded the rkdeveloptool and followed the instructions for flashing directly into the eMMC - or at least try to erase the flash and boot again on Multitools.
But when I run the db command, all I get is:
sudo ./rkdeveloptool db ./rk322x_loader_v1.10.256.bin
Downloading bootloader...
And it never gets past that.
Is there something I can do about it?
Link to comment
On 6/16/2022 at 3:54 PM, Zoli said:
Hello!
I would like to ask for help.
I have the following TV box:
MXQ-4k 5G
MXQ_RK3229
Wifi Chip: ESP8089-522014-P22G43
RK3229_MXQ_EMCP_V.4.0
Rockchip
4GB ram + 64GB storage
I want an SD card running Armbian for this box, but so far I haven't found a suitable Armbian image for this box.
From here I tried Armbian images: https://armbian.systemonachip.net/archive/rk322x-box/archive/
Do not write an image to the EMCP chip because it will be brick out of the box. So it stays in the box with the original firmware.
SD boot system may work, "Boot from sdcard" may be good.
These images work well when written to an SD card (starting from an SD card):
- Boot from SD card and works fine: Multitool (multitool.img)
- Starts and works well from SD card: LibreElec (LibreELEC-RK322x.arm-9.2-devel-20200427213119-b7186bc-rk3228a-mxq4kpro.img)
and this is also good (LibreELEC-RK322x.arm-9.2-devel-20220112105523-3ce5dd4-rk3228a-mxq4kpro.img)
Is there an Armbian that can boot from an SD card and work with it to install APT GET programs?
I would need an image file that can do this and work with my TV box.
I want to install Octoprint on linux to control a 3D printer via USB.
I would reach the box with a Wi-Fi connection. That would be the mission of the box.
Maybe this TV box is not suitable for this because there is no system for it.
The following may help something about my system.
  Reveal hidden contents
Multitool log: (dmesg.multitool.log)
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.194-rk322x (root@armbianbuild) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #47 SMP Thu Apr 9 17:37:46 UTC 2020
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Generic RK322x TV Box board
[    0.000000] cma: Reserved 128 MiB at 0x98000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 258560
[    0.000000] free_area_init_node: node 0, pgdat b1236b40, node_mem_map e76b9000
[    0.000000]   Normal zone: 2304 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 258560 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv65535.65535 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 14 pages/cpu @e7659000 s24856 r8192 d24296 u57344
[    0.000000] pcpu-alloc: s24856 r8192 d24296 u57344 alloc=14*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 256256
[    0.000000] Kernel command line: boot=PARTUUID=00628e24-01 root=PARTUUID=00628e24-02 rootwait console=ttyS2,115200 verbose=1 consoleblank=0
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 871700K/1034240K available (12820K kernel code, 875K rwdata, 3224K rodata, 796K init, 1219K bss, 31468K reserved, 131072K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xb0000000 - 0xf0000000   (1024 MB)
                   pkmap   : 0xafe00000 - 0xb0000000   (   2 MB)
                   modules : 0xaf000000 - 0xafe00000   (  14 MB)
                     .text : 0xb0008000 - 0xb0c8d53c   (12822 kB)
                     .init : 0xb10a1000 - 0xb1168000   ( 796 kB)
                     .data : 0xb1168000 - 0xb1242e94   ( 876 kB)
                      .bss : 0xb1244000 - 0xb1374ee4   (1220 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]     Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000024] Switching to timer-based delay loop, resolution 41ns
[    0.001760] Console: colour dummy device 80x30
[    0.001804] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001825] pid_max: default: 32768 minimum: 301
[    0.001976] Security Framework initialized
[    0.001992] Yama: becoming mindful.
[    0.002082] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002099] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003127] Initializing cgroup subsys io
[    0.003170] Initializing cgroup subsys memory
[    0.003221] Initializing cgroup subsys devices
[    0.003243] Initializing cgroup subsys freezer
[    0.003261] Initializing cgroup subsys net_cls
[    0.003279] Initializing cgroup subsys perf_event
[    0.003298] Initializing cgroup subsys net_prio
[    0.003332] Initializing cgroup subsys pids
[    0.003411] CPU: Testing write buffer coherency: ok
[    0.003471] ftrace: allocating 41720 entries in 123 pages
[    0.086889] /cpus/cpu@f00 missing clock-frequency property
[    0.086932] /cpus/cpu@f01 missing clock-frequency property
[    0.086951] /cpus/cpu@f02 missing clock-frequency property
[    0.086972] /cpus/cpu@f03 missing clock-frequency property
[    0.086986] CPU0: update cpu_capacity 430
[    0.086998] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.087100] Setting up static identity map for 0x60008280 - 0x600082d8
[    0.090503] CPU1: update cpu_capacity 430
[    0.090513] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.091797] CPU2: update cpu_capacity 430
[    0.091806] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.093063] CPU3: update cpu_capacity 430
[    0.093072] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.093236] Brought up 4 CPUs
[    0.093278] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.093287] CPU: All CPU(s) started in SVC mode.
[    0.095146] devtmpfs: initialized
[    0.113402] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.114017] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.114062] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.120812] xor: measuring software checksum speed
[    0.158888]    arm4regs  :  1011.000 MB/sec
[    0.198997]    8regs     :   705.000 MB/sec
[    0.239099]    32regs    :   684.000 MB/sec
[    0.279201]    neon      :  1018.000 MB/sec
[    0.279212] xor: using function: neon (1018.000 MB/sec)
[    0.279257] pinctrl core: initialized pinctrl subsystem
[    0.281074] NET: Registered protocol family 16
[    0.283509] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.295404] cpuidle: using governor ladder
[    0.307410] cpuidle: using governor menu
[    0.324343] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[    0.324515] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[    0.324663] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[    0.324824] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[    0.331182] console [pstore-1] enabled
[    0.331196] pstore: Registered ramoops as persistent store backend
[    0.331209] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0
[    0.334287] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.334312] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.432570] raid6: int32x1  gen()   133 MB/s
[    0.500584] raid6: int32x1  xor()   131 MB/s
[    0.568809] raid6: int32x2  gen()   166 MB/s
[    0.637100] raid6: int32x2  xor()   137 MB/s
[    0.705242] raid6: int32x4  gen()   163 MB/s
[    0.773482] raid6: int32x4  xor()   137 MB/s
[    0.841655] raid6: int32x8  gen()   166 MB/s
[    0.909920] raid6: int32x8  xor()   113 MB/s
[    0.977906] raid6: neonx1   gen()   381 MB/s
[    1.046207] raid6: neonx1   xor()   290 MB/s
[    1.114410] raid6: neonx2   gen()   519 MB/s
[    1.182568] raid6: neonx2   xor()   376 MB/s
[    1.250841] raid6: neonx4   gen()   581 MB/s
[    1.318999] raid6: neonx4   xor()   400 MB/s
[    1.387270] raid6: neonx8   gen()   559 MB/s
[    1.455486] raid6: neonx8   xor()   391 MB/s
[    1.455499] raid6: using algorithm neonx4 gen() 581 MB/s
[    1.455510] raid6: .... xor() 400 MB/s, rmw enabled
[    1.455521] raid6: using intx1 recovery algorithm
[    1.456656] rockchip-pm rockchip-suspend: not set wakeup-config
[    1.456681] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    1.457065] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@0[0]'
[    1.457631] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@1[0]'
[    1.458335] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-regulator[0]' - status (0)
[    1.459029] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0)
[    1.459667] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[    1.460615] iommu: Adding device 20020000.vpu-service to group 0
[    1.460731] iommu: Adding device 20030000.rkvdec to group 1
[    1.460830] iommu: Adding device 20050000.vop to group 2
[    1.460925] iommu: Adding device 20070000.iep to group 3
[    1.461551] rk_iommu 20020800.iommu: can't get sclk
[    1.462295] rk_iommu 20030480.iommu: can't get sclk
[    1.462560] rk_iommu 20053f00.iommu: can't get sclk
[    1.462708] rk_iommu 20070800.iommu: can't get aclk
[    1.462728] rk_iommu 20070800.iommu: can't get hclk
[    1.462744] rk_iommu 20070800.iommu: can't get sclk
[    1.463723] SCSI subsystem initialized
[    1.464170] usbcore: registered new interface driver usbfs
[    1.464273] usbcore: registered new interface driver hub
[    1.464417] usbcore: registered new device driver usb
[    1.464658] media: Linux media interface: v0.10
[    1.464743] Linux video capture interface: v2.00
[    1.464968] pps_core: LinuxPPS API ver. 1 registered
[    1.464984] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.465026] PTP clock support registered
[    1.467212] Advanced Linux Sound Architecture Driver Initialized.
[    1.468477] Bluetooth: Core ver 2.21
[    1.468562] NET: Registered protocol family 31
[    1.468575] Bluetooth: HCI device and connection manager initialized
[    1.468598] Bluetooth: HCI socket layer initialized
[    1.468617] Bluetooth: L2CAP socket layer initialized
[    1.468681] Bluetooth: SCO socket layer initialized
[    1.469604] NetLabel: Initializing
[    1.469629] NetLabel:  domain hash size = 128
[    1.469639] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.469725] NetLabel:  unlabeled traffic allowed by default
[    1.470932] clocksource: Switched to clocksource arch_sys_counter
[    1.574247] NET: Registered protocol family 2
[    1.575382] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.575506] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[    1.575864] TCP: Hash tables configured (established 8192 bind 8192)
[    1.575983] UDP hash table entries: 512 (order: 2, 24576 bytes)
[    1.576056] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[    1.576448] NET: Registered protocol family 1
[    1.577328] RPC: Registered named UNIX socket transport module.
[    1.577358] RPC: Registered udp transport module.
[    1.577368] RPC: Registered tcp transport module.
[    1.577379] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.578417] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    1.581682] Initialise system trusted keyring
[    1.596629] VFS: Disk quotas dquot_6.6.0
[    1.596973] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.599977] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.603727] NFS: Registering the id_resolver key type
[    1.603823] Key type id_resolver registered
[    1.603837] Key type id_legacy registered
[    1.603874] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.603973] ntfs: driver 2.1.32 [Flags: R/W].
[    1.604934] JFS: nTxBlock = 7834, nTxLock = 62673
[    1.617945] SGI XFS with security attributes, no debug enabled
[    1.627919] NET: Registered protocol family 38
[    1.627985] Key type asymmetric registered
[    1.628008] Asymmetric key parser 'x509' registered
[    1.628469] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.628802] io scheduler noop registered
[    1.628838] io scheduler deadline registered
[    1.628933] io scheduler cfq registered (default)
[    1.632620] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator
[    1.638207] rk-vcodec 20020000.vpu-service: no regulator for vcodec
[    1.638789] rk-vcodec 20020000.vpu-service: probe device
[    1.639398] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled
[    1.640965] rk-vcodec 20020000.vpu-service: could not find power_model node
[    1.640998] rk-vcodec 20020000.vpu-service: init success
[    1.641393] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry
[    1.645956] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330
[    1.645991] dma-pl330 110f0000.pdma:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.647339] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    1.647857] pwm-regulator vdd-arm-regulator: GPIO lookup for consumer enable
[    1.647879] pwm-regulator vdd-arm-regulator: using device tree for GPIO lookup
[    1.647899] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-arm-regulator[0]'
[    1.647913] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-arm-regulator[0]'
[    1.647927] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup
[    1.647942] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed
[    1.648694] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable
[    1.648719] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup
[    1.648736] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]'
[    1.648751] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]'
[    1.648764] pwm-regulator vdd-log-regulator: using lookup tables for GPIO lookup
[    1.648778] pwm-regulator vdd-log-regulator: lookup for GPIO enable failed
[    1.649917] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.650870] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A
[    2.682824] console [ttyS2] enabled
[    2.688385] [drm] Initialized drm 1.1.0 20060810
[    2.695698] [drm] Rockchip DRM driver version: v1.0.1
[    2.701101] rockchip-drm display-subsystem: devfreq is not set
[    2.707861] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d111b0)
[    2.715699] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports
[    2.722382] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.730259] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy)
[    2.741523] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d09708)
[    2.749036] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.755682] [drm] No driver support for vblank timestamp query.
[    2.761780] rockchip-drm display-subsystem: failed to parse display resources
[    3.392773] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    3.393479] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    3.393487] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[    3.393495] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[    3.393501] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[    3.393509] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[    3.393516] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[    3.393522] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[    3.393529] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[    3.393536] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[    3.393543] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[    3.393549] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[    3.393556] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[    3.393563] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[    3.393569] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[    3.393577] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[    3.473466] Console: switching to colour frame buffer device 240x67
[    3.641271] rockchip-drm display-subsystem: fb0:  frame buffer device
[    3.667964] brd: module loaded
[    3.686306] loop: module loaded
[    3.689640] lkdtm: No crash points registered, enable through debugfs
[    3.699750] libphy: Fixed MDIO Bus: probed
[    3.703969] tun: Universal TUN/TAP device driver, 1.6
[    3.709063] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    3.715845] CAN device driver interface
[    3.721662] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output).
[    3.728932] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30).
[    3.734632] rk_gmac-dwmac 30200000.ethernet: RX delay(0x10).
[    3.740378] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes).
[    3.746876] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed
[    3.758949] rk_gmac-dwmac 30200000.ethernet: init for RMII
[    3.799183] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    3.804296]  Ring mode enabled
[    3.807386]  DMA HW capability register supported
[    3.811963]  Normal descriptors
[    3.815315]  RX Checksum Offload Engine supported (type 2)
[    3.820816]  TX Checksum insertion supported
[    3.825104]  Wake-Up On Lan supported
[    3.828941] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: 9e:69:55:b9:b8:30
[    3.837423] eth%d: device MAC address 9e:69:55:b9:b8:30
[    3.842676]  Enable RX Mitigation via HW Watchdog Timer
[    3.848249] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@30200000[0]' - status (0)
[    3.870593] libphy: stmmac: probed
[    3.874310] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active
[    3.880866] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01)
[    3.886737] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02)
[    3.892601] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03)
[    3.898477] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04)
[    3.904341] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05)
[    3.910204] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06)
[    3.916068] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07)
[    3.921925] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08)
[    3.927800] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09)
[    3.933659] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a)
[    3.939600] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b)
[    3.945562] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c)
[    3.951503] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d)
[    3.957445] eth%d: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e)
[    3.963394] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f)
[    3.969334] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10)
[    3.975276] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11)
[    3.981230] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12)
[    3.987171] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13)
[    3.993112] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14)
[    3.999095] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15)
[    4.005059] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16)
[    4.011024] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17)
[    4.016979] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18)
[    4.022940] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19)
[    4.028903] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a)
[    4.034851] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b)
[    4.040800] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c)
[    4.046758] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d)
[    4.052709] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e)
[    4.058660] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f)
[    4.066666] PPP generic driver version 2.4.2
[    4.071656] Atmel at76x USB Wireless LAN Driver 0.17 loading
[    4.077567] usbcore: registered new interface driver at76c50x-usb
[    4.083884] usbcore: registered new interface driver rtl8187
[    4.089716] usbcore: registered new interface driver rndis_wlan
[    4.095821] usbcore: registered new interface driver zd1201
[    4.102073] usbcore: registered new interface driver rt2800usb
[    4.108235] Rockchip WiFi SYS interface (V1.00) ...
[    4.113349] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    4.120917] usbcore: registered new interface driver pegasus
[    4.126734] usbcore: registered new interface driver rtl8150
[    4.132530] usbcore: registered new interface driver r8152
[    4.138171] usbcore: registered new interface driver asix
[    4.143696] usbcore: registered new interface driver ax88179_178a
[    4.149922] usbcore: registered new interface driver cdc_ether
[    4.155901] usbcore: registered new interface driver dm9601
[    4.161626] usbcore: registered new interface driver smsc75xx
[    4.167553] usbcore: registered new interface driver smsc95xx
[    4.173430] usbcore: registered new interface driver net1080
[    4.179207] usbcore: registered new interface driver rndis_host
[    4.185253] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    4.192860] usbcore: registered new interface driver cdc_ncm
[    4.198645] usbcore: registered new interface driver cdc_mbim
[    4.205158] 30040000.usb supply vusb_d not found, using dummy regulator
[    4.211982] 30040000.usb supply vusb_a not found, using dummy regulator
[    4.232398] dwc2 30040000.usb: DWC OTG Controller
[    4.237303] dwc2 30040000.usb: new USB bus registered, assigned bus number 1
[    4.244483] dwc2 30040000.usb: irq 49, io mem 0x30040000
[    4.250277] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.257125] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.264380] usb usb1: Product: DWC OTG Controller
[    4.269111] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg
[    4.275402] usb usb1: SerialNumber: 30040000.usb
[    4.281459] hub 1-0:1.0: USB hub found
[    4.285371] hub 1-0:1.0: 1 port detected
[    4.291597] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.298207] ehci-platform: EHCI generic platform driver
[    4.306312] ehci-platform 30080000.usb: EHCI Host Controller
[    4.312618] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2
[    4.320984] ehci-platform 30080000.usb: irq 50, io mem 0x30080000
[    4.339032] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00
[    4.345670] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    4.352529] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.359777] usb usb2: Product: EHCI Host Controller
[    4.364682] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    4.370801] usb usb2: SerialNumber: 30080000.usb
[    4.376684] hub 2-0:1.0: USB hub found
[    4.380591] hub 2-0:1.0: 1 port detected
[    4.387806] ehci-platform 300c0000.usb: EHCI Host Controller
[    4.394096] ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3
[    4.402441] ehci-platform 300c0000.usb: irq 52, io mem 0x300c0000
[    4.419020] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00
[    4.425643] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    4.432499] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.439755] usb usb3: Product: EHCI Host Controller
[    4.444659] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    4.450777] usb usb3: SerialNumber: 300c0000.usb
[    4.456718] hub 3-0:1.0: USB hub found
[    4.460606] hub 3-0:1.0: 1 port detected
[    4.467820] ehci-platform 30100000.usb: EHCI Host Controller
[    4.474120] ehci-platform 30100000.usb: new USB bus registered, assigned bus number 4
[    4.482471] ehci-platform 30100000.usb: irq 54, io mem 0x30100000
[    4.499021] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00
[    4.505618] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    4.512476] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.519728] usb usb4: Product: EHCI Host Controller
[    4.524631] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    4.530749] usb usb4: SerialNumber: 30100000.usb
[    4.536704] hub 4-0:1.0: USB hub found
[    4.540615] hub 4-0:1.0: 1 port detected
[    4.545597] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.551895] ohci-platform: OHCI generic platform driver
[    4.557800] ohci-platform 300a0000.usb: Generic Platform OHCI controller
[    4.566210] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5
[    4.574562] ohci-platform 300a0000.usb: irq 51, io mem 0x300a0000
[    4.639360] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    4.646229] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.653496] usb usb5: Product: Generic Platform OHCI controller
[    4.659453] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    4.665577] usb usb5: SerialNumber: 300a0000.usb
[    4.671750] hub 5-0:1.0: USB hub found
[    4.675670] hub 5-0:1.0: 1 port detected
[    4.680808] ohci-platform 300e0000.usb: Generic Platform OHCI controller
[    4.688126] ohci-platform 300e0000.usb: new USB bus registered, assigned bus number 6
[    4.696425] ohci-platform 300e0000.usb: irq 53, io mem 0x300e0000
[    4.759399] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    4.766263] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.773547] usb usb6: Product: Generic Platform OHCI controller
[    4.779511] usb usb6: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    4.785636] usb usb6: SerialNumber: 300e0000.usb
[    4.792458] hub 6-0:1.0: USB hub found
[    4.796394] hub 6-0:1.0: 1 port detected
[    4.801503] ohci-platform 30120000.usb: Generic Platform OHCI controller
[    4.808842] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7
[    4.817149] ohci-platform 30120000.usb: irq 55, io mem 0x30120000
[    4.883314] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    4.890175] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.897433] usb usb7: Product: Generic Platform OHCI controller
[    4.903400] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    4.909527] usb usb7: SerialNumber: 30120000.usb
[    4.915933] hub 7-0:1.0: USB hub found
[    4.919847] hub 7-0:1.0: 1 port detected
[    4.925080] usbcore: registered new interface driver cdc_acm
[    4.930813] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    4.939050] usbcore: registered new interface driver cdc_wdm
[    4.945068] usbcore: registered new interface driver usb-storage
[    4.951376] usbcore: registered new interface driver usbserial
[    4.957364] usbcore: registered new interface driver usbserial_generic
[    4.964003] usbserial: USB Serial support registered for generic
[    4.970171] usbcore: registered new interface driver keyspan
[    4.975922] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    4.983854] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    4.991277] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    4.998675] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    5.006158] usbcore: registered new interface driver option
[    5.011842] usbserial: USB Serial support registered for GSM modem (1-port)
[    5.019627] usbcore: registered new interface driver oti6858
[    5.025668] usbserial: USB Serial support registered for oti6858
[    5.031883] usbcore: registered new interface driver qcserial
[    5.037746] usbserial: USB Serial support registered for Qualcomm USB modem
[    5.044921] usbcore: registered new interface driver sierra
[    5.050592] usbserial: USB Serial support registered for Sierra USB modem
[    5.058736] usbcore: registered new interface driver iforce
[    5.064609] usbcore: registered new interface driver xpad
[    5.070368] usbcore: registered new interface driver usbtouchscreen
[    5.078071] i2c /dev entries driver
[    5.085152] usbcore: registered new interface driver uvcvideo
[    5.090980] USB Video Class driver (1.1.1)
[    5.097522] Boot mode: normal
[    5.102335] rockchip-thermal 11150000.tsadc: tsadc is probed successfully!
[    5.111409] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    5.120601] Bluetooth: Virtual HCI driver ver 1.5
[    5.126103] Bluetooth: HCI UART driver ver 2.3
[    5.130647] Bluetooth: HCI UART protocol H4 registered
[    5.135823] Bluetooth: HCI UART protocol LL registered
[    5.141035] Bluetooth: HCI UART protocol ATH3K registered
[    5.146474] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    5.153349] Bluetooth: HCI UART protocol BCM registered
[    5.158888] usbcore: registered new interface driver bfusb
[    5.164650] usbcore: registered new interface driver btusb
[    5.170251] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    5.176781] cpu cpu0: leakage=4
[    5.180055] cpu cpu0: leakage-volt-sel=0
[    5.184481] cpu cpu0: Failed to get pvtm
[    5.190441] cpu cpu0: avs=0
[    5.193486] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    5.200517] cpu cpu0: failed to read out thermal zone (-22)
[    5.207167] cpu cpu0: failed to find power_model node
[    5.213405] Synopsys Designware Multimedia Card Interface Driver
[    5.220547] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode.
[    5.228076] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller.
[    5.234941] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a
[    5.241020] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo
[    5.250965] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found
[    5.257183] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found
[    5.263493] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer cd
[    5.263509] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    5.263569] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/dwmmc@30000000[0]' - status (0)
[    5.263641] gpio-49 (cd): gpiod_set_debounce: missing set() or set_debounce() operations
[    5.263656] dwmmc_rockchip 30000000.dwmmc: Got CD GPIO
[    5.268837] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer wp
[    5.268851] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    5.268866] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30000000[0]'
[    5.268876] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30000000[0]'
[    5.268886] dwmmc_rockchip 30000000.dwmmc: using lookup tables for GPIO lookup
[    5.268902] dwmmc_rockchip 30000000.dwmmc: lookup for GPIO wp failed
[    5.281963] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    5.295005] usb 7-1: new low-speed USB device number 2 using ohci-platform
[    5.304461] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized
[    5.311091] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available
[    5.320585] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode.
[    5.328195] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller.
[    5.335106] dwmmc_rockchip 30010000.dwmmc: Version ID is 270a
[    5.341060] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo
[    5.351009] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found
[    5.357265] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found
[    5.363791] dwmmc_rockchip 30010000.dwmmc: GPIO lookup for consumer wp
[    5.363816] dwmmc_rockchip 30010000.dwmmc: using device tree for GPIO lookup
[    5.363838] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30010000[0]'
[    5.363853] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30010000[0]'
[    5.363867] dwmmc_rockchip 30010000.dwmmc: using lookup tables for GPIO lookup
[    5.363883] dwmmc_rockchip 30010000.dwmmc: lookup for GPIO wp failed
[    5.377210] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2)
[    5.395838] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    5.405804] dwmmc_rockchip 30010000.dwmmc: 1 slots initialized
[    5.412122] dwmmc_rockchip 30020000.dwmmc: IDMAC supports 32-bit address mode.
[    5.419727] dwmmc_rockchip 30020000.dwmmc: Using internal DMA controller.
[    5.419817] mmc0: new high speed SDHC card at address 1234
[    5.421092] mmcblk0: mmc0:1234 SA04G 3.71 GiB
[    5.423268]  mmcblk0: p1 p2
[    5.439451] dwmmc_rockchip 30020000.dwmmc: Version ID is 270a
[    5.445400] dwmmc_rockchip 30020000.dwmmc: DW MMC controller at irq 47,32 bit host data width,256 deep fifo
[    5.455286] dwmmc_rockchip 30020000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    5.459010] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 300000Hz, actual 244140HZ div = 2)
[    5.472727] dwmmc_rockchip 30020000.dwmmc: No vmmc regulator found
[    5.478957] dwmmc_rockchip 30020000.dwmmc: No vqmmc regulator found
[    5.485284] dwmmc_rockchip 30020000.dwmmc: GPIO lookup for consumer wp
[    5.485307] dwmmc_rockchip 30020000.dwmmc: using device tree for GPIO lookup
[    5.485331] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30020000[0]'
[    5.485349] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30020000[0]'
[    5.485363] dwmmc_rockchip 30020000.dwmmc: using lookup tables for GPIO lookup
[    5.485380] dwmmc_rockchip 30020000.dwmmc: lookup for GPIO wp failed
[    5.498502] mmc_host mmc2: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3)
[    5.511141] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 200000Hz, actual 162760HZ div = 3)
[    5.520632] dwmmc_rockchip 30020000.dwmmc: 1 slots initialized
[    5.526038] usb 7-1: New USB device found, idVendor=03f0, idProduct=0024
[    5.526046] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.526054] usb 7-1: Product: HP Basic USB Keyboard
[    5.526059] usb 7-1: Manufacturer: CHICONY
[    5.550676] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/mmc[0]' - status (0)
[    5.551355] ledtrig-cpu: registered to indicate activity on CPUs
[    5.557777] hidraw: raw HID events driver (C) Jiri Kosina
[    5.573237] input: CHICONY HP Basic USB Keyboard as /devices/platform/30120000.usb/usb7/7-1/7-1:1.0/0003:03F0:0024.0001/input/input0
[    5.576133] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 100000Hz, actual 97656HZ div = 5)
[    5.609542] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    5.621362] mmc2: new high speed MMC card at address 0001
[    5.628051] mmcblk2: mmc2:0001 V10008 7.05 GiB
[    5.633366] mmcblk2boot0: mmc2:0001 V10008 partition 1 4.00 MiB
[    5.640042] mmcblk2boot1: mmc2:0001 V10008 partition 2 4.00 MiB
[    5.646697] mmcblk2rpmb: mmc2:0001 V10008 partition 3 4.00 MiB
[    5.654016] hid-generic 0003:03F0:0024.0001: input,hidraw0: USB HID v1.10 Keyboard [CHICONY HP Basic USB Keyboard] on usb-30120000.usb-1/input0
[    5.667636] usbcore: registered new interface driver usbhid
[    5.673344] usbhid: USB HID core driver
[    5.677938] ashmem: initialized
[    5.683655] rknandbase v1.2 2018-05-08
[    5.687982] rknand 30030000.nandc: rknand_probe clk rate = 150000000
[    5.694734] ftl_init fffffffe
[    5.697748] rk_ftl_init fail
[    5.702067] usbcore: registered new interface driver snd-usb-audio
[    5.708520] usbcore: registered new interface driver snd-ua101
[    5.714545] usbcore: registered new interface driver snd-usb-caiaq
[    5.720898] usbcore: registered new interface driver snd-usb-6fire
[    5.727211] usbcore: registered new interface driver snd-usb-hiface
[    5.733622] usbcore: registered new interface driver snd-bcd2000
[    5.739762] usbcore: registered new interface driver snd_usb_pod
[    5.745953] usbcore: registered new interface driver snd_usb_podhd
[    5.752275] usbcore: registered new interface driver snd_usb_toneport
[    5.758843] usbcore: registered new interface driver snd_usb_variax
[    5.771372] u32 classifier
[    5.774112]     input device check on
[    5.777835]     Actions configured
[    5.781290] Netfilter messages via NETLINK v0.30.
[    5.786054] nfnl_acct: registering with nfnetlink.
[    5.791002] nf_conntrack version 0.5.0 (15668 buckets, 62672 max)
[    5.798186] Initializing XFRM netlink socket
[    5.803607] NET: Registered protocol family 10
[    5.809907] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    5.815834] sit: IPv6 over IPv4 tunneling driver
[    5.821630] NET: Registered protocol family 17
[    5.826224] NET: Registered protocol family 15
[    5.830797] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    5.843508] Bridge firewalling registered
[    5.847562] can: controller area network core (rev 20120528 abi 9)
[    5.853861] NET: Registered protocol family 29
[    5.858354] can: raw protocol (rev 20120528)
[    5.862654] can: broadcast manager protocol (rev 20120528 t)
[    5.868350] can: netlink gateway (rev 20130117) max_hops=1
[    5.874573] Bluetooth: RFCOMM TTY layer initialized
[    5.879539] Bluetooth: RFCOMM socket layer initialized
[    5.884749] Bluetooth: RFCOMM ver 1.11
[    5.888554] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    5.894505] Bluetooth: HIDP socket layer initialized
[    5.899697] 8021q: 802.1Q VLAN Support v1.8
[    5.903973] lib80211: common routines for IEEE802.11 drivers
[    5.909662] lib80211_crypt: registered algorithm 'NULL'
[    5.909684] lib80211_crypt: registered algorithm 'WEP'
[    5.909699] lib80211_crypt: registered algorithm 'CCMP'
[    5.909713] lib80211_crypt: registered algorithm 'TKIP'
[    5.909730] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    5.914881] [BT_RFKILL]: Enter rfkill_rk_init
[    5.919610] Key type dns_resolver registered
[    5.924534] flash vendor_init_thread!
[    5.924640] Error: Driver 'sc031gs' is already registered, aborting...
[    5.925291] Registering SWP/SWPB emulation handler
[    5.926718] registered taskstats version 1
[    5.926736] Loading compiled-in X.509 certificates
[    5.930355] Btrfs loaded
[    5.932156] rga2: Driver loaded successfully ver:4.01
[    5.932458] rga2: Module initialized.
[    5.932499] pvtm list NULL
[    5.934438] rk-vcodec 20030000.rkvdec: leakage=4
[    5.934499] rk-vcodec 20030000.rkvdec: leakage-volt-sel=0
[    5.934664] rk-vcodec 20030000.rkvdec: Failed to get pvtm
[    5.935496] rk-vcodec 20030000.rkvdec: avs=0
[    5.935970] rk-vcodec 20030000.rkvdec: probe device
[    5.936773] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled
[    5.939173] rk-vcodec 20030000.rkvdec: init success
[    5.940951] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]'
[    5.940960] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]'
[    5.944674] asoc-simple-card hdmi-sound: i2s-hifi <-> 100c0000.i2s0 mapping ok
[    5.947796] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]'
[    5.947819] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]'
[    5.949410] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok
[    5.952860] hctosys: unable to open rtc device (rtc0)
[    5.959298] vendor storage:20190527 ret = 0
[    5.969303] ALSA device list:
[    5.969316]   #0: DW-I2S-HDMI
[    5.969319]   #1: SPDIF
[    6.031506] flash vendor storage:20170308 ret = -1
[    6.036749] ttyS2 - failed to request DMA, use interrupt mode
[    6.051091] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
[    6.058639] squashfs: SQUASHFS error: unable to read xattr id index table
[    6.070175] VFS: Mounted root (squashfs filesystem) readonly on device 179:2.
[    6.082126] devtmpfs: mounted
[    6.086416] Freeing unused kernel memory: 796K
[    6.090945] This architecture does not have kernel memory protection.
[    7.398177] random: dropbear: uninitialized urandom read (32 bytes read, 30 bits of entropy available)
LibreElec's log: (kodi.log)
2022-06-06 07:57:38.599 T:3011133456  NOTICE: -----------------------------------------------------------------------
2022-06-06 07:57:38.599 T:3011133456  NOTICE: Starting Kodi (18.6 Git:rockchip_18.6-Leia). Platform: Linux ARM 32-bit
2022-06-06 07:57:38.599 T:3011133456  NOTICE: Using Release Kodi x32 build
2022-06-06 07:57:38.599 T:3011133456  NOTICE: Kodi compiled 2020-04-27 by GCC 8.3.0 for Linux ARM 32-bit version 4.4.194 (263362)
2022-06-06 07:57:38.600 T:3011133456  NOTICE: Running on LibreELEC (knaerzche): devel-20200427213119-b7186bc 9.2, kernel: Linux ARM 32-bit version 4.4.194
2022-06-06 07:57:38.600 T:3011133456  NOTICE: FFmpeg version/source: 4.0.4-Kodi
2022-06-06 07:57:38.600 T:3011133456  NOTICE: Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available
2022-06-06 07:57:38.600 T:3011133456  NOTICE: ARM Features: Neon enabled
2022-06-06 07:57:38.600 T:3011133456  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi/
2022-06-06 07:57:38.600 T:3011133456  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
2022-06-06 07:57:38.601 T:3011133456  NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
2022-06-06 07:57:38.601 T:3011133456  NOTICE: special://masterprofile/ is mapped to: /storage/.kodi/userdata
2022-06-06 07:57:38.601 T:3011133456  NOTICE: special://envhome/ is mapped to: /storage
2022-06-06 07:57:38.601 T:3011133456  NOTICE: special://home/ is mapped to: /storage/.kodi
2022-06-06 07:57:38.601 T:3011133456  NOTICE: special://temp/ is mapped to: /storage/.kodi/temp
2022-06-06 07:57:38.601 T:3011133456  NOTICE: special://logpath/ is mapped to: /storage/.kodi/temp
2022-06-06 07:57:38.601 T:3011133456  NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
2022-06-06 07:57:38.601 T:3011133456  NOTICE: Local hostname: LibreELEC
2022-06-06 07:57:38.601 T:3011133456  NOTICE: Log File is located: /storage/.kodi/temp/kodi.log
2022-06-06 07:57:38.601 T:3011133456  NOTICE: -----------------------------------------------------------------------
2022-06-06 07:57:38.627 T:3011133456    INFO: loading settings
2022-06-06 07:57:38.631 T:3011133456  NOTICE: special://profile/ is mapped to: special://masterprofile/
2022-06-06 07:57:38.689 T:3011133456   DEBUG: CSkinSettings: no <skinsettings> tag found
2022-06-06 07:57:38.692 T:3011133456  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
2022-06-06 07:57:38.692 T:3011133456  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
                                            <?xml version="1.0" encoding="utf-8" ?>
                                            <advancedsettings>
                                              <cputempcommand>/usr/bin/cputemp</cputempcommand>
                                              <gputempcommand>/usr/bin/gputemp</gputempcommand>
                                              <showexitbutton>false</showexitbutton>
                                              <remotedelay>1</remotedelay>
                                              <samba>
                                                <clienttimeout>30</clienttimeout>
                                              </samba>
                                            </advancedsettings>
2022-06-06 07:57:38.692 T:3011133456 WARNING: CSettingsManager: missing version attribute
2022-06-06 07:57:38.695 T:3011133456  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
2022-06-06 07:57:38.696 T:3011133456  NOTICE: Default Video Player: VideoPlayer
2022-06-06 07:57:38.696 T:3011133456  NOTICE: Default Audio Player: paplayer
2022-06-06 07:57:38.696 T:3011133456  NOTICE: Disabled debug logging due to GUI setting. Level 0.
2022-06-06 07:57:38.696 T:3011133456  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
2022-06-06 07:57:38.696 T:3011133456  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
2022-06-06 07:57:39.040 T:3011133456  NOTICE: PulseAudio: Server found running - will try to use Pulse
2022-06-06 07:57:39.256 T:3011133456  NOTICE: Running database version Addons27
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: audioencoder.kodi.builtin.aac v1.0.0 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: audioencoder.kodi.builtin.wma v1.0.0 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: game.controller.default v1.0.19 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: game.controller.snes v1.0.18 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: kodi.binary.global.audioengine v1.0.1 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: kodi.binary.global.filesystem v1.0.2 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: kodi.binary.global.general v1.0.3 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: kodi.binary.global.gui v5.12.0 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: kodi.binary.global.main v1.0.14 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: kodi.binary.global.network v1.0.0 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: kodi.binary.instance.audiodecoder v2.0.0 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.audioencoder v2.0.0 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.game v1.1.0 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.imagedecoder v2.0.0 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.inputstream v2.0.8 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.peripheral v1.3.7 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.pvr v5.10.3 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.screensaver v2.0.0 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.vfs v2.0.0 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.videocodec v1.0.1 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.visualization v2.0.1 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.resource v1.0.0 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: metadata.album.universal v3.1.8 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: metadata.artists.universal v4.3.8 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: metadata.common.allmusic.com v3.2.2 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: metadata.common.fanart.tv v3.6.4 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: metadata.common.imdb.com v3.2.6 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: metadata.common.musicbrainz.org v2.2.4 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: metadata.common.theaudiodb.com v2.0.3 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: metadata.common.themoviedb.org v3.2.18 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: metadata.local v1.0.0 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: metadata.themoviedb.org v5.2.6 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: metadata.tvshows.themoviedb.org v3.5.14 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: os.libreelec.tv v9.2 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: os.openelec.tv v9.2 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: peripheral.joystick v1.4.9 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: repository.kodi.game v1.0.0 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: repository.libreelec.tv v9.2.0 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: repository.xbmc.org v3.1.6 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: resource.images.weathericons.default v1.1.8 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: resource.language.en_gb v2.0.1 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: resource.language.hu_hu v9.0.18 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: resource.uisounds.kodi v1.0.0 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: screensaver.xbmc.builtin.black v1.0.33 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: screensaver.xbmc.builtin.dim v1.0.59 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: script.module.pil v1.1.7 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: script.module.pycryptodome v3.4.3 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: script.program.driverselect v0.1.6 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: service.libreelec.settings v9.0.0 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: service.system.docker v9.2.0.127 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: skin.estuary v2.0.27 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: webinterface.default v18.x-2.4.6 installed
2022-06-06 07:57:39.861 T:3011133456  NOTICE: ADDON: xbmc.addon v18.6.0 installed
2022-06-06 07:57:39.861 T:3011133456  NOTICE: ADDON: xbmc.core v0.1.0 installed
2022-06-06 07:57:39.861 T:3011133456  NOTICE: ADDON: xbmc.gui v5.14.0 installed
2022-06-06 07:57:39.861 T:3011133456  NOTICE: ADDON: xbmc.json v10.3.0 installed
2022-06-06 07:57:39.861 T:3011133456  NOTICE: ADDON: xbmc.metadata v2.1.0 installed
2022-06-06 07:57:39.861 T:3011133456  NOTICE: ADDON: xbmc.python v2.26.0 installed
2022-06-06 07:57:39.861 T:3011133456  NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
2022-06-06 07:57:39.954 T:3011133456   ERROR: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2022-06-06 07:57:40.936 T:2988422016 WARNING: Pulseaudio module module-allow-passthrough not loaded - opening PT devices might fail
2022-06-06 07:57:40.939 T:2988422016  NOTICE: Found 2 Lists of Devices
2022-06-06 07:57:40.939 T:2988422016  NOTICE: Enumerated ALSA devices:
2022-06-06 07:57:40.939 T:2988422016  NOTICE:     Device 1
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_deviceName      : @
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_displayName     : Default (ROCKCHIP,RK3229 Analog)
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_displayNameExtra:
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_channels        : FL, FR
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_sampleRates     : 8000,16000,32000,48000,64000,96000
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_dataFormats     : AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_streamTypes     : No passthrough capabilities
2022-06-06 07:57:40.940 T:2988422016  NOTICE:     Device 2
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_deviceName      : sysdefault:CARD=ROCKCHIPRK3229
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_displayName     : ROCKCHIP,RK3229
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_displayNameExtra: Analog
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_channels        : FL, FR
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_sampleRates     : 8000,16000,32000,48000,64000,96000
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_dataFormats     : AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_streamTypes     : No passthrough capabilities
2022-06-06 07:57:40.941 T:2988422016  NOTICE:     Device 3
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_deviceName      : sysdefault:CARD=HDMI
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_displayName     : HDMI
2022-06-06 07:57:40.942 T:2988422016  NOTICE:         m_sampleRates     : 32000,44100,48000
2022-06-06 07:57:40.942 T:2988422016  NOTICE:         m_dataFormats     : AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2022-06-06 07:57:40.942 T:2988422016  NOTICE:         m_streamTypes     : No passthrough capabilities
2022-06-06 07:57:40.942 T:2988422016  NOTICE:     Device 4
2022-06-06 07:57:40.942 T:2988422016  NOTICE:         m_deviceName      : hdmi:CARD=HDMI,DEV=0
2022-06-06 07:57:40.942 T:2988422016  NOTICE:         m_displayName     : HDMI
2022-06-06 07:57:40.942 T:2988422016  NOTICE:         m_displayNameExtra: VES 43FHD_LCD_TV on HDMI
2022-06-06 07:57:40.942 T:2988422016  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_channels        : FL, FR
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_sampleRates     : 32000,44100,48000
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_dataFormats     : AE_FMT_RAW,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_MA,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
2022-06-06 07:57:40.943 T:2988422016  NOTICE:     Device 5
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_deviceName      : sysdefault:CARD=ROCKCHIPSPDIF
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_displayName     : ROCKCHIP,SPDIF
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_displayNameExtra: Analog
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_sampleRates     : 32000,44100,48000,96000,192000
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_dataFormats     : AE_FMT_S24NE4,AE_FMT_S16NE,AE_FMT_S16LE
2022-06-06 07:57:40.944 T:2988422016  NOTICE:         m_streamTypes     : No passthrough capabilities
2022-06-06 07:57:40.944 T:2988422016  NOTICE: Enumerated PULSE devices:
2022-06-06 07:57:40.944 T:2988422016  NOTICE:     Device 1
2022-06-06 07:57:40.944 T:2988422016  NOTICE:         m_deviceName      : Default
2022-06-06 07:57:40.944 T:2988422016  NOTICE:         m_displayName     : Default
2022-06-06 07:57:40.944 T:2988422016  NOTICE:         m_displayNameExtra: Bluetooth Audio (PULSEAUDIO)
2022-06-06 07:57:40.944 T:2988422016  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2022-06-06 07:57:40.944 T:2988422016  NOTICE:         m_channels        : FL, FR
2022-06-06 07:57:40.944 T:2988422016  NOTICE:         m_sampleRates     : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
2022-06-06 07:57:40.944 T:2988422016  NOTICE:         m_dataFormats     : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
2022-06-06 07:57:42.066 T:3011133456 WARNING: CDRMUtils::FindPlane - could not find plane
2022-06-06 07:57:42.073 T:3011133456  NOTICE: Found resolution 1920x1080 with 1920x1080 @ 60.000000 Hz
2022-06-06 07:57:42.073 T:3011133456  NOTICE: Found resolution 1920x1080 with 1920x1080i @ 60.000000 Hz
2022-06-06 07:57:42.073 T:3011133456  NOTICE: Found resolution 1920x1080 with 1920x1080 @ 50.000000 Hz
2022-06-06 07:57:42.074 T:3011133456  NOTICE: Found resolution 1920x1080 with 1920x1080i @ 50.000000 Hz
2022-06-06 07:57:42.074 T:3011133456  NOTICE: Found resolution 1920x1080 with 1920x1080i @ 48.000000 Hz
2022-06-06 07:57:42.074 T:3011133456  NOTICE: Found resolution 1920x1080 with 1920x1080 @ 30.000000 Hz
2022-06-06 07:57:42.074 T:3011133456  NOTICE: Found resolution 1920x1080 with 1920x1080 @ 25.000000 Hz
2022-06-06 07:57:42.075 T:3011133456  NOTICE: Found resolution 1920x1080 with 1920x1080 @ 24.000000 Hz
2022-06-06 07:57:42.075 T:3011133456  NOTICE: Found resolution 1600x1200 with 1600x1200 @ 60.000000 Hz
2022-06-06 07:57:42.075 T:3011133456  NOTICE: Found resolution 1680x1050 with 1680x1050 @ 60.000000 Hz
2022-06-06 07:57:42.075 T:3011133456  NOTICE: Found resolution 1400x1050 with 1400x1050 @ 60.000000 Hz
2022-06-06 07:57:42.076 T:3011133456  NOTICE: Found resolution 1280x1024 with 1280x1024 @ 60.000000 Hz
2022-06-06 07:57:42.076 T:3011133456  NOTICE: Found resolution 1440x900 with 1440x900 @ 60.000000 Hz
2022-06-06 07:57:42.076 T:3011133456  NOTICE: Found resolution 1280x960 with 1280x960 @ 60.000000 Hz
2022-06-06 07:57:42.076 T:3011133456  NOTICE: Found resolution 1280x800 with 1280x800 @ 60.000000 Hz
2022-06-06 07:57:42.077 T:3011133456  NOTICE: Found resolution 1280x720 with 1280x720 @ 60.000000 Hz
2022-06-06 07:57:42.077 T:3011133456  NOTICE: Found resolution 1280x720 with 1280x720 @ 50.000000 Hz
2022-06-06 07:57:42.077 T:3011133456  NOTICE: Found resolution 1024x768 with 1024x768 @ 60.000000 Hz
2022-06-06 07:57:42.077 T:3011133456  NOTICE: Found resolution 800x600 with 800x600 @ 60.000000 Hz
2022-06-06 07:57:42.078 T:3011133456  NOTICE: Found resolution 720x576 with 720x576 @ 50.000000 Hz
2022-06-06 07:57:42.078 T:3011133456  NOTICE: Found resolution 720x576 with 720x576i @ 50.000000 Hz
2022-06-06 07:57:42.078 T:3011133456  NOTICE: Found resolution 720x480 with 720x480 @ 60.000000 Hz
2022-06-06 07:57:42.078 T:3011133456  NOTICE: Found resolution 720x480 with 720x480i @ 60.000000 Hz
2022-06-06 07:57:42.079 T:3011133456  NOTICE: Found resolution 640x480 with 640x480 @ 60.000000 Hz
2022-06-06 07:57:42.084 T:3011133456  NOTICE: EGL_VERSION = 1.4 Linux-r7p0-00rel0
2022-06-06 07:57:42.084 T:3011133456  NOTICE: EGL_VENDOR = ARM
2022-06-06 07:57:42.084 T:3011133456  NOTICE: EGL_EXTENSIONS = EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_EXT_image_dma_buf_import EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_KHR_lock_surface EGL_KHR_lock_surface2 EGL_EXT_create_context_robustness EGL_ANDROID_blob_cache EGL_KHR_create_context EGL_KHR_partial_update EGL_KHR_create_context_no_error
2022-06-06 07:57:42.084 T:3011133456  NOTICE: EGL_CLIENT_EXTENSIONS = EGL_EXT_client_extensions EGL_EXT_platform_base EGL_KHR_platform_gbm
2022-06-06 07:57:42.090 T:3011133456  NOTICE: Checking resolution 25
2022-06-06 07:57:42.318 T:3011133456 WARNING: CGBMUtils::DestroySurface - surface already destroyed
2022-06-06 07:57:42.785 T:3011133456  NOTICE: GL_VENDOR = ARM
2022-06-06 07:57:42.785 T:3011133456  NOTICE: GL_RENDERER = Mali-400 MP
2022-06-06 07:57:42.785 T:3011133456  NOTICE: GL_VERSION = OpenGL ES 2.0
2022-06-06 07:57:42.785 T:3011133456  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
2022-06-06 07:57:42.785 T:3011133456  NOTICE: GL_EXTENSIONS = GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_OES_mapbuffer GL_KHR_no_error
2022-06-06 07:57:45.481 T:2923426688  NOTICE: Running database version Addons27
2022-06-06 07:57:45.489 T:2923426688  NOTICE: Running database version ViewModes6
2022-06-06 07:57:45.510 T:2923426688  NOTICE: Running database version Textures13
2022-06-06 07:57:45.555 T:2923426688  NOTICE: Running database version MyMusic72
2022-06-06 07:57:45.625 T:2923426688  NOTICE: Running database version MyVideos116
2022-06-06 07:57:45.638 T:2923426688  NOTICE: Running database version TV32
2022-06-06 07:57:45.649 T:2923426688  NOTICE: Running database version Epg12
2022-06-06 07:57:45.679 T:3011133456  NOTICE: start dvd mediatype detection
2022-06-06 07:57:45.869 T:3011133456  NOTICE:   load skin from: /usr/share/kodi/addons/skin.estuary (version: 2.0.27)
2022-06-06 07:57:47.257 T:3011133456 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
2022-06-06 07:57:47.397 T:3011133456  NOTICE: Register - new keyboard device registered on application->keyboard: Billentyűzet (0000:0000)
2022-06-06 07:57:47.399 T:3011133456  NOTICE: Register - new mouse device registered on application->mouse: Egér (0000:0000)
2022-06-06 07:57:47.413 T:3011133456  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2022-06-06 07:57:47.415 T:3011133456  NOTICE: Loaded playercorefactory configuration
2022-06-06 07:57:47.415 T:3011133456  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2022-06-06 07:57:47.416 T:3011133456  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2022-06-06 07:57:47.540 T:3011133456  NOTICE: initialize done
2022-06-06 07:57:47.545 T:3011133456  NOTICE: Running the application...
2022-06-06 07:57:47.567 T:3011133456  NOTICE: starting zeroconf publishing
2022-06-06 07:57:47.569 T:3011133456  NOTICE: CWebServer[8080]: Started
2022-06-06 07:57:47.575 T:2814321536  NOTICE: ES: Starting UDP Event server on port 9777
2022-06-06 07:57:47.576 T:2814321536  NOTICE: UDP: Listening on port 9777 (ipv6 : false)
2022-06-06 07:57:48.232 T:2898248576  NOTICE: Register - new cec device registered on cec->Linux: CEC Adapter (0000:0000)
2022-06-06 07:58:08.613 T:3011133456  NOTICE: Quitting due to POSIX signal
2022-06-06 07:58:08.679 T:3011133456  NOTICE: Stopping player
2022-06-06 07:58:08.680 T:3011133456  NOTICE: Storing total System Uptime
2022-06-06 07:58:08.680 T:3011133456  NOTICE: Saving settings
2022-06-06 07:58:08.713 T:3011133456  NOTICE: Saving skin settings
2022-06-06 07:58:08.720 T:3011133456  NOTICE: Stopping all
2022-06-06 07:58:08.721 T:3011133456  NOTICE: ES: Stopping event server
2022-06-06 07:58:08.753 T:3011133456  NOTICE: stopping zeroconf publishing
2022-06-06 07:58:08.777 T:3011133456  NOTICE: CWebServer[8080]: Stopped
2022-06-06 07:58:09.600 T:2814321536  NOTICE: ES: UDP Event server stopped
2022-06-06 07:58:09.625 T:3011133456  NOTICE: stop dvd detect media
2022-06-06 07:58:14.832 T:3011133456   ERROR: CPythonInvoker(1, /storage/.kodi/addons/service.system.docker/default.py): script didn't stop in 5 seconds - let's kill it
2022-06-06 07:58:15.071 T:3011133456  NOTICE: Application stopped
2022-06-06 07:58:15.272 T:3011133456  NOTICE: XBApplicationEx: destroying...
2022-06-06 07:58:29.877 T:3011133456  NOTICE: unload skin
2022-06-06 07:58:29.953 T:3011133456  NOTICE: unload sections
2022-06-06 07:58:30.174 T:3011133456  NOTICE: XBApplicationEx: application stopped!
Thanks
I think I had the same board as you, I installed Octoprint just fine on mine.
Link to comment
Share on other sites
On 6/24/2022 at 7:15 AM, Luís Hansen said:
Hello folks!
I might need your help here...
I have a board with a RK3228A chip. I followed the instructions but could never boot from the SD card directly.
I then flashed multitools on the card and it did boot. I created a backup, saved it, and then flashed the indicated ROM (on the original topic).
Now, it doesn't boot anymore, even with an SD card with multitools in it.
I tried the toothpick method, and it didn't work.
I then managed to get it into Mask ROM mode:
$ lsusb
Bus 003 Device 103: ID 2207:320b Fuzhou Rockchip Electronics Company RK3228/RK3229 in Mask ROM mode
I downloaded the rkdeveloptool and followed the instructions for flashing directly into the eMMC - or at least try to erase the flash and boot again on Multitools.
But when I run the db command, all I get is:
sudo ./rkdeveloptool db ./rk322x_loader_v1.10.256.bin
Downloading bootloader...
And it never gets past that.
Is there something I can do about it?
Hello!
Yes, fortunately there is something you can do. Here I supposed you have eMMC and not NAND, if you have a NAND chip, things are more complicated
I may just guess what's wrong with your board, so I am not 100% certain, but probably your problem is a DDR Memory that does not support 2-cycles (2T) Command Rate.
2T Command Rate is the default for most of the DDR memories installed on rk322x boards, but there is a very small minority that just want 1-cycle Command Rate (1T)
First of all, try this other loader: rk322x_loader_v1.10.256_no2t.bin and see if it gets uploaded correctly. A serial adapter connected to the board would be very welcome to see the log messages from the very first boot process, but I guess you don't have such tool.
If the upload process goes well, my theory is probably right.
You can now use rkdeveloptool ul rk322x_loader_v1.10.256_no2t.bin to upgrade the bootloader in the eMMC. This should be enough to let the multitool boot again.
You can start again with multitool, install again the image and then do not shutdown the box, but use the multitool menu item "Change DDR Command Rate" to set Command Rate to 1T; then you can shutdown and see if the image now boots.
Of course you can even restore the original Android image you took with multitool: just unpack the backup and then write with rkdeveloptool wl 0x0 <filename>
edit: I will never stress enough the fact that images should be first tested via sdcard before being burnt in eMMC, as I always suggest to do in instructions.
Link to comment
5 hours ago, jock said:
Hello!
Hi jock!
Unfortunately, no luck with the new loader. Since I have only one big chip (other than the processor), I'd guess I have an eMCP.
I also tried writing the backup, but it also fails. In fact, every single command fails: rfi, rci, wl, rl...
Before trying to flash, I tried testing with the SD Card, but it didn't work. I even tried with some different images, but none of them booted up. I read in another forum that some people could only get it to boot from the SD Card after cleaning the memory, and some only after actually flashing it.
The weird thing is that some people that have the exact same board as I do, with the same controller, memory, soc, revision, everything, followed your tutorial and got it to work.
They are also able to do stuff when the board is in MskROM mode. I don't know if I'm being stupid and doing something blatantly wrong, but not being able to even read the memory using the multitools is very strange.
Link to comment
Wait, in maskrom mode what you can do is only uploade the loader with rkdeveloptool db command; it is essential to go further with any other rkdeveloptool command.
I put here a couple of more loaders you can try and see if you get better luck.
Also be aware that I suggest to use the rkdeveloptool binary provided by rockchip on github repository.
rk322x_loader_v1.10.256_300_no2t.bin rk322x_loader_v1.10.256_2t.bin
Link to comment
rk322x_loader_v1.10.256_300_no2t.bin 194.33 kB · 0 downloads rk322x_loader_v1.10.256_2t.bin 194.33 kB · 0 downloads
Wow, the first one you suggested worked! The rk322x_loader_v1.10.256_300_no2t.bin one. Thank you! What's the difference between that one and the one you sent earlier?
Does that mean that my device doesn't support the 2-cycle Command Rate, and then I should follow the instructions to boot it into the multiloader and Change DDR Command Rate?
Link to comment
It's the same as the other in the previous post, just has memory configured to start at 300 MHz instead of 660 MHz.
That caused some incompatibilities in the past, in fact I always say myself that I need to change the loader in the first page and then always forget... :rolleyes:
Link to comment
It worked! I got it to install, connected an Ethernet cable and download the armbian-config package.
My new issue (woohoo) is that I have the ESP8089 wifi module, and I read that some people had troubles with it.
Well, when I run rockchip322x-config it correctly identifies the ESP8089, but then I can't connect to the wifi - it simply doesn't show on the armbian-config.
Is there any driver or config I must change for it to work?
Oh, and thanks a lot for you help! 🎉
Link to comment
Hello there!
@jock so I spent the past few days reading through the topic and testing around with different settings for led configuration and esp8089 settings (the crystal_26M_en setting).
According to the outdated ESP8089 manual, 0 is for 40, 1 is for 26 and 2 is for 24 MHz, so today I tried every single combination of led configuration and crystal frequency. For every test I first rebooted the computer, then shut it off (I even unplugged it out of the wall) and the restarted to be sure all the settings had been updated.
None of the combinations worked, and I captured a dmesg for every single test.
Now let me get into why I decided to run those tests.
Last night I somehow managed to make the wifi work while messing with the settings. I hadn't yet read a message in here about the firmware only updating when completely shutting it off, so I'm not sure what configuration I had at the time. It was supposed to be led config 7 and crystal 0 (40MHz), but it doesn't make sense (you'll see why). While it was working, I captured a dmesg.
I remember that when I got it to work I was testing adding the esp8089 driver to the blacklist and then activating it using modprobe. But then again, I'm not sure if I was doing the right thing after doing so. Was I supposed to reboot after doing that? Or should it work right away once modprobed?
Anyway, at least now I have hope that it can work, since I was it with my won eyes.
This is the dmesg captured when the wifi worked:
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.194-rk322x (root@runner7) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #2 SMP Wed Aug 25 20:09:42 UTC 2021
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Generic RK322x TV Box board
[    0.000000] cma: Reserved 16 MiB at 0x9f000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 253952
[    0.000000] free_area_init_node: node 0, pgdat b1253b40, node_mem_map ee6f1000
[    0.000000]   Normal zone: 2304 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 253952 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv65535.65535 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 14 pages/cpu @ee68f000 s24856 r8192 d24296 u57344
[    0.000000] pcpu-alloc: s24856 r8192 d24296 u57344 alloc=14*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 251648
[    0.000000] Kernel command line: earlyprintk root=UUID=bce0e15e-76b7-4f9c-9149-332bcfd83573 console=ttyS2,115200n8 console=tty1 rootwait rootfstype=ext4  consoleblank=0 loglevel=1 ubootpart=343a1e5a-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u coherent_pool=2M  cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 961148K/1015808K available (12862K kernel code, 919K rwdata, 3240K rodata, 808K init, 1219K bss, 38276K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xb0000000 - 0xf0000000   (1024 MB)
                   pkmap   : 0xafe00000 - 0xb0000000   (   2 MB)
                   modules : 0xaf000000 - 0xafe00000   (  14 MB)
                     .text : 0xb0008000 - 0xb0c97c6c   (12864 kB)
                     .init : 0xb10b0000 - 0xb117a000   ( 808 kB)
                     .data : 0xb117a000 - 0xb125fe94   ( 920 kB)
                      .bss : 0xb1261000 - 0xb1391f14   (1220 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]     Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000024] Switching to timer-based delay loop, resolution 41ns
[    0.001861] Console: colour dummy device 80x30
[    0.002049] console [tty1] enabled
[    0.002081] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002100] pid_max: default: 32768 minimum: 301
[    0.002245] Security Framework initialized
[    0.002260] Yama: becoming mindful.
[    0.002344] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002360] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003352] Initializing cgroup subsys io
[    0.003392] Initializing cgroup subsys memory
[    0.003437] Initializing cgroup subsys devices
[    0.003458] Initializing cgroup subsys freezer
[    0.003477] Initializing cgroup subsys net_cls
[    0.003494] Initializing cgroup subsys perf_event
[    0.003512] Initializing cgroup subsys net_prio
[    0.003545] Initializing cgroup subsys pids
[    0.003706] CPU: Testing write buffer coherency: ok
[    0.003766] ftrace: allocating 41892 entries in 123 pages
[    0.086458] /cpus/cpu@f00 missing clock-frequency property
[    0.086498] /cpus/cpu@f01 missing clock-frequency property
[    0.086517] /cpus/cpu@f02 missing clock-frequency property
[    0.086538] /cpus/cpu@f03 missing clock-frequency property
[    0.086551] CPU0: update cpu_capacity 430
[    0.086564] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.086665] Setting up static identity map for 0x60008280 - 0x600082d8
[    0.089947] CPU1: update cpu_capacity 430
[    0.089957] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.091195] CPU2: update cpu_capacity 430
[    0.091204] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.092416] CPU3: update cpu_capacity 430
[    0.092425] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.092575] Brought up 4 CPUs
[    0.092617] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.092626] CPU: All CPU(s) started in SVC mode.
[    0.094350] devtmpfs: initialized
[    0.114776] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.115382] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.115430] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.116983] xor: measuring software checksum speed
[    0.154353]    arm4regs  :  1011.000 MB/sec
[    0.194456]    8regs     :   705.000 MB/sec
[    0.234557]    32regs    :   684.000 MB/sec
[    0.274658]    neon      :  1018.000 MB/sec
[    0.274668] xor: using function: neon (1018.000 MB/sec)
[    0.274716] pinctrl core: initialized pinctrl subsystem
[    0.276480] NET: Registered protocol family 16
[    0.279154] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.290841] cpuidle: using governor ladder
[    0.302852] cpuidle: using governor menu
[    0.320355] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[    0.320537] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[    0.320694] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[    0.320872] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[    0.327387] console [pstore-1] enabled
[    0.327399] pstore: Registered ramoops as persistent store backend
[    0.327412] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0
[    0.330792] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.330813] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.427932] raid6: int32x1  gen()   133 MB/s
[    0.495931] raid6: int32x1  xor()   131 MB/s
[    0.564185] raid6: int32x2  gen()   166 MB/s
[    0.632236] raid6: int32x2  xor()   136 MB/s
[    0.700600] raid6: int32x4  gen()   163 MB/s
[    0.768688] raid6: int32x4  xor()   137 MB/s
[    0.836996] raid6: int32x8  gen()   166 MB/s
[    0.905261] raid6: int32x8  xor()   113 MB/s
[    0.973397] raid6: neonx1   gen()   382 MB/s
[    1.041520] raid6: neonx1   xor()   290 MB/s
[    1.109735] raid6: neonx2   gen()   519 MB/s
[    1.177859] raid6: neonx2   xor()   376 MB/s
[    1.246109] raid6: neonx4   gen()   581 MB/s
[    1.314295] raid6: neonx4   xor()   400 MB/s
[    1.382539] raid6: neonx8   gen()   559 MB/s
[    1.450751] raid6: neonx8   xor()   391 MB/s
[    1.450764] raid6: using algorithm neonx4 gen() 581 MB/s
[    1.450774] raid6: .... xor() 400 MB/s, rmw enabled
[    1.450784] raid6: using intx1 recovery algorithm
[    1.451939] rockchip-pm rockchip-suspend: not set wakeup-config
[    1.451967] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    1.452405] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@0[0]'
[    1.452969] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@1[0]'
[    1.453680] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-regulator[0]' - status (0)
[    1.454335] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0)
[    1.454975] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[    1.455924] iommu: Adding device 20020000.vpu-service to group 0
[    1.456041] iommu: Adding device 20030000.rkvdec to group 1
[    1.456153] iommu: Adding device 20050000.vop to group 2
[    1.456253] iommu: Adding device 20070000.iep to group 3
[    1.456851] rk_iommu 20020800.iommu: can't get sclk
[    1.457585] rk_iommu 20030480.iommu: can't get sclk
[    1.457862] rk_iommu 20053f00.iommu: can't get sclk
[    1.458018] rk_iommu 20070800.iommu: can't get aclk
[    1.458038] rk_iommu 20070800.iommu: can't get hclk
[    1.458054] rk_iommu 20070800.iommu: can't get sclk
[    1.458988] SCSI subsystem initialized
[    1.459456] usbcore: registered new interface driver usbfs
[    1.459564] usbcore: registered new interface driver hub
[    1.459706] usbcore: registered new device driver usb
[    1.459935] media: Linux media interface: v0.10
[    1.460018] Linux video capture interface: v2.00
[    1.460289] pps_core: LinuxPPS API ver. 1 registered
[    1.460305] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.460349] PTP clock support registered
[    1.462562] Advanced Linux Sound Architecture Driver Initialized.
[    1.463723] Bluetooth: Core ver 2.21
[    1.463808] NET: Registered protocol family 31
[    1.463823] Bluetooth: HCI device and connection manager initialized
[    1.463848] Bluetooth: HCI socket layer initialized
[    1.463865] Bluetooth: L2CAP socket layer initialized
[    1.463930] Bluetooth: SCO socket layer initialized
[    1.464809] NetLabel: Initializing
[    1.464832] NetLabel:  domain hash size = 128
[    1.464842] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.464922] NetLabel:  unlabeled traffic allowed by default
[    1.466492] clocksource: Switched to clocksource arch_sys_counter
[    1.567563] NET: Registered protocol family 2
[    1.568542] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.568666] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[    1.569023] TCP: Hash tables configured (established 8192 bind 8192)
[    1.569127] UDP hash table entries: 512 (order: 2, 24576 bytes)
[    1.569198] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[    1.569598] NET: Registered protocol family 1
[    1.570514] RPC: Registered named UNIX socket transport module.
[    1.570542] RPC: Registered udp transport module.
[    1.570553] RPC: Registered tcp transport module.
[    1.570564] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.570945] Trying to unpack rootfs image as initramfs...
[    2.072332] Freeing initrd memory: 7080K
[    2.073400] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    2.076629] Initialise system trusted keyring
[    2.091053] VFS: Disk quotas dquot_6.6.0
[    2.091395] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    2.094231] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.097887] NFS: Registering the id_resolver key type
[    2.097971] Key type id_resolver registered
[    2.097985] Key type id_legacy registered
[    2.098023] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.098157] ntfs: driver 2.1.32 [Flags: R/W].
[    2.099273] JFS: nTxBlock = 7692, nTxLock = 61538
[    2.110550] SGI XFS with security attributes, no debug enabled
[    2.120043] NET: Registered protocol family 38
[    2.120105] Key type asymmetric registered
[    2.120127] Asymmetric key parser 'x509' registered
[    2.120584] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.120980] io scheduler noop registered
[    2.121012] io scheduler deadline registered
[    2.121112] io scheduler cfq registered (default)
[    2.124812] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator
[    2.130406] rk-vcodec 20020000.vpu-service: no regulator for vcodec
[    2.130992] rk-vcodec 20020000.vpu-service: probe device
[    2.131490] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled
[    2.132865] rk-vcodec 20020000.vpu-service: could not find power_model node
[    2.132897] rk-vcodec 20020000.vpu-service: init success
[    2.133277] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry
[    2.137766] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330
[    2.137797] dma-pl330 110f0000.pdma:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    2.139130] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    2.139671] pwm-regulator vdd-arm-regulator: GPIO lookup for consumer enable
[    2.139693] pwm-regulator vdd-arm-regulator: using device tree for GPIO lookup
[    2.139712] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-arm-regulator[0]'
[    2.139727] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-arm-regulator[0]'
[    2.139741] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup
[    2.139757] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed
[    2.140493] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable
[    2.140516] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup
[    2.140533] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]'
[    2.140547] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]'
[    2.140561] pwm-regulator vdd-log-regulator: using lookup tables for GPIO lookup
[    2.140575] pwm-regulator vdd-log-regulator: lookup for GPIO enable failed
[    2.141729] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.142763] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A
[    2.143615] console [ttyS2] enabled
[    2.145641] [drm] Initialized drm 1.1.0 20060810
[    2.148373] [drm] Rockchip DRM driver version: v1.0.1
[    2.148648] rockchip-drm display-subsystem: devfreq is not set
[    2.149487] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d1b2b0)
[    2.149926] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports
[    2.149957] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.150082] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy)
[    2.151643] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d13808)
[    2.151674] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.151685] [drm] No driver support for vblank timestamp query.
[    2.151830] rockchip-drm display-subsystem: failed to parse display resources
[    2.776143] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    2.781654] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    2.781663] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[    2.781670] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[    2.781677] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[    2.781683] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[    2.781690] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[    2.781697] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[    2.781703] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[    2.781710] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[    2.781717] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[    2.781723] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[    2.781730] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[    2.781736] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[    2.781742] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[    2.781750] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[    2.853668] Console: switching to colour frame buffer device 240x67
[    2.903688] rockchip-drm display-subsystem: fb0:  frame buffer device
[    2.920164] Registered IR keymap rc-cec
[    2.920503] rc rc0: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0
[    2.921176] input: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0/input0
[    2.924201] brd: module loaded
[    2.938346] loop: module loaded
[    2.938620] lkdtm: No crash points registered, enable through debugfs
[    2.941768] libphy: Fixed MDIO Bus: probed
[    2.941813] tun: Universal TUN/TAP device driver, 1.6
[    2.941827] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.942314] CAN device driver interface
[    2.944164] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output).
[    2.944209] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30).
[    2.944228] rk_gmac-dwmac 30200000.ethernet: RX delay(0x10).
[    2.944286] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes).
[    2.944503] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed
[    2.949598] rk_gmac-dwmac 30200000.ethernet: init for RMII
[    2.982697] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    2.982717]  Ring mode enabled
[    2.982730]  DMA HW capability register supported
[    2.982743]  Normal descriptors
[    2.982758]  RX Checksum Offload Engine supported (type 2)
[    2.982771]  TX Checksum insertion supported
[    2.982780]  Wake-Up On Lan supported
[    2.982902] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: 4e:29:f7:d4:13:43
[    2.982919] eth%d: device MAC address 4e:29:f7:d4:13:43
[    2.982933]  Enable RX Mitigation via HW Watchdog Timer
[    2.983223] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@30200000[0]' - status (0)
[    3.403348] libphy: stmmac: probed
[    3.403393] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active
[    3.403411] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01)
[    3.403425] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02)
[    3.403440] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03)
[    3.403455] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04)
[    3.403470] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05)
[    3.403486] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06)
[    3.403501] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07)
[    3.403516] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08)
[    3.403530] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09)
[    3.403546] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a)
[    3.403561] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b)
[    3.403575] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c)
[    3.403590] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d)
[    3.403605] eth%d: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e)
[    3.403620] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f)
[    3.403635] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10)
[    3.403650] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11)
[    3.403665] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12)
[    3.403679] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13)
[    3.403694] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14)
[    3.403709] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15)
[    3.403724] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16)
[    3.403738] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17)
[    3.403753] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18)
[    3.403768] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19)
[    3.403783] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a)
[    3.403798] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b)
[    3.403813] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c)
[    3.403827] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d)
[    3.403842] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e)
[    3.403856] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f)
[    3.405674] PPP generic driver version 2.4.2
[    3.406198] Atmel at76x USB Wireless LAN Driver 0.17 loading
[    3.406373] usbcore: registered new interface driver at76c50x-usb
[    3.406651] usbcore: registered new interface driver rtl8187
[    3.406788] usbcore: registered new interface driver rndis_wlan
[    3.406927] usbcore: registered new interface driver zd1201
[    3.407504] usbcore: registered new interface driver rt2800usb
[    3.407666] Rockchip WiFi SYS interface (V1.00) ...
[    3.407754] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    3.407864] usbcore: registered new interface driver pegasus
[    3.407964] usbcore: registered new interface driver rtl8150
[    3.408059] usbcore: registered new interface driver r8152
[    3.408169] usbcore: registered new interface driver asix
[    3.408283] usbcore: registered new interface driver ax88179_178a
[    3.408393] usbcore: registered new interface driver cdc_ether
[    3.408488] usbcore: registered new interface driver dm9601
[    3.408601] usbcore: registered new interface driver smsc75xx
[    3.408709] usbcore: registered new interface driver smsc95xx
[    3.408800] usbcore: registered new interface driver net1080
[    3.408890] usbcore: registered new interface driver rndis_host
[    3.408993] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    3.409163] usbcore: registered new interface driver cdc_ncm
[    3.409253] usbcore: registered new interface driver cdc_mbim
[    3.409911] 30040000.usb supply vusb_d not found, using dummy regulator
[    3.410028] 30040000.usb supply vusb_a not found, using dummy regulator
[    3.423664] dwc2 30040000.usb: DWC OTG Controller
[    3.423739] dwc2 30040000.usb: new USB bus registered, assigned bus number 1
[    3.423822] dwc2 30040000.usb: irq 49, io mem 0x30040000
[    3.424355] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.424378] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.424394] usb usb1: Product: DWC OTG Controller
[    3.424408] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg
[    3.424421] usb usb1: SerialNumber: 30040000.usb
[    3.425681] hub 1-0:1.0: USB hub found
[    3.425778] hub 1-0:1.0: 1 port detected
[    3.427727] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.427768] ehci-platform: EHCI generic platform driver
[    3.430580] ehci-platform 30080000.usb: EHCI Host Controller
[    3.431086] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2
[    3.431534] ehci-platform 30080000.usb: irq 50, io mem 0x30080000
[    3.442497] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00
[    3.442880] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    3.442900] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.442918] usb usb2: Product: EHCI Host Controller
[    3.442932] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.442946] usb usb2: SerialNumber: 30080000.usb
[    3.444126] hub 2-0:1.0: USB hub found
[    3.444237] hub 2-0:1.0: 1 port detected
[    3.447399] ehci-platform 300c0000.usb: EHCI Host Controller
[    3.447916] ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3
[    3.448323] ehci-platform 300c0000.usb: irq 52, io mem 0x300c0000
[    3.458491] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00
[    3.458873] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    3.458895] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.458911] usb usb3: Product: EHCI Host Controller
[    3.458926] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.458940] usb usb3: SerialNumber: 300c0000.usb
[    3.460103] hub 3-0:1.0: USB hub found
[    3.460174] hub 3-0:1.0: 1 port detected
[    3.463312] ehci-platform 30100000.usb: EHCI Host Controller
[    3.463845] ehci-platform 30100000.usb: new USB bus registered, assigned bus number 4
[    3.464270] ehci-platform 30100000.usb: irq 54, io mem 0x30100000
[    3.474488] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00
[    3.474848] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    3.474868] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.474883] usb usb4: Product: EHCI Host Controller
[    3.474898] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.474911] usb usb4: SerialNumber: 30100000.usb
[    3.476117] hub 4-0:1.0: USB hub found
[    3.476213] hub 4-0:1.0: 1 port detected
[    3.477134] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.477237] ohci-platform: OHCI generic platform driver
[    3.477838] ohci-platform 300a0000.usb: Generic Platform OHCI controller
[    3.478370] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5
[    3.478894] ohci-platform 300a0000.usb: irq 51, io mem 0x300a0000
[    3.538824] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    3.538857] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.538874] usb usb5: Product: Generic Platform OHCI controller
[    3.538889] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.538903] usb usb5: SerialNumber: 300a0000.usb
[    3.540192] hub 5-0:1.0: USB hub found
[    3.540291] hub 5-0:1.0: 1 port detected
[    3.541320] ohci-platform 300e0000.usb: Generic Platform OHCI controller
[    3.541785] ohci-platform 300e0000.usb: new USB bus registered, assigned bus number 6
[    3.542148] ohci-platform 300e0000.usb: irq 53, io mem 0x300e0000
[    3.598804] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    3.598835] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.598852] usb usb6: Product: Generic Platform OHCI controller
[    3.598867] usb usb6: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.598881] usb usb6: SerialNumber: 300e0000.usb
[    3.600146] hub 6-0:1.0: USB hub found
[    3.600258] hub 6-0:1.0: 1 port detected
[    3.601265] ohci-platform 30120000.usb: Generic Platform OHCI controller
[    3.601767] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7
[    3.602170] ohci-platform 30120000.usb: irq 55, io mem 0x30120000
[    3.658809] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    3.658842] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.658859] usb usb7: Product: Generic Platform OHCI controller
[    3.658873] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.658889] usb usb7: SerialNumber: 30120000.usb
[    3.660049] hub 7-0:1.0: USB hub found
[    3.660127] hub 7-0:1.0: 1 port detected
[    3.661235] usbcore: registered new interface driver cdc_acm
[    3.661261] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    3.661395] usbcore: registered new interface driver cdc_wdm
[    3.661722] usbcore: registered new interface driver usb-storage
[    3.661993] usbcore: registered new interface driver usbserial
[    3.662091] usbcore: registered new interface driver usbserial_generic
[    3.662165] usbserial: USB Serial support registered for generic
[    3.662286] usbcore: registered new interface driver keyspan
[    3.662361] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    3.662572] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    3.662661] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    3.662739] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    3.662882] usbcore: registered new interface driver option
[    3.662949] usbserial: USB Serial support registered for GSM modem (1-port)
[    3.663709] usbcore: registered new interface driver oti6858
[    3.663791] usbserial: USB Serial support registered for oti6858
[    3.663910] usbcore: registered new interface driver qcserial
[    3.663985] usbserial: USB Serial support registered for Qualcomm USB modem
[    3.664156] usbcore: registered new interface driver sierra
[    3.664219] usbserial: USB Serial support registered for Sierra USB modem
[    3.666181] usbcore: registered new interface driver iforce
[    3.666389] usbcore: registered new interface driver xpad
[    3.666876] usbcore: registered new interface driver usbtouchscreen
[    3.668416] i2c /dev entries driver
[    3.670686] IR NEC protocol handler initialized
[    3.670724] IR RC5(x/sz) protocol handler initialized
[    3.670742] IR RC6 protocol handler initialized
[    3.670759] IR JVC protocol handler initialized
[    3.670780] IR Sony protocol handler initialized
[    3.670800] IR SANYO protocol handler initialized
[    3.670818] IR Sharp protocol handler initialized
[    3.670836] IR MCE Keyboard/mouse protocol handler initialized
[    3.670854] IR XMP protocol handler initialized
[    3.672887] usbcore: registered new interface driver uvcvideo
[    3.672907] USB Video Class driver (1.1.1)
[    3.675424] Boot mode: normal
[    3.676935] rockchip-thermal 11150000.tsadc: tsadc is probed successfully!
[    3.679097] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    3.679610] Bluetooth: Virtual HCI driver ver 1.5
[    3.679973] Bluetooth: HCI UART driver ver 2.3
[    3.679997] Bluetooth: HCI UART protocol H4 registered
[    3.680009] Bluetooth: HCI UART protocol LL registered
[    3.680020] Bluetooth: HCI UART protocol ATH3K registered
[    3.680033] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    3.680280] Bluetooth: HCI UART protocol BCM registered
[    3.680481] usbcore: registered new interface driver bfusb
[    3.680651] usbcore: registered new interface driver btusb
[    3.680679] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    3.681533] cpu cpu0: leakage=9
[    3.681575] cpu cpu0: leakage-volt-sel=1
[    3.681895] cpu cpu0: Failed to get pvtm
[    3.683838] cpu cpu0: avs=0
[    3.683947] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    3.683976] cpu cpu0: failed to read out thermal zone (-22)
[    3.684857] cpu cpu0: failed to find power_model node
[    3.685824] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset
[    3.685851] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup
[    3.685880] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0)
[    3.686386] Synopsys Designware Multimedia Card Interface Driver
[    3.687384] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode.
[    3.687558] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller.
[    3.687583] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a
[    3.687675] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo
[    3.687779] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found
[    3.687791] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found
[    3.687821] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer cd
[    3.687832] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    3.687870] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/dwmmc@30000000[0]' - status (0)
[    3.687925] gpio-49 (cd): gpiod_set_debounce: missing set() or set_debounce() operations
[    3.687940] dwmmc_rockchip 30000000.dwmmc: Got CD GPIO
[    3.687953] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer wp
[    3.687962] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    3.687975] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30000000[0]'
[    3.687988] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30000000[0]'
[    3.687999] dwmmc_rockchip 30000000.dwmmc: using lookup tables for GPIO lookup
[    3.688012] dwmmc_rockchip 30000000.dwmmc: lookup for GPIO wp failed
[    3.698580] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.711598] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized
[    3.712193] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available
[    3.712317] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode.
[    3.712502] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller.
[    3.712526] dwmmc_rockchip 30010000.dwmmc: Version ID is 270a
[    3.712613] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo
[    3.712711] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found
[    3.712725] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found
[    3.712748] dwmmc_rockchip 30010000.dwmmc: GPIO lookup for consumer wp
[    3.712761] dwmmc_rockchip 30010000.dwmmc: using device tree for GPIO lookup
[    3.712778] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30010000[0]'
[    3.712791] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30010000[0]'
[    3.712803] dwmmc_rockchip 30010000.dwmmc: using lookup tables for GPIO lookup
[    3.712817] dwmmc_rockchip 30010000.dwmmc: lookup for GPIO wp failed
[    3.712925] dwmmc_rockchip 30010000.dwmmc: allocated mmc-pwrseq
[    3.725931] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2)
[    3.738586] dwmmc_rockchip 30010000.dwmmc: 1 slots initialized
[    3.738936] dwmmc_rockchip 30020000.dwmmc: IDMAC supports 32-bit address mode.
[    3.739081] dwmmc_rockchip 30020000.dwmmc: Using internal DMA controller.
[    3.739103] dwmmc_rockchip 30020000.dwmmc: Version ID is 270a
[    3.739190] dwmmc_rockchip 30020000.dwmmc: DW MMC controller at irq 47,32 bit host data width,256 deep fifo
[    3.739292] dwmmc_rockchip 30020000.dwmmc: No vmmc regulator found
[    3.739309] dwmmc_rockchip 30020000.dwmmc: No vqmmc regulator found
[    3.739332] dwmmc_rockchip 30020000.dwmmc: GPIO lookup for consumer wp
[    3.739342] dwmmc_rockchip 30020000.dwmmc: using device tree for GPIO lookup
[    3.739355] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30020000[0]'
[    3.739367] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30020000[0]'
[    3.739379] dwmmc_rockchip 30020000.dwmmc: using lookup tables for GPIO lookup
[    3.739392] dwmmc_rockchip 30020000.dwmmc: lookup for GPIO wp failed
[    3.752237] mmc_host mmc2: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3)
[    3.765041] dwmmc_rockchip 30020000.dwmmc: 1 slots initialized
[    3.765861] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/working[0]' - status (0)
[    3.766683] ledtrig-cpu: registered to indicate activity on CPUs
[    3.766821] hidraw: raw HID events driver (C) Jiri Kosina
[    3.767529] usbcore: registered new interface driver usbhid
[    3.767548] usbhid: USB HID core driver
[    3.768020] ashmem: initialized
[    3.770391] rknandbase v1.2 2018-05-08
[    3.770950] rknand 30030000.nandc: rknand_probe clk rate = 150000000
[    3.771260] ftl_init fffffffe
[    3.771273] rk_ftl_init fail
[    3.773384] usbcore: registered new interface driver snd-usb-audio
[    3.773775] usbcore: registered new interface driver snd-ua101
[    3.773993] usbcore: registered new interface driver snd-usb-caiaq
[    3.774201] usbcore: registered new interface driver snd-usb-6fire
[    3.774409] usbcore: registered new interface driver snd-usb-hiface
[    3.774775] usbcore: registered new interface driver snd-bcd2000
[    3.775067] usbcore: registered new interface driver snd_usb_pod
[    3.775319] usbcore: registered new interface driver snd_usb_podhd
[    3.775487] usbcore: registered new interface driver snd_usb_toneport
[    3.775643] usbcore: registered new interface driver snd_usb_variax
[    3.778807] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 300000Hz, actual 244140HZ div = 2)
[    3.786407] u32 classifier
[    3.786522]     input device check on
[    3.786537]     Actions configured
[    3.786581] Netfilter messages via NETLINK v0.30.
[    3.786645] nfnl_acct: registering with nfnetlink.
[    3.786821] nf_conntrack version 0.5.0 (15384 buckets, 61536 max)
[    3.788301] Initializing XFRM netlink socket
[    3.789991] NET: Registered protocol family 10
[    3.792701] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.793306] sit: IPv6 over IPv4 tunneling driver
[    3.794961] NET: Registered protocol family 17
[    3.795057] NET: Registered protocol family 15
[    3.795195] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    3.795279] Bridge firewalling registered
[    3.795304] can: controller area network core (rev 20120528 abi 9)
[    3.795454] NET: Registered protocol family 29
[    3.795497] can: raw protocol (rev 20120528)
[    3.795527] can: broadcast manager protocol (rev 20120528 t)
[    3.795568] can: netlink gateway (rev 20130117) max_hops=1
[    3.796479] Bluetooth: RFCOMM TTY layer initialized
[    3.796646] Bluetooth: RFCOMM socket layer initialized
[    3.796719] Bluetooth: RFCOMM ver 1.11
[    3.796776] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.796809] Bluetooth: HIDP socket layer initialized
[    3.797038] 8021q: 802.1Q VLAN Support v1.8
[    3.797127] lib80211: common routines for IEEE802.11 drivers
[    3.797150] lib80211_crypt: registered algorithm 'NULL'
[    3.797184] lib80211_crypt: registered algorithm 'WEP'
[    3.797214] lib80211_crypt: registered algorithm 'CCMP'
[    3.797243] lib80211_crypt: registered algorithm 'TKIP'
[    3.797387] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
[    3.797479] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    3.797935] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    3.797998] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = esp8089
[    3.798020] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    3.798036] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    3.798057] of_get_named_gpiod_flags: can't parse 'WIFI,poweren_gpio' property of node '/wireless-wlan[0]'
[    3.798078] of_get_named_gpiod_flags: can't parse 'WIFI,vbat_gpio' property of node '/wireless-wlan[0]'
[    3.798098] of_get_named_gpiod_flags: can't parse 'WIFI,reset_gpio' property of node '/wireless-wlan[0]'
[    3.798169] of_get_named_gpiod_flags: parsed 'WIFI,host_wake_irq' property of node '/wireless-wlan[0]' - status (0)
[    3.798190] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 28, flags = 1.
[    3.798220] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    3.798238] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    3.798261] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    3.798853] [BT_RFKILL]: Enter rfkill_rk_init
[    3.800243] Key type dns_resolver registered
[    3.800852] mmc2: new high speed MMC card at address 0001
[    3.802122] flash vendor_init_thread!
[    3.802171] flash vendor storage:20170308 ret = -1
[    3.802303] Error: Driver 'sc031gs' is already registered, aborting...
[    3.802878] mmcblk2: mmc2:0001 P1J95K 7.30 GiB
[    3.804033] mmcblk2boot0: mmc2:0001 P1J95K partition 1 2.00 MiB
[    3.804068] Registering SWP/SWPB emulation handler
[    3.805173] mmcblk2boot1: mmc2:0001 P1J95K partition 2 2.00 MiB
[    3.806255] mmcblk2rpmb: mmc2:0001 P1J95K partition 3 2.00 MiB
[    3.806550] registered taskstats version 1
[    3.806606] Loading compiled-in X.509 certificates
[    3.808801]  mmcblk2: p1
[    3.813658] Btrfs loaded
[    3.816033] rga2: Driver loaded successfully ver:4.01
[    3.816467] rga2: Module initialized.
[    3.816577] pvtm list NULL
[    3.818697] rk-vcodec 20030000.rkvdec: leakage=6
[    3.818756] rk-vcodec 20030000.rkvdec: leakage-volt-sel=1
[    3.818961] rk-vcodec 20030000.rkvdec: Failed to get pvtm
[    3.819707] rk-vcodec 20030000.rkvdec: avs=0
[    3.820245] rk-vcodec 20030000.rkvdec: probe device
[    3.821061] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled
[    3.823514] rk-vcodec 20030000.rkvdec: init success
[    3.825436] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]'
[    3.825474] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]'
[    3.827361] asoc-simple-card hdmi-sound: i2s-hifi <-> 100c0000.i2s0 mapping ok
[    3.830897] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]'
[    3.830946] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]'
[    3.832709] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok
[    3.834644] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 200000Hz, actual 162760HZ div = 3)
[    3.836756] hctosys: unable to open rtc device (rtc0)
[    3.859132] ALSA device list:
[    3.859178]   #0: DW-I2S-HDMI
[    3.859190]   #1: SPDIF
[    3.860631] Freeing unused kernel memory: 808K
[    3.860654] This architecture does not have kernel memory protection.
[    3.893453] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 100000Hz, actual 97656HZ div = 5)
[    3.966229] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[    3.995942] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[    4.009303] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[    4.013437] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    4.015654] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[    4.015821] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[    4.015955] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[    4.016032] mmc1: new high speed SDIO card at address 0001
[    4.054661] usb 5-1: new full-speed USB device number 2 using ohci-platform
[    4.268714] usb 5-1: New USB device found, idVendor=046d, idProduct=c534
[    4.268771] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.268788] usb 5-1: Product: USB Receiver
[    4.268800] usb 5-1: Manufacturer: Logitech
[    4.282989] input: Logitech USB Receiver as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.0/0003:046D:C534.0001/input/input1
[    4.310866] vendor storage:20190527 ret = 0
[    4.341259] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-300a0000.usb-1/input0
[    4.352171] input: Logitech USB Receiver as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.1/0003:046D:C534.0002/input/input2
[    4.408065] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-300a0000.usb-1/input1
[    5.452268] EXT4-fs (mmcblk2p1): mounted filesystem with writeback data mode. Opts: (null)
[    6.030952] systemd[1]: System time before build time, advancing clock.
[    6.049145] systemd[1]: Inserted module 'autofs4'
[    6.060086] ip_tables: (C) 2000-2006 Netfilter Core Team
[    6.075052] cgroup: cgroup2: unknown option "nsdelegate"
[    6.096413] systemd[1]: systemd 245.4-4ubuntu3.15 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    6.098313] systemd[1]: Detected architecture arm.
[    6.120466] systemd[1]: Set hostname to <rk322x-box>.
[    6.313340] ttyS2 - failed to request DMA, use interrupt mode
[    7.095525] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.095979] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    7.096012] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    7.100230] systemd[1]: Created slice system-modprobe.slice.
[    7.101214] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.103121] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.103881] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.105401] systemd[1]: Created slice User and Session Slice.
[    7.106237] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.106807] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.108201] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.109023] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.110260] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.110382] systemd[1]: Reached target Remote File Systems.
[    7.111147] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.111252] systemd[1]: Reached target Slices.
[    7.111842] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.111928] systemd[1]: Reached target Swap.
[    7.112427] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.112510] systemd[1]: Reached target System Time Set.
[    7.113152] random: systemd: uninitialized urandom read (16 bytes read, 71 bits of entropy available)
[    7.117794] systemd[1]: Listening on Syslog Socket.
[    7.119752] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.120981] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    7.130693] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    7.131825] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.133506] systemd[1]: Listening on Journal Socket.
[    7.135261] systemd[1]: Listening on udev Control Socket.
[    7.136641] systemd[1]: Listening on udev Kernel Socket.
[    7.138006] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    7.144306] systemd[1]: Mounting POSIX Message Queue File System...
[    7.154326] systemd[1]: Mounting Kernel Debug File System...
[    7.165215] systemd[1]: Mounting Kernel Trace File System...
[    7.178066] systemd[1]: Starting Restore / save the current clock...
[    7.188500] systemd[1]: Starting Set the console keyboard layout...
[    7.203596] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    7.205334] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[    7.220730] systemd[1]: Started Nameserver information manager.
[    7.239277] systemd[1]: Reached target Network (Pre).
[    7.244115] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    7.244522] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.260411] systemd[1]: Starting Load Kernel Modules...
[    7.274035] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.289877] systemd[1]: Starting udev Coldplug all Devices...
[    7.309293] systemd[1]: Mounted POSIX Message Queue File System.
[    7.313204] systemd[1]: Mounted Kernel Debug File System.
[    7.317359] systemd[1]: Mounted Kernel Trace File System.
[    7.325769] systemd[1]: Finished Restore / save the current clock.
[    7.333894] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    7.341995] EXT4-fs (mmcblk2p1): re-mounted. Opts: commit=600,errors=remount-ro
[    7.357170] systemd[1]: Finished Load Kernel Modules.
[    7.362080] systemd[1]: Finished Remount Root and Kernel File Systems.
[    7.365107] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    7.372295] systemd[1]: Mounting Kernel Configuration File System...
[    7.375854] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    7.376565] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    7.385574] systemd[1]: Starting Load/Save Random Seed...
[    7.396488] systemd[1]: Starting Apply Kernel Variables...
[    7.412236] systemd[1]: Starting Create System Users...
[    7.436450] systemd[1]: Mounted Kernel Configuration File System.
[    7.500022] systemd[1]: Finished Apply Kernel Variables.
[    7.504283] systemd[1]: Finished Create System Users.
[    7.512642] systemd[1]: Starting Create Static Device Nodes in /dev...
[    7.587078] systemd[1]: Finished Create Static Device Nodes in /dev.
[    7.595294] systemd[1]: Starting udev Kernel Device Manager...
[    7.636346] systemd[1]: Finished Set the console keyboard layout.
[    7.638645] systemd[1]: Reached target Local File Systems (Pre).
[    7.648971] systemd[1]: Mounting /tmp...
[    7.672849] systemd[1]: Mounted /tmp.
[    7.675580] systemd[1]: Reached target Local File Systems.
[    7.685524] systemd[1]: Starting Armbian ZRAM config...
[    7.707848] systemd[1]: Starting Set console font and keymap...
[    7.732513] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    7.743485] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    7.778985] systemd[1]: Finished Set console font and keymap.
[    7.793173] systemd[1]: plymouth-read-write.service: Succeeded.
[    7.796778] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    7.963868] systemd[1]: Finished udev Coldplug all Devices.
[    7.983957] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[    7.996851] systemd[1]: Started udev Kernel Device Manager.
[    8.024278] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[    8.024661] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[    8.024969] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[    8.025404] systemd[1]: Reached target Local Encrypted Volumes.
[    8.072194] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[    8.097175] systemd[1]: Starting Raise network interfaces...
[    8.231965] zram: Added device: zram0
[    8.234782] zram: Added device: zram1
[    8.240224] zram: Added device: zram2
[    8.613324] rk3228-codec 12010000.codec: GPIO lookup for consumer spk-en
[    8.613363] rk3228-codec 12010000.codec: using device tree for GPIO lookup
[    8.613386] of_get_named_gpiod_flags: can't parse 'spk-en-gpios' property of node '/codec@12010000[0]'
[    8.613430] of_get_named_gpiod_flags: parsed 'spk-en-gpio' property of node '/codec@12010000[0]' - status (0)
[    8.613502] rk3228-codec 12010000.codec: spk_depop_time use default value.
[    8.614926] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]'
[    8.614971] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]'
[    8.626172] systemd[1]: Found device /dev/ttyS2.
[    8.631072] zram0: detected capacity change from 0 to 504537088
[    8.653625] asoc-simple-card sound: rk3228-hifi <-> 100b0000.i2s1 mapping ok
[    8.677192] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '20:09:06', on 'Aug 25 2021'.
[    8.677566] mali-utgard 20001000.gpu: mali_platform_device->num_resources = 13
[    8.677593] mali-utgard 20001000.gpu: resource[0].start = 0x0x20001000
[    8.677606] mali-utgard 20001000.gpu: resource[1].start = 0x0x20000000
[    8.677617] mali-utgard 20001000.gpu: resource[2].start = 0x0x20003000
[    8.677628] mali-utgard 20001000.gpu: resource[3].start = 0x0x20008000
[    8.677639] mali-utgard 20001000.gpu: resource[4].start = 0x0x20004000
[    8.677650] mali-utgard 20001000.gpu: resource[5].start = 0x0x2000a000
[    8.677661] mali-utgard 20001000.gpu: resource[6].start = 0x0x20005000
[    8.677672] mali-utgard 20001000.gpu: resource[7].start = 0x0x00000020
[    8.677682] mali-utgard 20001000.gpu: resource[8].start = 0x0x00000021
[    8.677694] mali-utgard 20001000.gpu: resource[9].start = 0x0x00000022
[    8.677705] mali-utgard 20001000.gpu: resource[10].start = 0x0x00000021
[    8.677764] mali-utgard 20001000.gpu: resource[11].start = 0x0x00000022
[    8.677774] mali-utgard 20001000.gpu: resource[12].start = 0x0x00000021
[    8.677787] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 623; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali.
[    8.679554] cfg80211: World regulatory domain updated:
[    8.679610] cfg80211:  DFS Master region: unset
[    8.679624] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    8.679643] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    8.679658] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    8.679669] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    8.679683] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    8.679696] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    8.679709] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[    8.679719] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    8.679731] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[    8.680329] mali-utgard 20001000.gpu: leakage=6
[    8.680384] mali-utgard 20001000.gpu: leakage-volt-sel=1
[    8.680644] mali-utgard 20001000.gpu: Failed to get pvtm
[    8.684422] mali-utgard 20001000.gpu: avs=0
[    8.685025] mali-utgard 20001000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    8.697492] Mali: Mali device driver loaded
[    8.782725] devfreq 20001000.gpu: Couldn't update frequency transition information.
[    9.129414] gpio_ir_recv ir-receiver: GPIO lookup for consumer (null)
[    9.129460] gpio_ir_recv ir-receiver: using device tree for GPIO lookup
[    9.129538] of_get_named_gpiod_flags: parsed 'gpios' property of node '/ir-receiver[0]' - status (0)
[    9.129706] Registered IR keymap rc-rktvbox
[    9.131913] rc rc1: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1
[    9.134419] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1/input3
[    9.187420] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    9.193554] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    9.193588] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[    9.193602] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[    9.193613] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[    9.193623] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[    9.193634] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[    9.193644] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[    9.193654] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[    9.193664] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[    9.193674] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[    9.193685] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[    9.193695] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[    9.193705] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[    9.193715] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[    9.193726] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[    9.262807] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    9.264779] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    9.266358] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    9.302382] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    9.341894] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[    9.342589] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[    9.343086] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[    9.344408] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    9.345220] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    9.345850] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    9.346332] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    9.382220] systemd[1]: plymouth-read-write.service: Succeeded.
[    9.403331] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    9.474030] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    9.477154] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    9.478956] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    9.494985] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    9.518840] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[    9.519524] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[    9.525436] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[    9.526703] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    9.531043] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    9.531960] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    9.536786] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    9.592446] systemd[1]: plymouth-read-write.service: Succeeded.
[    9.601381] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    9.677117] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    9.678314] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[    9.714999] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    9.716835] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    9.740168] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    9.787537] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[    9.788027] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[    9.788345] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[    9.789372] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    9.790071] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    9.793446] Adding 492708k swap on /dev/zram0.  Priority:5 extents:1 across:492708k SS
[    9.795176] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    9.795636] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[    9.835781] mmc1: card 0001 removed
[    9.859047] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2)
[    9.885694] systemd[1]: plymouth-read-write.service: Succeeded.
[    9.914886] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 300000Hz, actual 244140HZ div = 2)
[    9.925546] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    9.966823] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 200000Hz, actual 162760HZ div = 3)
[   10.022862] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 100000Hz, actual 97656HZ div = 5)
[   10.095537] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[   10.147571] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   10.151902] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   10.154231] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   10.165783] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[   10.175770] random: nonblocking pool is initialized
[   10.181124] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[   10.181888] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   10.185856] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[   10.188516] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[   10.188657] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[   10.188744] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[   10.188807] mmc1: new high speed SDIO card at address 0001
[   10.238003] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[   10.246936] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   10.247514] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[   10.248987] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   10.249864] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   10.257013] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   10.257930] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[   10.280287] systemd[1]: Finished Load/Save Random Seed.
[   10.394956] systemd[1]: plymouth-read-write.service: Succeeded.
[   10.413446] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   10.436684] systemd[1]: Finished Raise network interfaces.
[   10.474021] zram1: detected capacity change from 0 to 52428800
[   10.477968] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   10.578128] systemd[1]: Finished Armbian ZRAM config.
[   10.593857] systemd[1]: Starting Armbian memory supported logging...
[   10.675229] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   10.747856] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
[   10.771261] systemd[1]: Started Load/Save RF Kill Switch Status.
[   15.501754] systemd[1]: Finished Armbian memory supported logging.
[   15.513888] systemd[1]: Starting Journal Service...
[   15.771205] systemd[1]: systemd-rfkill.service: Succeeded.
[   16.092346] systemd[1]: Started Journal Service.
[   16.154737] systemd-journald[669]: Received client request to flush runtime journal.
[   17.593832] nr_pdflush_threads exported in /proc is scheduled for removal
[   40.611192] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   40.785981] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   40.792745] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   41.234239] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   42.675064] rk_gmac-dwmac 30200000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[   43.847905] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   43.847989] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   43.848042] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   43.848077] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   43.848102] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   43.848130] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[  159.114042] wlan0: authenticate with 04:95:e6:a5:1d:c1
[  159.119166] wlan0: send auth to 04:95:e6:a5:1d:c1 (try 1/3)
[  159.121875] wlan0: authenticated
[  159.146401] wlan0: associate with 04:95:e6:a5:1d:c1 (try 1/3)
[  159.151094] wlan0: RX AssocResp from 04:95:e6:a5:1d:c1 (capab=0x411 status=0 aid=3)
[  159.151404] wlan0: associated
[  159.152134] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[  170.678408] rk_gmac-dwmac 30200000.ethernet eth0: Link is Down
Here's one of the 21 other dmesgs I captured when testing the different combinations. They all look similar, but if we need to, I have all of them dafely stored here.
Every test had one of 2 possile outcomes: either the ESP8089 was detected and the wlan connection existed on the ifconfig but no networks were visible, or it wasn't detected at all and no wlan connection even existed.
For this one, the ESP8089 was detected and the wlan was there.
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.194-rk322x (root@runner7) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #2 SMP Wed Aug 25 20:09:42 UTC 2021
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Generic RK322x TV Box board
[    0.000000] cma: Reserved 16 MiB at 0x9f000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 253952
[    0.000000] free_area_init_node: node 0, pgdat b1253b40, node_mem_map ee6f1000
[    0.000000]   Normal zone: 2304 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 253952 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv65535.65535 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 14 pages/cpu @ee68f000 s24856 r8192 d24296 u57344
[    0.000000] pcpu-alloc: s24856 r8192 d24296 u57344 alloc=14*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 251648
[    0.000000] Kernel command line: earlyprintk root=UUID=bce0e15e-76b7-4f9c-9149-332bcfd83573 console=ttyS2,115200n8 console=tty1 rootwait rootfstype=ext4  consoleblank=0 loglevel=1 ubootpart=343a1e5a-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u coherent_pool=2M  cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 960640K/1015808K available (12862K kernel code, 919K rwdata, 3240K rodata, 808K init, 1219K bss, 38784K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xb0000000 - 0xf0000000   (1024 MB)
                   pkmap   : 0xafe00000 - 0xb0000000   (   2 MB)
                   modules : 0xaf000000 - 0xafe00000   (  14 MB)
                     .text : 0xb0008000 - 0xb0c97c6c   (12864 kB)
                     .init : 0xb10b0000 - 0xb117a000   ( 808 kB)
                     .data : 0xb117a000 - 0xb125fe94   ( 920 kB)
                      .bss : 0xb1261000 - 0xb1391f14   (1220 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]     Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000024] Switching to timer-based delay loop, resolution 41ns
[    0.001859] Console: colour dummy device 80x30
[    0.002049] console [tty1] enabled
[    0.002079] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002098] pid_max: default: 32768 minimum: 301
[    0.002241] Security Framework initialized
[    0.002256] Yama: becoming mindful.
[    0.002341] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002358] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003357] Initializing cgroup subsys io
[    0.003397] Initializing cgroup subsys memory
[    0.003443] Initializing cgroup subsys devices
[    0.003465] Initializing cgroup subsys freezer
[    0.003485] Initializing cgroup subsys net_cls
[    0.003503] Initializing cgroup subsys perf_event
[    0.003521] Initializing cgroup subsys net_prio
[    0.003553] Initializing cgroup subsys pids
[    0.003716] CPU: Testing write buffer coherency: ok
[    0.003776] ftrace: allocating 41892 entries in 123 pages
[    0.086461] /cpus/cpu@f00 missing clock-frequency property
[    0.086502] /cpus/cpu@f01 missing clock-frequency property
[    0.086521] /cpus/cpu@f02 missing clock-frequency property
[    0.086542] /cpus/cpu@f03 missing clock-frequency property
[    0.086557] CPU0: update cpu_capacity 430
[    0.086568] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.086668] Setting up static identity map for 0x60008280 - 0x600082d8
[    0.089943] CPU1: update cpu_capacity 430
[    0.089954] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.091195] CPU2: update cpu_capacity 430
[    0.091204] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.092420] CPU3: update cpu_capacity 430
[    0.092429] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.092587] Brought up 4 CPUs
[    0.092630] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.092638] CPU: All CPU(s) started in SVC mode.
[    0.094368] devtmpfs: initialized
[    0.114776] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.115382] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.115431] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.116958] xor: measuring software checksum speed
[    0.154361]    arm4regs  :  1011.000 MB/sec
[    0.194464]    8regs     :   705.000 MB/sec
[    0.234565]    32regs    :   684.000 MB/sec
[    0.274667]    neon      :  1018.000 MB/sec
[    0.274677] xor: using function: neon (1018.000 MB/sec)
[    0.274726] pinctrl core: initialized pinctrl subsystem
[    0.276493] NET: Registered protocol family 16
[    0.279161] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.290850] cpuidle: using governor ladder
[    0.302861] cpuidle: using governor menu
[    0.320383] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[    0.320566] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[    0.320721] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[    0.320896] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[    0.328025] console [pstore-1] enabled
[    0.328038] pstore: Registered ramoops as persistent store backend
[    0.328050] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0
[    0.331537] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.331560] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.431980] raid6: int32x1  gen()   133 MB/s
[    0.500015] raid6: int32x1  xor()   131 MB/s
[    0.568223] raid6: int32x2  gen()   166 MB/s
[    0.636274] raid6: int32x2  xor()   136 MB/s
[    0.704638] raid6: int32x4  gen()   163 MB/s
[    0.772822] raid6: int32x4  xor()   137 MB/s
[    0.841045] raid6: int32x8  gen()   166 MB/s
[    0.909301] raid6: int32x8  xor()   113 MB/s
[    0.977440] raid6: neonx1   gen()   382 MB/s
[    1.045552] raid6: neonx1   xor()   290 MB/s
[    1.113770] raid6: neonx2   gen()   519 MB/s
[    1.181908] raid6: neonx2   xor()   376 MB/s
[    1.250154] raid6: neonx4   gen()   581 MB/s
[    1.318335] raid6: neonx4   xor()   400 MB/s
[    1.386588] raid6: neonx8   gen()   559 MB/s
[    1.454798] raid6: neonx8   xor()   391 MB/s
[    1.454810] raid6: using algorithm neonx4 gen() 581 MB/s
[    1.454820] raid6: .... xor() 400 MB/s, rmw enabled
[    1.454831] raid6: using intx1 recovery algorithm
[    1.455993] rockchip-pm rockchip-suspend: not set wakeup-config
[    1.456018] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    1.456449] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@0[0]'
[    1.457009] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@1[0]'
[    1.457720] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-regulator[0]' - status (0)
[    1.458376] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0)
[    1.459001] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[    1.459942] iommu: Adding device 20020000.vpu-service to group 0
[    1.460060] iommu: Adding device 20030000.rkvdec to group 1
[    1.460177] iommu: Adding device 20050000.vop to group 2
[    1.460278] iommu: Adding device 20070000.iep to group 3
[    1.460876] rk_iommu 20020800.iommu: can't get sclk
[    1.461604] rk_iommu 20030480.iommu: can't get sclk
[    1.461874] rk_iommu 20053f00.iommu: can't get sclk
[    1.462024] rk_iommu 20070800.iommu: can't get aclk
[    1.462045] rk_iommu 20070800.iommu: can't get hclk
[    1.462061] rk_iommu 20070800.iommu: can't get sclk
[    1.462995] SCSI subsystem initialized
[    1.463462] usbcore: registered new interface driver usbfs
[    1.463567] usbcore: registered new interface driver hub
[    1.463708] usbcore: registered new device driver usb
[    1.463942] media: Linux media interface: v0.10
[    1.464027] Linux video capture interface: v2.00
[    1.464295] pps_core: LinuxPPS API ver. 1 registered
[    1.464312] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.464355] PTP clock support registered
[    1.466570] Advanced Linux Sound Architecture Driver Initialized.
[    1.467739] Bluetooth: Core ver 2.21
[    1.467822] NET: Registered protocol family 31
[    1.467837] Bluetooth: HCI device and connection manager initialized
[    1.467859] Bluetooth: HCI socket layer initialized
[    1.467877] Bluetooth: L2CAP socket layer initialized
[    1.467937] Bluetooth: SCO socket layer initialized
[    1.468878] NetLabel: Initializing
[    1.468902] NetLabel:  domain hash size = 128
[    1.468912] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.468995] NetLabel:  unlabeled traffic allowed by default
[    1.470509] clocksource: Switched to clocksource arch_sys_counter
[    1.571630] NET: Registered protocol family 2
[    1.572602] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.572726] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[    1.573082] TCP: Hash tables configured (established 8192 bind 8192)
[    1.573184] UDP hash table entries: 512 (order: 2, 24576 bytes)
[    1.573255] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[    1.573654] NET: Registered protocol family 1
[    1.574464] RPC: Registered named UNIX socket transport module.
[    1.574586] RPC: Registered udp transport module.
[    1.574601] RPC: Registered tcp transport module.
[    1.574612] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.574992] Trying to unpack rootfs image as initramfs...
[    2.114391] Freeing initrd memory: 7588K
[    2.115585] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    2.118811] Initialise system trusted keyring
[    2.133243] VFS: Disk quotas dquot_6.6.0
[    2.133584] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    2.136476] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.140153] NFS: Registering the id_resolver key type
[    2.140252] Key type id_resolver registered
[    2.140265] Key type id_legacy registered
[    2.140303] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.140423] ntfs: driver 2.1.32 [Flags: R/W].
[    2.141418] JFS: nTxBlock = 7692, nTxLock = 61538
[    2.152707] SGI XFS with security attributes, no debug enabled
[    2.162674] NET: Registered protocol family 38
[    2.162738] Key type asymmetric registered
[    2.162760] Asymmetric key parser 'x509' registered
[    2.163209] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.163725] io scheduler noop registered
[    2.163758] io scheduler deadline registered
[    2.163856] io scheduler cfq registered (default)
[    2.167524] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator
[    2.173228] rk-vcodec 20020000.vpu-service: no regulator for vcodec
[    2.173722] rk-vcodec 20020000.vpu-service: probe device
[    2.174194] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled
[    2.175729] rk-vcodec 20020000.vpu-service: could not find power_model node
[    2.175759] rk-vcodec 20020000.vpu-service: init success
[    2.176147] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry
[    2.180700] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330
[    2.180733] dma-pl330 110f0000.pdma:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    2.182005] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    2.182610] pwm-regulator vdd-arm-regulator: GPIO lookup for consumer enable
[    2.182634] pwm-regulator vdd-arm-regulator: using device tree for GPIO lookup
[    2.182652] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-arm-regulator[0]'
[    2.182667] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-arm-regulator[0]'
[    2.182681] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup
[    2.182697] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed
[    2.183444] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable
[    2.183468] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup
[    2.183485] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]'
[    2.183500] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]'
[    2.183514] pwm-regulator vdd-log-regulator: using lookup tables for GPIO lookup
[    2.183530] pwm-regulator vdd-log-regulator: lookup for GPIO enable failed
[    2.184682] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.185621] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A
[    2.186553] console [ttyS2] enabled
[    2.188631] [drm] Initialized drm 1.1.0 20060810
[    2.191333] [drm] Rockchip DRM driver version: v1.0.1
[    2.191632] rockchip-drm display-subsystem: devfreq is not set
[    2.192472] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d1b2b0)
[    2.192931] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports
[    2.192962] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.193088] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy)
[    2.194644] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d13808)
[    2.194677] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.194688] [drm] No driver support for vblank timestamp query.
[    2.194831] rockchip-drm display-subsystem: failed to parse display resources
[    2.817314] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    2.822842] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    2.822851] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[    2.822858] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[    2.822865] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[    2.822871] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[    2.822878] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[    2.822885] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[    2.822891] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[    2.822898] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[    2.822905] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[    2.822911] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[    2.822918] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[    2.822924] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[    2.822930] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[    2.822938] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[    2.894805] Console: switching to colour frame buffer device 240x67
[    2.944930] rockchip-drm display-subsystem: fb0:  frame buffer device
[    2.960358] Registered IR keymap rc-cec
[    2.960663] rc rc0: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0
[    2.961360] input: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0/input0
[    2.964290] brd: module loaded
[    2.978691] loop: module loaded
[    2.978803] lkdtm: No crash points registered, enable through debugfs
[    2.981961] libphy: Fixed MDIO Bus: probed
[    2.982007] tun: Universal TUN/TAP device driver, 1.6
[    2.982022] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.982637] CAN device driver interface
[    2.984426] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output).
[    2.984460] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30).
[    2.984476] rk_gmac-dwmac 30200000.ethernet: RX delay(0x10).
[    2.984524] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes).
[    2.984704] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed
[    2.989790] rk_gmac-dwmac 30200000.ethernet: init for RMII
[    3.022761] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    3.022781]  Ring mode enabled
[    3.022794]  DMA HW capability register supported
[    3.022807]  Normal descriptors
[    3.022822]  RX Checksum Offload Engine supported (type 2)
[    3.022834]  TX Checksum insertion supported
[    3.022843]  Wake-Up On Lan supported
[    3.022964] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: 4e:29:f7:d4:13:43
[    3.022982] eth%d: device MAC address 4e:29:f7:d4:13:43
[    3.022993]  Enable RX Mitigation via HW Watchdog Timer
[    3.023282] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@30200000[0]' - status (0)
[    3.461647] libphy: stmmac: probed
[    3.461692] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active
[    3.461708] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01)
[    3.461722] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02)
[    3.461737] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03)
[    3.461752] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04)
[    3.461766] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05)
[    3.461780] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06)
[    3.461795] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07)
[    3.461810] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08)
[    3.461825] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09)
[    3.461840] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a)
[    3.461854] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b)
[    3.461869] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c)
[    3.461884] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d)
[    3.461899] eth%d: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e)
[    3.461914] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f)
[    3.461929] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10)
[    3.461943] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11)
[    3.461958] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12)
[    3.461973] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13)
[    3.461987] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14)
[    3.462003] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15)
[    3.462016] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16)
[    3.462029] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17)
[    3.462042] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18)
[    3.462055] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19)
[    3.462069] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a)
[    3.462084] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b)
[    3.462099] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c)
[    3.462113] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d)
[    3.462128] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e)
[    3.462143] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f)
[    3.464053] PPP generic driver version 2.4.2
[    3.464629] Atmel at76x USB Wireless LAN Driver 0.17 loading
[    3.464807] usbcore: registered new interface driver at76c50x-usb
[    3.464969] usbcore: registered new interface driver rtl8187
[    3.465100] usbcore: registered new interface driver rndis_wlan
[    3.465207] usbcore: registered new interface driver zd1201
[    3.465803] usbcore: registered new interface driver rt2800usb
[    3.465963] Rockchip WiFi SYS interface (V1.00) ...
[    3.466052] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    3.466167] usbcore: registered new interface driver pegasus
[    3.466269] usbcore: registered new interface driver rtl8150
[    3.466363] usbcore: registered new interface driver r8152
[    3.466574] usbcore: registered new interface driver asix
[    3.466708] usbcore: registered new interface driver ax88179_178a
[    3.466805] usbcore: registered new interface driver cdc_ether
[    3.466941] usbcore: registered new interface driver dm9601
[    3.467084] usbcore: registered new interface driver smsc75xx
[    3.467204] usbcore: registered new interface driver smsc95xx
[    3.467296] usbcore: registered new interface driver net1080
[    3.467389] usbcore: registered new interface driver rndis_host
[    3.467473] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    3.467651] usbcore: registered new interface driver cdc_ncm
[    3.467757] usbcore: registered new interface driver cdc_mbim
[    3.468366] 30040000.usb supply vusb_d not found, using dummy regulator
[    3.468510] 30040000.usb supply vusb_a not found, using dummy regulator
[    3.482173] dwc2 30040000.usb: DWC OTG Controller
[    3.482246] dwc2 30040000.usb: new USB bus registered, assigned bus number 1
[    3.482330] dwc2 30040000.usb: irq 49, io mem 0x30040000
[    3.482868] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.482896] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.482914] usb usb1: Product: DWC OTG Controller
[    3.482930] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg
[    3.482944] usb usb1: SerialNumber: 30040000.usb
[    3.484283] hub 1-0:1.0: USB hub found
[    3.484370] hub 1-0:1.0: 1 port detected
[    3.486261] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.486303] ehci-platform: EHCI generic platform driver
[    3.489163] ehci-platform 30080000.usb: EHCI Host Controller
[    3.489653] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2
[    3.490081] ehci-platform 30080000.usb: irq 50, io mem 0x30080000
[    3.498568] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00
[    3.498957] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    3.498980] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.498997] usb usb2: Product: EHCI Host Controller
[    3.499013] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.499026] usb usb2: SerialNumber: 30080000.usb
[    3.500299] hub 2-0:1.0: USB hub found
[    3.500396] hub 2-0:1.0: 1 port detected
[    3.503536] ehci-platform 300c0000.usb: EHCI Host Controller
[    3.504131] ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3
[    3.504551] ehci-platform 300c0000.usb: irq 52, io mem 0x300c0000
[    3.514561] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00
[    3.514939] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    3.514963] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.514980] usb usb3: Product: EHCI Host Controller
[    3.514997] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.515013] usb usb3: SerialNumber: 300c0000.usb
[    3.516275] hub 3-0:1.0: USB hub found
[    3.516365] hub 3-0:1.0: 1 port detected
[    3.519530] ehci-platform 30100000.usb: EHCI Host Controller
[    3.520110] ehci-platform 30100000.usb: new USB bus registered, assigned bus number 4
[    3.520533] ehci-platform 30100000.usb: irq 54, io mem 0x30100000
[    3.530568] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00
[    3.530995] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    3.531019] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.531034] usb usb4: Product: EHCI Host Controller
[    3.531049] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.531063] usb usb4: SerialNumber: 30100000.usb
[    3.532303] hub 4-0:1.0: USB hub found
[    3.532399] hub 4-0:1.0: 1 port detected
[    3.533415] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.533478] ohci-platform: OHCI generic platform driver
[    3.534064] ohci-platform 300a0000.usb: Generic Platform OHCI controller
[    3.534585] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5
[    3.534916] ohci-platform 300a0000.usb: irq 51, io mem 0x300a0000
[    3.594860] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    3.594888] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.594903] usb usb5: Product: Generic Platform OHCI controller
[    3.594917] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.594931] usb usb5: SerialNumber: 300a0000.usb
[    3.596206] hub 5-0:1.0: USB hub found
[    3.596300] hub 5-0:1.0: 1 port detected
[    3.597398] ohci-platform 300e0000.usb: Generic Platform OHCI controller
[    3.597867] ohci-platform 300e0000.usb: new USB bus registered, assigned bus number 6
[    3.598291] ohci-platform 300e0000.usb: irq 53, io mem 0x300e0000
[    3.654851] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    3.654881] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.654898] usb usb6: Product: Generic Platform OHCI controller
[    3.654915] usb usb6: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.654929] usb usb6: SerialNumber: 300e0000.usb
[    3.656183] hub 6-0:1.0: USB hub found
[    3.656286] hub 6-0:1.0: 1 port detected
[    3.657323] ohci-platform 30120000.usb: Generic Platform OHCI controller
[    3.657841] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7
[    3.658202] ohci-platform 30120000.usb: irq 55, io mem 0x30120000
[    3.714858] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    3.714892] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.714909] usb usb7: Product: Generic Platform OHCI controller
[    3.714923] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.714938] usb usb7: SerialNumber: 30120000.usb
[    3.716206] hub 7-0:1.0: USB hub found
[    3.716316] hub 7-0:1.0: 1 port detected
[    3.717662] usbcore: registered new interface driver cdc_acm
[    3.717686] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    3.717808] usbcore: registered new interface driver cdc_wdm
[    3.718113] usbcore: registered new interface driver usb-storage
[    3.718341] usbcore: registered new interface driver usbserial
[    3.718439] usbcore: registered new interface driver usbserial_generic
[    3.718636] usbserial: USB Serial support registered for generic
[    3.718803] usbcore: registered new interface driver keyspan
[    3.718877] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    3.718950] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    3.719016] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    3.719084] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    3.719221] usbcore: registered new interface driver option
[    3.719295] usbserial: USB Serial support registered for GSM modem (1-port)
[    3.720042] usbcore: registered new interface driver oti6858
[    3.720127] usbserial: USB Serial support registered for oti6858
[    3.720255] usbcore: registered new interface driver qcserial
[    3.720344] usbserial: USB Serial support registered for Qualcomm USB modem
[    3.720523] usbcore: registered new interface driver sierra
[    3.720597] usbserial: USB Serial support registered for Sierra USB modem
[    3.722674] usbcore: registered new interface driver iforce
[    3.722892] usbcore: registered new interface driver xpad
[    3.723194] usbcore: registered new interface driver usbtouchscreen
[    3.724689] i2c /dev entries driver
[    3.727042] IR NEC protocol handler initialized
[    3.727076] IR RC5(x/sz) protocol handler initialized
[    3.727099] IR RC6 protocol handler initialized
[    3.727117] IR JVC protocol handler initialized
[    3.727137] IR Sony protocol handler initialized
[    3.727157] IR SANYO protocol handler initialized
[    3.727175] IR Sharp protocol handler initialized
[    3.727193] IR MCE Keyboard/mouse protocol handler initialized
[    3.727213] IR XMP protocol handler initialized
[    3.729224] usbcore: registered new interface driver uvcvideo
[    3.729248] USB Video Class driver (1.1.1)
[    3.731784] Boot mode: normal
[    3.733428] rockchip-thermal 11150000.tsadc: tsadc is probed successfully!
[    3.735505] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    3.735984] Bluetooth: Virtual HCI driver ver 1.5
[    3.736362] Bluetooth: HCI UART driver ver 2.3
[    3.736385] Bluetooth: HCI UART protocol H4 registered
[    3.736397] Bluetooth: HCI UART protocol LL registered
[    3.736408] Bluetooth: HCI UART protocol ATH3K registered
[    3.736421] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    3.736660] Bluetooth: HCI UART protocol BCM registered
[    3.736857] usbcore: registered new interface driver bfusb
[    3.737019] usbcore: registered new interface driver btusb
[    3.737044] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    3.737880] cpu cpu0: leakage=9
[    3.737924] cpu cpu0: leakage-volt-sel=1
[    3.738195] cpu cpu0: Failed to get pvtm
[    3.740186] cpu cpu0: avs=0
[    3.740317] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    3.740351] cpu cpu0: failed to read out thermal zone (-22)
[    3.741219] cpu cpu0: failed to find power_model node
[    3.742204] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset
[    3.742233] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup
[    3.742262] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0)
[    3.742903] Synopsys Designware Multimedia Card Interface Driver
[    3.743751] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode.
[    3.743949] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller.
[    3.743978] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a
[    3.744078] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo
[    3.744155] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found
[    3.744168] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found
[    3.744196] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer cd
[    3.744207] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    3.744244] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/dwmmc@30000000[0]' - status (0)
[    3.744299] gpio-49 (cd): gpiod_set_debounce: missing set() or set_debounce() operations
[    3.744314] dwmmc_rockchip 30000000.dwmmc: Got CD GPIO
[    3.744329] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer wp
[    3.744338] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    3.744350] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30000000[0]'
[    3.744363] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30000000[0]'
[    3.744374] dwmmc_rockchip 30000000.dwmmc: using lookup tables for GPIO lookup
[    3.744384] dwmmc_rockchip 30000000.dwmmc: lookup for GPIO wp failed
[    3.757287] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.770279] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized
[    3.770901] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available
[    3.771026] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode.
[    3.771173] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller.
[    3.771198] dwmmc_rockchip 30010000.dwmmc: Version ID is 270a
[    3.771312] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo
[    3.771389] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found
[    3.771402] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found
[    3.771427] dwmmc_rockchip 30010000.dwmmc: GPIO lookup for consumer wp
[    3.771441] dwmmc_rockchip 30010000.dwmmc: using device tree for GPIO lookup
[    3.771456] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30010000[0]'
[    3.771469] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30010000[0]'
[    3.771478] dwmmc_rockchip 30010000.dwmmc: using lookup tables for GPIO lookup
[    3.771490] dwmmc_rockchip 30010000.dwmmc: lookup for GPIO wp failed
[    3.771596] dwmmc_rockchip 30010000.dwmmc: allocated mmc-pwrseq
[    3.784559] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2)
[    3.797217] dwmmc_rockchip 30010000.dwmmc: 1 slots initialized
[    3.797577] dwmmc_rockchip 30020000.dwmmc: IDMAC supports 32-bit address mode.
[    3.797737] dwmmc_rockchip 30020000.dwmmc: Using internal DMA controller.
[    3.797762] dwmmc_rockchip 30020000.dwmmc: Version ID is 270a
[    3.797855] dwmmc_rockchip 30020000.dwmmc: DW MMC controller at irq 47,32 bit host data width,256 deep fifo
[    3.797920] dwmmc_rockchip 30020000.dwmmc: No vmmc regulator found
[    3.797935] dwmmc_rockchip 30020000.dwmmc: No vqmmc regulator found
[    3.797959] dwmmc_rockchip 30020000.dwmmc: GPIO lookup for consumer wp
[    3.797973] dwmmc_rockchip 30020000.dwmmc: using device tree for GPIO lookup
[    3.797988] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30020000[0]'
[    3.797998] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30020000[0]'
[    3.798009] dwmmc_rockchip 30020000.dwmmc: using lookup tables for GPIO lookup
[    3.798023] dwmmc_rockchip 30020000.dwmmc: lookup for GPIO wp failed
[    3.810943] mmc_host mmc2: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3)
[    3.822913] dwmmc_rockchip 30020000.dwmmc: 1 slots initialized
[    3.823885] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/working[0]' - status (0)
[    3.824932] ledtrig-cpu: registered to indicate activity on CPUs
[    3.825164] hidraw: raw HID events driver (C) Jiri Kosina
[    3.826242] usbcore: registered new interface driver usbhid
[    3.826275] usbhid: USB HID core driver
[    3.827900] ashmem: initialized
[    3.832397] rknandbase v1.2 2018-05-08
[    3.833003] rknand 30030000.nandc: rknand_probe clk rate = 150000000
[    3.833650] ftl_init fffffffe
[    3.833672] rk_ftl_init fail
[    3.834952] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 300000Hz, actual 244140HZ div = 2)
[    3.835771] usbcore: registered new interface driver snd-usb-audio
[    3.835982] usbcore: registered new interface driver snd-ua101
[    3.836334] usbcore: registered new interface driver snd-usb-caiaq
[    3.836656] usbcore: registered new interface driver snd-usb-6fire
[    3.836906] usbcore: registered new interface driver snd-usb-hiface
[    3.837066] usbcore: registered new interface driver snd-bcd2000
[    3.837222] usbcore: registered new interface driver snd_usb_pod
[    3.837375] usbcore: registered new interface driver snd_usb_podhd
[    3.837524] usbcore: registered new interface driver snd_usb_toneport
[    3.837665] usbcore: registered new interface driver snd_usb_variax
[    3.847922] u32 classifier
[    3.847960]     input device check on
[    3.847969]     Actions configured
[    3.847996] Netfilter messages via NETLINK v0.30.
[    3.848037] nfnl_acct: registering with nfnetlink.
[    3.848182] nf_conntrack version 0.5.0 (15384 buckets, 61536 max)
[    3.849461] Initializing XFRM netlink socket
[    3.851033] NET: Registered protocol family 10
[    3.853475] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.854167] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
[    3.854591] sit: IPv6 over IPv4 tunneling driver
[    3.856127] NET: Registered protocol family 17
[    3.856376] NET: Registered protocol family 15
[    3.856806] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    3.857070] Bridge firewalling registered
[    3.857130] can: controller area network core (rev 20120528 abi 9)
[    3.857432] mmc2: new high speed MMC card at address 0001
[    3.858185] NET: Registered protocol family 29
[    3.858241] can: raw protocol (rev 20120528)
[    3.858271] can: broadcast manager protocol (rev 20120528 t)
[    3.858314] can: netlink gateway (rev 20130117) max_hops=1
[    3.859144] mmcblk2: mmc2:0001 P1J95K 7.30 GiB
[    3.860018] mmcblk2boot0: mmc2:0001 P1J95K partition 1 2.00 MiB
[    3.860706] Bluetooth: RFCOMM TTY layer initialized
[    3.860784] Bluetooth: RFCOMM socket layer initialized
[    3.860909] mmcblk2boot1: mmc2:0001 P1J95K partition 2 2.00 MiB
[    3.861121] Bluetooth: RFCOMM ver 1.11
[    3.861253] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.861639] Bluetooth: HIDP socket layer initialized
[    3.861832] mmcblk2rpmb: mmc2:0001 P1J95K partition 3 2.00 MiB
[    3.862580] 8021q: 802.1Q VLAN Support v1.8
[    3.863179] lib80211: common routines for IEEE802.11 drivers
[    3.863225] lib80211_crypt: registered algorithm 'NULL'
[    3.863262] lib80211_crypt: registered algorithm 'WEP'
[    3.863285] lib80211_crypt: registered algorithm 'CCMP'
[    3.863309] lib80211_crypt: registered algorithm 'TKIP'
[    3.863331] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    3.863559] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    3.863608] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = esp8089
[    3.863626] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    3.863640] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    3.863658] of_get_named_gpiod_flags: can't parse 'WIFI,poweren_gpio' property of node '/wireless-wlan[0]'
[    3.863672] of_get_named_gpiod_flags: can't parse 'WIFI,vbat_gpio' property of node '/wireless-wlan[0]'
[    3.863686] of_get_named_gpiod_flags: can't parse 'WIFI,reset_gpio' property of node '/wireless-wlan[0]'
[    3.863792] of_get_named_gpiod_flags: parsed 'WIFI,host_wake_irq' property of node '/wireless-wlan[0]' - status (0)
[    3.863814] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 28, flags = 1.
[    3.863907]  mmcblk2: p1
[    3.864380] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    3.864408] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    3.864432] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    3.866114] [BT_RFKILL]: Enter rfkill_rk_init
[    3.867228] Key type dns_resolver registered
[    3.867874] flash vendor_init_thread!
[    3.867901] flash vendor storage:20170308 ret = -1
[    3.867999] Error: Driver 'sc031gs' is already registered, aborting...
[    3.869178] Registering SWP/SWPB emulation handler
[    3.870321] vendor storage:20190527 ret = 0
[    3.871284] registered taskstats version 1
[    3.871329] Loading compiled-in X.509 certificates
[    3.875495] Btrfs loaded
[    3.877194] rga2: Driver loaded successfully ver:4.01
[    3.877582] rga2: Module initialized.
[    3.877641] pvtm list NULL
[    3.879491] rk-vcodec 20030000.rkvdec: leakage=6
[    3.879546] rk-vcodec 20030000.rkvdec: leakage-volt-sel=1
[    3.879722] rk-vcodec 20030000.rkvdec: Failed to get pvtm
[    3.880295] rk-vcodec 20030000.rkvdec: avs=0
[    3.880692] rk-vcodec 20030000.rkvdec: probe device
[    3.881339] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled
[    3.883371] rk-vcodec 20030000.rkvdec: init success
[    3.884927] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]'
[    3.884962] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]'
[    3.886636] asoc-simple-card hdmi-sound: i2s-hifi <-> 100c0000.i2s0 mapping ok
[    3.887751] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 200000Hz, actual 162760HZ div = 3)
[    3.889634] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]'
[    3.889666] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]'
[    3.891242] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok
[    3.894818] hctosys: unable to open rtc device (rtc0)
[    3.914748] ALSA device list:
[    3.914793]   #0: DW-I2S-HDMI
[    3.914807]   #1: SPDIF
[    3.916421] Freeing unused kernel memory: 808K
[    3.916443] This architecture does not have kernel memory protection.
[    3.946729] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 100000Hz, actual 97656HZ div = 5)
[    4.017797] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[    4.048008] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[    4.061442] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[    4.065557] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    4.068792] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[    4.068997] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[    4.069176] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[    4.069282] mmc1: new high speed SDIO card at address 0001
[    4.110659] usb 5-1: new full-speed USB device number 2 using ohci-platform
[    4.323873] usb 5-1: New USB device found, idVendor=046d, idProduct=c534
[    4.323924] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.323937] usb 5-1: Product: USB Receiver
[    4.323952] usb 5-1: Manufacturer: Logitech
[    4.335872] input: Logitech USB Receiver as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.0/0003:046D:C534.0001/input/input1
[    4.393234] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-300a0000.usb-1/input0
[    4.403528] input: Logitech USB Receiver as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.1/0003:046D:C534.0002/input/input2
[    4.461228] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-300a0000.usb-1/input1
[    5.425737] EXT4-fs (mmcblk2p1): mounted filesystem with writeback data mode. Opts: (null)
[    6.035835] systemd[1]: System time before build time, advancing clock.
[    6.052310] systemd[1]: Inserted module 'autofs4'
[    6.061584] ip_tables: (C) 2000-2006 Netfilter Core Team
[    6.073647] cgroup: cgroup2: unknown option "nsdelegate"
[    6.095989] systemd[1]: systemd 245.4-4ubuntu3.17 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    6.097359] systemd[1]: Detected architecture arm.
[    6.112733] systemd[1]: Set hostname to <klipper>.
[    6.322175] ttyS2 - failed to request DMA, use interrupt mode
[    6.402039] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    6.408213] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    6.408241] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[    6.408251] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[    6.408261] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[    6.408271] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[    6.408281] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[    6.408291] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[    6.408301] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[    6.408311] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[    6.408322] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[    6.408331] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[    6.408341] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[    6.408350] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[    6.408360] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[    6.408370] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[    7.345012] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.345613] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    7.345662] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    7.350718] systemd[1]: Created slice system-modprobe.slice.
[    7.351949] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.354025] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.355070] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.356926] systemd[1]: Created slice User and Session Slice.
[    7.357992] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.358647] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.360332] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.361325] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.362923] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.363107] systemd[1]: Reached target Remote File Systems.
[    7.363885] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.364010] systemd[1]: Reached target Slices.
[    7.364724] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.364841] systemd[1]: Reached target Swap.
[    7.365465] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.365583] systemd[1]: Reached target System Time Set.
[    7.366374] random: systemd: uninitialized urandom read (16 bytes read, 90 bits of entropy available)
[    7.367584] systemd[1]: Listening on Syslog Socket.
[    7.369313] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.370892] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    7.383519] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    7.384902] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.387016] systemd[1]: Listening on Journal Socket.
[    7.389065] systemd[1]: Listening on udev Control Socket.
[    7.390859] systemd[1]: Listening on udev Kernel Socket.
[    7.392512] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    7.400167] systemd[1]: Mounting POSIX Message Queue File System...
[    7.411803] systemd[1]: Mounting Kernel Debug File System...
[    7.425856] systemd[1]: Mounting Kernel Trace File System...
[    7.441827] systemd[1]: Starting Restore / save the current clock...
[    7.455644] systemd[1]: Starting Set the console keyboard layout...
[    7.470467] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    7.472732] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[    7.488145] systemd[1]: Started Nameserver information manager.
[    7.520684] systemd[1]: Reached target Network (Pre).
[    7.525354] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    7.525751] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.541629] systemd[1]: Starting Load Kernel Modules...
[    7.556139] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.572672] systemd[1]: Starting udev Coldplug all Devices...
[    7.603029] systemd[1]: Mounted POSIX Message Queue File System.
[    7.607089] systemd[1]: Mounted Kernel Debug File System.
[    7.610324] systemd[1]: Mounted Kernel Trace File System.
[    7.621027] systemd[1]: Finished Restore / save the current clock.
[    7.631514] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    7.647224] systemd[1]: Finished Load Kernel Modules.
[    7.653712] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    7.656037] EXT4-fs (mmcblk2p1): re-mounted. Opts: commit=600,errors=remount-ro
[    7.668425] systemd[1]: Mounting Kernel Configuration File System...
[    7.682082] systemd[1]: Starting Apply Kernel Variables...
[    7.707860] systemd[1]: Finished Remount Root and Kernel File Systems.
[    7.710957] systemd[1]: Mounted Kernel Configuration File System.
[    7.716158] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    7.727059] systemd[1]: Starting Platform Persistent Storage Archival...
[    7.744395] systemd[1]: Starting Load/Save Random Seed...
[    7.756529] systemd[1]: Starting Create System Users...
[    7.845583] systemd[1]: Finished Apply Kernel Variables.
[    7.857432] systemd[1]: Finished Platform Persistent Storage Archival.
[    7.892688] systemd[1]: Finished Create System Users.
[    7.903049] systemd[1]: Starting Create Static Device Nodes in /dev...
[    7.976071] systemd[1]: Finished Set the console keyboard layout.
[    8.000588] systemd[1]: Finished Create Static Device Nodes in /dev.
[    8.002928] systemd[1]: Reached target Local File Systems (Pre).
[    8.012557] systemd[1]: Mounting /tmp...
[    8.024258] systemd[1]: Starting udev Kernel Device Manager...
[    8.040735] systemd[1]: Mounted /tmp.
[    8.050001] systemd[1]: Reached target Local File Systems.
[    8.069614] systemd[1]: Starting Armbian leds state...
[    8.090014] systemd[1]: Starting Armbian ZRAM config...
[    8.111045] systemd[1]: Starting Set console font and keymap...
[    8.133077] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    8.142844] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    8.195732] systemd[1]: plymouth-read-write.service: Succeeded.
[    8.200213] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    8.224344] systemd[1]: Finished Set console font and keymap.
[    8.247547] systemd[1]: Finished Armbian leds state.
[    8.461930] systemd[1]: Finished udev Coldplug all Devices.
[    8.481339] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[    8.532153] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[    8.555682] systemd[1]: Starting Raise network interfaces...
[    8.575998] systemd[1]: Started udev Kernel Device Manager.
[    8.589889] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[    8.590467] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[    8.591086] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[    8.591673] systemd[1]: Reached target Local Encrypted Volumes.
[    8.633704] zram: Added device: zram0
[    8.643079] zram: Added device: zram1
[    8.647474] zram: Added device: zram2
[    8.751584] cfg80211: World regulatory domain updated:
[    8.751638] cfg80211:  DFS Master region: unset
[    8.751652] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    8.751671] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    8.751688] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    8.751711] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    8.751745] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    8.751783] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    8.751803] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[    8.751816] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    8.751836] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[    9.146479] zram0: detected capacity change from 0 to 504537088
[    9.317512] systemd[1]: Found device /dev/ttyS2.
[    9.329354] rk3228-codec 12010000.codec: GPIO lookup for consumer spk-en
[    9.329364] rk3228-codec 12010000.codec: using device tree for GPIO lookup
[    9.329376] of_get_named_gpiod_flags: can't parse 'spk-en-gpios' property of node '/codec@12010000[0]'
[    9.329425] of_get_named_gpiod_flags: parsed 'spk-en-gpio' property of node '/codec@12010000[0]' - status (0)
[    9.329507] rk3228-codec 12010000.codec: spk_depop_time use default value.
[    9.331562] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]'
[    9.331574] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]'
[    9.340407] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '20:09:06', on 'Aug 25 2021'.
[    9.341969] mali-utgard 20001000.gpu: mali_platform_device->num_resources = 13
[    9.342013] mali-utgard 20001000.gpu: resource[0].start = 0x0x20001000
[    9.342027] mali-utgard 20001000.gpu: resource[1].start = 0x0x20000000
[    9.342040] mali-utgard 20001000.gpu: resource[2].start = 0x0x20003000
[    9.342054] mali-utgard 20001000.gpu: resource[3].start = 0x0x20008000
[    9.342067] mali-utgard 20001000.gpu: resource[4].start = 0x0x20004000
[    9.342078] mali-utgard 20001000.gpu: resource[5].start = 0x0x2000a000
[    9.342089] mali-utgard 20001000.gpu: resource[6].start = 0x0x20005000
[    9.342102] mali-utgard 20001000.gpu: resource[7].start = 0x0x00000020
[    9.342114] mali-utgard 20001000.gpu: resource[8].start = 0x0x00000021
[    9.342128] mali-utgard 20001000.gpu: resource[9].start = 0x0x00000022
[    9.342138] mali-utgard 20001000.gpu: resource[10].start = 0x0x00000021
[    9.342151] mali-utgard 20001000.gpu: resource[11].start = 0x0x00000022
[    9.342161] mali-utgard 20001000.gpu: resource[12].start = 0x0x00000021
[    9.342176] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 623; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali.
[    9.342849] mali-utgard 20001000.gpu: leakage=6
[    9.342897] mali-utgard 20001000.gpu: leakage-volt-sel=1
[    9.343071] mali-utgard 20001000.gpu: Failed to get pvtm
[    9.343708] mali-utgard 20001000.gpu: avs=0
[    9.344167] mali-utgard 20001000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    9.369397] asoc-simple-card sound: rk3228-hifi <-> 100b0000.i2s1 mapping ok
[    9.398230] Mali: Mali device driver loaded
[    9.443093] devfreq 20001000.gpu: Couldn't update frequency transition information.
[    9.940716] gpio_ir_recv ir-receiver: GPIO lookup for consumer (null)
[    9.940776] gpio_ir_recv ir-receiver: using device tree for GPIO lookup
[    9.940848] of_get_named_gpiod_flags: parsed 'gpios' property of node '/ir-receiver[0]' - status (0)
[    9.941004] Registered IR keymap rc-rktvbox
[    9.941302] rc rc1: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1
[    9.941999] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1/input3
[   10.034237] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   10.036169] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   10.037627] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   10.057350] random: nonblocking pool is initialized
[   10.127802] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   10.180905] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[   10.181300] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   10.181590] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[   10.183901] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   10.184600] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   10.185228] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   10.212805] systemd[1]: Finished Load/Save Random Seed.
[   10.247574] systemd[1]: plymouth-read-write.service: Succeeded.
[   10.272507] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   10.372109] Adding 492708k swap on /dev/zram0.  Priority:5 extents:1 across:492708k SS
[   10.654998] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   10.656050] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   10.703965] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   10.705285] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   10.767587] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   10.815850] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[   10.816386] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   10.816704] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[   10.850746] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   10.851462] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   10.852249] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   10.852850] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   10.867036] systemd[1]: plymouth-read-write.service: Succeeded.
[   10.885453] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   10.967816] mmc1: card 0001 removed
[   10.987624] systemd[1]: Finished Raise network interfaces.
[   10.990839] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2)
[   11.042909] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 300000Hz, actual 244140HZ div = 2)
[   11.089672] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   11.090955] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   11.092247] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   11.093578] zram1: detected capacity change from 0 to 52428800
[   11.106830] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   11.121417] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 200000Hz, actual 162760HZ div = 3)
[   11.132038] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[   11.132611] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   11.133002] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[   11.134303] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   11.134985] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   11.135612] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   11.136236] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   11.141623] systemd[1]: plymouth-read-write.service: Succeeded.
[   11.150479] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   11.178776] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 100000Hz, actual 97656HZ div = 5)
[   11.212825] systemd[1]: Finished Armbian ZRAM config.
[   11.240037] systemd[1]: Starting Armbian memory supported logging...
[   11.251330] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[   11.285851] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[   11.306687] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[   11.310819] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[   11.312374] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[   11.312479] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[   11.312567] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[   11.312620] mmc1: new high speed SDIO card at address 0001
[   11.393860] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
[   11.683347] systemd[1]: Starting Load/Save RF Kill Switch Status...
[   11.760305] systemd[1]: Started Load/Save RF Kill Switch Status.
[   16.571114] systemd[1]: Finished Armbian memory supported logging.
[   16.583309] systemd[1]: Starting Journal Service...
[   16.769767] systemd[1]: systemd-rfkill.service: Succeeded.
[   17.147840] systemd[1]: Started Journal Service.
[   17.211582] systemd-journald[665]: Received client request to flush runtime journal.
[   18.649046] nr_pdflush_threads exported in /proc is scheduled for removal
[   41.707060] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   41.947183] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   41.950850] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   42.829618] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   46.385214] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.385299] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.385361] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.385401] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.385436] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.385464] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
For this one, the ESP8089 wasn't even detected:
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.194-rk322x (root@runner7) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #2 SMP Wed Aug 25 20:09:42 UTC 2021
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Generic RK322x TV Box board
[    0.000000] cma: Reserved 16 MiB at 0x9f000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 253952
[    0.000000] free_area_init_node: node 0, pgdat b1253b40, node_mem_map ee6f1000
[    0.000000]   Normal zone: 2304 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 253952 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv65535.65535 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 14 pages/cpu @ee68f000 s24856 r8192 d24296 u57344
[    0.000000] pcpu-alloc: s24856 r8192 d24296 u57344 alloc=14*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 251648
[    0.000000] Kernel command line: earlyprintk root=UUID=bce0e15e-76b7-4f9c-9149-332bcfd83573 console=ttyS2,115200n8 console=tty1 rootwait rootfstype=ext4  consoleblank=0 loglevel=1 ubootpart=343a1e5a-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u coherent_pool=2M  cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 960640K/1015808K available (12862K kernel code, 919K rwdata, 3240K rodata, 808K init, 1219K bss, 38784K reserved, 16384K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xb0000000 - 0xf0000000   (1024 MB)
                   pkmap   : 0xafe00000 - 0xb0000000   (   2 MB)
                   modules : 0xaf000000 - 0xafe00000   (  14 MB)
                     .text : 0xb0008000 - 0xb0c97c6c   (12864 kB)
                     .init : 0xb10b0000 - 0xb117a000   ( 808 kB)
                     .data : 0xb117a000 - 0xb125fe94   ( 920 kB)
                      .bss : 0xb1261000 - 0xb1391f14   (1220 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]     Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000025] Switching to timer-based delay loop, resolution 41ns
[    0.001857] Console: colour dummy device 80x30
[    0.002048] console [tty1] enabled
[    0.002077] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.002096] pid_max: default: 32768 minimum: 301
[    0.002241] Security Framework initialized
[    0.002255] Yama: becoming mindful.
[    0.002340] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002357] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003361] Initializing cgroup subsys io
[    0.003401] Initializing cgroup subsys memory
[    0.003449] Initializing cgroup subsys devices
[    0.003470] Initializing cgroup subsys freezer
[    0.003488] Initializing cgroup subsys net_cls
[    0.003506] Initializing cgroup subsys perf_event
[    0.003524] Initializing cgroup subsys net_prio
[    0.003558] Initializing cgroup subsys pids
[    0.003715] CPU: Testing write buffer coherency: ok
[    0.003775] ftrace: allocating 41892 entries in 123 pages
[    0.086467] /cpus/cpu@f00 missing clock-frequency property
[    0.086508] /cpus/cpu@f01 missing clock-frequency property
[    0.086526] /cpus/cpu@f02 missing clock-frequency property
[    0.086547] /cpus/cpu@f03 missing clock-frequency property
[    0.086560] CPU0: update cpu_capacity 430
[    0.086572] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.086673] Setting up static identity map for 0x60008280 - 0x600082d8
[    0.089915] CPU1: update cpu_capacity 430
[    0.089927] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.091159] CPU2: update cpu_capacity 430
[    0.091168] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.092381] CPU3: update cpu_capacity 430
[    0.092390] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.092544] Brought up 4 CPUs
[    0.092588] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.092596] CPU: All CPU(s) started in SVC mode.
[    0.094345] devtmpfs: initialized
[    0.114737] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.115340] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.115389] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.116931] xor: measuring software checksum speed
[    0.154345]    arm4regs  :  1011.000 MB/sec
[    0.194449]    8regs     :   705.000 MB/sec
[    0.234549]    32regs    :   684.000 MB/sec
[    0.274652]    neon      :  1018.000 MB/sec
[    0.274663] xor: using function: neon (1018.000 MB/sec)
[    0.274708] pinctrl core: initialized pinctrl subsystem
[    0.276476] NET: Registered protocol family 16
[    0.279157] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.290834] cpuidle: using governor ladder
[    0.302843] cpuidle: using governor menu
[    0.320305] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[    0.320486] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[    0.320640] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[    0.320816] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[    0.327941] console [pstore-1] enabled
[    0.327954] pstore: Registered ramoops as persistent store backend
[    0.327967] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0
[    0.331466] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.331491] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.427942] raid6: int32x1  gen()   133 MB/s
[    0.495970] raid6: int32x1  xor()   131 MB/s
[    0.564196] raid6: int32x2  gen()   166 MB/s
[    0.632254] raid6: int32x2  xor()   136 MB/s
[    0.700618] raid6: int32x4  gen()   163 MB/s
[    0.768868] raid6: int32x4  xor()   137 MB/s
[    0.837015] raid6: int32x8  gen()   166 MB/s
[    0.905277] raid6: int32x8  xor()   113 MB/s
[    0.973413] raid6: neonx1   gen()   382 MB/s
[    1.041524] raid6: neonx1   xor()   290 MB/s
[    1.109747] raid6: neonx2   gen()   519 MB/s
[    1.177882] raid6: neonx2   xor()   376 MB/s
[    1.246148] raid6: neonx4   gen()   581 MB/s
[    1.314304] raid6: neonx4   xor()   400 MB/s
[    1.382568] raid6: neonx8   gen()   559 MB/s
[    1.450771] raid6: neonx8   xor()   391 MB/s
[    1.450784] raid6: using algorithm neonx4 gen() 581 MB/s
[    1.450794] raid6: .... xor() 400 MB/s, rmw enabled
[    1.450804] raid6: using intx1 recovery algorithm
[    1.451957] rockchip-pm rockchip-suspend: not set wakeup-config
[    1.451985] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    1.452420] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@0[0]'
[    1.452979] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@1[0]'
[    1.453689] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-regulator[0]' - status (0)
[    1.454348] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0)
[    1.454985] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[    1.455942] iommu: Adding device 20020000.vpu-service to group 0
[    1.456060] iommu: Adding device 20030000.rkvdec to group 1
[    1.456169] iommu: Adding device 20050000.vop to group 2
[    1.456267] iommu: Adding device 20070000.iep to group 3
[    1.456870] rk_iommu 20020800.iommu: can't get sclk
[    1.457601] rk_iommu 20030480.iommu: can't get sclk
[    1.457879] rk_iommu 20053f00.iommu: can't get sclk
[    1.458029] rk_iommu 20070800.iommu: can't get aclk
[    1.458049] rk_iommu 20070800.iommu: can't get hclk
[    1.458065] rk_iommu 20070800.iommu: can't get sclk
[    1.458995] SCSI subsystem initialized
[    1.459458] usbcore: registered new interface driver usbfs
[    1.459564] usbcore: registered new interface driver hub
[    1.459707] usbcore: registered new device driver usb
[    1.459939] media: Linux media interface: v0.10
[    1.460021] Linux video capture interface: v2.00
[    1.460291] pps_core: LinuxPPS API ver. 1 registered
[    1.460309] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.460353] PTP clock support registered
[    1.462545] Advanced Linux Sound Architecture Driver Initialized.
[    1.463725] Bluetooth: Core ver 2.21
[    1.463809] NET: Registered protocol family 31
[    1.463825] Bluetooth: HCI device and connection manager initialized
[    1.463849] Bluetooth: HCI socket layer initialized
[    1.463867] Bluetooth: L2CAP socket layer initialized
[    1.463930] Bluetooth: SCO socket layer initialized
[    1.464871] NetLabel: Initializing
[    1.464896] NetLabel:  domain hash size = 128
[    1.464906] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.464989] NetLabel:  unlabeled traffic allowed by default
[    1.466486] clocksource: Switched to clocksource arch_sys_counter
[    1.567571] NET: Registered protocol family 2
[    1.568543] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.568664] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[    1.569021] TCP: Hash tables configured (established 8192 bind 8192)
[    1.569124] UDP hash table entries: 512 (order: 2, 24576 bytes)
[    1.569195] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[    1.569577] NET: Registered protocol family 1
[    1.570391] RPC: Registered named UNIX socket transport module.
[    1.570420] RPC: Registered udp transport module.
[    1.570431] RPC: Registered tcp transport module.
[    1.570442] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.570922] Trying to unpack rootfs image as initramfs...
[    2.110714] Freeing initrd memory: 7588K
[    2.111850] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    2.115090] Initialise system trusted keyring
[    2.129535] VFS: Disk quotas dquot_6.6.0
[    2.129878] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    2.132761] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.136448] NFS: Registering the id_resolver key type
[    2.136541] Key type id_resolver registered
[    2.136554] Key type id_legacy registered
[    2.136592] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.136710] ntfs: driver 2.1.32 [Flags: R/W].
[    2.137706] JFS: nTxBlock = 7692, nTxLock = 61538
[    2.148997] SGI XFS with security attributes, no debug enabled
[    2.159004] NET: Registered protocol family 38
[    2.159066] Key type asymmetric registered
[    2.159088] Asymmetric key parser 'x509' registered
[    2.159533] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    2.160046] io scheduler noop registered
[    2.160077] io scheduler deadline registered
[    2.160173] io scheduler cfq registered (default)
[    2.163844] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator
[    2.169495] rk-vcodec 20020000.vpu-service: no regulator for vcodec
[    2.169997] rk-vcodec 20020000.vpu-service: probe device
[    2.170544] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled
[    2.172009] rk-vcodec 20020000.vpu-service: could not find power_model node
[    2.172040] rk-vcodec 20020000.vpu-service: init success
[    2.172426] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry
[    2.176967] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330
[    2.177000] dma-pl330 110f0000.pdma:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    2.178270] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    2.178923] pwm-regulator vdd-arm-regulator: GPIO lookup for consumer enable
[    2.178948] pwm-regulator vdd-arm-regulator: using device tree for GPIO lookup
[    2.178967] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-arm-regulator[0]'
[    2.178982] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-arm-regulator[0]'
[    2.178995] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup
[    2.179011] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed
[    2.179741] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable
[    2.179764] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup
[    2.179780] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]'
[    2.179795] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]'
[    2.179809] pwm-regulator vdd-log-regulator: using lookup tables for GPIO lookup
[    2.179825] pwm-regulator vdd-log-regulator: lookup for GPIO enable failed
[    2.180983] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.181901] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A
[    2.182828] console [ttyS2] enabled
[    2.184858] [drm] Initialized drm 1.1.0 20060810
[    2.187577] [drm] Rockchip DRM driver version: v1.0.1
[    2.187881] rockchip-drm display-subsystem: devfreq is not set
[    2.188710] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d1b2b0)
[    2.189163] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports
[    2.189194] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.189321] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy)
[    2.190866] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d13808)
[    2.190899] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.190910] [drm] No driver support for vblank timestamp query.
[    2.191056] rockchip-drm display-subsystem: failed to parse display resources
[    2.813458] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    2.818988] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    2.818996] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[    2.819004] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[    2.819010] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[    2.819017] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[    2.819024] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[    2.819030] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[    2.819037] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[    2.819044] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[    2.819051] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[    2.819057] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[    2.819064] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[    2.819070] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[    2.819077] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[    2.819084] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[    2.891157] Console: switching to colour frame buffer device 240x67
[    2.941211] rockchip-drm display-subsystem: fb0:  frame buffer device
[    2.956268] Registered IR keymap rc-cec
[    2.956579] rc rc0: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0
[    2.957285] input: RC for dw_hdmi as /devices/platform/200a0000.hdmi/rc/rc0/input0
[    2.960189] brd: module loaded
[    2.974367] loop: module loaded
[    2.974570] lkdtm: No crash points registered, enable through debugfs
[    2.977726] libphy: Fixed MDIO Bus: probed
[    2.977770] tun: Universal TUN/TAP device driver, 1.6
[    2.977783] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.978302] CAN device driver interface
[    2.980217] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output).
[    2.980257] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30).
[    2.980275] rk_gmac-dwmac 30200000.ethernet: RX delay(0x10).
[    2.980328] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes).
[    2.980511] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed
[    2.985612] rk_gmac-dwmac 30200000.ethernet: init for RMII
[    3.018653] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    3.018673]  Ring mode enabled
[    3.018688]  DMA HW capability register supported
[    3.018701]  Normal descriptors
[    3.018717]  RX Checksum Offload Engine supported (type 2)
[    3.018728]  TX Checksum insertion supported
[    3.018737]  Wake-Up On Lan supported
[    3.018856] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: 4e:29:f7:d4:13:43
[    3.018874] eth%d: device MAC address 4e:29:f7:d4:13:43
[    3.018885]  Enable RX Mitigation via HW Watchdog Timer
[    3.019186] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@30200000[0]' - status (0)
[    3.459382] libphy: stmmac: probed
[    3.459429] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active
[    3.459446] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01)
[    3.459460] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02)
[    3.459474] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03)
[    3.459489] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04)
[    3.459504] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05)
[    3.459519] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06)
[    3.459534] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07)
[    3.459549] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08)
[    3.459563] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09)
[    3.459578] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a)
[    3.459592] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b)
[    3.459608] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c)
[    3.459623] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d)
[    3.459637] eth%d: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e)
[    3.459652] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f)
[    3.459667] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10)
[    3.459682] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11)
[    3.459697] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12)
[    3.459712] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13)
[    3.459726] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14)
[    3.459740] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15)
[    3.459756] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16)
[    3.459770] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17)
[    3.459786] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18)
[    3.459800] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19)
[    3.459815] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a)
[    3.459829] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b)
[    3.459845] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c)
[    3.459859] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d)
[    3.459874] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e)
[    3.459889] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f)
[    3.461733] PPP generic driver version 2.4.2
[    3.462331] Atmel at76x USB Wireless LAN Driver 0.17 loading
[    3.462607] usbcore: registered new interface driver at76c50x-usb
[    3.462791] usbcore: registered new interface driver rtl8187
[    3.462922] usbcore: registered new interface driver rndis_wlan
[    3.463037] usbcore: registered new interface driver zd1201
[    3.463640] usbcore: registered new interface driver rt2800usb
[    3.463784] Rockchip WiFi SYS interface (V1.00) ...
[    3.463859] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    3.463987] usbcore: registered new interface driver pegasus
[    3.464079] usbcore: registered new interface driver rtl8150
[    3.464165] usbcore: registered new interface driver r8152
[    3.464272] usbcore: registered new interface driver asix
[    3.464356] usbcore: registered new interface driver ax88179_178a
[    3.464438] usbcore: registered new interface driver cdc_ether
[    3.464553] usbcore: registered new interface driver dm9601
[    3.464690] usbcore: registered new interface driver smsc75xx
[    3.464809] usbcore: registered new interface driver smsc95xx
[    3.464900] usbcore: registered new interface driver net1080
[    3.464994] usbcore: registered new interface driver rndis_host
[    3.465087] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    3.465263] usbcore: registered new interface driver cdc_ncm
[    3.465378] usbcore: registered new interface driver cdc_mbim
[    3.466052] 30040000.usb supply vusb_d not found, using dummy regulator
[    3.466182] 30040000.usb supply vusb_a not found, using dummy regulator
[    3.479948] dwc2 30040000.usb: DWC OTG Controller
[    3.480024] dwc2 30040000.usb: new USB bus registered, assigned bus number 1
[    3.480104] dwc2 30040000.usb: irq 49, io mem 0x30040000
[    3.480537] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.480586] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.480601] usb usb1: Product: DWC OTG Controller
[    3.480615] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg
[    3.480629] usb usb1: SerialNumber: 30040000.usb
[    3.481901] hub 1-0:1.0: USB hub found
[    3.482000] hub 1-0:1.0: 1 port detected
[    3.484063] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.484104] ehci-platform: EHCI generic platform driver
[    3.486867] ehci-platform 30080000.usb: EHCI Host Controller
[    3.487367] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2
[    3.487788] ehci-platform 30080000.usb: irq 50, io mem 0x30080000
[    3.498552] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00
[    3.498934] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    3.498954] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.498972] usb usb2: Product: EHCI Host Controller
[    3.498987] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.499001] usb usb2: SerialNumber: 30080000.usb
[    3.500261] hub 2-0:1.0: USB hub found
[    3.500364] hub 2-0:1.0: 1 port detected
[    3.503588] ehci-platform 300c0000.usb: EHCI Host Controller
[    3.504199] ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3
[    3.504610] ehci-platform 300c0000.usb: irq 52, io mem 0x300c0000
[    3.514541] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00
[    3.514923] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    3.514949] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.514965] usb usb3: Product: EHCI Host Controller
[    3.514979] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.514993] usb usb3: SerialNumber: 300c0000.usb
[    3.516263] hub 3-0:1.0: USB hub found
[    3.516360] hub 3-0:1.0: 1 port detected
[    3.519516] ehci-platform 30100000.usb: EHCI Host Controller
[    3.520084] ehci-platform 30100000.usb: new USB bus registered, assigned bus number 4
[    3.520519] ehci-platform 30100000.usb: irq 54, io mem 0x30100000
[    3.530531] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00
[    3.530916] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    3.530936] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.530952] usb usb4: Product: EHCI Host Controller
[    3.530965] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.530979] usb usb4: SerialNumber: 30100000.usb
[    3.532167] hub 4-0:1.0: USB hub found
[    3.532256] hub 4-0:1.0: 1 port detected
[    3.533261] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.533329] ohci-platform: OHCI generic platform driver
[    3.533920] ohci-platform 300a0000.usb: Generic Platform OHCI controller
[    3.534538] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5
[    3.534955] ohci-platform 300a0000.usb: irq 51, io mem 0x300a0000
[    3.594854] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    3.594879] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.594896] usb usb5: Product: Generic Platform OHCI controller
[    3.594913] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.594927] usb usb5: SerialNumber: 300a0000.usb
[    3.596193] hub 5-0:1.0: USB hub found
[    3.596286] hub 5-0:1.0: 1 port detected
[    3.597338] ohci-platform 300e0000.usb: Generic Platform OHCI controller
[    3.597751] ohci-platform 300e0000.usb: new USB bus registered, assigned bus number 6
[    3.598164] ohci-platform 300e0000.usb: irq 53, io mem 0x300e0000
[    3.654840] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    3.654870] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.654886] usb usb6: Product: Generic Platform OHCI controller
[    3.654900] usb usb6: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.654914] usb usb6: SerialNumber: 300e0000.usb
[    3.656179] hub 6-0:1.0: USB hub found
[    3.656282] hub 6-0:1.0: 1 port detected
[    3.657315] ohci-platform 30120000.usb: Generic Platform OHCI controller
[    3.657840] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7
[    3.658196] ohci-platform 30120000.usb: irq 55, io mem 0x30120000
[    3.714832] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    3.714863] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.714881] usb usb7: Product: Generic Platform OHCI controller
[    3.714898] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.714913] usb usb7: SerialNumber: 30120000.usb
[    3.716185] hub 7-0:1.0: USB hub found
[    3.716288] hub 7-0:1.0: 1 port detected
[    3.717646] usbcore: registered new interface driver cdc_acm
[    3.717671] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    3.717808] usbcore: registered new interface driver cdc_wdm
[    3.718139] usbcore: registered new interface driver usb-storage
[    3.718390] usbcore: registered new interface driver usbserial
[    3.718600] usbcore: registered new interface driver usbserial_generic
[    3.718718] usbserial: USB Serial support registered for generic
[    3.718864] usbcore: registered new interface driver keyspan
[    3.718934] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    3.718998] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    3.719068] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    3.719130] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    3.719255] usbcore: registered new interface driver option
[    3.719330] usbserial: USB Serial support registered for GSM modem (1-port)
[    3.720153] usbcore: registered new interface driver oti6858
[    3.720229] usbserial: USB Serial support registered for oti6858
[    3.720348] usbcore: registered new interface driver qcserial
[    3.720432] usbserial: USB Serial support registered for Qualcomm USB modem
[    3.720613] usbcore: registered new interface driver sierra
[    3.720683] usbserial: USB Serial support registered for Sierra USB modem
[    3.722781] usbcore: registered new interface driver iforce
[    3.722986] usbcore: registered new interface driver xpad
[    3.723291] usbcore: registered new interface driver usbtouchscreen
[    3.724807] i2c /dev entries driver
[    3.727164] IR NEC protocol handler initialized
[    3.727203] IR RC5(x/sz) protocol handler initialized
[    3.727221] IR RC6 protocol handler initialized
[    3.727242] IR JVC protocol handler initialized
[    3.727261] IR Sony protocol handler initialized
[    3.727281] IR SANYO protocol handler initialized
[    3.727304] IR Sharp protocol handler initialized
[    3.727322] IR MCE Keyboard/mouse protocol handler initialized
[    3.727340] IR XMP protocol handler initialized
[    3.729336] usbcore: registered new interface driver uvcvideo
[    3.729356] USB Video Class driver (1.1.1)
[    3.731883] Boot mode: normal
[    3.733538] rockchip-thermal 11150000.tsadc: tsadc is probed successfully!
[    3.735697] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    3.736164] Bluetooth: Virtual HCI driver ver 1.5
[    3.736535] Bluetooth: HCI UART driver ver 2.3
[    3.736558] Bluetooth: HCI UART protocol H4 registered
[    3.736570] Bluetooth: HCI UART protocol LL registered
[    3.736583] Bluetooth: HCI UART protocol ATH3K registered
[    3.736598] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    3.736839] Bluetooth: HCI UART protocol BCM registered
[    3.737031] usbcore: registered new interface driver bfusb
[    3.737194] usbcore: registered new interface driver btusb
[    3.737219] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    3.738034] cpu cpu0: leakage=9
[    3.738078] cpu cpu0: leakage-volt-sel=1
[    3.738351] cpu cpu0: Failed to get pvtm
[    3.740365] cpu cpu0: avs=0
[    3.740494] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    3.740526] cpu cpu0: failed to read out thermal zone (-22)
[    3.741400] cpu cpu0: failed to find power_model node
[    3.742394] pwrseq_simple sdio-pwrseq: GPIO lookup for consumer reset
[    3.742422] pwrseq_simple sdio-pwrseq: using device tree for GPIO lookup
[    3.742541] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/sdio-pwrseq[0]' - status (0)
[    3.743116] Synopsys Designware Multimedia Card Interface Driver
[    3.743946] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode.
[    3.744143] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller.
[    3.744170] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a
[    3.744270] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo
[    3.744346] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found
[    3.744360] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found
[    3.744393] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer cd
[    3.744407] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    3.744447] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/dwmmc@30000000[0]' - status (0)
[    3.744498] gpio-49 (cd): gpiod_set_debounce: missing set() or set_debounce() operations
[    3.744512] dwmmc_rockchip 30000000.dwmmc: Got CD GPIO
[    3.744528] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer wp
[    3.744540] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    3.744551] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30000000[0]'
[    3.744563] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30000000[0]'
[    3.744573] dwmmc_rockchip 30000000.dwmmc: using lookup tables for GPIO lookup
[    3.744585] dwmmc_rockchip 30000000.dwmmc: lookup for GPIO wp failed
[    3.757497] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.770554] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized
[    3.771093] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available
[    3.771217] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode.
[    3.771365] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller.
[    3.771390] dwmmc_rockchip 30010000.dwmmc: Version ID is 270a
[    3.771504] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo
[    3.771582] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found
[    3.771600] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found
[    3.771625] dwmmc_rockchip 30010000.dwmmc: GPIO lookup for consumer wp
[    3.771637] dwmmc_rockchip 30010000.dwmmc: using device tree for GPIO lookup
[    3.771651] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30010000[0]'
[    3.771665] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30010000[0]'
[    3.771675] dwmmc_rockchip 30010000.dwmmc: using lookup tables for GPIO lookup
[    3.771688] dwmmc_rockchip 30010000.dwmmc: lookup for GPIO wp failed
[    3.771794] dwmmc_rockchip 30010000.dwmmc: allocated mmc-pwrseq
[    3.784792] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2)
[    3.797420] dwmmc_rockchip 30010000.dwmmc: 1 slots initialized
[    3.797717] dwmmc_rockchip 30020000.dwmmc: IDMAC supports 32-bit address mode.
[    3.797849] dwmmc_rockchip 30020000.dwmmc: Using internal DMA controller.
[    3.797875] dwmmc_rockchip 30020000.dwmmc: Version ID is 270a
[    3.797961] dwmmc_rockchip 30020000.dwmmc: DW MMC controller at irq 47,32 bit host data width,256 deep fifo
[    3.798035] dwmmc_rockchip 30020000.dwmmc: No vmmc regulator found
[    3.798049] dwmmc_rockchip 30020000.dwmmc: No vqmmc regulator found
[    3.798075] dwmmc_rockchip 30020000.dwmmc: GPIO lookup for consumer wp
[    3.798085] dwmmc_rockchip 30020000.dwmmc: using device tree for GPIO lookup
[    3.798097] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30020000[0]'
[    3.798111] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30020000[0]'
[    3.798121] dwmmc_rockchip 30020000.dwmmc: using lookup tables for GPIO lookup
[    3.798132] dwmmc_rockchip 30020000.dwmmc: lookup for GPIO wp failed
[    3.811044] mmc_host mmc2: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3)
[    3.822821] dwmmc_rockchip 30020000.dwmmc: 1 slots initialized
[    3.823786] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/working[0]' - status (0)
[    3.824851] ledtrig-cpu: registered to indicate activity on CPUs
[    3.825070] hidraw: raw HID events driver (C) Jiri Kosina
[    3.826173] usbcore: registered new interface driver usbhid
[    3.826204] usbhid: USB HID core driver
[    3.827737] ashmem: initialized
[    3.832142] rknandbase v1.2 2018-05-08
[    3.832747] rknand 30030000.nandc: rknand_probe clk rate = 150000000
[    3.833400] ftl_init fffffffe
[    3.833424] rk_ftl_init fail
[    3.835400] usbcore: registered new interface driver snd-usb-audio
[    3.835624] usbcore: registered new interface driver snd-ua101
[    3.835824] usbcore: registered new interface driver snd-usb-caiaq
[    3.836099] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 300000Hz, actual 244140HZ div = 2)
[    3.836432] usbcore: registered new interface driver snd-usb-6fire
[    3.836684] usbcore: registered new interface driver snd-usb-hiface
[    3.836846] usbcore: registered new interface driver snd-bcd2000
[    3.836996] usbcore: registered new interface driver snd_usb_pod
[    3.837145] usbcore: registered new interface driver snd_usb_podhd
[    3.837299] usbcore: registered new interface driver snd_usb_toneport
[    3.837437] usbcore: registered new interface driver snd_usb_variax
[    3.847722] u32 classifier
[    3.847752]     input device check on
[    3.847762]     Actions configured
[    3.847785] Netfilter messages via NETLINK v0.30.
[    3.847824] nfnl_acct: registering with nfnetlink.
[    3.847967] nf_conntrack version 0.5.0 (15384 buckets, 61536 max)
[    3.849267] Initializing XFRM netlink socket
[    3.850856] NET: Registered protocol family 10
[    3.853364] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.853912] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
[    3.854365] sit: IPv6 over IPv4 tunneling driver
[    3.856110] NET: Registered protocol family 17
[    3.856409] NET: Registered protocol family 15
[    3.856839] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    3.857165] mmc2: new high speed MMC card at address 0001
[    3.857855] Bridge firewalling registered
[    3.857915] can: controller area network core (rev 20120528 abi 9)
[    3.858600] NET: Registered protocol family 29
[    3.858751] mmcblk2: mmc2:0001 P1J95K 7.30 GiB
[    3.858966] can: raw protocol (rev 20120528)
[    3.859003] can: broadcast manager protocol (rev 20120528 t)
[    3.859055] can: netlink gateway (rev 20130117) max_hops=1
[    3.859667] mmcblk2boot0: mmc2:0001 P1J95K partition 1 2.00 MiB
[    3.860491] mmcblk2boot1: mmc2:0001 P1J95K partition 2 2.00 MiB
[    3.861358] mmcblk2rpmb: mmc2:0001 P1J95K partition 3 2.00 MiB
[    3.862035] Bluetooth: RFCOMM TTY layer initialized
[    3.862090] Bluetooth: RFCOMM socket layer initialized
[    3.862733] Bluetooth: RFCOMM ver 1.11
[    3.862881] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.862928] Bluetooth: HIDP socket layer initialized
[    3.863046] 8021q: 802.1Q VLAN Support v1.8
[    3.863127] lib80211: common routines for IEEE802.11 drivers
[    3.863146] lib80211_crypt: registered algorithm 'NULL'
[    3.863175] lib80211_crypt: registered algorithm 'WEP'
[    3.863246] lib80211_crypt: registered algorithm 'CCMP'
[    3.863278] lib80211_crypt: registered algorithm 'TKIP'
[    3.863302] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    3.863408]  mmcblk2: p1
[    3.863574] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    3.863624] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = esp8089
[    3.863638] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    3.863651] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    3.863669] of_get_named_gpiod_flags: can't parse 'WIFI,poweren_gpio' property of node '/wireless-wlan[0]'
[    3.863684] of_get_named_gpiod_flags: can't parse 'WIFI,vbat_gpio' property of node '/wireless-wlan[0]'
[    3.863698] of_get_named_gpiod_flags: can't parse 'WIFI,reset_gpio' property of node '/wireless-wlan[0]'
[    3.863752] of_get_named_gpiod_flags: parsed 'WIFI,host_wake_irq' property of node '/wireless-wlan[0]' - status (0)
[    3.863766] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 28, flags = 1.
[    3.863788] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    3.863801] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    3.863821] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    3.864237] [BT_RFKILL]: Enter rfkill_rk_init
[    3.864648] Key type dns_resolver registered
[    3.865419] flash vendor_init_thread!
[    3.865463] flash vendor storage:20170308 ret = -1
[    3.865627] Error: Driver 'sc031gs' is already registered, aborting...
[    3.867335] Registering SWP/SWPB emulation handler
[    3.868426] vendor storage:20190527 ret = 0
[    3.869493] registered taskstats version 1
[    3.869537] Loading compiled-in X.509 certificates
[    3.873665] Btrfs loaded
[    3.875506] rga2: Driver loaded successfully ver:4.01
[    3.875904] rga2: Module initialized.
[    3.875964] pvtm list NULL
[    3.877737] rk-vcodec 20030000.rkvdec: leakage=6
[    3.877793] rk-vcodec 20030000.rkvdec: leakage-volt-sel=1
[    3.877962] rk-vcodec 20030000.rkvdec: Failed to get pvtm
[    3.878732] rk-vcodec 20030000.rkvdec: avs=0
[    3.879177] rk-vcodec 20030000.rkvdec: probe device
[    3.879846] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled
[    3.881754] rk-vcodec 20030000.rkvdec: init success
[    3.883507] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]'
[    3.883546] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]'
[    3.885069] asoc-simple-card hdmi-sound: i2s-hifi <-> 100c0000.i2s0 mapping ok
[    3.887785] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 200000Hz, actual 162760HZ div = 3)
[    3.888196] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]'
[    3.888226] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]'
[    3.889610] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok
[    3.893157] hctosys: unable to open rtc device (rtc0)
[    3.913419] ALSA device list:
[    3.913469]   #0: DW-I2S-HDMI
[    3.913482]   #1: SPDIF
[    3.915032] Freeing unused kernel memory: 808K
[    3.915060] This architecture does not have kernel memory protection.
[    3.942737] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 100000Hz, actual 97656HZ div = 5)
[    4.110640] usb 5-1: new full-speed USB device number 2 using ohci-platform
[    4.323841] usb 5-1: New USB device found, idVendor=046d, idProduct=c534
[    4.323886] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    4.323898] usb 5-1: Product: USB Receiver
[    4.323912] usb 5-1: Manufacturer: Logitech
[    4.335433] input: Logitech USB Receiver as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.0/0003:046D:C534.0001/input/input1
[    4.393175] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-300a0000.usb-1/input0
[    4.404494] input: Logitech USB Receiver as /devices/platform/300a0000.usb/usb5/5-1/5-1:1.1/0003:046D:C534.0002/input/input2
[    4.460133] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-300a0000.usb-1/input1
[    5.499743] EXT4-fs (mmcblk2p1): mounted filesystem with writeback data mode. Opts: (null)
[    6.141033] systemd[1]: System time before build time, advancing clock.
[    6.158729] systemd[1]: Inserted module 'autofs4'
[    6.169798] ip_tables: (C) 2000-2006 Netfilter Core Team
[    6.185101] cgroup: cgroup2: unknown option "nsdelegate"
[    6.211639] systemd[1]: systemd 245.4-4ubuntu3.17 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    6.213207] systemd[1]: Detected architecture arm.
[    6.230776] systemd[1]: Set hostname to <klipper>.
[    6.491902] ttyS2 - failed to request DMA, use interrupt mode
[    7.489275] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.489872] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    7.489918] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    7.495195] systemd[1]: Created slice system-modprobe.slice.
[    7.496389] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.498437] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    7.499530] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.501411] systemd[1]: Created slice User and Session Slice.
[    7.502568] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.503153] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.504800] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.505780] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    7.507367] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.507538] systemd[1]: Reached target Remote File Systems.
[    7.508338] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.508465] systemd[1]: Reached target Slices.
[    7.509164] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.509275] systemd[1]: Reached target Swap.
[    7.509908] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.510012] systemd[1]: Reached target System Time Set.
[    7.510998] random: systemd: uninitialized urandom read (16 bytes read, 87 bits of entropy available)
[    7.511995] systemd[1]: Listening on Syslog Socket.
[    7.513767] systemd[1]: Listening on fsck to fsckd communication Socket.
[    7.515297] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    7.527609] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    7.528988] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.531177] systemd[1]: Listening on Journal Socket.
[    7.533297] systemd[1]: Listening on udev Control Socket.
[    7.535132] systemd[1]: Listening on udev Kernel Socket.
[    7.536827] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    7.544456] systemd[1]: Mounting POSIX Message Queue File System...
[    7.556196] systemd[1]: Mounting Kernel Debug File System...
[    7.570184] systemd[1]: Mounting Kernel Trace File System...
[    7.586653] systemd[1]: Starting Restore / save the current clock...
[    7.599920] systemd[1]: Starting Set the console keyboard layout...
[    7.614655] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    7.616868] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[    7.631500] systemd[1]: Started Nameserver information manager.
[    7.658390] systemd[1]: Reached target Network (Pre).
[    7.663577] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    7.663966] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    7.679803] systemd[1]: Starting Load Kernel Modules...
[    7.695653] systemd[1]: Starting Remount Root and Kernel File Systems...
[    7.712418] systemd[1]: Starting udev Coldplug all Devices...
[    7.736476] systemd[1]: Mounted POSIX Message Queue File System.
[    7.739559] systemd[1]: Mounted Kernel Debug File System.
[    7.742707] systemd[1]: Mounted Kernel Trace File System.
[    7.751328] systemd[1]: Finished Restore / save the current clock.
[    7.760391] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    7.776627] systemd[1]: Finished Load Kernel Modules.
[    7.781106] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    7.792497] systemd[1]: Mounting Kernel Configuration File System...
[    7.796052] EXT4-fs (mmcblk2p1): re-mounted. Opts: commit=600,errors=remount-ro
[    7.806408] systemd[1]: Starting Apply Kernel Variables...
[    7.833188] systemd[1]: Finished Remount Root and Kernel File Systems.
[    7.843611] systemd[1]: Mounted Kernel Configuration File System.
[    7.849057] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    7.861395] systemd[1]: Starting Platform Persistent Storage Archival...
[    7.880670] systemd[1]: Starting Load/Save Random Seed...
[    7.894411] systemd[1]: Starting Create System Users...
[    7.984744] systemd[1]: Finished Apply Kernel Variables.
[    8.015829] systemd[1]: Finished Platform Persistent Storage Archival.
[    8.021502] systemd[1]: Finished Create System Users.
[    8.032772] systemd[1]: Starting Create Static Device Nodes in /dev...
[    8.126913] systemd[1]: Finished Create Static Device Nodes in /dev.
[    8.136598] systemd[1]: Starting udev Kernel Device Manager...
[    8.147150] systemd[1]: Finished Set the console keyboard layout.
[    8.149552] systemd[1]: Reached target Local File Systems (Pre).
[    8.162289] systemd[1]: Mounting /tmp...
[    8.190641] systemd[1]: Mounted /tmp.
[    8.203549] systemd[1]: Reached target Local File Systems.
[    8.231620] systemd[1]: Starting Armbian leds state...
[    8.259728] systemd[1]: Starting Armbian ZRAM config...
[    8.280523] systemd[1]: Starting Set console font and keymap...
[    8.309697] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[    8.325114] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[    8.371146] systemd[1]: plymouth-read-write.service: Succeeded.
[    8.376119] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[    8.395872] systemd[1]: Finished Set console font and keymap.
[    8.415672] systemd[1]: Finished Armbian leds state.
[    8.584837] random: nonblocking pool is initialized
[    8.607709] systemd[1]: Finished Load/Save Random Seed.
[    8.625103] systemd[1]: Finished udev Coldplug all Devices.
[    8.645218] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
[    8.655143] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[    8.680844] systemd[1]: Started udev Kernel Device Manager.
[    8.703740] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
[    8.782096] systemd[1]: Starting Raise network interfaces...
[    8.807957] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[    8.808405] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[    8.808720] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[    8.809061] systemd[1]: Reached target Local Encrypted Volumes.
[    8.868403] zram: Added device: zram0
[    8.887458] zram: Added device: zram1
[    8.904426] zram: Added device: zram2
[    8.922321] cfg80211: World regulatory domain updated:
[    8.922376] cfg80211:  DFS Master region: unset
[    8.922389] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[    8.922407] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[    8.922424] cfg80211:   (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    8.922436] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[    8.922585] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[    8.922610] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[    8.922622] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[    8.922634] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[    8.922652] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[    9.293474] zram0: detected capacity change from 0 to 504537088
[    9.425747] Adding 492708k swap on /dev/zram0.  Priority:5 extents:1 across:492708k SS
[    9.454758] systemd[1]: Found device /dev/ttyS2.
[    9.479546] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 417; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '', rk_ko_ver is '5', built at '20:09:06', on 'Aug 25 2021'.
[    9.479552] rk3228-codec 12010000.codec: GPIO lookup for consumer spk-en
[    9.479570] rk3228-codec 12010000.codec: using device tree for GPIO lookup
[    9.479586] of_get_named_gpiod_flags: can't parse 'spk-en-gpios' property of node '/codec@12010000[0]'
[    9.479635] of_get_named_gpiod_flags: parsed 'spk-en-gpio' property of node '/codec@12010000[0]' - status (0)
[    9.479755] rk3228-codec 12010000.codec: spk_depop_time use default value.
[    9.487416] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]'
[    9.487478] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]'
[    9.508587] mali-utgard 20001000.gpu: mali_platform_device->num_resources = 13
[    9.508653] mali-utgard 20001000.gpu: resource[0].start = 0x0x20001000
[    9.508668] mali-utgard 20001000.gpu: resource[1].start = 0x0x20000000
[    9.508683] mali-utgard 20001000.gpu: resource[2].start = 0x0x20003000
[    9.508717] mali-utgard 20001000.gpu: resource[3].start = 0x0x20008000
[    9.508746] mali-utgard 20001000.gpu: resource[4].start = 0x0x20004000
[    9.508760] mali-utgard 20001000.gpu: resource[5].start = 0x0x2000a000
[    9.508773] mali-utgard 20001000.gpu: resource[6].start = 0x0x20005000
[    9.508786] mali-utgard 20001000.gpu: resource[7].start = 0x0x00000020
[    9.508797] mali-utgard 20001000.gpu: resource[8].start = 0x0x00000021
[    9.508819] mali-utgard 20001000.gpu: resource[9].start = 0x0x00000022
[    9.508853] mali-utgard 20001000.gpu: resource[10].start = 0x0x00000021
[    9.508875] mali-utgard 20001000.gpu: resource[11].start = 0x0x00000022
[    9.508890] mali-utgard 20001000.gpu: resource[12].start = 0x0x00000021
[    9.508909] D : [File] : drivers/gpu/arm/mali400/mali/platform/rk/rk.c; [Line] : 623; [Func] : mali_platform_device_init(); to add platform_specific_data to platform_device_of_mali.
[    9.509576] mali-utgard 20001000.gpu: leakage=6
[    9.509658] mali-utgard 20001000.gpu: leakage-volt-sel=1
[    9.509957] mali-utgard 20001000.gpu: Failed to get pvtm
[    9.511275] mali-utgard 20001000.gpu: avs=0
[    9.512097] mali-utgard 20001000.gpu: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    9.522970] asoc-simple-card sound: rk3228-hifi <-> 100b0000.i2s1 mapping ok
[    9.524941] Mali: Mali device driver loaded
[    9.614850] devfreq 20001000.gpu: Couldn't update frequency transition information.
[   10.034378] gpio_ir_recv ir-receiver: GPIO lookup for consumer (null)
[   10.034448] gpio_ir_recv ir-receiver: using device tree for GPIO lookup
[   10.034736] of_get_named_gpiod_flags: parsed 'gpios' property of node '/ir-receiver[0]' - status (0)
[   10.035114] Registered IR keymap rc-rktvbox
[   10.035579] rc rc1: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1
[   10.036260] input: gpio_ir_recv as /devices/platform/ir-receiver/rc/rc1/input3
[   10.104007] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   10.105974] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   10.111947] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   10.131062] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   10.165986] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[   10.167444] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   10.168003] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[   10.169368] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   10.183277] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   10.184204] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   10.188922] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   10.229020] systemd[1]: plymouth-read-write.service: Succeeded.
[   10.236567] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   10.293841] zram1: detected capacity change from 0 to 52428800
[   10.345046] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   10.356231] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   10.357632] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   10.409506] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   10.452094] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[   10.452804] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   10.453194] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[   10.454329] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   10.457072] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   10.457990] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   10.471471] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   10.537181] systemd[1]: plymouth-read-write.service: Succeeded.
[   10.549737] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   10.675801] systemd[1]: Finished Armbian ZRAM config.
[   10.742375] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   10.752878] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   10.780260] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   10.785742] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   10.817714] systemd[1]: Starting Armbian memory supported logging...
[   10.879730] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   10.920880] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[   10.921594] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   10.922078] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[   10.923668] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   10.924252] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   10.924947] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   10.925486] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   10.968733] systemd[1]: plymouth-read-write.service: Succeeded.
[   10.976263] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   11.181299] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
[   11.211513] systemd[1]: Finished Raise network interfaces.
[   11.260421] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   11.262424] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   11.264356] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   11.280839] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
[   11.294255] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
[   11.296438] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
[   11.297089] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
[   11.298799] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   11.299545] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[   11.300545] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   11.301371] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[   11.325133] systemd[1]: plymouth-read-write.service: Succeeded.
[   11.334454] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
[   16.878388] systemd[1]: Finished Armbian memory supported logging.
[   16.891631] systemd[1]: Starting Journal Service...
[   17.426648] systemd[1]: Started Journal Service.
[   17.490944] systemd-journald[642]: Received client request to flush runtime journal.
[   18.907992] nr_pdflush_threads exported in /proc is scheduled for removal
[   42.252630] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   46.796494] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.796578] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.796638] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.796667] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.796703] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   46.796734] [drm:dw_hdmi_rockchip_set_property] *ERROR* failed to set rockchip hdmi connector property
[   85.206185] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[   85.206238] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[   85.206257] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[   85.206278] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[   85.206296] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[   85.206315] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[   85.206333] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[   85.206355] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[   85.206376] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[   85.206396] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[   85.206414] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[   85.206435] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[   85.206673] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[   85.206716] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[   85.206745] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
To finish up, here are some photos of my board (it's the exact same, as far as I can tell, as the one @Hoa Nguyen Vuhad) - alhough the marks say it's a "MXQPRO_V72". There are 2 oscilators, one close the wifi chip and one close to the RK3228A. The one close to the ESP8089 is 26 MHz and the other one 24MHz (i assume) - that's why I thought i didn't make sense for anything to work with the crystal set to 40 MHz.
https://photos.app.goo.gl/ggv6xZmMhybY9J77A
That's all I got for today haha. Once again, thanks for the help, and I'm sure I'll get this working with your help!
Link to comment
Share on other sites
@Luís Hansen First congrats for all the diving you had into the matter!
About the ESP8089, there are some facts can help us giving a starting point:
  • Your board is a MXQPRO_V72, there should be a led-conf right for your board in the list; stay stick to that, there is no sense in trying all the others
  • The ESP8089 has a 26Mhz crystal (the other 24Mhz is for the SoC, all rockchip SoCs have a 24Mhz reference crystal so far), so using anything else will result in the chip to be unable to attach to an access point (will show the networks though)
If the wlan device does not appear, it is something related to sdio bus and/or powering the chip (the pwrseq you can see in the dmesg), the original device tree can be useful to see if there is something wrong with that.
Link to comment
Thanks for the reply!
How do I find out what's the correct led config for my device? I'm assuming it's the MXQ_PRO.
How do I get the original device tree? I printed the DTB file that was on the /boot folder, does it help?
I also have a backup of the original emmc content, maybe it can give us a hint about something.
I also noticed that when I run modinfo esp8089, on the last parm line it says:
config:Firmware init config string (format: key=value;) (charp)
But it doesn't seem to have the crystal config. I'm not sure if it should appear there.
I read through the armbian_first_run.txt.template and it had FR_net_wifi_enabled=0. It says that if both are enabled, eth will be automatically disabled. As I'm able to connect via Ethernet and the wifi enabled was 0 (I assume), I wonder if it has something to do with it.
The thing is: I can't understand why the network is created but no wifi networks are visible. Why would it work exactly once, randomly, and then never work again?
Thanks @jock!
Link to comment
That should be right. Of course I can't be sure, but probably it is so.
This is the right place to find the original device tree. Usually it is contained somewhere in the first 32 megabytes of the image.
You can post it somewhere, I will try to extract it by myself, otherwiser binwalk utility should be able to extract it, or there is a tool @fabiobassa may hint you (I don't have the link)
If the network device is there (wlan0) but it is not able to see the networks or not able to connect, the issue is probably related to the crystal frequency or the firmware (but this last one is unlikely)
If the wlan0 device does not appear at all, then it is a matter of wrong bits in device tree.
This is the general behaviour, but indeed something from device tree may also prevent the device from work.
No, absolutely; that file is not in use during normal runtime.
Link to comment
I think I managed to get the original device tree!
Here it is: extracted_dtb.txt
Also, here's the device tree currently running on the device (I extracted using this method) current_dtb.txt
Thanks in advance!
Edited by Luís Hansen
Added current DTB
Link to comment
6 hours ago, jock said:
@Luís Hansen Maybe I spotted something wrong in led-conf6 device tree overlay.
Please overwrite the existing /boot/dtb/overlay/rk322x-led-conf6.dtbo file with this one: rk322x-led-conf6.dtbo
Then run rk322x-config, select led-conf6 and reboot.
BTW dmesg log is helpful, armbianmonitor -u link is even better
Hello there!
When I did that, I noticed there were no led-conf6.dtbo nor led-conf7.dtbo files on that folder!
I'm not sure how that's possible, but maybe that's why it worked for one boot and then never again.
Anyway, when I tried that, the ESP8089 was not detected.
Here are the dmesg and armbianmonitor outputs: not_found_new_led6_en1.txt armbianmonitor_new_led6_en1.txt
Thanks!
[EDIT]
I mounted a couple images locally, and none of them had the led-conf6 or 7 files:
Link to comment
11 hours ago, jock said:
@Luís Hansen Of course you have no such overlays, you took an archived/obsolete image from August 2021
You're right. Those were the versions that had the wlan-esp8089 ovlerlay. I'm not sure why the new versions don't have them, maybe it's not needed anymore?
Anyway, I booted into the newest version, tried out with the default config_led6 and your new version. On both, the network card was not detected. When I run rk322x-config it always says there's no wifi chip.
Here's the dmesg output: conf6_new_version_dmesg.txt
And here's the armbian monitor output: conf6_new_version_armbianmonitor.txt
I also tried running modinfo esp8089 and modprobe esp8089 and if failed, esp8089 module wasn't found.
Link to comment
So, I've been testing with other images. The ones in here https://users.armbian.com/jock/rk322x/armbian/stable with the legacy kernel also don't have the led6 or 7 configs.
I tried both versions (legacy and current kernels) with the old and new led6 overlays - no luck.
I even tried comparing my device's original device tree with the rk322x default one. I "decompiled" to DTS, copied the wlan part, recompiled to DTB but still did not get it to work.
Also found out that my box won't boot from the card - except if it has the multitool in it - if the original android is on the eMMC.
I restored it but then had to erase the flash for it to boot again into armbian - no big deal, I still have the backup if I need.
@jock, do you see any obvious reasons why the esp8089 wouldn't even be seen/detected by the device? Is there a way for me to debug which devices linux sees as connected?
Link to comment
@Luís Hansen sorry but I don't see an obvious reason. As far as I remember, even in the previous case the esp8089 was not detected on MXQPRO board. Indeed there is something wrong with the dtb, but even looking throughly at it I could not find the real cause. Having such a board in my lab could make it much easier to understand at which level the problem is.
The fact that rk322x-config says "no wifi chip detected" means that the chip is not even exposed on the sdio bus; there could be multiple reason: the chip is turned off, there is a misconfiguration with the bus, etc...
For example, these commands:
cat /sys/bus/sdio/devices/mmc1:0001:1/vendor
cat /sys/bus/sdio/devices/mmc1:0001:1/device
should not fail and show you valid hexadecimal values to identify the esp8089 even if the driver is not loaded or not working, because they work as long as the hardware is detected by the kernel. So this the first problem that must be solved and honestly, since you say that doing trial and error with the variosu led-conf* overlays, you could try each overlay and report in which case the led-conf works.
Link to comment
Hi @jock! So after a few days of testing, I can say with 100% certainty: it's random.
I tested with every led config on some versions with the new kernel (5), including the latest one on your original post. With none of them the ESP8089 was even powered on.
cat /sys/bus/sdio/devices/mmc1:0001:1/vendor always failed.
So I went back to the old kernel (4), and the chip was detected with most configs, but with none it detected any wifi networks. Then I realized something - what if I only overlaid the wlan part, not the led config.
Well, turns out I got the wifi to work quite a few times like that. It was absolutely random: without changing any config, sometimes it would just work, and then stop working once I rebooted. Sometimes, on those reboots, it wouldn't even recognize the chip was plugged in the next time. Only for it to work again in the next boot. Sometimes it booted up working, and then, without rebooting, stopped all of a sudden and wouldn't even detect the chip anymore - without me changing anything.
I captured quite a few data: from device trees of when wifi was working to armbianmonitor outputs and even commands histories.
But, from what I can tell, there are no differences between working vs non-working DTBs. So I'm not sure those are useful.
Anyway, what I'm doing now, as a last effort, is to change the iwlwifi module configs - maybe it's putting the device to sleep and it's not recovering? I think that may be one cause because one of the things I noticed when comparing the wlan device trees of the original firmware (running Android) and the armbian ones, is that there are some pins missing from the later.
Link to comment
On 5/29/2022 at 5:36 AM, jock said:
@Felipe Triana DDR memory detection is made by a rockchip proprietary code that is called ddrbin as the very first binary code.
It's a closed source binary, so whatever it does and how it does is not known. It produces some debug messages that may be useful to you (memory arrangement, density, bus width) when the serial adapter is connected to the board.
There is a tool, ddrbin_tool, that can be used to alter ddr speed, ddr command rate timing and uart debug speed, but nothing more.
If you totally erased the NAND, then the ddrbin in use is the one from the sdcard, if you installed "jump start" with multitool, then the ddrbin in use is from NAND.
Multitool can't completely erase the NAND because the kernel driver has some limitations and cannot access the first sectors of the NAND, thus multitool can't neither write or read the installed ddrbin  in NAND.
Tried another box, it features a HYN-H9TKNNNBPDAR-ARNGH memory chip and a eMMC, working with RK3229. I didn't found many informations about this memory chip, but l was really using 2GB on Android, and I found something on Ali, it also says 2GB, but I dont know, ARMBIAN found 1GB only. Is there anything I could do?
EDIT: aparrently this memory chip was used on MOTO X 2013, and also is 2GB. See page 15 from this Ifixit guide.
Edited by Felipe Triana
Link to comment
  Hide contents
  Reveal hidden contents
Hi Felipe! Where did you buy this one?
I'm assuming you're from Brazil, and I'm about to give up on mine, restore the original emmc contents and send it back. So I'd love to get one that actually works - even if it has only 1 gig of memory hehehe.
Link to comment
I buyed on Mercado Livre, but its a surprise box, almost literraly, I've been lucky that all three that I buyed worked, even if all they uses different hardware. What problem you are facing? Maybe I can help.
Link to comment
My wifi is not consistent. It randomly works or not.
Link to comment
Dont use wireless, it never works Haha Of my 3 boards, 2 detect the wifi chip, it connects, but if I reboot or sometimes out of nothing, even if connected, stops responding, and you need to send ping google.com to work again. Wi-fi always is shit anyway, just use ethernet cable or a external Wi-Fi adapter from TP Link.
Link to comment
Ooh, that really sucks. Is that the general experience using armbian on those boxes? Is this your experience @jock?
I feel like it shouldn't be an issue when those boxes are meant to be always connected to the internet to stream content, and I haven't heard a lot of users complaining about disconnections on the stock Android.
Link to comment
Well no, in my experience some wifi works very well and some others don't.
Also take in consideration that the tv boxes have no public specs and no schematics. These are the cheapest general purpose hardware you can find on the chinese market and manufacturers put the cheapest hardware on the market on them, so supporting the huge variety of peripherals requires lot of  reverse engineering.
Tuning for "perfect" stability requires time, patience, knowledge and obviously the hardware at disposal to do tests and tests...
Consider that I've never seen your board - never ever had any board with eMCP or esp8089 chips: it is quite an accomplishment letting it boot without major manual operations and/or special hardware.
Link to comment
Yup, totally agreed.
The thing is that I'm returning my non-reliable version and trying to get a realizable version.
What board versions should I look after if I'm looking for reliability?
Or would you say my best option would be to actually use a wifi range extender and plug in an Ethernet cable?
Link to comment
