Guest Posted February 22, 2024 Posted February 22, 2024 I built armbian using the branch 23.11 with legacy-kernel 5.10.160 for use as a Nextcloud server. Version: Armbian-unofficial 23.11.0-trunk Bullseye \l . 5.10.160-legacy-rk35xx After running sudo apt upgrade there were a few packages which were being upgraded successfully from 23.11.0-trunk to 23.11.1. Unfortunately the package armbian-bsp-cli-orangepi5-plus-legacy cannot be upgraded to 23.11.1 due to the base-files still being on 23.11.0-trunk. The system is running fine though. $ sudo apt update && sudo apt list --upgradable Hit:2 http://deb.debian.org/debian bullseye InRelease Hit:3 http://deb.debian.org/debian bullseye-updates InRelease Hit:4 http://deb.debian.org/debian bullseye-backports InRelease Hit:5 http://security.debian.org bullseye-security InRelease Hit:6 https://packages.sury.org/php bullseye InRelease Hit:1 http://mirrors.dotsrc.org/armbian-apt bullseye InRelease Reading package lists... Done Building dependency tree... Done Reading state information... Done 1 package can be upgraded. Run 'apt list --upgradable' to see it. Listing... Done armbian-bsp-cli-orangepi5-plus-legacy/bullseye 23.11.1 arm64 [upgradable from: 23.11.0-trunk] $ sudo apt install --only-upgrade armbian-bsp-cli-orangepi5-plus-legacy Reading package lists... Done Building dependency tree... Done Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: armbian-bsp-cli-orangepi5-plus-legacy : Depends: base-files (>= 23.11.1) but 23.11.0-trunk-11.1+deb11u8-bullseye is to be installed E: Unable to correct problems, you have held broken packages. $ apt-cache policy base-files base-files: Installed: 23.11.0-trunk-11.1+deb11u8-bullseye Candidate: 23.11.0-trunk-11.1+deb11u8-bullseye Version table: *** 23.11.0-trunk-11.1+deb11u8-bullseye 100 100 /var/lib/dpkg/status 23.8.1-bullseye 500 500 http://apt.armbian.com bullseye/main arm64 Packages 11.1+deb11u9 500 500 http://deb.debian.org/debian bullseye/main arm64 Packages How do I fix this issue? Is there a safe way to upgrade the base-files to 23.11.1? I cannot rebuild the system! Any help is appreciated:) 0 Quote
j0ta Posted February 26, 2024 Posted February 26, 2024 (edited) Att I was able to upgrade it by using the beta package of base-files which has now been removed from beta repositories, they made some tweak to produce that bullseye base-files and never did it again Edited February 26, 2024 by j0ta 0 Quote
j0ta Posted March 15, 2024 Posted March 15, 2024 (edited) An update it seems you can use the bookworm base-files deb on a bullseye system It will change /etc/debian_version to 12.5 revert to 11.x with I forgot to check bullseye version before apply the bookworm base-file if someone can, post the correct bullseye version Cheers ! Edited March 15, 2024 by j0ta 0 Quote
Guest Posted March 15, 2024 Posted March 15, 2024 Interesting, thanks for the tip. I might try it. But as far as I know NextcloudPi does not fully support bookworm yet and I don't want to risk breaking a running system. I'll try to create a full backup first. 0 Quote
