vlad59 Posted February 9, 2017 Posted February 9, 2017 Hi, No real problem, just a question. I'm using latest Armbian Jessie 5.25 with my good old Banana Pi. root@marvin:~# cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies 144000 312000 528000 720000 864000 912000 960000 root@marvin:~# cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq 480000 root@marvin:~# cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq 960000 Please notice that 480MHz (the min freq) is not in the available frequencies. So that gives the following output with cpufreq-info : root@marvin:~# cpufreq-info cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. analyzing CPU 0: driver: cpufreq-dt CPUs which run at the same hardware frequency: 0 1 CPUs which need to have their frequency coordinated by software: 0 1 maximum transition latency: 244 us. hardware limits: 144 MHz - 960 MHz available frequency steps: 144 MHz, 312 MHz, 528 MHz, 720 MHz, 864 MHz, 912 MHz, 960 MHz available cpufreq governors: conservative, ondemand, userspace, powersave, performance, schedutil current policy: frequency should be within 480 MHz and 960 MHz. The governor "schedutil" may decide which speed to use within this range. current CPU frequency is 528 MHz (asserted by call to hardware). cpufreq stats: 144 MHz:0,00%, 312 MHz:0,00%, 528 MHz:98,22%, 720 MHz:1,04%, 864 MHz:0,08%, 912 MHz:0,23%, 960 MHz:0,43% (39367) analyzing CPU 1: driver: cpufreq-dt CPUs which run at the same hardware frequency: 0 1 CPUs which need to have their frequency coordinated by software: 0 1 maximum transition latency: 244 us. hardware limits: 144 MHz - 960 MHz available frequency steps: 144 MHz, 312 MHz, 528 MHz, 720 MHz, 864 MHz, 912 MHz, 960 MHz available cpufreq governors: conservative, ondemand, userspace, powersave, performance, schedutil current policy: frequency should be within 480 MHz and 960 MHz. The governor "schedutil" may decide which speed to use within this range. current CPU frequency is 528 MHz (asserted by call to hardware). cpufreq stats: 144 MHz:0,00%, 312 MHz:0,00%, 528 MHz:98,22%, 720 MHz:1,04%, 864 MHz:0,08%, 912 MHz:0,23%, 960 MHz:0,43% (39367) Should I set /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq to 528000 or is there a problem with 480MHz not being in available frequencies ? IIRC I had the same problem with the previous kernel (Armbian 5.24), I do not remember if it happened before.
Solution tkaiser Posted February 9, 2017 Solution Posted February 9, 2017 You compare cpufreq-utils 'policy' (contents of /etc/default/cpufrequtils) and kernel capabilities (contents of .dts file). Armbian usually sets identical minimum cpufreq policy for all boards of the same SoC family: https://github.com/igorpecovnik/lib/blob/master/config/sources/sun7i.conf#L26 And for whatever reasons DT contents for BPi vary (you can search linux-sunxi archives for specific reasons why this and that happens). From a practical point of view there is exactly no difference between 480 MHz and 528 MHz since these 48 MHz are simply negligible You could adjust cpufreq-utils settings but why? Makes no sense unless you use 144 or 312 MHz (which has some drawbacks if you chose ondemand like overall lower CPU performance, should work better with schedutil governor but there are also some problems reported. IIRC audio pops when using schedutil)
vlad59 Posted February 9, 2017 Author Posted February 9, 2017 The only thing I wanted to change is to set scaling_min_freq to 528000 for consistency. But it won't change a single thing. Anyway thanks a lot for your answer, my curiosity is satisfied .
