If someone is interested i have compiled some TSLIB deb packages for the Pine64 Touch Screen to work without evdev driver or any other service behind.
Advantages:
* Easy to install (if you know how to edit xorg.conf)
* No service needed
* No calibration needed
Disadvantages:
* works on X11 only
Information and deb packages:
https://github.com/avafinger/pine64-touchscreen
Hope it can be useful.
Hi and many thanks for your work with the tslib X11 driver.
I tried following this on a pine64+ running kernel 3.10.104-pine64
but X is failing to start with a segfault:
9.307] (**) Option "config_info" "udev:/sys/devices/virtual/input/input0/event0"
[     9.307] (II) XINPUT: Adding extended input device "sunxi-keyboard" (type: KEYBOARD, id 10)
[     9.307] (**) Option "xkb_rules" "evdev"
[     9.307] (**) Option "xkb_model" "pc105"
[     9.307] (**) Option "xkb_layout" "us"
[     9.308] (II) config/udev: Adding input device sunxi-ths (/dev/input/event2)
[     9.309] (II) No input driver specified, ignoring this device.
[     9.309] (II) This device may have been added with another device file.
[     9.309] (II) config/udev: Adding input device gt9xxf_ts (/dev/input/event5)
[     9.310] (**) gt9xxf_ts: Applying InputClass "evdev touchscreen catchall"
[     9.310] (**) gt9xxf_ts: Applying InputClass "Pine64-Touchscreen"
[     9.310] (II) LoadModule: "tslib"
[     9.310] (II) Loading /usr/lib/xorg/modules/input/tslib_drv.so
[     9.314] (II) Module tslib: vendor="X.Org Foundation"
[     9.314]    compiled for 1.18.4, module version = 0.0.1
[     9.314]    Module class: X.Org XInput Driver
[     9.314]    ABI class: X.Org XInput driver, version 22.1
[     9.314] (II) Using input driver 'tslib' for 'gt9xxf_ts'
[     9.314] (**) gt9xxf_ts: always reports core events
[     9.333] (EE)
[     9.333] (EE) Backtrace:
[     9.333] (EE) 0: /usr/lib/xorg/Xorg (xorg_backtrace+0x58) [0x5557b0cc48]
[     9.333] (EE)
[     9.333] (EE) Segmentation fault at address 0x0
[     9.333] (EE)
Fatal server error:
[     9.333] (EE) Caught signal 11 (Segmentation fault). Server aborting
[     9.333] (EE)
[     9.333] (EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
for help.
[     9.333] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[     9.333] (EE)
Any ideas?
BR.
--Marius--
