d83fr Posted March 3, 2024 Posted March 3, 2024 Hi All, Current running a RockPi4C+, it has crashed after a dist-update (it seems that uboot update not recognize my nvme), then, I reinstall it, on SD card only , but only found a community rolling version, And, now that my system is booting, I want/need to go back to stable, I read about armbian-config to do that, but not enable on RockPi4C+ What is the "cli" way Thank you 0 Quote
SteeMan Posted March 3, 2024 Posted March 3, 2024 10 minutes ago, d83fr said: I read about armbian-config to do that, but not enable on RockPi4C+ I'm not sure what you mean by this as armbian-config is available on all Armbian builds. 0 Quote
d83fr Posted March 3, 2024 Author Posted March 3, 2024 OK, perhaps my wrong, got a "Unable to locate package armbian-config", on which repo is it, I got ... ohhh ! by doing an update, armbian repo disappear !! cat you give me your /etc/pat/source.list.d/armbian.list 0 Quote
SteeMan Posted March 3, 2024 Posted March 3, 2024 What you may be finding is that in armbian-config you are not seeing any stable releases. That would be because your board is not supported by Armbian. It in in unmaintained/community support status. Community supported boards now only get rolling automated builds, no stable releases. 0 Quote
SteeMan Posted March 3, 2024 Posted March 3, 2024 What version do you have installed? That package should be already installed on all builds (except I believe cli minimal builds) 0 Quote
d83fr Posted March 3, 2024 Author Posted March 3, 2024 I'm using bookworm minimal, but, my bad, found armbian-config, your are pointing me right by saying that it have to be enable. armbian-config installed will try to go to stable, and see Thank you 0 Quote
