Armbianmonitor:
Hi guys,
I downloaded Armbian 24.2.1 Jammy CLI (Armbian_24.2.1_Orangepizeroplus_jammy_current_6.6.16.img.xz) for the Orange Pi Zero Plus and it's not booting. Boot log below:
U-Boot SPL 2024.01-armbian (Feb 09 2024 - 19:21:37 +0000)
DRAM: 512 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.9(debug):armbian
NOTICE:  BL31: Built : 19:20:27, Feb  9 2024
NOTICE:  BL31: Detected Allwinner H5 SoC (1718)
NOTICE:  BL31: Found U-Boot DTB at 0x20a4ef0, model: Xunlong Orange Pi Zero Plus
INFO:    ARM GICv2 driver initialized
INFO:    Configuring SPC Controller
NOTICE:  PMIC: Assuming H5 reference regulator design
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
INFO:    BL31: cortex_a53: CPU workaround for 1530924 was applied
SCP/INF: Crust v0.6.10000
INFO:    PSCI: Suspend is available via SCPI
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
U-Boot 2024.01-armbian (Feb 09 2024 - 19:21:37 +0000) Allwinner Technology
CPU:   Allwinner H5 (SUN50I)
Model: Xunlong Orange Pi Zero Plus
DRAM:  512 MiB
Core:  67 devices, 20 uclasses, devicetree: separate
WDT:   Not starting watchdog@1c20ca0
MMC:   mmc@1c0f000: 0, mmc@1c10000: 1
Loading Environment from FAT... MMC: no card present
** Bad device specification mmc 0 **
In:    serial,usbkbd
Out:   serial,vidconsole
Err:   serial,vidconsole
Net:   eth0: ethernet@1c30000
Couldn't find partition mmc 0
starting USB...
Bus usb@1c1a000: sun4i_usb_phy phy@1c19400: External vbus detected, not enabling our own vbus
USB EHCI 1.00
Bus usb@1c1a400: USB OHCI 1.0
Bus usb@1c1b000: USB EHCI 1.00
Bus usb@1c1b400: USB OHCI 1.0
scanning bus usb@1c1a000 for devices... 1 USB Device(s) found
scanning bus usb@1c1a400 for devices... 1 USB Device(s) found
scanning bus usb@1c1b000 for devices... 1 USB Device(s) found
scanning bus usb@1c1b400 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
Device 0: unknown device
ethernet@1c30000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
Retrieving file: pxelinux.cfg/01-02-01-a6-4a-c9-69
Retrieving file: pxelinux.cfg/00000000
Retrieving file: pxelinux.cfg/default-arm-sunxi-sunxi
Config file not found
I don't have a TTL at the moment, but I can confirm too that:
Armbian 24.2.1 Jammy CLI - does not boot
Armbian 24.2.1 Bookworm CLI - boots
tagging the maintainer for visibility @schwar3kat
