xalu Posted February 17, 2017 Posted February 17, 2017 Howdy, I set up a new OrangePi Zero with the Legacy 3.4.113 Ubuntu Xenial. I was able to get wifi working however when I try to do a sudo-apt get update or upgrade it freezes and crashes. I am using a 32gb Samsung Evo. Cpu temp is hovering around 57 C with no load. Any tips besides reinstalling the image?
tkaiser Posted February 17, 2017 Posted February 17, 2017 Any tips besides reinstalling the image? Check your power supply (that means: PSU and especially the cable between PSU and board -- always remember that Micro USB is crap to power anything needing more than a few mA) and also SD card. If you run 'stress -c 4' and board also freezes/crashes then you suffer from undervoltage or sometimes undercurrent To check your SD card you can issue the following below (2nd step only if installation survives first step) armbianmonitor -c $HOME sudo armbianmonitor -u Insufficient power supply leading to freezes/crashes might then be responsible for a corrupted filesystem on SD card and from then on when strange things happen it might be either or
xalu Posted February 17, 2017 Author Posted February 17, 2017 Thanks! Switched power supply and its working fine.
